Ervaringen Benq VL3735
  • 609 views sinds 30-01-2008
  • ChristianD
  • Laatst online: 07-10 12:49
Ik heb net een Benq VL3735 gekocht en wil mijn ervaring met deze LCD tv hier met jullie delen. Dit is mijn eerste topic hier op GOT, dus tips zijn natuurlijk altijd welkom.
De Benq VL3735 is zoals men zegt een FullHD lcd televisie. Hieronder de volledige specs van de benq website.
Afbeeldingslocatie: http://image2.sina.com.cn/IT/cr/2006/0919/867945187.jpg
URL website:
http://www.benq.com/products/LCDTV/?product=904
Algemene specificaties:
Full HD 1920X1080
Display extremely delicate images with HDTV 1080 resolution compatibility. The fine images provide you with the sensation of watching true-to-film images.
8ms Quick Response Time
Equipped with an ultra-fast 8ms gray-to-gray response time, the VL3231 delivers smooth images with no laggings.
1200:1 High Contrast Ratio
Processes bright and dark images precisely, so that you can see every detail even in the darkest images.
Ultimate Visual Sensation
Exclusive Senseye Technology for Fine-Tuned, True-to-Film Images.
By optimizing the color, clarity, motion and contrast, Senseye technology produces vivid, true-to-film images that are distinctly deeper, richer and clearer.
10-bit Color Processing
10-bit Color processing processes 1.07 billion colors all at once. This amplifies the color refinement level, smoothes over gray scales, and produces true and rich color.
HDMI (High-Definition Multi-media Interface)
An all-digital audio/video interface allows uncompressed signals to be translated into the highest quality available. With built-in intelligence, the HDMI also provides you with a simple way of controlling your HDMI-linked system.
Sensi-Light Sensor
A special feature that auto-adjusts the backlight for a more comfortable viewing experience while also conserving power.
Soft Mute
One of the most irritating problems with conventional TVs is that when you use the "Mute" function, the sound volume suddenly seems too loud when the volume is switched back on.. BenQ's Soft Mute ensures that the volume level returns to the previous level gradually without a sudden shocking blast of sound.
Swivel View
Everyone has his or her point of view. That's why the VL3231 can swivel up to 15 degrees to suit any angle of viewing. Choose what's comfortable, sit back and enjoy.
Detailed specifications
Screen Size: 94cm/37"
Aspect Ratio: 16:9
Brightness: 550 nits
Contrast Ratio: 1200:1
Response Time: 8 ms
Viewing Angle: 176/ 176
Resolution: 1920x1080
Display Compatible: 480i / 480p/ 720p/ 576i/ 576p/ 720p/ 1080i/ 1080p(HDMI)
Broadcasting System: NTSC/ PAL/ SECAM
Speakers: 10Wx2
Video Features Senseye Technology: Yes
10 Bit color processing: Yes
Aspect Ratio Adjustment: 4:3/ 16:9/ Letter box/ Wide/ Real
Picture Modes: Cinema/ Dynamic/ Standard/ Personal
Sharpness Enhancement: Yes
Low Angle Modle: Yes
De-Interlacing: Motion Adaptive
3D Y/C Comb Filter: Yes (3D)
Auto Contrast Enhancement: Yes
Noise reduction: Yes
Audio Features Sound Effect: Virtual Dolby Sound
Other Features PIP/PBP: PIP
Personal Setting: 1
Picture Freeze: Yes
Sensi-Light Sensor: Yes
Swivel View: Yes
Connector Auto Detection: Yes
Soft Mute: Yes
Backlight Eco Mode: Bright/ Normal/ Dark/ Auto
Color temperature: Warm/ Cool/ Standard
Sleep Timer: 0, 30,60,90,120,150,180
PC Mode Horizontal Frequency: 31.5 ~ 60 KHz
Vertical Frequency: 50 ~85 Hz
DPMS: Yes
Image Auto Setting N/A
Horizontal Frequency 31.5 ~ 60 KHz
Vertical Frequency 50 ~85 Hz
Input Terminals Composite AV (Video+L/R): 2 (Rear x1 + Side x1)
S-Video: 2 (Rear x1 + Side x1)
Scart: rear x 2 (Full, Half)
Component (Y Pb Pr / Y Cb Cr) + Audio: 2
Analogue TV Tuner: 1
D-Sub: 1
DVI: Thru HDMI
HDMI: 1
PC Audio: 1
RS 232: Through D-sub
Output Terminals Headphone: 1 at side
Audio Out: L/R
Dimensions Dimension with Stand (W x H x D mm): 970x748x295
Dimension w/o Stand (W x H x D mm): 970x697x122
Weight Weight (with stand, Kg): 27.6
Weight (without stand, Kg): 23
Color N/A
Power Consumption 210 W
Power Supply AC 200~240V, 50/60 Hz
Accessories (included) Remote Control with Battery
Garantie
Niet geheel onbelangrijk. Benq levert 2 jaar onsite garantie. Heb nog niet kunnen uitvinden welke uitzonderingen er gehanteerd worden, maar als een bedrijf 2 jaar onsite geeft geeft mij toch wel vertrouwen in een product.
