StatBar 2.0 is go for launch!
Pagina: 1 2 Laatste
  • 618 views sinds 30-01-2008
  • Mr. B.
Het heeft ff geduurd, maar hier is ie dan toch: StatBar 2.0 *D (met RC5 blokjesteller, as requested :))
[edit]
Progje is aangepast (versienr. niet gewijzigd); de blokjesteller zou nu zowel met de oude als de nieuwe RC5 client goed moeten werken :)
OK, hij werkte dus nog niet helemaal goed met de nieuwe client; bij 1 packet (en niet 1 packets) ging ie de mist in :o
Is gefixt... :z
[/edit]
Het volgende is veranderd t.o.v. v1.2 (koppie-peest uit de helpfile, ik ga het niet nog eens vertalen ;)):
- If you had the about- or help screen visible and the StatBar window was about to reset automatically (e.g. because of a change in screen resolution), the program would crash. Fixed.
- Added the configuration window, in which you can select which information elements will be displayed and which won't.
- Added master volume and mute control.
- Added detection of Windows Whistler (which is actually NT 5.1).
- Added the option to hide the CPU and memory history graphs.
- Added the "Windows Default" color scheme.
- Improved the speed of color scheme changing.
- Added the RC5 counter.
- Added atomic time server synchronization.
- Added the ability to set the interval at which StatBar updates its information yourself.
- Added the the ability to auto-hide the main window.
- Made various (big) enhancements to the routines that manage how StatBar deals with the Windows shell. Also, the main window will not overlap the Windows Start button anymore if you have placed the taskbar at the side of your screen.
- When moving the main window from top to bottom or vice versa, it used to reset itself completely. This doesn't happen anymore.
- Replaced the RichText help screen with this help file; therefore the RICHTX32.OCX file is no longer needed.
- Numerous internal changes.
Screenie zoals ik 'm op m'n scherm heb staan (laptop):
Afbeeldingslocatie: http://members.home.nl/bkneepkens/statbar.jpg
Het volgende staat op de lijst voor eventuele volgende versies:
- Een infomodule die je vrije harddiskruimte weergeeft
- Multimonitor ondersteuning (als ik er ooit achterkom hoe ik dat voorelkaar krijg, en zodra ik het zelf kan testen :P)
- Knopjes voor shutdown/reboot/logoff
- Logmogelijkheden voor CPU en geheugengebruik
- POP3 mail notifier dingetje (misschien)
- Nog wat andere dingen waar ik nu ff niet op kan komen :)
[edit nr. 2]
Ook op de lijst voor een volgende versie: OGR tellertje (met dank aan wildhagen)
[/edit nr. 2]
Owja, als je merkt dat ie:
- Niet werkt onder LiteStep/Talisman/iedere andere shell dan explorer.exe,
- Onder Win98/ME je CPU- en/of geheugengebruik verkeerd aangeeft,
- 1 of 2 MB te weinig aangeeft bij je totale geheugen;
Lees dan svp eerst ff Tips, Tricks & Notes in de helpfile voor je hier komt klagen :P
Verdere opmerkingen:
- Het enige wat je nodig hebt om 'm te draaien is MSVBVM50.DLL, maar die staat hoogstwaarschijnlijk al op je machine. Zoniet, dan kun je 'm downen van m'n homepage.
- Vraag me svp niet of d'r een CPU temperatuurmetertje of DU meter in kan. Het eerste gaat gewoon niet lukken, het tweede waarschijnlijk ook niet.
- Dank aan GeonetiX voor het RC5-blokjes-uitlees-mIRC-script en een testlogje :) (Nee, ik heb zelf geen }:O, en ik ga d'r ook geen installeren :P)
StatBar 2.0 staat hier, enjoy :)
StatBar.nl - @GoT
Het verschil tussen theorie en praktijk is in de praktijk altijd veel groter dan in theorie.
  • uibeltje
  • Laatst online: 24-11 14:10
uibeltje
Idiotheque
kewl, gelijk ff downen :)
  • Palomar
cool.. ziet er vet uit :) vooral dat auto-hide is erg handig :)
Joh... ff leeche die hap :)
i was waiting for this :)
  • Femme
  • Laatst online: 14:48
Femme
Hardwareconnaisseur
Official Jony Ive fan
Cool proggie :).
Is het ook mogelijk om 'm niet op m'n primary display weer te geven (dus op een tweede monitor?).
  • Palomar
alleen mij rc5 countertje geeft allemaal ????-tekentjes.. ik heb buff-out.rc5 geselcteerd, das toch de goeie? Of moet ik ff wachten tot ie geflusht heeft ofzo?
