Probleem met lange afsluit tijden
  • 110 views sinds 30-01-2008
hoi allemaal,
ik heb nu al een tijdje een probleem dat mijn computer er erg lang over doet om af te sluiten
kunnen jullie mij helpen hiermee?
ik heb een:
Intel pentium 4HT 3ghz @3.45
Asus P5ND2 SLI
XF-i Elite pro
Nvidia G-force 7900GT
1 gig DDR2 geheugen
logitech i-navigator
Razer copperhead muis
ik hoop dat dit genoeg info is of willen jullie een dxdiag?
System Information
Time of this report: 6/11/2006, 08:59:04
Machine name: ORZON
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz (2 CPUs)
Memory: 1024MB RAM
Page File: 295MB used, 2164MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file nv4_disp.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 7900 GT
Manufacturer: NVIDIA
Chip type: GeForce 7900 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0291&SUBSYS_032110DE&REV_A1
Display Memory: 256.0 MB
Current Mode: 1024 x 768 (32 bit) (75Hz)
Monitor: Default Monitor
Monitor Max Res:
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.9131 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 6/1/2006 17:22:00, 4529408 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 6/1/2006 17:22:00, 3925920 bytes
Device Identifier: {D7B71E3E-41D1-11CF-C550-2B2300C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0291
SubSys ID: 0x032110DE
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SB X-Fi Audio [A000]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0005&SUBSYS_00221102&REV_00
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 5.12.0001.1144 (English)
WHQL Logo'd: Yes
Date and Size: 10/29/2005 19:16:24, 439680 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 1, 192000
Static/Strm HW Mix Bufs: 128, 128
Static/Strm HW 3D Bufs: 128, 128
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: SB X-Fi DMusic Synth [A000], Hardware (Kernel Mode), Output, DLS, Internal, Default Port
MPU-401, Hardware (Kernel Mode), Input, No DLS, External
MPU-401, Hardware (Kernel Mode), Output, No DLS, External
SB X-Fi Audio [A000], Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB X-Fi Synth A [A000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU-401 [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
SB X-Fi Synth B [A000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB X-Fi MIDI Port [A000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU-401 [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
SB X-Fi MIDI Port [A000] [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Internet Keys USB
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC30A
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x003B
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/4/2004 08:08:42, 57600 bytes
| Driver: usbd.sys, 3/31/2003 14:00:00, 4736 bytes
Gameport Devices
+ PCI bus
| Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 8/4/2004 08:07:46, 68224 bytes
+-+ Standard Game Port
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 8/4/2004 08:08:21, 10624 bytes
PS/2 Devices
+ Logitech HID-Compliant Keyboard
| Matching Device ID: hid\vid_046d&pid_c30a&mi_00
| Service: kbdhid
| Driver: kbdhid.sys, 8/4/2004 07:58:34, 14848 bytes
| Driver: kbdclass.sys, 8/4/2004 07:58:32, 24576 bytes
+ HID Keyboard Device
| Vendor/Product ID: 0x1532, 0x0101
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 10:01:07, 40840 bytes
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 8/4/2004 07:58:32, 23040 bytes
| Driver: mouhid.sys, 3/31/2003 14:00:00, 12160 bytes
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 9.0 GB
Total Space: 20.0 GB
File System: NTFS
Model: Maxtor 6L200M0
Drive: D:
Free Space: 112.9 GB
Total Space: 174.5 GB
File System: NTFS
Drive: G:
Free Space: 62.1 GB
Total Space: 76.4 GB
File System: NTFS
Model: SAMSUNG SP0802N
Drive: E:
Model: DVDRW IDE 16X
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/4/2004 07:59:52, 49536 bytes
Drive: F:
Model: PLEXTOR CD-R PX-W5224A
Drive: I:
Model: QW7084L UCX204P SCSI CdRom Device
System Devices
Name: Intel(R) PRO/1000 MT Network Connection
Device ID: PCI\VEN_8086&DEV_100E&SUBSYS_80EE1043&REV_02\4&169C35E&0&6090
Driver: n/a
Name: Creative SB X-Fi
Device ID: PCI\VEN_1102&DEV_0005&SUBSYS_00221102&REV_00\4&169C35E&0&3090
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/4/2004 09:56:42, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004 09:56:58, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/4/2004 08:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/4/2004 08:07:58, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/4/2004 08:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/4/2004 08:08:02, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 09:56:57, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ctac32k.sys, 5.12.0001.1144 (English), 10/29/2005 19:15:32, 502272 bytes
Driver: C:\WINDOWS\system32\drivers\ctaud2k.sys, 5.12.0001.1144 (English), 10/29/2005 19:16:24, 439680 bytes
Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 5.12.0001.1144 (English), 10/29/2005 19:15:48, 114688 bytes
Driver: C:\WINDOWS\system32\drivers\ctprxy2k.sys, 5.12.0001.1144 (English), 10/29/2005 19:16:24, 7168 bytes
Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 5.12.0001.1144 (English), 10/29/2005 19:15:40, 143360 bytes
Driver: C:\WINDOWS\system32\drivers\emupia2k.sys, 5.12.0001.1144 (English), 10/29/2005 19:15:38, 77824 bytes
Driver: C:\WINDOWS\system32\drivers\ha10kx2k.sys, 5.12.0001.1144 (English), 10/29/2005 19:15:54, 751104 bytes
Driver: C:\WINDOWS\system32\drivers\haP16v2k.sys, 5.12.0001.1144 (English), 10/29/2005 19:15:56, 153088 bytes
Driver: C:\WINDOWS\system32\drivers\haP17v2k.sys, 5.12.0001.1144 (English), 10/29/2005 19:15:58, 178688 bytes
Driver: C:\WINDOWS\system32\drivers\ha20x2k.sys, 5.12.0001.1144 (English), 10/29/2005 19:16:12, 1095680 bytes
Driver: C:\WINDOWS\system32\drivers\pfmodnt.sys, 3.00.0000.0011 (English), 10/29/2005 19:40:38, 9216 bytes
Driver: C:\WINDOWS\system32\ctdlang.dat, 10/29/2005 19:20:08, 366255 bytes
Driver: C:\WINDOWS\system32\ctstatic.dat, 10/29/2005 19:13:24, 313207 bytes
Driver: C:\WINDOWS\system32\ctdaught.dat, 10/29/2005 19:13:24, 53932 bytes
Driver: C:\WINDOWS\system32\a3d.dll, 80.00.0000.0003 (English), 10/29/2005 19:38:58, 33792 bytes
Driver: C:\WINDOWS\system32\commonfx.dll, 5.12.0001.1144 (English), 10/29/2005 19:18:46, 87040 bytes
Driver: C:\WINDOWS\system32\ctaudfx.dll, 5.12.0001.1144 (English), 10/29/2005 19:18:50, 536576 bytes
Driver: C:\WINDOWS\system32\ctsblfx.dll, 5.12.0001.1144 (English), 10/29/2005 19:19:12, 548352 bytes
Driver: C:\WINDOWS\system32\cteapsfx.dll, 5.12.0001.1144 (English), 10/29/2005 19:19:06, 157696 bytes
Driver: C:\WINDOWS\system32\CTEXFIFX.dll, 5.12.0001.1144 (English), 10/29/2005 19:19:22, 1160192 bytes
Driver: C:\WINDOWS\system32\CTHWIUT.DLL, 5.12.0001.1144 (English), 10/29/2005 19:19:30, 61952 bytes
Driver: C:\WINDOWS\system32\CT20XUT.DLL, 5.12.0001.1144 (English), 10/29/2005 19:19:30, 158208 bytes
Driver: C:\WINDOWS\system32\ctemupia.dll, 5.12.0001.1144 (English), 10/29/2005 19:19:32, 106496 bytes
Driver: C:\WINDOWS\system32\piaproxy.dll, 5.12.0001.1144 (English), 10/29/2005 19:15:34, 73728 bytes
Driver: C:\WINDOWS\system32\ctdproxy.dll, 5.12.0001.1144 (English), 10/29/2005 19:16:14, 71680 bytes
Driver: C:\WINDOWS\system32\sfman32.dll, 5.12.0001.0130 (English), 10/29/2005 19:15:44, 21504 bytes
Driver: C:\WINDOWS\system32\data\cts20x.dat, 10/29/2005 19:13:24, 2091 bytes
Driver: C:\WINDOWS\system32\data\ctd20x.dat, 10/29/2005 19:13:24, 12545 bytes
Driver: C:\WINDOWS\system32\SBXFi.ico, 2/7/2005 17:45:22, 766 bytes
Driver: C:\WINDOWS\system32\XFi.bmp, 2/7/2005 17:45:22, 3128 bytes
Driver: C:\WINDOWS\system32\ctcoinst.dll, 3.00.0002.0011 (English), 10/29/2005 19:42:42, 81920 bytes
Driver: C:\WINDOWS\system32\ctdvinst.dll, 0.03.0000.0029 (English), 10/29/2005 19:42:44, 134656 bytes
Driver: C:\WINDOWS\system32\drivers\ctdvda2k.sys, 5.13.0001.0463 (English), 7/13/2005 17:18:50, 340704 bytes
Name: NVIDIA GeForce 7900 GT
Device ID: PCI\VEN_10DE&DEV_0291&SUBSYS_032110DE&REV_A1\4&36AAE60&0&0010
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0010.9131 (English), 6/1/2006 17:22:00, 3925920 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0010.9131 (English), 6/1/2006 17:22:00, 4529408 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0010.9131 (English), 6/1/2006 17:22:00, 155715 bytes
Driver: C:\WINDOWS\system32\nvhwvid.dll, 6.14.0010.9131 (), 6/1/2006 17:22:00, 581632 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0010.9131 (), 6/1/2006 17:22:00, 196608 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0010.9131 (English), 6/1/2006 17:22:00, 5632000 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0010.9131 (English), 6/1/2006 17:22:00, 7618560 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0010.9131 (English), 6/1/2006 17:22:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0010.9131 (English), 6/1/2006 17:22:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11038 (English), 6/1/2006 17:22:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0010.9131 (English), 6/1/2006 17:22:00, 229376 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0010.9131 (English), 6/1/2006 17:22:00, 5652480 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0010.9131 (English), 6/1/2006 17:22:00, 3100672 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0010.9131 (English), 6/1/2006 17:22:00, 188416 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0010.9131 (English), 6/1/2006 17:22:00, 888832 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0010.9131 (English), 6/1/2006 17:22:00, 2924544 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0010.9131 (English), 6/1/2006 17:22:00, 1257472 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 6/1/2006 17:22:00, 170949 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 6/1/2006 17:22:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 6/1/2006 17:22:00, 35840 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 6/1/2006 17:22:00, 35840 bytes