Eigen bevindingen
Dit is mijn eerste LCD televisie. Gezien deze LCD televisie helemaal een hoge native resolutie heeft was het eerste keer zien van normale televisie (via digitale televisie van kpn) was ik enigzins teleurgesteld. De televisie krijgt nu namelijk een lage resolutie beeld binnen en moet deze met zijn eigen scaler gaan vergroten naar de resolutie van 1920x1080. Dit gaf een ietwat blokkerig/onscherp beeld. Hetzelfde gold voor DVD's. Echter na wat rommellen met de instellingen van contrast/scherpte kan de beeldkwaliteit acceptabel gemaakt worden. Ik heb het echter niet zo scherp kunnen krijgen als dat mijn Sony beeldbuis televisie het weer geeft.
Een ander verhaal is de beeld output van mijn xbox360. Dit is verbluffend. Ik maak gebruik van de component hd kabel van de premium versie en de resolutie die dan verstuurd wordt is 1080i. De scherpte en helderheid is ongeloofelijk. Ik heb xbox360 aangesloten op mijn xp mediacenter 2005 en gebruikt de xbox dus ook als extender om film/muziek/fotos te bekijken. Ik had van de microsoft wmv HD showcase website al diverse 1080p promo filmpjes gedownload en dan merk je pas hoe goed deze televisie tot zijn recht komt. Haarscherp beeld.
Een ander goed punt van een HD lcd is het weergeven van foto's. Wanneer ik dit deed via mijn oude televisie was het altijd wat vaag en onscherp. Dit kwam doordat er een vertaling plaats vond naar de PAL resolutie. Dit is nu niet nodig en worden mijn foto's (van mijn canon ixus 55) nu perfect weergegeven.
Spelletjes op de xbox360 zijn nu ook verbluffend. Dead or Alive 4 bijvoorbeeld laat nu zo ongeloofelijk veel details zien.
Ik zal binnenkort wat foto's maken van de televisie met verschillende invoerbronnen.
Geluid
De speaker die er onderzit geeft goed geluid af. Zelfs het virtuele geluid wat de televisie kan produceren komt er goed uit. Natuurlijk een goede DD5.1 installatie overwint het, maar ja die wil je ook niet elke keer aanzetten voor het nieuws te bekijken.
De speaker die aan de TV zit is een vast onderdeel. Zover ik kon zien is het niet mogelijk om deze te verwijderen. Persoonlijk vind ik hierdoor de hoogte/breedte verhouding van de televisie er beter uit komen.
[ Voor 5% gewijzigd door ChristianD op 06-10-2006 15:04 . Reden: Toevoegen van stukje over garantie en geluid. ]
bla di bla bla
Hallo zou je aub wat foto's willen maken van deze monster in actie?
ik ben namelijk erg benieuwd naar de kwaliteit enz van deze televisie.
alvast bedankt voor de moeite.