  • uibeltje
uibeltje
Idiotheque
bij mij krijg ik de RC5 blokken teller niet werkend, welk bestand moet ik daar precies voor aangeven?
  • Mr. B.
Op zondag 28 januari 2001 17:27 schreef Femme het volgende:
Cool proggie :).
Nog niet, dat bedoelde ik dus met multi-monitor support :)
StatBar.nl - @GoT
  • Mr. B.
Op zondag 28 januari 2001 17:28 schreef rick_h het volgende:
Op zondag 28 januari 2001 17:28 schreef uibeltje het volgende:bij mij krijg ik de RC5 blokken teller niet werkend, welk bestand moet ik daar precies voor aangeven?
De file die je moet aangeven is je logfile, niet je buff-out.rc5 zelf :)
StatBar.nl - @GoT
  • Palomar
welke is da tdan? ik heb alleen een install.log maar dat is hem volgens mij niet... geeft ook ????
  • Mr. B.
Op zondag 28 januari 2001 17:34 schreef rick_h het volgende:
Degene waar dit soort zooi instaat:
[Nov 30 10:25:02 UTC] Saved RC5 3*2^28 packet CED0CCAA:D0000000 (84.70% done)
[Nov 30 10:25:02 UTC] Summary: 2 RC5 packets (4*2^28 keys)
                      0.00:22:16.89 - [640.29 kkeys/s]
[Nov 30 10:25:02 UTC] 501 RC5 packets (3862 work units) are in buff-in.rc5
[Nov 30 10:25:02 UTC] Projected ideal time to completion: 18.14:16:32.00
[Nov 30 10:25:03 UTC] 84 RC5 packets (172 work units) are in buff-out.rc5
Ik heb van GeonetiX zo'n logfile gekregen; volgens hem wordt die aangemaakt door die RC5 client. Hij zei ook dat je de filenaam zelf kon instellen.
StatBar.nl - @GoT
  • uibeltje
uibeltje
Idiotheque
je moet in je configuratie van je koe wel instellen dat je een logfile wilt laten maken :)
Dat heb ik nu ook gedaan maar nog steeds allemaal ???? weet iemand wat er niet goed gaat? De file ziet er idd zo uit als hierboven door Mr. B. gepost.
  • r00tie
  • Laatst online: 21-10 17:11
Ik heb rc5.log aangegeven en nog allemaal ????
What could it be?
  • Palomar
ja klopt.. ik heb al ff in de properties gekeken van de dnetc client maar je moet wel zelf instellen dat er een logfile wordt gemaakt. dan doet ie het wel :) standaard maakt ie geen logfile aan (bij mij dan..)
  • Roeland_
  • Laatst online: 23-11 15:12
Ik moet zeggen: Perfect, RC5 is helemaal }:O
Trouwens, om rc5 aan het }:O }:O te krijgen moet je eerst een in je client een logfile aanmaken.
  • r00tie
Ik krijg het nog steeds niet voor elkaar
  • DBA907
  • Laatst online: 14-10-2025
Elke keer als ik een msg verstuur met ICQ popped statbar up. beetje irritant, maar verder vette util :9
edit: in autohide
  • uibeltje
uibeltje
Idiotheque
Op zondag 28 januari 2001 17:48 schreef r00tie het volgende:
ik ook niet, toch maakt de koe een file aan rc5.log
dit staat er in:
dnetc v2.8012-465-GTR-00122516 for Win32 (WindowsNT 5.0).
Using email address (distributed.net ID) 'uibeltje@hotmail.com'
[Jan 28 16:43:59 UTC] RC5: Loaded FCD49F54:30000000:32*2^28 (55.40% done)
[Jan 28 16:43:59 UTC] RC5: Summary: 3 packets (32.00 stats units)
0.02:12:57.20 - [1,077,091 keys/s]
[Jan 28 16:43:59 UTC] RC5: 137 packets (3814.00 stats units) remain in
buff-in.rc5
Projected ideal time to completion: 9.14:57:32.00
[Jan 28 16:43:59 UTC] RC5: 110 packets (2333.00 stats units) are in
buff-out.rc5
[Jan 28 16:43:59 UTC] 1 cruncher has been started.
[Jan 28 16:48:03 UTC] *Break* Restarting...
[Jan 28 16:48:03 UTC] RC5: Saved FCD49F54:30000000:32*2^28 (57.60% done)
0.00:04:04.05 - [798,260 keys/s]
[Jan 28 16:48:03 UTC] RC5: Summary: 3 packets (32.00 stats units)
[Jan 28 16:48:03 UTC] RC5: 138 packets (3846.00 stats units) are in
buff-in.rc5
[Jan 28 16:48:04 UTC] RC5: 110 packets (2333.00 stats units) are in
buff-out.rc5
ook heb ik die file aangegeven in StatBar. Maakt het nog uit wat voor type logfile er wordt gemaakt? Je hebt bv. unlimited, FIFO enz.