Name: PCI standard RAM Controller
Device ID: PCI\VEN_10DE&DEV_00B4&SUBSYS_00000000&REV_A1\3&2411E6FE&0&04
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_007F&SUBSYS_00000000&REV_A1\3&2411E6FE&0&01
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_007E&SUBSYS_00000000&REV_A2\3&2411E6FE&0&10
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/4/2004 08:07:46, 68224 bytes
Device ID: PCI\VEN_10DE&DEV_007D&SUBSYS_00000000&REV_A1\3&2411E6FE&0&0E
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_007C&SUBSYS_00000000&REV_A1\3&2411E6FE&0&0D
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_007B&SUBSYS_00000000&REV_A1\3&2411E6FE&0&0C
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_007A&SUBSYS_00000000&REV_A1\3&2411E6FE&0&0B
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0079&SUBSYS_00000000&REV_A1\3&2411E6FE&0&0A
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0078&SUBSYS_00000000&REV_A1\3&2411E6FE&0&09
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0076&SUBSYS_00000000&REV_A1\3&2411E6FE&0&08
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0075&SUBSYS_00000000&REV_A1\3&2411E6FE&0&02
Driver: n/a
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_10DE&DEV_0071&SUBSYS_00000000&REV_A1\3&2411E6FE&0&00
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_006F&SUBSYS_00000000&REV_A1\3&2411E6FE&0&03
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_003F&SUBSYS_00000000&REV_A1\3&2411E6FE&0&48
Driver: n/a
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DE&DEV_003E&SUBSYS_818A1043&REV_F2\3&2411E6FE&0&88
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/4/2004 07:59:41, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/4/2004 07:59:42, 95360 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 3/31/2003 14:00:00, 3328 bytes
Device ID: PCI\VEN_10DE&DEV_003D&SUBSYS_00000000&REV_A2\3&2411E6FE&0&90
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_003C&SUBSYS_818A1043&REV_A2\3&2411E6FE&0&5A
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/4/2004 08:08:37, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/4/2004 08:08:42, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 09:56:46, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/4/2004 08:08:42, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 09:56:42, 7168 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_003B&SUBSYS_818A1043&REV_A1\3&2411E6FE&0&59
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/4/2004 08:08:36, 17024 bytes
Device ID: PCI\VEN_10DE&DEV_003B&SUBSYS_818A1043&REV_A1\3&2411E6FE&0&58
Device ID: PCI\VEN_10DE&DEV_0036&SUBSYS_818A1043&REV_F2\3&2411E6FE&0&80
Device ID: PCI\VEN_10DE&DEV_0035&SUBSYS_818A1043&REV_F2\3&2411E6FE&0&78
Name: SM Bus Controller
Device ID: PCI\VEN_10DE&DEV_0034&SUBSYS_818A1043&REV_A2\3&2411E6FE&0&51
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0030&SUBSYS_00000000&REV_A3\3&2411E6FE&0&50
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 3/31/2003 14:00:00, 35840 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 3/31/2003 14:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:41 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:41 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:41 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 3/31/2003 14:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:41 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 3/31/2003 14:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 3/31/2003 14:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 3/31/2003 14:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 3/31/2003 14:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 3/31/2003 14:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 3/31/2003 14:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:48 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:48 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:03 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:03 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:48 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 3/31/2003 14:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 3/31/2003 14:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 3/31/2003 14:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:57 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 3/31/2003 14:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:44 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/4/2004 08:08:21 10624 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 82432 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 6/6/2006 20:45:00 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 6/6/2006 20:45:00 577536 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 6/6/2006 20:45:00 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 6/6/2006 20:45:00 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 6/6/2006 20:45:00 