  • ChristianD
Verwijderd schreef op vrijdag 06 oktober 2006 @ 15:45:
Van het weekend heb ik het erg druk, maar actie foto's staan in de planning ;)
bla di bla bla
Wel vreemd dat er zo weinig nog bekend is over deze tv. Lijkt wel of jij de eerste bent die deze monitor heeft. Of is er iemand anders die nog wat reviews is tegengekomen?
  • f@stmem
  • Laatst online: 04-10 11:45
Ik heb zelf sinds 2 weken deze TV en heb ook lopen zoeken naar reviews. Maar helaas niks gevonden. Ik moet toegeven dat het een mooie TV is zeker voor die prijs. Wees nou eerlijk waar vind je een 37" LCD-TV die 1080P 1:1 weergeeft voor minder dan 1700 Euro.
Analoge TV vind ik erg tegenvallen. Maar HDTV content via Windows media center is een lust om naar te kijken. Het wordt tijd dat Nederland over gaat naar HDTV uitzendingen.
fastmem, jij hebt dus die 1080P al getest en geen problemen ondervonden? Als dat namelijk zo is bestel ik hem ook meteen :)
  • f@stmem
Verwijderd schreef op maandag 09 oktober 2006 @ 14:30:
Xeress ik heb 1080P getest met een media center PC met een Asus A8N-VM CSM (NVIDIA GeForce 6150 + nForce 430) op dit moederbord zit een DVI uitgang welke je met de laatste forceware drivers gewoon kan instellen op 1080P. icm met 512MB en een athlon 64 3200+ en nvidia purevideo speelt hij moeiteloos 1080P content af. :9~ :9~ TV stelt zich automatisch goed in op 1080P je moet niet meer zitten klooien zoals bij een Benq DV3750 (welke met moeite kon worden ingesteld op 1080i) Als je via een PC met DVI 1080P wilt afspelen is dit scherm een aanrader.
Als je nog meer info wil laat het dan even weten.
Thanks. Eigelijk het enigste wat ik echt wou weten is die 1080P input. Nu ik weet dat dat goed zit ga ik hem ook bestellen. Blijkbaar hebben niet veel winkels hem direct op voorraad, dus het wordt even afwachten.
Dan misschien nog 1 klein vraagje; hoe ervaar jij de dvd weergave? ChristianD was er niet helemaal van overtuigd namelijk.
Ik ben enorm benieuwd naar de 'actiefoto's'. Ben ook benieuwd naar hoe hij hangend zijn plaats heeft.
  • f@stmem
Verwijderd schreef op maandag 09 oktober 2006 @ 21:00:
Dvd ziet erg goed uit mits je er een paar meter vanaf zit. En je je dvd speler via HDMI of Component hebt aangesloten. Zelf maak ik gebruik van een Denon 2910 dvd speler welke ik via HDMI of component het DVD beeld laat upscalen naar 720P.
Ik zat ook al even te kijken naar upscale dvd players. Bv de samsung DVD-HD860 die kan upscalen naar 1080i. Zoals ik het nu begrijp is de upscaler van deze tv gewoon niet super. Zo een upscale dvd speler is dan de uitkomst.
Waar ik wel erg benieuwd naar ben, zijn er ook digitale tv ontvangers die upscalen?
Overigens, lijkt benq weer eens wat leverings problemen te hebben. Is wel erg gebruikelijk bij ze als ze een nieuw product lanceren. :/
  • Da_Pat
  • Laatst online: 04-04 00:18
Weet iemand of dit LCD scherm ook HDCP heeft.
Ik heb snel even op de benq site gekeken maar kon het niet vinden. Verder lijkt het mij een prima LCD scherm voor een zeer scherpe prijs.
Alle HDMI heeft HDCP ondersteuning. Dus deze tv heeft ook HDCP, echter wel maar 1HDMI aansluiting. Samsung heeft er de laatste tijd 2.