  • Mr. B.
Vaag? :?
Hij kijkt naar de laatste regel in de file waar "butt-out.rc5" in voor komt, die zou d'r uit moeten zien als "[Nov 30 10:25:03 UTC] 84 RC5 packets (172 work units) are in buff-out.rc5"
StatBar zoekt vervolgens in die regel naar "RC5" en "work", en pakt de getallen die daar voor staan.
StatBar.nl - @GoT
  • Mr. B.
Op zondag 28 januari 2001 17:49 schreef PsychoRealm het volgende:
edit: in autohide
Dan krijgt StatBar de "focus" van Windows, en zodra dat gebeurt moet ie popuppen (vaag woord :P) ja. Waarschijnlijk houdt ICQ zelf z'n focus niet; kan ik helaas nix aan doen...
StatBar.nl - @GoT
  • Mr. B.
buff-out.rc5
OMG... is het logfile formaat van die client aangepast? :? Zie m'n post hierboven; het gaat dus fout omdat ie "work" niet vindt. Probeer het eens met een ander type logfile dan?
StatBar.nl - @GoT
  • Palomar
ik gebruik 'no limit'.. dan moet je nog ff een filename verzinnen van het logbestand (bij mij 'koelog') en dat bestand invullen.. werkt bij mij gewoon..
  • r00tie
het is van work units naar stats units gegaan, dus StatBar moet aangepast worden!
I'm such a genius ;)
Perfect Proggie!!!
Bij mij leest 'ie perfect Koei.log uit :P
Alleen jammer dat 'ie te breed wordt als je alle opties wilt weergeven ;(
  • r00tie
Op zondag 28 januari 2001 17:57 schreef Mr. B. het volgende:
Is het veel werk om het aan te passen dat hij op stat zoekt ipv work?
  • Mr. B.
Op zondag 28 januari 2001 18:02 schreef r00tie het volgende:
Nieuwe versie van die client ofzo? Damn :(
StatBar.nl - @GoT
  • Mr. B.
r00tie: tjek jor meel pliez :)
StatBar.nl - @GoT
  • D.R.
D.R.
XBox Live Tag: CrazyCavia
v1.2 werkte perfect.
Deze gedownd, register even leeggehaald, prog gestart, naam ingevult en...
Error..forget it.
Wat ik ook probeer, register, resolutie, helpt allemaal niks :(
Die .dll is geinstalleerd. Ik weet het niet meer :?
Flickr | Groningen Eelde Aviation Society | Flightdiary
  • Jasper
  • Laatst online: 22-11 09:07
Idd ja, jammer van die nieuwe rc5 client..
Enne, mijn icq neukt er, tot nu, ook niet meer van op! *D
  • wildhagen
wildhagen
Blablabla
Is er ook een versie voor OGR in de maak?
PS: hij geeft het geheugen ook niet goed aan, hij zegt dat ik 255 MB heb, terwijl ik er toch écht 256 heb (en ja, Windows zelf zegt wél keurig 256 MB).
Virussen? Scan ze hier!
  • Mr. B.
Op zondag 28 januari 2001 18:31 schreef D.R. het volgende:
Error..forget it.
Vaag... welke Windows versie? Nog andere progs actief die dwars zouden kunnen zitten? Wat voor foutmelding krijg je BTW?
StatBar.nl - @GoT
  • Mr. B.
Progje aangepast: werkt nu ook goed met de nieuwe RC5 client (zie ook begin van de thread :))
Op zondag 28 januari 2001 18:37 schreef wildhagen het volgende:Is er ook een versie voor OGR in de maak?
Als je me ff een logfile mailt (ik neem aan dat de OGR client ook logt?) en erbij vertelt wat voor info je graag wilt zien zal ik kijken wat ik kan doen :)
Tja, StatBar gebruikt de GlobalMemoryStatus API call om geheugenstuff uit te vragen, en die geeft helaas niet altijd de goede waardes terug.
Welke Windows versie heb je? Als het Win9x/ME is zal die waarschijnlijk idd 256 meg aangeven in Control Panel - System; als je NT/2K hebt staat het daar in KB's aangegeven; op mijn laptop geeft ie daar 196080 KB aan, terwijl 192 meg toch echt 196608 KB is).
StatBar.nl - @GoT
  • r00tie
Mr. B> Wat ga je eraan doen????
  • SaURoN
Hoe krijg je dan een log file waar stel je dat in koetje in ?
  • uibeltje
uibeltje
Idiotheque
Op zondag 28 januari 2001 18:04 schreef r00tie het volgende:
ja, is dat veel werk?
