[UD-Grid] Nieuws updates
Pagina: 1 2 Laatste
  • 1.704 views sinds 30-01-2008
  • Omied
  • Laatst online: 31-08 08:11
Blue_man schreef op zaterdag 04 februari 2006 @ 09:19:
De nieuwspost van hierboven gaat over Cancer-WU's, die Rosetta's blijven normaalgezien geldig :) (5 Rosetta's? * Blue_man begint te rekenen :P )
Met andere woorden: die cancer-WU's vervallen wel na een aantal dagen? (Ik heb namelijk ook nog een paar Cancer-WU's... Zou zonde zijn als die punten vervallen... :P)
Maar als het goed begrijp vervallen de Cancer-WU's 2 weken nadat de 'job' is afgelopen, maar dat duurt vast nog wel even? Het bewaren van punten tot de 14de moet wel lukken toch? :)
[ Voor 22% gewijzigd door Omied op 05-02-2006 23:21 ]
  • Blue_man
  • Laatst online: 21-05-2024
Zou moeten lukken inderdaad :)
le·vens·moe (bn.)
1.genoeg van het leven hebbend, het leven als een last beschouwend.
  • Blue_man
Here is the weekly status:
Cancer data - As I mentioned previously, Oxford has verified our previous results and has released all of the new data. There is plenty to keep us busy for a while. They also wish to run all of the new data against the previous protein when we are done with the current protein.
Some members are experiencing aborted WUs with the new data. We are currently investigating this issue. The problem is a bit elusive since not all members are experiencing it and some members are experiencing it much more frequently than others. I have verified that there are results for each and every WU and that the total is approximately the same for all. I have also verified that there are approximately the same (small) number of errors returned for each WU.
This tells me that there is not a problem with any particular WU, but some other issue. If there was a bad WU, we would see either a significantly lower number of results or a significantly greater number of errors. This is not the case. We will keep looking into this issue until we find a solution.
These WUs appear to be processing much faster than the previous batches. I am not sure of the reason for this and will rely on Oxford to tell us if something is not right. Note that there is a bunch of data to be processed. I am not quick to modify the job configuration (adding more Ligands) since the next ones I upload may take longer.
It has been noticed that the number of hits is high for some of the WUs. Again I do not know the reason for this and will have to rely on Oxford to tell us if something is wrong.
Thank you for your contribution.
le·vens·moe (bn.)
  • Blue_man
Dear Members,
We have finished processing the current Rosetta job. A new one will be uploaded tonight. Some members may have experienced a "Cannot connect" message due to this. Until the new job is active, I have reset the current one to continue to dispatch to prevent these messages.
De servers lijken er nu uit te liggen, geen idee hoe dat met jullie zit maar op het forum beginnen er berichten binnen te stromen.
We laten de moed niet zakken voor de valentijnsflush nietwaar :)
le·vens·moe (bn.)
  • Blue_man
Dear Members,
I have uploaded another batch of cancer data. The last job will remain active for a few days to give members time to receive credit for any outstanding workunits. Since these new workunits are processing so quickly, I do not think we need to wait a whole week.
Doorcrunshen jullie!
le·vens·moe (bn.)
  • Blue_man
Dear Members,
Cancer Data - We continue to have an issue with occassional aborts that is still under investigation. As I mentioned in the Member to Member Support thread, this issue has been identified as a problem with the Ligandfit application itself crashing. This has nothing to do with the UD servers dropping results or not giving due credit. The Ligandfit application has not changed in a very long time, prior to the last batch of cancer data that received no complaints. This would point to something with the new data that is causing Ligandfit to be unstable.
Note that we are receiving successful results from each and every workunit so there are not "bad workunits" that will always fail. Some members have stated that retrying a workunit that just aborted will result in a successful completion.
Although a bit frustrating because of lost points, know that we are getting successful results that can be returned to Oxford to assist in the search for the cure for cancer which is the ultimate objective of this project.
Zoals je ziet zijn ze er wel degelijk mee bezig. Al zouden we eens moeten stoken, want ze hadden een aantal plannen waar ik niet meer van hoor ...
le·vens·moe (bn.)
  • Blue_man
Dear Members,
Here is the weekly status of Grid.org.
Outage: There was a temporary outage over the weekend that caused connectivity problems with Grid.org servers. This was caused by a router failure in our datacenter and was unanticipated. The problem has since been rectified and everything should be functioning normally.
Cancer data: I have uploaded a new chunk of data and have sent the last result set to Oxford for analysis. Some members have noticed that this batch produces an awful lot of hits. I am asking if this is to be expected and if this could in any way be related to the occassional workunit aborts that some members are seeing.
Onder het mom van 'what happend to the following' heb ik op grid.org een thread gestart. Heb jij nog aanvullingen? Geef ze me door op reageer op mijn post.
Hou het wel netjes daar! klik hier
le·vens·moe (bn.)