I vraag me echt af hoe 1080P eruit ziet op deze LCD, ook al scale je een normale DVD met je tv omhoog met je pc naar deze resolutie. Wanneer komen de plaatjes :)
  • PeterPan
  • Laatst online: 08-10 21:11
Doet de PC/VGA ingang ook 1920x1080 zonder problemen?
Edit: 1360x768 maximaal volgens de handleiding :'(
[ Voor 36% gewijzigd door PeterPan op 16-10-2006 15:16 . Reden: gevonden ]
  • bennovb
  • Laatst online: 29-09 12:44
bennovb
Max OC = 3725Mhz..!!!
Dat valt nog wel mee als je via HDMI aansluit toch ?
Supported Component/HDMI input signal timing
Resolution Horizontal Vertical Dot Clock Note
Frequency (KHz) Frequency (Hz) Frequency (MHz)
720 x 480p 31.47 59.94 27 Progressive
720 x 576p 31.25 50 27 Progressive
1280 x 720p 44.955 59.94 74.176 Progressive
1280 x 720p 37.5 50 74.25 Progressive
1920 x 1080i 33.716 59.94 74.176 Interlaced
1920 x 1080i 33.75 60 74.25 Interlaced
1920 x 1080p 28.13 50 74.25 Progressive
1920 x 1080p 60 74.25 Progressive
• PC (VGA/DVI) and Video (Component/HDMI) timing modes outside of these tables are not
recognised and will not be displayed.
• To gain the best quality image on the TV, you should select 1024 x 768 @60Hz as your PC VGA
source resolution, and select the '4:3' aspect ratio on the TV when viewing VGA input.
• If the picture contains movement or character shimmering when the signal timing is changed,
activate the Auto function in the Setup menu to recalibrate the image.
Surface Pro 4 (Core m3, 4GB, 128GB) + Lumia 640XL Dual Sim (Verkocht ; PCH-DL, 2x Xeon 2.4 D1 SL6VL (@18x133), CM Heatpipes, 4x 512MB Adata Vitesta DDR500, Windowed Stacker, TSP 500W EPS, BroadCom 8prt SATA RAID, 36GB Raptor + 4x 200GB Seagate RAID5)
  • Synthetika
  • Laatst online: 09:21
ChristianD, mooie openingspost, zeer interessant topic. _/-\o_
Ook hier iemand die erg nieuwsgierig is naar foto's van het beestje in actie met 1080p.
Hier even het lijstje dat er in de handleiding net voor staat:
Supported VGA/DVI input signal timing
720 x 400 37.9 70 35.5 VESA
640 x 480 31.5 60 25.175
640 x 480 37.9 72 31.5 VGA
640 x 480 37.5 75 31.5
800 x 600 37.9 60 40
800 x 600 48.1 72 50 SVGA
800 x 600 46.9 75 49.5
1024 x 768 48.4 60 65
1024 x 768 56.5 70 75 XGA
1024 x 768 60 75 78.75
1280 x 960 60 60 108 VESA
1280 x 1024 64 60 108 SXGA
1360 x 768 47.7 60 85.5 VESA
En nu nog even opnieuw deze zin:
Maar eigenlijk is het dus als volgt:
- 1080p 1:1 pixelmapping is mogelijk zolang er via DVI of HDMI ook HDCP-informatie wordt meegestuurd door je videokaart. Ik ga er dus even vanuit dat je je pc aansluit via een DVI->HDMI of HDMI->HDMI kabel. (via VGA kan natuurlijk ook, maar het heeft niet mijn voorkeur)
- een videokaart die géén (volgens de VL3735 correcte) HDCP-informatie meestuurt bij 1080p, heeft als resultaat dat de VL3735 geen hogere resolutie accepteert dan 1360x768.
De handleiding suggereert dus alleen dat je met je PC dus niet hoger kan dan 1360x768 omdat ze er vanuit gaan dat er geen HDCP-signaal uit je videokaart komt. Please correct me if i'm wrong! Ik wil het zo helder mogelijk hebben, niet alleen voor mezelf maar ook voor iedere tweakert die wil weten wat ie met het beestje wel en niet kan.