Ik zou het erg fijn vinden als die functie zou werken. :)
  • Mr. B.
Op zondag 28 januari 2001 18:49 schreef r00tie het volgende:
Eh, waaraan? :? :)
Het probleem met de nieuwe RC5 client is inmiddels gefixt (hoop ik :o)
StatBar.nl - @GoT
  • wildhagen
wildhagen
Blablabla
Oké, zal hem zo mailen. Wat is je emailadres?
Denk je eraan dat ook hier net als bij RC5 2 verschillende soorten logfiles zijn? Qua versies bedoel ik.
Wat ik graag zou willen zien is : hoeveel stubs (blocks) er gedaan zijn en het aantal Gnodes (wu's) dat waren.
Ik heb WinWhistler 2410.
  • Mr. B.
Op zondag 28 januari 2001 18:49 schreef SaURoN het volgende:
Dat weet ik niet; ik draai zelf geen koe :+
Daar kunnen ze je in het DPC forum vast verder mee helpen :)
StatBar.nl - @GoT
  • jelmervos
jelmervos
Simple user
Hoeveel geheugen vreet dit programma zelf?
"The shell stopped unexpectedly and Explorer.exe was restarted."
  • r00tie
Hij doet ut nog steeds niet bij mij, ik heb hem van dezelfde locatie gedownload, maar doet ut nog steeds niet :'(
  • SaURoN
Mijn koe balkje wat er instaat doet het niet ;(
voor de rest is het een B-) programma
  • justguyver
  • Laatst online: 21-11 15:18
bij mij werkt de koe balk ook niet ;(
voor de rest is het een goed programma
  • SaURoN
Mijn arme }:O ;( hoe zal zij zich wel niet voelen vast heel erg :'(
}:0 moet mij vergeven plz
  • D.R.
D.R.
Draai Win98SE, geen extra programma's.
error:
Afbeeldingslocatie: http://members.home.nl/dan/error.jpg
Hij werkt ook goed onder whistler 2410 :)
  • Palomar
ik heb nog een bug(je) ontdekt.. ik speelde net counterstrike (spel) en het menu is in 640x480, mn desktop (+ statbar) staat op 1024x768. Als ik Counterstrike weer afsluit en naar mn statbar kijk zijn er nog maar 2 items aanwezig...
Heb je ook een ge-unpackte versie voor me? (ongecomprimeerde exe) zodat ik bij de resources kan? dan kan ik em ff wat beter in me desktop verwerken :)
  • Mr. B.
Op zondag 28 januari 2001 19:16 schreef rick_h het volgende:
StatBar past het aantal items automatisch aan; als je resolutie verlaagd wordt haalt ie de meest rechtse items weg zodat de rest nog op je scherm past. Je zult zien dat ie dat ook doet als je handmatig je resolutie verlaagt :)
typo
StatBar.nl - @GoT
Man, i love this program, alles werkt perfect, ook de RC5-counter:):):)
  • Mr. B.
Op zondag 28 januari 2001 19:21 schreef Razor_Blade het volgende:
Ah, je wilt de gfx gaan modden? :P
Zal ook met een ge-unpackte versie van de exe niet gaan; VB slaat die niet als resource op, sorry :)
StatBar.nl - @GoT
  • Obi
  • Laatst online: 03-09 16:58
Obi
Wow dude, de Autohide-functie is perfect! Thanx man :)
  • Jasper
Sorry Mr.B, maar icq neukt weder op! :(
Het gebeurt alleen wanneer een icq window automatisch op popped wanneer er een bericht komt. Een vriend van me heeft er ook last van. Van de week een verse install van w2k erover en dan zal ik kijken of het nog steeds zo is..
Verder izzie errug goed btw! :D
  • Mr. B.
Op zondag 28 januari 2001 19:33 schreef Jasper het volgende:
Tja, StatBar werkt nu toch echt zoveel mogelijk zoals het volgens Microsoft hoort... ben bang dat ICQ toch iets niet helemaal goed doet.
BTW, het screenshotje wat je in het draadje over StatBar 1.2 hebt gepost herken ik; dat heb ik zelf ook een keer gehad. Ik heb toen ICQ 1 keer opnieuw geïnstalleerd, en daarna is het nooit meer voorgekomen.
StatBar.nl - @GoT
Damn, net deed m'n RC5 counter het prima, nu stopt ie er ineens mee:(:(:(
  • uibeltje
uibeltje
Idiotheque
Op zondag 28 januari 2001 18:53 schreef jelmervos het volgende:
bij mij
ff kijken
7.592 kb best wel veel dus :(
  • johnwoo
  • Laatst online: 18:56
johnwoo
3S-GTE
Werkt weer perfect hoor! Erg mooi!
