Mijn computer is een MSI K8N Platinum SLI met een AMD 64 3200. Het geheugen dat er nu in zit is 2x 512 Mb GEIL GE1GB3200BDC (2,5-8-4-4, double sided). Nu wil ik er 1 Gb bij plaatsen. Als ik hetzelfde geheugen erin zet, dan draait het niet op DDR 400 maar op DDR 333. Even speuren op het net leverde onderstaande informatie op:
DIMM Module Combination Install at least one DIMM module on the slots. Each DIMM slot supports up to a maximum size of 1GB. Users can install either single- or double-sided modules to meet their own needs. Please note that each DIMM can work respectively for singlechannel DDR, but there are some rules while using dual-channel DDR (Please refer to the suggested DDR population table below). Users may install memory modules of different type and density on different-channel DDR DIMMs. However, the same type and density memory modules are necessary while using dual-channel DDR, or instability may happen. Please refer to the following table for detailed dual-channel DDR. Other combination not listed below will function as single-channel DDR.
Green DIMM1 (Ch A) Purple DIMM2 (Ch
Green DIMM3 (Ch A) Purple DIMM4 (Ch
System Density
128MB ~ 1GB 128MB ~ 1GB - - 256MB ~ 2GB
- - 128MB ~ 1GB 128MB ~ 1GB 256MB ~ 2GB
128MB ~ 1GB 128MB ~ 1GB 128MB ~ 1GB 128MB ~ 1GB 512MB ~ 4GB
MSI Reminds You...
• Dual-channel DDR works ONLY in the 3 combinations listed in the table shown above.
• Please select the identical memory modules to install on the dual channel, and DO NOT install three memory modules on three DIMMs, or it may cause some failures.
• Always insert the memory modules into the GREEN slots first, and it is strongly recommended not to insert the memory modules into the PURPLE slots while the GREEN slots are left empty.
• This mainboard DO NOT support the memory module installed with more than 18 pieces of IC (integrated circuit).
• The Maximum memory speed decreases when the following two memory combination is selected:
- Each channel is installed with two double-sided memory module
- Both DIMM1 and DIMM3 are installed with double-sided memory module
• Due to the South Bridge resource deployment, the system density will only be detected up to 3+ GB (not full 4GB) when each DIMM is installed with an 1GB memory module
Recommended Memory Combination List
DIMM Slots Max Speed
Green Purple Green Purple
DIMM1 DIMM2 DIMM3 DIMM4
S - - - DDR 400
- - S - DDR 400
D - - - DDR 400
- - D - DDR 400
S - S - DDR 400
D - D - DDR 333
S S - - DDR 400
- - S S DDR 400
D D - - DDR 400
- - D D DDR 400
S S S S DDR 400
D D D D DDR 333
S: Single Side
D: Double Side
http://www.msi-computer.c...ath=22_31&products_id=148
De tabel geeft geen oplossing als ik twee keer Double Sided geheugen erin zou zetten (wat ik al heb) en er twee keer Single Sided geheugen bij zou zetten. Ik heb dan ook geen idee of het systeem dan wel op DDR 400 zou lopen EN op Double Channel mode (=128 bits).
Hebben jullie hierin ervaring?
Alvast bedankt voor jullie reactie.
MSI Reminds You...
S - - - DDR 400
- - S - DDR 400
D - - - DDR 400
- - D - DDR 400
S - S - DDR 400
D - D - DDR 333
S S - - DDR 400
- - S S DDR 400
D D - - DDR 400
- - D D DDR 400
S S S S DDR 400
D D D D DDR 333
S: Single Side
D: Double Side