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 6/6/2006 20:45:01 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 6/6/2006 20:44:59 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 6/6/2006 20:44:59 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 6/6/2006 20:44:59 223232 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 05:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 09:56:42 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 09:56:46 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 09:56:41 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 09:56:42 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/4/2004 09:56:42 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 09:56:42 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 09:56:57 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 09:56:43 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 20480 bytes
qasf.dll: 10.00.0000.3650 English Final Retail 10/11/2004 11:20:30 221184 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 09:56:44 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 09:56:44 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 09:56:44 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 09:56:44 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 09:56:24 733696 bytes
quartz.dll: 6.05.2600.2749 English Final Retail 8/30/2005 05:54:26 1287168 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/4/2004 09:56:45 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 09:56:57 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 09:56:57 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 09:56:42 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 09:56:42 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 09:56:42 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 09:56:42 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 09:56:42 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 09:56:57 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 09:56:44 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/4/2004 08:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:42 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/4/2004 08:08:02 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/4/2004 07:58:38 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/4/2004 07:58:40 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/4/2004 07:58:41 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/4/2004 07:58:41 4352 bytes
mstee.sys: 5.03.2600.2180 English Final Retail 8/4/2004 07:58:38 5504 bytes
ipsink.ax: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:58 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 09:56:57 118272 bytes
ndisip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 08:10:12 10880 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 08:10:12 15360 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 09:56:43 1428480 bytes
slip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 08:10:16 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/4/2004 08:10:28 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/4/2004 08:10:16 17024 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:57 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:44 17408 bytes
kstvtune.ax: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:58 61952 bytes
ksxbar.ax: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:58 43008 bytes
kswdmcap.ax: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:58 90624 bytes
vfwwdm32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 09:56:46 53760 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/4/2004 08:10:22 19328 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 09:56:46 50688 bytes
DirectShow Filters
WDM Streaming VBI Codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.2180
CC Decoder,0x00200000,2,1,,5.03.2600.2180
WST Codec,0x00200000,1,1,,5.03.2600.2180
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Creative LiveRecording Filter,0x00400000,0,1,LiveRec.ax,2.01.0001.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
CT Upsampler filter,0x00100000,1,1,Upsample.ax,2.00.0005.0000
CyberLink DVD Navigator,0x00600000,0,3,CLNAVX.ax,5.00.0000.1818
Creative Wave Writer,0x00200000,1,0,WavWrite.ax,3.00.0012.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Creative MLP Source Filter,0x00400000,0,1,MlpSrc.ax,3.00.0000.0000
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3650
Creative NVF Filter,0x00400000,0,1,NvfSrc.ax,3.00.0000.0000
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
BPM Metadata,0x001fffff,1,1,MetaBPM.ax,1.00.0004.0000
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CT Time-Scaling filter,0x00100000,1,1,TimeScal.ax,2.03.0001.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
SVM Metadata,0x001fffff,1,1,MetaSVM.ax,1.00.0006.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
CyberLink Audio Effect,0x00200000,1,1,claudfx.ax,5.00.0000.1028