Ik heb de laatste tijd geen tijd meer gehad om aan mijn eigen bar te werken, dus blijf ik voorlopig StatBar gebruiken ;)
Bij mij bijna 8MB, toch wel een stuk meer dan de 4MB (als ik het me goed herinner) die versie 1.2 gebruikte... Maar ja, geheugen zat! :P
4200Wp ZO + 840Wp ZW + 1680Wp NW | 14xIQ7+ + 1xDS3-L | MTVenusE | HWP1
  • Mr. B.
Hier 6576 KB... dat ie zoveel nodig heeft komt puur omdat ie helemaal is opgebouwd uit graphics en er nu 4 verschillende kleurenschema's inzitten.
StatBar.nl - @GoT
  • SaURoN
hey waar is die update dan dat de koe het wel doet ?
  • wildhagen
wildhagen
Blablabla
5748 kB hiero.
  • uibeltje
uibeltje
Idiotheque
Op zondag 28 januari 2001 20:14 schreef SaURoN het volgende:
die wil ik dus ook graag :)
  • SaURoN
probleem heb ik ook ik draai beide
op 1280*1024 en nog heb ik het :(
(in cs ook 1280*1024)
  • Mr. B.
Zelfde locatie... ik heb 'm gewoon opnieuw ge-upload.
StatBar.nl - @GoT
  • SaURoN
jup werkt nu goed
Bl2 Wu 6 omdat koe de vorige keer niet uit zijn stal wou komen ;(
  • Palomar
Op zondag 28 januari 2001 19:23 schreef Mr. B. het volgende:
typo
ja.. maar die resolutie van 640x480 in counterstrike (en veel andere games) is maar tijdelijk.. als je weer terug gaat naar windows blijven er maar 2 items over. Nu moet ik handmatig bij 'configuration' de items weer toevoegen..
  • Woef
Ja hier staan wat screenshots :)
http://www.rorupc.nl/reviews/statbarbeta/
en hier nog een topic:
http://gathering.tweakers.net/forum/list_messages/111443
En bij mij gebruikt het ongeveer 5 mb :)
  • r00tie
Hier de Rc5 counter nog steeds niet werken, Mr. B, kan je hem ff e-mailen naar hetzelfde mail adres van toenstraks?
  • Mr. B.
Op zondag 28 januari 2001 21:42 schreef r00tie het volgende:
Hij zou het nu toch moeten doen lijkt me, als je tenminste in je RC5 client aangeeft dat ie die logfile moet aanmaken (en vervolgens ook die file selecteert in StatBar). Maargoed, hij ligt in je mailbox :)
StatBar.nl - @GoT
  • r00tie
Thanx m8y
  • r00tie
Die RC5 counter doet ut gewoon niet bij mij
  • Mr. B.
Op zondag 28 januari 2001 21:57 schreef r00tie het volgende:
Dan weet ik het zo 1-2-3 ook niet meer... kun je me ff de logfile mailen die je rc5 client aanmaakt?
StatBar.nl - @GoT
  • BrammeS
  • Laatst online: 24-11 09:13
Mischien wordt het tijd dat mr B zelf eens de client(en) instaleert zodat hij zelf kan zien hoe dit alles werkt!
Verder ziet alles er top uit :)
Advanced sheep-counting strategies
  • Mr. B.
Op zondag 28 januari 2001 22:14 schreef BrammeS het volgende:
Zo'n soort reactie had ik wel verwacht... :P
StatBar.nl - @GoT
Toppie proggie
Ik vind alleen dat hij te snel naar beneden komt
Nu moet ik telkens heel voorzichtig naar het kruisje rechtboven anders komt statbar.
  • uibeltje
uibeltje
Idiotheque
Op zondag 28 januari 2001 23:19 schreef jordyb het volgende:
Toppie proggie
bij mij zie je hem altijd :)
vraagje: moet blocks en workunits niet omgedraaid worden? Ik heb nu 2 bl. en 64 wu, volgens mij moet dat 2 wu en 64 bl zijn :?
  • Mr. B.
Op zondag 28 januari 2001 23:19 schreef jordyb het volgende:Toppie proggie
Hmm... ik vind het zelf niet te snel, maar da's een kwestie van smaak natuurlijk. Een oplossing is natuurlijk om m'n niet op auto hide te zetten, of 'm onderaan je scherm te plaatsen.