Wat ik namelijk link vind is dat je voorlopig af moet gaan op ervaringen met specifieke videokaarten voor de weergave van 1080p, omdat de VL3735 nog relatief nieuw is... wie zegt dat hij dan ook meteen werkt op elke videokaart die HDCP ondersteunt op zijn dvi/hdmi uitgang? :/
(fipo, ik heb altijd alleen braaf zitten lezen maar nu moest ik wel even iets neerkalken)
[ Voor 13% gewijzigd door Synthetika op 18-10-2006 02:32 ]
  • PeterPan
B3NN0 schreef op dinsdag 17 oktober 2006 @ 02:30:
Nog een Benno op het forum :*)
Bedankt voor het lijstje met HDMI specs. Ik wil mijn Xbox 360 via VGA aansluiten op 1080p als de patch uit is om zo DVD's en HD-DVDs (drive in pre-order :) ) en ook games in 1080p te kunnen draaien.
Op de Samsung F71 na ben ik nog geen schermen tegen gekomen die dat over VGA kunnen en 40" is misschien toch een beetje teveel van het goede (kleine 3m kijkafstand in een kamer die niet veel breeder is)
  • f@stmem
Benn0 schreef op maandag 16 oktober 2006 @ 14:49:
Ik heb gewoon een DVI -> HDMI kabel gekocht en zo mijn PC aangesloten. En dan geeft mijn Nvidia kaart geen problemen met het instellen van 1920x1080.(wel met de laatste nvidia drivers).
De VGA poort is een ander verhaal.
f@stmem schreef op maandag 09 oktober 2006 @ 13:13:
...dat is dan de allerniewste Toshiba 37WL67 ;) , die is er vanaf 1518.-
bij http://www.pick2pay.nl/ en meerdere winkels trouwens die onder de 1700 duiken. (ook Stassen).
Zie : http://www.kieskeurig.nl/...6251EC1257202003DDF22.htm
Lijkt mij een betere jongen dan de BenQ, gezien de zeer goede kwaliteit van de recente modellen van Toshiba. Maar dat is imho.
[ Voor 87% gewijzigd door Verwijderd op 18-10-2006 14:19 ]
  • Synthetika
Lijkt mij een betere jongen dan de BenQ, gezien de zeer goed kwaliteit van de recente modellen van Toshiba. Maar dat is imho.
Inderdaad een erg scherpe prijs voor die specs en dat design. :9
Alleen staat bij Toshiba nergens dat het een 1080p tv is? Hij heeft inderdaad wel Full HD-resolutie, maar de 37WL67 ondersteunt (volgens hun website) maar input tot 1080i. Dan deinterlacet de ingebouwde Faroudja-chip het 1080i50/1080i60 beeld neem ik aan wel naar een strak 1080p60 plaatje. (of dat er dan net zo goed uitziet als een 'echt' 1080p signaal... geen idee)
Ik hoop stiekem dat ze de 1080p ondersteuning vergeten zijn erbij te zetten en dat hij daadwerkelijk 1080p@50/60Hz accepteert. ;) anders heb je voor nog minder geld de BenQ DV3750 met dezelfde deinterlacing-chip en eveneens max. 1080i ondersteuning.
[ Voor 8% gewijzigd door Synthetika op 18-10-2006 17:39 ]
Synthetika schreef op woensdag 18 oktober 2006 @ 14:34:
mmm.. op de site : http://www.toshiba.de/con...t/defaultid1_1_id2_2.aspx
de WL67 (FullHD)serie: 2x HDMI / HDCP (480p/480i/576p/576i/720p/1.080i)
de WL68 (HDReady)serie: 3x HDMI / HDCP (480i/480p/576i/576p/720p/1.080i/1.080p)
Zo te zien lijkt het dus of de HDReady wel 1080p, aankan en de FullHD maar 1080i :?
Die toshiba is wel erg interresant. De benq heeft namelijk maar 1 hdmi port, wat ik echt een groot nadeel vind. (1x pc, 1 x home cinema set en in de toekomst....)