Zoals sommigen misschien wel gemerkt zullen hebben was het toekennen van een device aan een persoon op http://www.heeftdelangste.nl de afgelopen 2 dagen niet mogelijk.
De maker en beheerder van de stats heeft net aangegeven dat alles weer werkt :D
Ik heb even getest en inderdaad alles doet het weer.
Marcel _/-\o_ _/-\o_ _/-\o_
  • Blue_man
En jij ook bedankt Allied om je zweep nog eens boven te halen!
le·vens·moe (bn.)
  • InSPiRE
  • Laatst online: 21-03 20:19
Weer een nieuws berichtje... Oxford moet opschieten en ligandfit crasht nog steeds...
Dear Members,
Here is the weekly Grid.org status. Things are relatively quiet although we still have a few outstanding issues.
Cancer data - I have not heard back from our Oxford contact regarding the last batch of results I sent. This was an attempt to have them validate the many hits we are seeing on some of these workunits. It seems suspicious to me, but I am not well versed in computational chemistry and cannot speak to this. It will be up to Oxford, who provided the data, to determine if the results are valid for their research. Until then we will just keep crunching away at the new data.
There is still the issue of Ligandfit crashing. Although I do not know why, it appears that there is something about the new data that causes Ligandfit to get in a bad state. I have also mentioned this to our Oxford contact and hope that he may be able to shed some light on this issue. Perhaps the many hits or complexity of the new data is the contributing factor.
As always, thank you for your contribution.
Posted: Wed Mar 08, 2006 4:25 pm Post subject: Comment On Cancer Data
Dear Members,
I have received a response from our Oxford contact regarding some of the issues we have seen with the new cancer data.
High number of hits - It was stated that a determination could not be made at this stage as to whether the data was generating too many hits or not. After we process all of the data and send it back, they will apply a cutoff criteria in order to isolate the best hits. It may be that once the data is analyzed, they will suggest a change to the Ligandfit input parameters and a rerun of the data. Remember, research implies trial and error.
Aborts - While nothing specific was identified yet, they stated that is was possible for the data to cause Ligandfit to error out. It was mentioned that some of the datas are not discrete organic molecules which may be different that data that was processed in the past. It may be that under certain circumstances this data causes Ligandfit to abort, although we have seen that a replay of the data usually produces a good result so we are not talking about a bad WU per se. They also stated that in the future they will filter out anything that they think may cause an issue. Bottom line is this issue remains elusive and we do not have the answer yet.
_________________
Robby Brewer
Senior Support Engineer
United Devices
Posted: Fri Mar 10, 2006 12:02 am Post subject: Server Backing Off...
Dear Members,
We have received too many results again for the servers to hold. I am in the process of clearing some space now. Please be patient while I get the situation remedied. The root problem is that these workunits are processing much more quickly than the previous batch. This is causing many more results in a much shorter period of time. This equates to disk space filling up much more quickly.
It is obvious that our process needs to be changed to limit the time a job runs. I thought two weeks would be sufficient, but I think now I need to turn these around every week.
_________________
Robby Brewer
United Devices
en
Posted: Fri Mar 10, 2006 12:03 am Post subject:
I am currently uploading a new job. It has already started dispatching and I have verified a new workunit. Since we got a little backed up, it may take a while for everyone to connect and get a new workunit. I will post some info tomorrow on our new (shorter) process for turning these jobs around.
_________________
Robby Brewer
United Devices
  • Blue_man
Top van jullie dat je de updates hier ook posten, kwestie van alles snel en gemakkelijk door te kunnen lezen (altijd prettig om met een positief bericht te kunnen afsluiten ;) ).
le·vens·moe (bn.)
Belangrijke info:
Posted: Mon Mar 13, 2006 10:01 pm Post subject: Grid.org status
Dear Members,
Here is the weekly status for Grid.org.
Cancer job - As you probably noticed, we had a small outage last week due to the amount of results being returned for the new cancer jobs. These WUs are running within a few hours each probably due to the (non) complexity of the new protein. This translates to lots of disk space being used up very quickly. Due to this, I will need to roll up the results of these jobs much faster than pervious ones in order to keep below maximum disk space. Here is what I propose:
On Wednesdays I will submit a new cancer job. Once it has been activated, I will run the roll up script which should only affect the previous job. The roll up script will mark the previous job inactive as part of its processing. Once the roll up script has finished, I will reset the job to be active. This will allow outstanding results to be credited.
On Fridays, I will delete the older job that has already had the results rolled up so any outstanding workunits will not be credited. You would have had 2 days to return your results which should be plenty considering the WUs complete within hours.
There may be a small window while the results are being rolled up to where newly returned results will be rejected. This would be due to the job being temporarily marked as inactive. Unfortunately, I see no way around this. The impact should be very minimal. If you are that concerned about a lost workunit, shutdown your agent on wednesdays until I post that the job has been reactivated.