Op zondag 28 januari 2001 23:37 schreef uibeltje het volgende:
Hier ook :)
Dat klopt toch echt wel denk ik... kijk maar in je logfile :)
StatBar.nl - @GoT
  • uibeltje
uibeltje
Idiotheque
Op zondag 28 januari 2001 23:43 schreef Mr. B. het volgende:
You're right, tijd om te gaan :Z denk ik
  • Dexter
  • Laatst online: 19-11 15:28
Dexter
d((o_o))b
Ik weet niet of het al eerder ter sprake gebracht is, maar is het niet mogelijk om voor dual systemen 2 cpu metertjes te maken?
Zou wel heel fijn zijn, want het proggie is zooooo goed.
THNX!!!
Dex
'It's all a matter of opinion' LTJ Bukem | 'You don't need eyes to see, you need vision' Maxi Jazz
hier bij mij werkt RC5-tellertje ook niet.
dit is de laatste lijn uit mn .log-file
RC5: 1 packet (6.00 stats units) is in buff-out.rc5
  • Mr. B.
Op maandag 29 januari 2001 00:23 schreef [MoRtAl] het volgende:
Aaarrrghhh... gvd! Bij 1 schrijft die client "packet" en niet "packets" weg |:(
Is gefixt, je kunt StatBar opnieuw downen :)
StatBar.nl - @GoT
  • Mr. B.
Op zondag 28 januari 2001 23:56 schreef Dexter het volgende:
Ik ben bang dat dat niet gaat lukken, maar ik zal kijken wat ik kan doen.
StatBar.nl - @GoT
Op maandag 29 januari 2001 00:28 schreef Mr. B. het volgende:
oke, dank je, ik heb trouwens versie 2.8012.465a :)
  • E-Vix
  • Laatst online: 23-11 11:36
E-Vix
Nu met sneeuw!
Heb net de laatste versie gedownload, maar bij mij geeft ie nog allemaal ??? bij }:O
Mijn logfile ziet er zo uit :
[Jan 29 00:04:13 UTC] RC5: using core #2 (RG class 6).
[Jan 29 00:04:13 UTC] RC5: Loaded 0443AAF1:B0000000:32*2^28 (87.70% done)
[Jan 29 00:04:13 UTC] RC5: 127 packets (2752.00 stats units) remain in
buff-in.rc5
[Jan 29 00:04:13 UTC] RC5: 42 packets (1222.00 stats units) are in
buff-out.rc5
[Jan 29 00:04:13 UTC] 1 cruncher has been started.
Mijn logfile is trouwens 265 kb groot, en staat niet op een maximum ingesteld. Heeft dat nog enige invloed op statbar?
Failed opening '/home/users/7942/signature.inc' for inclusion (include_path='.:') in /home/www/got/userstats.php on line 25
  • Mr. B.
Op maandag 29 januari 2001 01:11 schreef E-Vix het volgende:
[Jan 29 00:04:13 UTC] RC5: 127 packets (2752.00 stats units) remain in buff-in.rc5
[Jan 29 00:04:13 UTC] RC5: 42 packets (1222.00 stats units) are in buff-out.rc5
Vaag... als ik dat ff in een file copy-paste doet ie het wel? :?
StatBar.nl - @GoT
  • Thefirstikke
mooi gemaakt!!
netjes!
  • Mr. B.
StatBar zou files tot 2 GB aan moeten kunnen, dus 265 KB is geen probleem :)
StatBar.nl - @GoT
  • E-Vix
E-Vix
Nu met sneeuw!
Nog veel weirder... Ik heb mijn hele logfile gerenamed, en een nieuwe aangemaakt. Dit is alles wat er in mijn logfile staat :
[Jan 29 00:28:29 UTC] *Break* Restarting...
[Jan 29 00:28:29 UTC] RC5: Saved 0443AAF3:D0000000:32*2^28 (19.50% done)
0.00:01:22.68 - [2,529,391 keys/s]
[Jan 29 00:28:29 UTC] RC5: 127 packets (2752.00 stats units) are in
buff-in.rc5
[Jan 29 00:28:29 UTC] RC5: 43 packets (1254.00 stats units) are in
buff-out.rc5
dnetc v2.8012-465-GTR-01012012 for Win32 (Windows 4.90).
Using email address (distributed.net ID) 'e-vix@planet.nl'
[Jan 29 00:28:30 UTC] RC5: Loaded 0443AAF3:D0000000:32*2^28 (19.50% done)
[Jan 29 00:28:30 UTC] RC5: 126 packets (2720.00 stats units) remain in
buff-in.rc5
Projected ideal time to completion: 3.08:05:20.00
[Jan 29 00:28:30 UTC] RC5: 43 packets (1254.00 stats units) are in
buff-out.rc5
[Jan 29 00:28:30 UTC] 1 cruncher has been started.
Hier geeft ie alleen maar ???'s op.
