[KPN] VoIP dienst InternetPlusBellen deel 11 Vorige deel Overzicht Volgende deel Laatste deel
Pagina: 1 ... 10 11 Laatste
  • 39.432 views sinds 30-01-2008
  • Edmund
hans-d schreef op dinsdag 27 februari 2007 @ 15:08:
Hier hetzelfde, kan ook geen mail meer ophalen.
Hier werkt het wel. Of jah misschien is het wel; inmiddels weer ;)
In ieder geval kunnen we weer verder in deel 12!
[ Voor 21% gewijzigd door Edmund op 27-02-2007 15:49 ]
  • Arnout
  • Laatst online: 14:02
sinds 11u inderdaad weer problemen:
29
30
31
32
33
34
35
36
37
Feb 27 11:06:26 localhost fetchmail[2186]: Authorization failure on x@kpnplanet.nl@pop.kpnplanet.nl (previously authorized)
Feb 27 11:30:27 localhost fetchmail[2186]: Authorization failure on x@kpnplanet.nl@pop.kpnplanet.nl (previously authorized)
Feb 27 11:32:22 localhost fetchmail[2186]: Authorization failure on x@kpnplanet.nl@pop.kpnplanet.nl (previously authorized)
Feb 27 11:36:28 localhost fetchmail[2186]: Authorization failure on x@kpnplanet.nl@pop.kpnplanet.nl (previously authorized)
Feb 27 11:59:06 localhost fetchmail[2186]: Authorization failure on x@kpnplanet.nl@pop.kpnplanet.nl (previously authorized)
Feb 27 12:41:24 localhost fetchmail[2186]: Authorization failure on x@kpnplanet.nl@pop.kpnplanet.nl (previously authorized)
Feb 27 13:25:46 localhost fetchmail[2186]: Authorization failure on x@kpnplanet.nl@pop.kpnplanet.nl (previously authorized)
Feb 27 13:43:55 localhost fetchmail[2186]: Authorization failure on x@kpnplanet.nl@pop.kpnplanet.nl (previously authorized)
Feb 27 13:45:06 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 13:47:40 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 13:48:40 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 13:50:49 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 13:54:54 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 13:55:54 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 13:58:09 localhost fetchmail[2186]: Authorization failure on x@kpnplanet.nl@pop.kpnplanet.nl (previously authorized)
Feb 27 13:59:20 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 14:00:20 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 14:01:20 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 14:07:39 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 14:08:39 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 14:15:46 localhost fetchmail[2186]: Authorization failure on x@kpnplanet.nl@pop.kpnplanet.nl (previously authorized)
Feb 27 14:23:52 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 14:24:52 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 14:28:20 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 14:32:04 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 14:36:36 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 14:40:57 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 14:43:13 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 14:47:14 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 14:48:14 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 14:50:46 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 14:52:54 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 14:56:47 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 14:57:47 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 15:01:07 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 15:02:07 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
Feb 27 15:03:07 localhost fetchmail[2186]: POP3 connection to pop.kpnplanet.nl failed: Connection refused
We kunnen weer verder in deel 12: [KPN] VoIP dienst InternetPlusBellen deel 12
@Jan-E
IK heb nog nooit in mijnKPN Macadressen kunnen invoeren. Maar als jij zegt dat het wel kon heb ik geen reden om aan te nemen dat het niet zo is, IK heb het nooit gekund in ieder geval :) .
Maar wat ik al aangaf, in de webinterface is dit dus ook prima te doen.
  • EricEric752
  • Laatst online: 19:51
Gisteren is er weer gezellig een KPN monteur bij me langs geweest. Dezelfde als de vorige keer trouwens. Dat ging ongeveer zo:
Zaterdagavond belde iemand van KPN om een afspraak te maken voor het bezoek van de monteur. Ik vertelde hem dat de monteur van harte welkom was, maar dat de beste man niets zou kunnen doen. De problemen die ik heb heeft elke IPB-er namelijk, ook al ondervinden ze die niet altijd: het "te-veel-connecties-probleem-waardoor-de-telefoon-het-niet-meer-doet-probleem", UPnP dat niet werkt en het 13 minuten probleem. Om te voorkomen dat ik later de zwarte Piet zou krijgen als ik de monteur zou weigeren, zei ik wel tegen de KPN-er aan te telefoon dat het slechts mijn persoonlijke inschatting was dat de monteur niets zou kunnen doen en dat de monteur natuurlijk langs mocht komen als KPN dat noodzakelijk vond.
Dus de monteur komt langs, vertelt mijn volkomen a-technische vriendin dat hij niks kan doen, dat het aan torrents ligt, dat half maart het 13 minuten probleem opgelost is (als ik me niet vergis heb ik hier gelezen dat de firmware met die fix al uit is) en dat heel veel mensen teruggaan naar adsl + analoog. Ik weet niet hoeveel monteurs KPN dagelijks rond heeft rijden voor dergelijke activiteiten, maar het lijkt me een duur grapje.
  • SCIxX
  • Laatst online: 08:48
RonaldM schreef op dinsdag 27 februari 2007 @ 08:19:
Gisteren had ik door een korte spanningsuitval geen VOIP meer op mijn Siemens Experiabox. ADSL werkte nog prima (de kinderen konden dus gewoon lekker surfen). Je kreeg wel kiestoon alleen na het kiezen van ieder willekeurig nummer kreeg ik 'in gesprek' toon. Diverse resetvarianten hebben niet geholpen. Vanmorgen 06:30 de helpdesk aan de lijn gehad en na wat sleutelen ging het VOIP lampje weer aan en werkte het telefoniedeel weer.
Nu vraag ik me alleen af of dit nu bij iedere spanningsuitval zo veel moeite gaat kosten om mijn telefonie weer in de lucht te krijgen :? . Ik was vanmorgen zo blij dat het weer werkte dat ik het vergeten ben te vragen aan de helpdeskmedewerker.
Half 7 sochtends? Dat is knap. :D
Normaal gesproken zou bij stroomuitval het VOIP lampje niet uit moeten gaan, als dit wel gebeurt kan een reset het verhelpen aangezien de box dan een poging doet deze gegevens weer binnen te halen. Werkt dit niet zul je toch echter moeten bellen.
  • SCIxX
BadVibes schreef op vrijdag 23 februari 2007 @ 12:22:
Mijn EB is alleen maar te bereiken is via het ip "10.0.0.138". Dit is het oude adres van mijn Speedtouch, hoe kan dit toch? Toen ik hem net aangesloten had, kon ik wel via 192.168.1.254 de pagina bereiken. Echter zonder in te hoeven loggen, klopt dit? Is dit wel veilig?
Erachter (via WAN) heb ik een Asus WL-500gP staan deze deel adressen uit in 192.168.1.20-40. Deze Asus router wil ik altijd hetzelfde adres laten geven door de EB, volgens mij kan dit. Maar kan het nu wel of niet dat al het verkeer door wordt gelsuisd naar de Asus router? Ik las ergens dat ik dan alle poorten van 0 t/m 65xxx door moet sluizen?
De ST780 vereist idd geen wachtwoord zoals de siemens. Echter maakt het weinig uit, je moet tenslotte verbonden zijn met de EB om deze te bereiken. Dus wanneer niemand je WEP/WPA sleutel heeft en ook niet stiekem een netwerkkabeltje in je EB heeft gestopt hoef je je geen zorgen te maken.
Verkeerde topic --> [KPN] VoIP dienst InternetPlusBellen deel 12
/me vraagt zich af waarom deze nog open is..