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
CyberLink Line21 Decoder Filter,0x00200000,0,2,CLLine21.ax,4.00.0000.3030
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
CyberLink AudioCD Filter,0x00600000,0,1,CLAudioCD.ax,5.00.0000.1031
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PCM to EXT,0x00200000,0,0,Pcm2Ext.ax,6.00.0002.0000
Stream Control Filter,0x001fffff,1,1,StreamCon.ax,1.00.0000.0001
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CT Karaoke filter,0x00100000,1,1,Karaoke.ax,2.00.0003.0000
Creative MP3 Source Filter,0x00400000,0,1,Mp3Src.ax,3.01.0003.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
CT PDP filter,0x00100000,1,1,PDP.ax,1.00.0008.0000
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
Peak Follower Filter,0x001fffff,1,1,PassPeak.ax,1.00.0000.0003
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.02.0000.0008
Creative AC3 Source Filter,0x00400000,0,1,AC3Src.ax,3.00.0002.0000
CT SmartVolumeManagement filter,0x00100000,1,1,DSCompr.ax,1.00.0002.0000
Creative Audio Gain Filter,0x00200000,1,1,AudGain.ax,1.00.0000.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3650
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Creative MP3 Writer,0x00200000,1,0,MP3Write.ax,3.00.0002.0000
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0028
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
AudSkip Filter,0x001fffff,1,1,AudSkip.ax,1.00.0000.0004
CT HPVirtualizer filter,0x00100000,1,1,Virtual.ax,1.00.0000.0000
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
CyberLink Audio Decoder,0x00601000,1,1,claud.ax,5.00.0000.1029
CyberLink Video/SP Decoder,0x00600000,2,3,CLVSD.ax,5.00.0000.1031
CyberLink TimeStretch Filter,0x00200000,1,1,CLAuTS.ax,1.00.0000.0704
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AC3Filter,0x40000000,1,1,ac3filter.ax,0.07.0000.0000
CT CMSS3 filter,0x00100000,1,1,CMSS3.ax,3.00.0013.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
Creative PCM Raw Writer,0x00200000,1,0,RawWrit.ax,1.00.0000.0000
Noise Reduction,0x00100000,1,1,NoisRedu.ax,3.00.0002.0000
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0028
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
Creative WMA Writer,0x00200000,1,0,WMAWrite.ax,3.00.0010.0000
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Creative WMA Source Filter,0x00400000,0,1,WmaSrc.ax,3.01.0000.0000
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.1226
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Creative CDDA Source Filter,0x00400000,0,1,CDDA.ax,3.00.0002.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.2180
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00200000,2,2,,5.03.2600.2180
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 6.2.5 Codec (2 Logical CPUs),0x00200000,1,1,qcap.dll,6.05.2600.2180
Logitech Video (I420),0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 6.2.5 YV12 Decoder,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
MSN Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Audio Capture Sources:
SB X-Fi Audio [A000],0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2749
MPU-401,0x00200000,1,0,quartz.dll,6.05.2600.2749
SB X-Fi MIDI Port [A000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB X-Fi Synth A [A000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB X-Fi Synth B [A000],0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming Capture Devices:
,0x00000000,0,0,,
SB X-Fi MIDI Port [A000],0x00200000,2,2,,5.03.2600.2180
SB X-Fi Audio [A000],0x00200000,3,2,,5.03.2600.2180
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
SB X-Fi DMusic Synth [A000],0x00200000,1,1,,5.03.2600.2180
SB X-Fi Synth A [A000],0x00200000,1,1,,5.03.2600.2180
SB X-Fi Synth B [A000],0x00200000,1,1,,5.03.2600.2180
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.2600.2180
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
WDM Streaming Communication Transforms:
Audio Renderers:
SB X-Fi Audio [A000],0x00200000,1,0,quartz.dll,6.05.2600.2749
CyberLink Audio Renderer,0x00200000,1,0,CLADR.ax,5.00.0000.1006
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: SB X-Fi Audio [A000],0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming System Devices:
MPU-401,0x00200000,3,2,,5.03.2600.2180
SB X-Fi Synth A [A000],0x00200000,11,2,,5.03.2600.2180
SB X-Fi Audio [A000],0x00200000,13,2,,5.03.2600.2180
BDA Receiver Component:
BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.2180
ik hoop dat jullie mij kunnen helpen
Wat versta jij onder lang ? bij mij duurd het ook redelijk lang maar het is bij XP normaal dat het redelijk lang duurd voordat hij echt uitgaat.
nou 10 minuten toch zeker wel
en toen ik windows net nieuw instaleerde was het gelijk afsluiten end at deed hij tot een week geleden ook nog.
ik heb windows een maand geleden er nieuw op gezet.
maa rik bedoel vooral het deel dat als ik op uitschakelen klik hij er dus echt 10 minuten over doet voordat ik het windows is logging off screen krijg.