Als ik vervolgens van
buff-out.rc5
[Jan 29 00:28:30 UTC] RC5: 43 packets (1254.00 stats units) are in buff-out.rc5
maak, dan doet ie het wel.
niet duidelijk te zien, vandaar een link naar mijn logfile : http://www.loempia.com/rc5_log.txt
  • Mr. B.
Op maandag 29 januari 2001 01:34 schreef E-Vix het volgende:Nog veel weirder... Ik heb mijn hele logfile gerenamed, en een nieuwe aangemaakt. Dit is alles wat er in mijn logfile staat :
buff-in.rc5
buff-out.rc5
buff-in.rc5
buff-out.rc5
buff-out.rc5
Hmm... nja, StatBar kijkt naar de laatste regel waar "buff-out.rc5" in voorkomt. Ik vind het vreemd dat ie dat bij jou op een nieuwe regel zet... probeer eens een ander logfile formaat in te stellen in je rc5 client?
StatBar.nl - @GoT
  • Anton
  • Laatst online: 15-11 16:38
Anton
NetApp Implementation Engineer
Bij mij doet ie precies hetzelfde, 'buff-out.rc5' staat op een nieuwe regel. Zowel bij de nieuwste client, als bij een oeroude (2.7xxx) is dat het geval bij mij. Dus ik zie ook geen rc5-stats in statbar :'(
Edit: en ik weet al waarom ook: Als de totale regel langer is dan in het console-venstertje van de client past, zet ie het laatste woord ("buff-out.rc5" dus) op een nieuwe regel.
Ik scrobbel ook audio
  • mvds
  • Laatst online: 24-11 16:30
mvds
Totally awesome!
Bij mij werkt ie perfect hoor. Ik heb de nieuwste versie draaien van de dnet client. Mooi proggie...
  • Yucko
  • Laatst online: 18:00
Yucko
Property of Loontje
Mr. B
fantastisch programma. kan niet anders zeggen. chappeau! *D
 iPhone 15 Pro Max Titanium Black 256GB -  iPad Pro 2018 12.9" Space Gray 64GB -  MacBook Air M4 13" 16GB/512GB -  AirPods Pro 3 -  Watch Ultra 4 Black -  TV 4K 4th gen -  TV 4K 3rd gen 128GB -  Wireless CarPlay
  • Hurricane
  • Laatst online: 12:25
Hurricane
Alles is anders dan het lijkt!
Kan je er ook een optie inmaken die de snelheid weergeeft van het netwerk/internet als je aan het leechen bent? Net zoiets DU- meter???
  • Mr. B.
Op maandag 29 januari 2001 10:47 schreef Anton het volgende:
Hmm, eigenlijk een probleem met die client dus. Dat console venstertje, kun je dat handmatig vergroten?
Zo nee, dan zal ik kijken of ik daar in de volgende versie wat aan kan doen.
StatBar.nl - @GoT
  • Mr. B.
Op maandag 29 januari 2001 12:46 schreef Hurricane het volgende:
Dat gaat waarschijnlijk niet lukken, lees svp m'n 1e post :)
StatBar.nl - @GoT
Heb je geen Winamp lugin ofzo??
Dat lijkt me vet bruut.
Gewoon zo een stereo dingetje erin
  • Mr. B.
Op maandag 29 januari 2001 13:02 schreef jordyb het volgende:
Wat bedoel je precies met stereo dingetje? Play, stop knopjes e.d. voor winamp is misschien wel een idee :)
StatBar.nl - @GoT
Is je site uit de lucht of kan ik dit volledig aan UPC toeschrijven :(
Ik krijg em dus niet te pakken :)
ps ik denk dat ie een VU-metertje voor winamp in gedachten had, maar die knoppies zouden nog beter zijn ;)
Op maandag 29 januari 2001 13:16 schreef Mr. B. het volgende:
Nee dat kan ook maar ik doelde meer op zo een staafdiagrammatje dat telkens beweegt.
Meer bas staafdiagrammetje omhoog.
Snappie????
  • Bezulba
  • Laatst online: 24-11 09:44
Bezulba
Formerly known as Eendje
en dan ook gelijk die stop start dingen erbij :) en ook een "maak koffie" knop.. dan is ie helemaal compleet! :)
blup
  • Palomar
ik heb hem hier ff op school geprobeerd (winNT4 WS) en hij crasht meteen.. hier de logfile van dr. watson..
Microsoft (R) Windows NT (TM) Version 4.00 DrWtsn32
Copyright (C) 1985-1996 Microsoft Corp. All rights reserved.