  • Synthetika
Verwijderd schreef op donderdag 19 oktober 2006 @ 21:07:
Dat is absoluut zo. Dat niet alleen, ik zit zelf een beetje met het feit dat de BenQ VL3735 voor een erg leuke prijs 1080p kan weergeven. Maar als je kijkt naar verschillende reviews, dan zie je puur qua beeldkwaliteit dat merken als Toshiba en Samsung constant positief uit de testen komen. Een goed voorbeeld is bijvoorbeeld de beeldkwaliteit die zulke tv's nog uit PAL-signalen toveren (tv, dvd, xbox1). En waarom heeft de VL3735 'Motion-Adaptive Deinterlacing' ipv de beroemde Faroudja-chip die in de DV3750 zit? Die Toshiba's worden qua deinterlacing zo geprezen juist omdat ze gewoon in hun hele collectie die Faroudja-chip hebben zitten.
Maar het is ook de insteek die je hebt: wil je echt alleen dat 1080p beeld er goed uitziet, met name via je PC (dan kies je de BenQ)? Of wil je ook dat hij het maximale haalt uit je collectie dvd's, je PAL-formaat (720x576) tv-signaal, je "oude" xbox/ps2/gamecube? Dan heb je denk ik een probleem of je moet 2700 euro overhebben voor een nieuw 1080p-model van Philips (die dan ook wel alles fatsoenlijk doet, alleen is het dan weer de vraag of de ingebouwde scaler daar ook uit te schakelen is).
Waarom ik dan niet de BenQ VL3735 zou kopen? Misschien maak ik wel helemaal niet zoveel gebruik van de 1080p mogelijkheid en wil ik gewoon genieten van goed beeld met alles wat ik erop aansluit. Voor mijn werk heb ik een aantal Bluray-films (import USA, 1080p) moeten testen op een Full-HD 37" scherm en ik kan je zeggen dat je het verschil met 720p op dit moment alleen echt goed ziet bij een film als Shrek. Kan natuurlijk ook eraan liggen dat er pas een paar bluray-films op de markt zijn, maar toch.
Ik kan bij nader inzien gewoon niet zoveel doeleinden bedenken waarvoor je 1080p de komende tijd nodig zou hebben. HD-DVD/Bluray duurt nog een paar jaar voordat het gemeengoed is, en een xbox360 / ps3 is vereist om zo'n scherm qua gaming ten volle te kunnen benutten. Over HDTV in Nederland heb ik het dan nog niet eens gehad. Ja tuurlijk kun je nu alvast investeren in de toekomst, maar de prijzen dalen me nog wat te snel.
Misschien is er gewoon nog geen 1080p tv op de markt onder de 2000 euro die voor echt alle doeleinden perfect beeld geeft (dus niet alleen eenvoudigweg de weergave van 1080p). Natuurlijk is het magisch om 1080p materiaal te zien op zo'n tv, natuurlijk is dat prachtig. Maar mijn punt is een beetje dat je behoorlijk moet investeren als je er zoveel mogelijk van wil profiteren. Een xbox360/ps3, een mediacenter pc voor je gedownloade 1080p content of voor pc-gaming op 1920x1080, een HDTV-abonnement waarbij je voor 20 euro per maand 2 of 3 schamele HDTV-zenders krijgt. :z
Misschien moet ik gewoon niet zeuren en beseffen dat je voor meer moet sparen dan alleen die 1080p tv. 8)7 :+
  • DarkScorpion
  • Laatst online: 19-09 20:25
@ ChristianD
Ik las pas geleden gelezen op tweakers dat de Xbox 360 een update heeft gekregen om 1080p signalen te versturen.
Heb jij dit al uitgeprobeert op jou scherm?
Ik wilde even je bevindingen daarover weten.
Alvast bedankt :)
  • tHe_BiNk
tHe_BiNk
He's evil! Very EVIL!
Ik zit met smart op de fotos te wachten ;-). Het enige nadeel aan deze TV is dat er maar 1 DVI/HDMI port opzit.