_________________
Robby Brewer
United Devices
Blue_man zal nog vast wel aanvullend reageren :) .
  • Blue_man
Ik had het bericht deze middag ook al zien staan en wou het posten toen ik thuiskwam, alleen was Liz me al voor :)
En natuurlijk wil ik nog wat zeggen hierover :) Ik had namelijk mbt de stats een topic geopend en via een post in member news antwoord gekregen. link.
Ook heb ik nog iets kunnen toevoegen aan mijn 'what happend to the following'-thread: link.
le·vens·moe (bn.)
  • Blue_man
Dear Members,
As per our new process described on Monday, I have uploaded a new cancer job and rolled up results from the previous one. On Friday I will deactivate the previous job afterwhich no more credit will be given.
Hopefully this process will keep results at a minimum to conserve disk space, but still allow everyone to participate and receive credit for their work.
Als ze deze meldingen vol houden weet je perfect wanneer je flushen moet.
le·vens·moe (bn.)
  • Blue_man
Dear Members,
Cancer data - Things are running relatively smoothly right now. I hope the new cancer job process is working for everyone. As soon as we crunch through all of the new data against the current new protein, Oxford would like us to crunch the new data against the last older protein as well. It will be interesting to see if the number of aborts we are seeing goes down or remains the same.
Please note that for UDMon users the ud_mon.ini file must be updated with the new protein in the Proteins section. If this is not done, you will see many aborts for WU 8581771 in the log, which is a protein not a workunit. Please remind newer members of this if you see them post about the aborts. We do have a random abort problem, but those have nothing to do with WU 8581771. The line should look like this:
8581771=LF:AUR-B
Jullie lezen het :)
le·vens·moe (bn.)
  • Blue_man
even over wat nieuws bij UD-Grid (nieuwe hardware etc ... ):
The new equipment was purchased a while back. It is not online due to a few outstanding issues.
1) There are some code modifications to the Grid MP product that must be made to allow Grid.org to run on the new hardware.
2) There are migration tools that need to be written to do things such as migrate the Grid.org database from SQL Server running on AIX to DB2 running on Linux.
3) The applications that are currently running need to be ported to the new version of Grid MP which may involve the product vendors to make software changes as well.
We knew that this process would take a while to complete and therefore made some changes to the current system to stabilize it and minimize downtime.
1) We cannibalized the beta server in order to replace any of the failed drives in the database server as well as providing redudancy in the form of RAID. We have had no hardware issues with the database server since we have done this.
2) We had an IBM technician come out and verify the quality of the RAID/hardware configuration. There were some configuration changes that were performed as well.
3) We overhauled the backup strategy that has been in place for quite a while, but was lacking. There are now daily backups being performed and we would be able to restore quickly following a catastrophic failure.
The only issues we have had recently occurred because of disk space being consumed quicker than expected due to the high number of results coming in from the new cancer data which processes very quickly. I think the new job process will prevent that from occurring again.
It would be nice to be on the new system, but the ultimate goal is to help in the research for the cure for cancer. That goal is being met and members are crunching meaningful data to that effort.
I want to also say that we obviously have access to our own building (not a dorm room) on weekends. What was said regarding this is that UD does not currently have 24x7 support for Grid.org. That is a company decision based on financials. There is expense associated with having a staff available around the clock.
Members volunteer compute nodes. UD volunteers resources to the various research projects as well. This includes servers, rack space, power, bandwidth, environmental conditioning, IT, and support. We are all volunteering resources to what we hope is a worthwhile cause. Please try to keep this in mind and not focus on everything that could be better. The most important thing is the research itself. When I have more real news regarding the migration of Grid.org I will post in Member News.
Over heeftdelangste.nl: Oude teams of teams met maar één device zijn er uit gefilterd; nieuwe leden komen naar het schijnt niet standaard meer in het lijstje te vinden op de homepagina.
Daardoor is alles wat korter qua laadtijd en zou het script minder timeouts moeten krijgen.
le·vens·moe (bn.)
  • Blue_man
Dear Members,
I have rolled up the results from the current Cancer job and submitted a new one. Credit for the previous job will be given until Friday morning. If you are running UD Mon and are concerned about getting credit for all workunits, this would be a good time to dump/refresh your cache with the new ones.
Die ud_mon vanavond nog vernieuwen dus, oude results gewoon insturen door dmv fudc 'cycle all slots' aan te vinken. Of je kan natuurlijk alles handmatig doen als je van handwerkjes houdt :)
le·vens·moe (bn.)
  • Blue_man
Dear Members,
There have been a few suggestions to extend the time that the previous cancer job is deleted in order to give slow machines a chance to finish crunching. We want to accomodate all members regardless of the speed of their machines so I am going to change the day to Monday. New jobs will be submitted on Wednesdays and old jobs will be deleted on Mondays.
Lijkt me goed nieuws voor iedereen :)
le·vens·moe (bn.)