[ Voor 29% gewijzigd door Verwijderd op 23-06-2006 09:13 ]
Hangt puur af van welke applicaties er opgestart zijn. En welke virusscanner hij gebruikt. (ook)
Wellicht heeft ie een virusscanner die bij het afsluiten een aantal dingen controleert. (run once bijvoorbeeld)
Bij mij duurt het niet megalang, 1 minuut ofzo.
Maar nu heb ik ook niet zo verschrikkelijk veel applicaties/services draaien. Daarvoor hebben we een server he. :P
meestal heb ik maar 2 applicaties draaien, naast de nromale processes zijn er 32 ofzo
en ook al sluit ik alles af zelfs norton.
dan nog doet hij er 10 minuten over.
ik had eerst mcafee maar daar duurde het inderdaan nog langer.
  • Bulls
  • Laatst online: 10:02
alsje de pc wil uitzetten dan druk je toch op de uit knop? dan gaat hij zelf alles netjes afsluiten totdat hij zichzelf uitschakeld. alleen lost dit je probleem niet op,
  • The__Virus
  • Laatst online: 19-10 21:20
Je hebt ook niet toevallig aangegeven je pagefile iedere keer te legen bij het afsluiten? Dit kun je o.a. zien aan het onophoudelijk branden van je HDD-activiteit indicatie LED (wat een naam :P) voor een lange tijd.
[ Voor 42% gewijzigd door The__Virus op 23-06-2006 12:10 ]
  • MPAnnihilator
  • Laatst online: 17-08 19:36
Als je een nieuw userprofiel aanmaakt , hiermee inlogt , en daarna uitlogt , heb je het probleem daarmee dan ook ?
Mijn Specs
hoe zet je dat pagefile legen uit?
een user profile aan maken heeft geen effect heb dan ngo steeds het zelfde probleem
  • Kaizah
  • Laatst online: 01-09 11:29
je kan met registry gaan klooien, er is een optie "WaitToKillAppTimeout" en daar achter een waarde. als je die waarde verkleint dan sluit hij gewoon die app als het te lang duurt.. hiermee heb je wel kans dat hij dingen vergeet die hij op dat moment dan aan het doen is..
mijn pc sluit in 10 seconden
  • chromeeh
  • Laatst online: 11:35
chromeeh
the Gnome
Ik had dit probleem eerst ook...
Raar genoeg nu ik een andere virusscanner (had McAfee, heb nu AntiVir) gebruikt, sluit m'n pc wel snel (lees binnen een minuut complete shutdown)
En ik heb niets veranderd aan de ClearPagefile entries...
"Some day, I hope to find the nuggets on a chicken."
ja ik had eerst ok mcafee maar daarwerd hij erg loangzaamvan dus toend eed ik nieuwe windows install met norton. dat gign geod voor een maand aar nu doet hij dus echt hele lang over afsluiten.
ik heb het probleem gevonden het was mijn itouch driver van mij i-nav keyboard. nu sluit hij wel goed af.
in iedergeval bedankt voor jullie hulp.
  • Renegade!
  • Laatst online: 22-12-2025
Verwijderd schreef op zondag 25 juni 2006 @ 18:42:
Wat deed die driver dan? En zeg even hoe je het opgelost hebt, bespaard misschien mensen die in de toekomst de "search-functie" gebruiken een hoop last...
nou de driver die er toen op zat had een programma geinstaleerd dat backweb heet ik weet niet of jullie dat iets zegt.
maar dat programma creert een fout in windows XP waardoor xp enorm vertraagd.
ikheb nu gewoon de driver gedeinstaleerd en de windows driver gebruikt. ik mis nu wel wat functies maar datis beter dan een trage pc.
ik heb ook al gemaild naar logitech ik hoop snel antwoord te krijgen.