Hier nog een link naar een ander forum.
http://www.avforums.com/f...t=387886&highlight=vl3735
APPLYitYourself.co.uk - APPLYitYourself.com - PLAKhetzelf.nl - Raamfolie, muurstickers en stickers - WindowDeco.nl Raamfolie op maat.
  • joosdijkstra
  • Laatst online: 23-09 16:04
Scaled (overscan) deze tv ook als je 1080p Materiaal uitzend? De samsung F71 scaled namelijk wel het beeld waardoor je toch nog kwaliteits verlies hebt.
Samsung topic:
[LCD TV] Samsung LCD TV's ( alle series ) Deel 3
Het topic lijkt na de reactie van Synthetika een beetje dood te zijn. Zijn er nog ervaringen die eigenaren van de vl3735 met ons kunnen delen? Is het waar wat Synthetika zegt en kan het apparaat alleen 1080p goed vertonen, of is er meer? Wat zijn de eigenschappen van digitale televisie en dit apparaat?
  • st18
  • Laatst online: 27-02 23:10
Na de (1080p) Xbox360 update zijn hier weinig reacties meer geweest over hoe deze TV aan het presteren is.
1. Werkt bijvoorbeeld 1080p via VGA nou wel of niet bij deze tv (icm xbox en/of pc).
2. Ondersteund hij nou ook 1080p over component of alleen over HDMI/DVI?
3. En heeft hij last van overscan op 1080 of is het écht 1:1 zonder overscan? En zo ja, op welke ingangen?
Dit topic staat al een maand droog, je zou verwachten dat er nu wat meer uitgebreidere tests zijn uitgevoerd door de mensen die hem in bezit hebben. Ben van plan ook een 1080p tv te kopen, voornamelijk voor Xbox, Mediacenter en HD content. Ik hoop dus dat er mensen zijn die wat meer input kunnen geven na het al wat langer te werken met deze tv.
Ik ben in het bezit van de BenQ VL3735. Ik ben er zeer tevreden over. Had eerst een CRT (32PW9525) wat een van de betere en dure CRT TV's was. Allereerst het grootste nadeel, de Benq kan slecht 4:3 na 16:9 omzetten. Gebruikt meer de Sony en Samsung methode. De uiteinden worden dus opgerekt en dit werkt uiterst storend. Philips doet dit als een van de weinige erg goed.
Natuurlijk kun je wel in letterbox perfect kijken of als er een 16:9 uitzending is heb je ook perfect beeld. De Benq heeft geen Faroudji chip en dat merk je. TV beelden zijn dan ook wat blokkerig als je van dichtbij kijkt. Maar dat hebben natuurlijk meer panels en ook van de grote (duurdere) merken.
Ik kijk Sateliet TV en heb ook een versterker van Philips met beeldverbeteraar (inderdaad met een Fajoudji chip) en heb nu een prachtig beeld. De kleuren zijn zeer realistisch en heb geen blokjes en kartelrandjes of welke fouten dan ook in een PAL TV uitzending.
Wil je echt weten wat de Benq kan dan koop er zoals ik een HDTV SAT receiver bij. Je weet niet wat je ziet. Dit panel kan perfect overweg met HDTV uitzendingen (bv BBC HD in MPEG4 die gratis is). Je krijgt een perfecte weergave van de 1080i uitzendingen en het Benq panels is werkelijk levensecht. Ook als je DVD's met HD Demo's afspeelt heb je ongelooflijk mooi beeld. Ik heb vaker in winkels zulke demo's gezien maar de VL3735 is volgens mij echt beter hierin. De Philips 37PF7931D zal met SD uitzendingen beter zijn daar standaard hij in hele batterij beeldverbeteraars heeft ingebouwd maar in HD is de Benq beter daar hij veel levendiger lijkt. De SD uitzendingen zijn bij mij nu ook perfect en ik denk zelfs beter daar de extra gekochte Philips DFR 9000 in samenwerking met het in de Benq gebouwde panel gewoon een schitterend resultaat geeft.