  • Blue_man
UD-Grid, HT (Hyper Threading) en SMP (Symmetric Multi Processing)
Hyper Threading:
HT does not work well with UD as LigandFit requires the FPU all the time and there is still only one to share between the 2 running UD processes (if you use the various methods mentioned here or elsewhere). HT will work if you need to share the processing between integer and FPU activities but not if both processes require integer or FPU only.
If your primary goal is crunching then turn off HT as it gives you very little benefit anyway. In some cases HT will actually slow things down because the instruction & data caches are split between both logical processors. HT only benefits if you run SMP capable apps all the time (like some graphics rendering apps etc) which you probably don't if you only have one processor.
Having a processor intensive task then effectively halving the available processor resources will only have one obvious result. You will be better off in the long run by turning off HT and overclocking the processor.
Cheers
Orbi
SMP:
Tao schreef op vrijdag 17 maart 2006 @ 16:31:
Inderdaad 2 clients draaien onder aparte inlogaccounts.
Bij elke account moet je de affinity van de koe via de taskmanager op 1 en dezelfde cpu zetten.
Dus: guest1 -> alles op cpu0, bij guest2 -> alles op cpu1.
Vergeet NIET om ud.exe op compatibilitymode NT4 te zetten. (B.v. via Verkenner, rechtermuis-klik op ud.exe, dan naar eigenschappen, compat.mode, en dan NT kiezen.)
Zo draai ik ook al bijna 5 jaar onafgebroken mijn kudde :)
Enig probleempje is dat bij herstarten van de pc (of na uitloggen van het account) je alles opnieuw kan instellen :(
Mijn advies is dus: NIET MEER UITZETTEN :) :) :) :) :)
ofte ook wel volgende quote:
quote: Kewjoe
ok here goes:
WinXP allows Switching of users without closing another users programs. Its called "Fast User Switching"
As mentioned later in the thread, being on a domain disables Fast User Switching.
Next.. i have two accounts on the machine.
Account #1:
Install UD in Directory A
Run UD
Set Affinty to CPU 1
Switch Users
Account #2:
Install UD in Directory B
set Compatibility Mode to NT 4 (Service Pack 5) <--- THIS IS HOW I GOT IT TO WORK *Important*
Run UD
Set Affinity to CPU 0
From there it will work. Check Taskmanager to make sure both processors are being used.
Deze methode werkt enkel icm met Windows XP.
[ Voor 46% gewijzigd door Blue_man op 26-03-2006 09:43 ]
le·vens·moe (bn.)
  • Blue_man
Dear Members,
Cancer job - There is no new information to post at this time other than to restate that each week the previous cancer job will be deleted on Mondays instead of Wednesdays. This will give members running on slower machines a chance to return their outstanding workunits for credit.
The previous cancer job has been deleted. If you have any outstanding workunits that have not yet been processed, they will not be given credit and should be dumped.
le·vens·moe (bn.)
  • Blue_man
Dear Members,
Here is the weekly status update for Grid.org.
Cancer data - I have deleted the previous Cancer job so no more credit can be given for outstanding workunits. We continue to process a new job each week, which means things are going pretty well. The Ligandift aborts still continue and probably will through the entire new batch of data that Oxford provided. We will see what the behavior is when we run this data against the previous protein which will be the next task.
Alstublieft!
le·vens·moe (bn.)
  • InSPiRE
Jammer dat de UD server weer eens niet te bereiken is.
Op het forum van grid.org is nog geen duidelijkheid te vinden omtrent de oorzaak van de problemen.
  • Blue_man
Ikzelf ben offline voor de rest van de avond, maar ik neem aan dat anderen staan te trappelen om een bericht van R. Brewer te posten ;)
le·vens·moe (bn.)
En idd het nieuwsbericht wat Blue_man reeds verwachtte. Met name UD-mon gebruikers, lees het goed!
Posted: Thu Apr 06, 2006 8:21 pm Post subject: Backing off
Dear Members,
We experienced a brief outage again due to the large amount of results. I thought that rolling up once a week was sufficient, but apparently we still ran out of space. The system has been recovered now and everyone should be able to connect now.
There may be some lost workunits due to the nature of this problem. I apologize for that. A new job has been submitted so if you are running UDMon, you should dump all of your cached workunits and reload.. Credit will not be given for the previous outstanding workunits because the job had to be deleted as part of the recovery procedure.
I will be adding some additional disk monitoring tools to hopefully notify me before this issue can reoccur. Again, I thought that our weekly rollup process was sufficient. Please bear with me as we continue to tweak the process.