  • JunkieXP
  • Laatst online: 08-10 11:35
JunkieXP
Missing the BB10 Flow =)!
Ik wil niet zeiken maar zover ik weet heb ik datzelfde backweb ook draaien (ben niet thuis dus kan het even niet controleren).
maar mijn afsluit tijd is hooguit 10 seconde.
Dus het probleem is bij jou misschien wel verholpen maar mijn gevoel zegt dat dit niet het probleem was :X
Desktop: Wacom Intuos Pro | Logitech Z2300
Gadgets: iPhone 13 Mini
Earcandy: Sony WH1000XM3 & Beats Pro
Het Algemene Screen-Protector Topic
  • MPAnnihilator
Je kan in XP instellen dat XP maar x-aantal milliseconden wacht voor het afsluiten van processen bij het afsluiten van je PC. Heb je met deze waarden al eens gespeeld :) ?
Zoek met RegEdit maar eens naar : "WaitToKillAppTimeout" , zet dit op 500 ofzo...
[ Voor 23% gewijzigd door MPAnnihilator op 27-06-2006 16:09 ]
Mijn Specs
-GF-Annihilator schreef op dinsdag 27 juni 2006 @ 14:41:
Dit moet het probleem niet kunnen zijn, dat hij zo langzaam afsluit. Standaard staat de "WaitToKillAppTimeout" op 20000. Als je applicaties echt gaat killen, kan er nog meer fout gaan lijkt mij.. >:)
WaitToKillAppTimeout - Tijd om af te sluiten
WaitToKillAppTimeout is de tijd die een applicatie heeft na de opdracht afsluiten om werkelijk te stoppen. De opdracht tot afsluiten wordt via de afsluitknop [X] of bij het stoppen van Windows gegeven. Als een applicatie niet binnen die tijd is afgesloten toont Windows een venster met daarin de optie voor het gedwongen sluiten van de toepassing in kwestie.
Er zijn ook sites die adviseren WaitToKillServiceTimeout aan te passen. Deze waarde lijkt erg op de WaittoKillAppTimeout maar geldt alleen voor Services. Bekende Services zijn de Windows Firewall en Wireless Zero Configuration.
En dan gaat het mis
Wat is nu het probleem van deze versnellende tip? Op het moment dat een toepassing of de computer het erg druk heeft, zal deze een tijd niet reageren op berichten van Windows. En vervolgens meedogenloos om zeep worden geholpen door bovenstaande instellingen. Dat is natuurlijk funest als de toepassing nog niet opgeslagen wijzigingen bevat.
Een van de acties die door bovenstaande instellingen riskant is geworden, is het afsluiten van het systeem (zonder eerst alle documenten op te slaan). Allerlei sluimerende applicaties worden wakker gemaakt en krijgen de opdracht te stoppen. Op zo'n moment kan het heel goed zijn dat toepassingen de WaitToKillAppTimeout overschrijd. In combinatie met AutoEndTasks wordt zo'n programma dan zonder pardon (en zonder op te slaan) afgesloten.
Als je dus sneller wilt afsluiten; wees voorzichtig en laat vooral AutoEndTasks op de standaardwaarde.
[ Voor 68% gewijzigd door Verwijderd op 27-06-2006 17:13 ]
  • MPAnnihilator
Verwijderd schreef op dinsdag 27 juni 2006 @ 17:07:
En dan gaat het mis
Mjah, er zit waarheid in je bericht , doch , bij mij werkt dit perfect , 500 werkt bij mij wel ok. Natuurlijk als word nog openstaan met een niet bewaard bestand open , dan heb je'n probleem. Maar ik sluit eerst zelf de programmas O-) Je stuurprograma's zoals die van Logitech worden hierdoor toch sneller afgesloten denk ik _/-\o_
Mijn Specs
-GF-Annihilator schreef op woensdag 28 juni 2006 @ 08:36:
Eigenlijk klopt er geen zak van heel die configuratie. Als de WaitToKillAppTimeout standaard op 20000 staat, betekend het dus dat Windows na 20 seconden al de draaiende applicaties gaat killen en afsluiten. De pc van de TS (Thalon) doet er echter 10 minuten over. >:)
Data type - REG_SZ
Range - Milliseconds in decimal
Default value - 20000 (20 seconds)
[ Voor 7% gewijzigd door Verwijderd op 28-06-2006 13:45 ]