Ik heb DVD met HD content (1080P) via de PC van DVI naar HDMI gestuurd met prachtig beeld als resultaat. De Benq werd direct herkend door de PC. Via VGA kreeg ik hem niet in 1080 maar dat doet volgens mij geen enkele LCD TV.
Als je deze Benq en een upscaler (die SD in HDTV resolutie omzet) gebruikt heb je dus een ongelooflijk mooie set in huis.
Er zijn maar weinig 1080P LCD TV's en deze Benq is volgens mij de beste keus gezien de prijs.
Ik heb ook een Toshiba overwogen die ongeveer hetzelfde kostte maar deze is echt veel minder dan de Benq.
De VL3735 draait ook bijna in alle modes aangestuurd door verschillende apparaten (576, 720P en 1080i en 1080P) via de HDMI en de Toshiba (maar ook Philips) blijkt nogal wat problemen ermee te hebben.
Het design van de Benq is naar mijn idee ook mooi. Zeker als je hem ophangt is het een prachtig scherm (de voet is meestal wat ontsierend bij panels)
Het panel is vrij strak van vorm met weinig tierenlanteintjes.
Geeft een beetje een B&O look en het kunstof met alluminium kleurtje bevalt me nu ook perfect.
Zwart had eerst mijn voorkeur maar het springt teveel naar voren.
De zwarte rond om het scherm is perfect als contrast werking.
Al met al een Panel dat bij HDTV echt ongelooflijk scherp beeld geeft. Je ziet echt elk detail met zeer mooie en levensechte kleuren. Huidskleuren zijn zeer realistisch, goud lijkt echt goud en de huid van een olifant (vaak in de demo te zien op BBC HD) is echt leerachtig. Het lijkt echt alsof je door een raam naar buiten kijkt.
De publieke omroepen hier moeten zich schamen dat ze nog niet in HDTV uitzenden. Het verschil in kijkervaring in HDTV en SD is nog veel groter dan DVD en een kopie op een oude VHS band.
Ik heb de Benq aangesloten op een digitale versterker maar daarvoor maakte ik gebruik van de eigen ingebouwde speaker. Dit geluid was echt goed te noemen en ik was toch wat gewend met mijn Philips 32PW9525 TV met 5 speakers en subwoofer ingebouwd. Veel toestellen klinken blikkerig maar de Benq voldoet redelijk goed met het geluid.
De Benq is niet in grote winkels te zien maar ik denk als hij in een Media Markt waar ze HD content laten zien naast de dure Sony's en andere A-Merken stond hij deze kon verslaan.
  • Jeev
  • Laatst online: 06-04-2025
wie kan me vertellen wat precies het verschil is tussen de VL3735 en de VL3733... Op de site zie ik geen verschil in specs beide kunnen 1080p weergeven, terwijl de VL3733 en stukje goedkoper is.
http://benq.nl/products/LCDTV/?product=761&page=specifications
Kent iemand misschien meer 1080p 37" lcd schermen rond de prijs van de VL3733? Ik ben op zoek naar een betaalbare, voornamelijk om via de DVI input hd films af te spelen via mn pc..
[ Voor 47% gewijzigd door Jeev op 19-01-2007 20:20 ]
  • Wimpy006
  • Laatst online: 05-10 01:59
Ik heb ook een tijd gezocht naar het verschil tussen de twee BenQ TV's. Het lijkt erop dat de VL3733 net als de VL4233 wel 1080p accepteert op de ingang maar het downscaled naar de resolutie van het scherm die maar 1366 x 768 is. Zit er nu oook aan te twijfelen om die BenQ VL3735 te kopen, maar vind die nu nog net wat te duur. Maar heeft er nog iemand meer ervaringen over deze TV?
Mijn huidige systeem: Te veel nieuwe oude rommel op om te noemen.
g*dverf*ckingd*mme is er nou geen enkele Full HDTV beschikbaar die gewoonwegjes 1080p accepteert vanuit de PC ? Bedoel come on ... al die TV sh*t is leuk maar het duurt nog wel 10 jaar voordat we in NL echte 1080p HDTV zullen zien.