_________________
Robby Brewer
United Devices
En een aanvullende Blue-message:
Blue_man schreef op vrijdag 07 april 2006 @ 19:23:
[b]Liz: zet je even in het vet dat mensen hun ud_mon slots moeten vernieuwen (bvb met fudc) en dit zo snel mogelijk ;)
[ Voor 14% gewijzigd door Verwijderd op 07-04-2006 19:38 ]
Posted: Fri Apr 07, 2006 2:17 pm Post subject: Backing off...part two
Dear Members,
There was another "backing off" issue starting last night with the cancer job only. This is completely my fault. When I ran the rollup script yesterday to merge the results of the previous job, I forgot to stop the script after the rollup was done. Since the script was still running, it started marking workunits on the new job as complete as the results came in. When all workunits had been marked complete, the job quit dispatching.
I have reset the job and everything should be working again now. There should also be no lost results/points. Again I apologize for the inconvenience and thank you for your contribution.
_________________
Robby Brewer
United Devices
Hopelijk is tweemaal recht is scheepsrecht :P .
  • Blue_man
le·vens·moe (bn.)
  • Blue_man
Dear Members,
All is relatively quiet. I have succeeded in putting some disk space monitors in place to hopefully prevent another disk space issue like we had last week. Thank you for your contribution.
Hardeschijfruimte is echt een probleem, wetende dat hun nieuwe computersysteem staat te idlen ...
Achja, het zijn en blijven werknemers natuurlijk (maar toch, mocht ik er werken ...)
Zondag/maandag ochtend ud_mon slots vernieuwen luitjes (niet vergeten!)
le·vens·moe (bn.)
Posted: Wed Apr 12, 2006 7:57 pm Post subject: Cancer job
Dear Members,
I have rolled up results for the last cancer job and submitted another one. Results for the last cancer job will be credited until Monday. If you are running UD Mon, please dump your cache and reload with the new workunits or you may lose some credit.
_________________
Robby Brewer
United Devices
Let op dit is ondertussen een ouder bericht, dat wordt ondanks de Paas meteen/gelijk/direct/hurry up achter de koeien aan.
Als de }:O }:O }:O nou maar een beetje willen meewerken!
Mocht iemand hulp nodig hebben Plantje is net wakker :P .
Hoe zit het nou eigenlijk duurt sowieso de tijdsverloop van een batch maar 1 week?
  • Omied
Verwijderd schreef op zondag 16 april 2006 @ 18:47:
Ja, het ziet er wel naar uit... De computer van m'n vriendin heeft al 3 weken UD-Grid, maar heeft nooit de tijd een WU op tijd af te maken... :(
  • Blue_man
Dear Members,
Due to high temperatures and electrical power constraints, the state of Texas has been performing rolling blackouts in an effort to reduce load. It is possible that one of these blackouts might hit the United Devices location. If this happens Grid.org may be unavailable for a period of time. We do have UPS backup that will carry us for a while, but not indefinitely. Please be patient if Grid.org becomes unavailable. We will have it back up as soon as possible.
Men weze gewaarschuwd, het is misschien handig om enkele slots van je ud_mon op te vullen? Let er wel op om deze ten laatste zondagavond te flushen, wil je.
le·vens·moe (bn.)
  • Blue_man
Dear Members,
Things are still quiet so there is not much to report. The previous cancer job has been deleted and so no credit will be given for outstanding results. As usual, I will submit a new cancer job on Wednesday.
Is duidelijk genoeg dunkt me.
Tevens wil ik jullie aandacht vestigen op de onafgewerkte FAQ op http://www.blueman.be/udfaq/udgrid.xml . Indien jullie stukjes hebben die erin passen wil ik die graag horen.
Wat mezelf betreft hoop ik in de maand juli tijd te maken voor deze FAQ (en wie weet wat nog).
[ Voor 2% gewijzigd door Blue_man op 24-04-2006 19:20 . Reden: Rechtstreekse link ]
le·vens·moe (bn.)
  • MrMaD1909
  • Laatst online: 31-10-2023
MrMaD1909
Ik graas alles @ NGS
PostPosted: Mon May 01, 2006 2:23 pm Post subject: Grid.org status Reply with quote
Dear Members,
We continue to crunch the new cancer jobs. A new one will be uploaded on Wednesday. We also uploaded a new Rosetta job over the weekend.
_________________
Robby Brewer
United Devices
Niet veel te melden, maar dan hebben we dat vast gemeld.
PC's:Dell AMD IBM T41 Tungsten|C
  • Blue_man
Dear Members,
We will be performing some maintenance on one of our routers today. There may be a small outage due to this. Both the forums and the gird.org servers may be affected. The work will begin at 6 PM CST and should last 1.5 hours.
Kan een slimme kop me even uitrekenen wat dat is op onze tijd?
Wie 1 WU per minuut doet vult dus best even ud_mon op (maar wel alles zondag terugsturen ookal is nog niet alles verwerkt).
le·vens·moe (bn.)
Hoe stuur je dan een WU terug die nog niet is verwerkt?
Send/receive (bij ud_mon) geeft namelijk geen gevolg.