Application exception occurred:
App: (pid=130)
When: 10/29/2000 @ 15:33:34.501
Exception number: c0000005 (access violation)
*----> System Information <----*
Computer Name: D254-12
User Name: Student
Number of Processors: 1
Processor Type: x86 Family 6 Model 5 Stepping 1
Windows Version: 4.0
Current Build: 1381
Service Pack: 6
Current Type: Uniprocessor Free
Registered Organization: Hanzehogeschool FT
Registered Owner: Informatica
*----> Task List <----*
0 Idle.exe
2 System.exe
20 SMSS.exe
26 CSRSS.exe
34 WINLOGON.exe
40 SERVICES.exe
43 LSASS.exe
67 SPOOLSS.exe
74 NETDDE.exe
89 amgrsrvc.exe
98 Mcshield.exe
109 VsTskMgr.exe
121 NMAGENT.exe
133 LOCATOR.exe
142 RPCSS.exe
150 PSTORES.exe
153 mstask.exe
126 NDDEAGNT.exe
179 EXPLORER.exe
176 LOADWC.exe
83 systray.exe
173 EM_EXEC.exe
64 realplay.exe
182 shstat.exe
177 IEXPLORE.exe
130 StatBar.exe
216 DRWTSN32.exe
0 _Total.exe
(00400000 - 00400000)
(77f60000 - 77fbe000) dll\ntdll.dbg
(0f000000 - 0f14d000) MSVBVM50.dbg
(77f00000 - 77f5e000) dll\kernel32.dbg
(77e70000 - 77ec5000) dll\user32.dbg
(77ed0000 - 77efc000) dll\gdi32.dbg
(77dc0000 - 77dff000) dll\advapi32.dbg
(77e10000 - 77e67000) dll\rpcrt4.dbg
(77b20000 - 77bd7000) dll\ole32.dbg
(65340000 - 653d2000) oleaut32.dbg
(01140000 - 01166000) asycfilt.dbg
(776b0000 - 776c4000) dll\ws2_32.dbg
(78000000 - 78040000)
(776a0000 - 776a7000) dll\ws2help.dbg
State Dump for Thread Id 0xdf
eax=00000000 ebx=00c4b064 ecx=00000086 edx=77fa5560 esi=00000000 edi=00c4de24
eip=00000000 esp=0012fbb0 ebp=0012fbc8 iopl=0 nv up ei pl zr na po nc
cs=001b ss=0023 ds=0023 es=0023 fs=003b gs=0000 efl=00000246
function: <nosymbols>
*----> Stack Back Trace <----*
FramePtr ReturnAd Param#1 Param#2 Param#3 Param#4 Function Name
0012fbac 77e72c6a 000d034a 00000086 00000000 00000000 !<nosymbols>
0012fbc8 77e72cf5 00000000 000d034a 00000086 00000000 user32!GetFocus
0012fbe8 0043abba 00000000 000d034a 00000086 00000000 user32!CallWindowProcA
*----> Raw Stack Dump <----*
0012fbb0 6a 2c e7 77 4a 03 0d 00 - 86 00 00 00 00 00 00 00 j,.wJ...........
0012fbc0 00 00 00 00 00 00 00 00 - e8 fb 12 00 f5 2c e7 77 .............,.w
0012fbd0 00 00 00 00 4a 03 0d 00 - 86 00 00 00 00 00 00 00 ....J...........
0012fbe0 00 00 00 00 01 00 00 00 - fc fc 12 00 ba ab 43 00 ..............C.
0012fbf0 00 00 00 00 4a 03 0d 00 - 86 00 00 00 00 00 00 00 ....J...........
0012fc00 00 00 00 00 24 de c4 00 - 00 00 00 00 64 b0 c4 00 ....$.......d...
0012fc10 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
0012fc20 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
0012fc30 00 00 00 00 86 00 00 00 - 00 00 00 00 00 00 00 00 ................
0012fc40 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
0012fc50 00 00 00 00 86 00 00 00 - 00 00 00 00 00 00 00 00 ................
0012fc60 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
0012fc70 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
0012fc80 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
0012fc90 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
0012fca0 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
0012fcb0 00 00 00 00 01 00 12 00 - 01 00 00 00 00 00 00 00 ................
0012fcc0 48 70 13 00 04 00 00 00 - 00 00 00 00 00 00 00 00 Hp..............
0012fcd0 00 00 00 00 00 00 00 00 - 00 00 00 00 a8 ff 12 00 ................
0012fce0 a6 24 40 00 04 fc 12 00 - 28 15 40 00 00 00 00 00 .$@.....(.@.....
misschien heb je dr wat aan.... :D
  • Mr. B.
Op maandag 29 januari 2001 13:23 schreef jordyb het volgende:
Snappie????
Oh een VU meter :)
Ben bang dat dat niet gaat lukken... ;(
StatBar.nl - @GoT
Pagina: 1 2 Laatste