  • MrMaD1909
MrMaD1909
Als je "detect aborted WU's" aan hebt staan gooit hij ze er zelf uit als het zover is. Waarschijnlijk krijg je er dan geen punten meer voor. Het is nu zorgen dat je op donderdag een WU'tje ophaalt en die blijft crunchen tot de tweede zondag. Dan krijg je de meeste punten per WU.
MrMaD1909 schreef op vrijdag 05 mei 2006 @ 23:02:
Oké die staat aan, maar is het niet mogelijk om het zelf aan te sturen zodat er weer met die device gecruncht kan worden?
  • Blue_man
Hm, die optie ik weet niet wat ik daarvan denken moet; is dat wel zo betrouwbaar?
Nouja jullie weten wel al wat ik zeggen wil :) fudc: http://www.blueman.be/udfaq/udgrid.xml#251 kan alle slots verversen (ook de niet verwerkte).
Ik probeer ondertussen even uit te vissen wat er aan het handje is...
le·vens·moe (bn.)
  • MrMaD1909
MrMaD1909
Op mijn werk kon ik het forum van grid.org wel lezen. Het blijkt dat de nieuw geplaatste router waarschijnlijk "problemen" geeft. Ongeveer 1/3 van de mensen kan niet connecten. 2/3 van de mensen wel dus. Er werden wat opties gegeven om via een proxy te connecten naar UD, maar aangezien die bij mij geen effect sorteren, geef ik ze maar niet door. (voor de geïnterresseerden, kopje member-to-member support op hun forum)
  • TommyGun
  • Laatst online: 30-10 12:07
TommyGun
Stik er maar in!
Mja het zaakje connect nog steeds niet én kan niet op het forum dus als je toch die proxy kunt posten?
B.v.d
  • InSPiRE
using this prox was able to connect for WU and forum
216.55.181.230 port 3128
  • TommyGun
TommyGun
Stik er maar in!
Bedankt nu werkt het weer
En de officiële verklaring van UD-grid.
Posted: Mon May 08, 2006 5:38 pm Post subject: Unable to connect
Dear Members,
After the router maintenance on Friday, some members experienced some connectivity errors. This was not limited to grid.org, but UD connectivity in general. The maintenance task that was performed dealt with Border Gateway Protocol (BGP) which allows connectivity to two separate internet providers. The idea being that if one provider goes down there will be automatic failover to the other internet provider resulting in some redundancy.
For some reason, enabling BGP on the router resulted in connectivity loss (apparently for anyone coming in through one or the other provider which is why everyone was not affected). We have not determined the reason for this yet. In the meantime, BGP has been disabled and all connectivity should have been restored for all members.
_________________
Robby Brewer
United Devices
  • TommyGun
TommyGun
Stik er maar in!
Aight het werkt weer zonder proxy iig.
  • Blue_man
Dear Members,
I have rolled up the results from the previous cancer job and submitted a new one. Results for the previous job will be credited until Monday. If you are running UD Mon, you may want to dump your cache in order to process the new workunits.
Merk op dat je alle slots dient te hernieuwen!
le·vens·moe (bn.)
  • Blue_man
Dear Members,
Here is the weekly status for Grid.org:
Cancer job: I have deleted the previous cancer job which everyone should have finished processing by now.
Team stats: These are missing for 5/12/06 for some reason. We have not had a stats problem in a while. I have requested a DBA to manually fix these when they get a chance. The stats will hopefully be up to date later today.
le·vens·moe (bn.)
  • Blue_man
Er is een nieuwsupdate:
Dear Members,
Here is the weekly status.
Stats - Should all be up to date now.
Rosetta - We have submitted a new Rosetta job for those processing HPF. Results from the previous job will be credited for a while.
Cancer - Nothing new to report. We are still seeing workunit aborts, but the root cause has not been identified yet.
Zie ook mijn post in de DPCH; 'Should all be up to date now' laat blijken dat er een extra statsupdate geweest is en dat daardoor we op zaterdag konden genieten van dubbele stats :)
le·vens·moe (bn.)
  • Blue_man
Dear Members,
I have rolled up the results for the previous cancer job and submitted a new one. As usual, outstanding results will be credited until Monday.
Et voila.
le·vens·moe (bn.)
  • Blue_man
Dear Members,
The latest Rosetta job completed over the weekend. This caused some members to experience the "cannot connect..." messages. I have reset the job so that outstanding results can still be credited and verified that I could download a workunit. Everyone should be able to connect now.
Waarom ze deze job herstart hebben is mij een raadsel. Als het de laatste is, is het de laatste punt.
Daarom raad ik iedereen die nu Human Proteome Folding/Rosetta (@ UD-Grid) draait om in zijn profielen ook kanker te selecteren.
Bij mijn weten gaat grid.org niet meedoen met HPF deel 2. Naar ik meen zijn ze daar al aan begonnen/gaan ze daarmee beginnen bij World Community Grid. Ik ben net als vorig jaar nog steeds benieuwd welk tweede project ze nu gaan doen.
le·vens·moe (bn.)
  • Blue_man
Dear Members,
Cancer job - Oxford would like us to finish the current batch of data by the end of June. This means I will have to start submitting multiple jobs and rolling them up a bit sooner than we have been doing. Since these workunits process so quickly even on slow machines, it should not affect anyones ability to return results for credit even if I cut the processing time by a few days. I will make posts as I submit/rollup jobs.
Blijkbaar maken ze van UD een spel voor de die-hards, de believers en de zitteblijvers.
De kans dat je geen punten krijgt voor je langzamere pc wordt groter (doch nog steeds in het voordeel tov andere projecten, want daar telt je oude pc niet mee).
Ik zou dus zeggen koop gauw op een tweedehandsmarkt nog een reepje geheugen en prik het in die oude schoendoos die staat te snorren.
Daarbij ben ik benieuwd wat we na juni gaan krijgen?
le·vens·moe (bn.)
  • Blue_man
Dear Members,
I have rolled up the previous cancer job and submitted two more. You will find that these workunits have twice as many Ligands as the previous ones. I verified that I could download one and it appears to be processing fine. Depending on how many results we receive, I may roll these up sooner than next Wednesday.
le·vens·moe (bn.)
  • Blue_man
Dear Members,
As I mentioned last week, I am having to accelerate the cancer jobs so that I can have results to Oxford by the end of the month. Today I rolled up the results from the previous two jobs and submitted two more. Results for the previous job will be credited until Wednesday, which should give everyone a chance to return their results.
Je hebt dus tot woensdag om je resultaten in te dienen! (ik neem aan woensdagochtend aangezien het dan in Texas nog nacht is).
le·vens·moe (bn.)
\o/
Ik doe nu ook mee :)
dusch:
Hoi allemaal!
Hee, ik zie nu dat ik Rosetta aan het doen ben, maar daarnet was ik nog bezig met Cancer Research. aan en uitzetten was voldoende :? ik snap nog steeds niet hoe hij aan rosetta kwam...
[ Voor 74% gewijzigd door Verwijderd op 13-06-2006 15:37 ]
  • Blue_man
Dear Members,
I have rolled up the results from the last two jobs. Note that unlike the other jobs that had 1 or 2 bad WUs, these last jobs had several 40 - 50. This would account for the higher rates of aborts seen in this last batch. I have submitted three more jobs. Results for the previous jobs will be credited until at least Wednesday.
Is je WU tegen woensdag niet verwerkt druk dan ctrl-alt-del of ga naar taakbeheer en stop de taak ud_xxxxxx.exe (waar de x'en cijfers voorstellen).
Hij gaat dan de huidige taak stopzetten en automatisch een nieuwe downloaden. De (deels) verwerkte WU gaat punten opleveren.
le·vens·moe (bn.)
  • Blue_man
Dear Members,
Here is the (late) update for Grid.org. I apologize for my late post, but there have been some support issues that have consumed much of my time recently.
Cancer job: I will be submitting a new job today that will actually consist of workunits that we have already processed. The reason for this is that I must submit at least something before I do my result rollup or else members will get the "cannot connect..." message. I will then rollup the results of the current cancer jobs. This will be the final results for all data that Oxford has provided for us to crunch. They will analyze it and hopefully will not require a respin.
I will then look at submitting this same cancer data set against the previous protein that was used. It may take a couple of days to get the job correct so please be patient.
Stats: The team stats did not update the other day so I had to manually rerun the task yesterday. This would affect the stats task that was supposed to run last night so I am rerunning again currently. Everything should be caught up by tomorrow.
Connectivity: Some members have reported some connectivity problems to the grid.org portal - members services, forums, etc. Other members are able to connect with no problem. We have not been able to identify what may be happening here. I have not been able to reproduce this issue and there have been no changes to the UD hardware/network. We are still looking into this and if anyone has any additional info, please let me know.
Ik heb blijkbaar ook de deur toegedaan in Texas, vanaf nu crunshen we/jullie oude WU's. Hopelijk komt er snel goed nieuws zodat het hele project een doorstart kan maken.
le·vens·moe (bn.)
  • Blue_man
Dear Members,
I have rolled up the results from the last batches of data, which completes that batch of data against the current protein. I was also asked by Oxford to run the same data against the previous protein. Until I hear otherwise, that is what we are going to do. Today I submitted a new job that runs the first batch of the latest data against the previous protein we ran against late last year.
This job seems to be taking much longer than the ones we have been running lately. Therefore, I have reduced the ligand count back down to 600. Some members may have received a slow 1200 ligand workunit. If so, please dump that workunit because I have deleted the job and no credit will be given for results.
Finally, it will take a while for one of these workunits to complete. It is possible that there is some sort of problem with these workunits and that they may fail in the final stages of execution. I do not expect this, but I did not get a chance to test this on another system first. If there is some sort of a problem, we will deal with it quickly.
It will be interesting to see if we get any aborts like we did against the previous protein and what that rate is.
Zoals Liz wist te melden in de DPCH, nu ook het nieuwsbericht hier op GoT :)
le·vens·moe (bn.)
Er is nog interessant UD-grid nieuws van 3 juli.
Posted: Mon Jul 03, 2006 3:54 pm Post subject: Grid.org / Cancer Job Status
Dear Members,
Cancer Job - Obviously, the WUs are taking too long to process. I tried to upload a new job as soon as possible after rolling up the last batch because many members were talking about leaving. Therefore I did not test how long the new WUs would take, but just that they would indeed process. These long running WUs have caused a harsher response apparently than not having anything to crunch. I guess I can't win either way.
I have suspended the 600 ligand job so that no more WUs will be sent out. I have uploaded a new job with a total of 100 ligands. I have not tested how long these will now take. If it is still takes too long, we will reduce the number of ligands further. There is no built in timeout in the previous 600 ligand WUs, so if you want to continue crunching on them you can. I will wait a reasonable amount of time before deleting that job so that credit may be given. If you do not want to continue, delete the WU and you will get one of the 100 ligand ones.
Rosetta Job - I think I mentioned this before, but some members have asked me recently. The HPF project that we were working on is apparently done. There are no more new batches of data available to us to work on. I have heard nothing about Grid.org participating in HPF2 if there is such a thing. The WUs that are currently active have all been previously processed so the work is redundant. I am not going to delete it though until I am sure that there will be no more HPF projects for Grid.org to work on.
_________________
Robby Brewer
United Devices
Naar dit topic is het nog wel eens zoeken, niet?
Blue_man, Pim is het een idee om er een sticky van te maken?
Posted: Mon Jul 10, 2006 3:20 pm Post subject: Grid.org Status
Dear Members,
Here is te weekly Grid.org status.
Cancer - After a few false starts, I think we have a good Ligand number at 100. These take much longer than the previous ones, but it seems that even a slow machine should be able to crunch a single WU in one week. Unless I hear otherwise, we will stick with 100 ligand WUs.
It also appears that the aborts have gone away. Since nothing has changed other than the protein we are working on (as was the case when they started happening), I think this proves that there was something in the last protein that the Ligandfit application had an occassional problem with and not an issue with UD hardware. Since Oxford delivered the protein, they would have to be the ones to figure out what is different in the two proteins.
Regarding the 600 ligand job, I will let that one spin for another week or two to give everyone a chance to return their results. Otherwise, we will go back to the one week cycle we were on previously with the 100 ligand WUs.
Rosetta - This project is apparently complete. Since I do not know if we will be doing any other Rosetta projects, I am going to leave this running until I hear something official. This means currently any Rosetta work is for points only. The actual work will be ignored. If I turn the job off, I am sure that many machines will get the flashing explanation point and cause an uproar. Active members who read the boards can make a decision whether they want to set their profile to the cancer job only or not. Maybe some members think the Rosetta screensaver is cool.
Connection issues - We have had random connection issues recently. Restarting the load balancer last week appeared to have fixed the issue, but I noticed a few complaints today. I do not know if this is the same issue or something different. There is a request into IT to check the load balancer again to see if it has some sort of chronic problem. In the meantime, I can only suggest to retry until you get the page you want. There is a 50/50 chance you will get directed correctly if the load balancer is acting up. Luckily these are not agent connection issue, but limited to the member web pages.
_________________
Robby Brewer
United Devices
Zit deze keer leuk nieuws tussen :) .
Aangezien Blue_man onder de slingers zit hierbij de UD-grid post.
Posted: Mon Jul 17, 2006 6:38 pm Post subject: Grid.org/Cancer Job Status
Dear Members,
Cancer Job - I received several PMs asking to extend the result credit time on the previous jobs since they were taking so long. Even the 100 Ligand WUs were taking a while for some members. I have submitted a new 50 Ligand WU job to try to get the processing time down. We will see how this works out.
We want all members to be able to participate regardless of the power of their machines. I will leave the current jobs active for at least another week to give time for results to come in. Note that the jobs must be set inactive as always while I roll up the results. Hopefully you will not have the bad luck of trying to return one of these large WU results while the job is inactive.
Please post in a couple days to let me know how the 50 Ligand WUs are working out.
_________________
Robby Brewer
United Devices
UD-grid is op 50 ligand WU's over gegaan en Robby houdt op z'n minst nog de huidige taken een week actief.
  • Blue_man
Zoals sommigen al gemerkt zullen hebben, heeft WCG nu ook een anti-kanker-project. Natuurlijk doet UD ook onderzoek naar een medicijn tegen kanker. Waar zit hem dan juist het verschil?
Vanochtend vond ik deze quote:
No they won't overlap. UD Cancer project is fitting prospective molecules (ligands) against target cancer proteins. The WCG cancer project is scanning tissue samples for cancer biomarkers (so that doctors will be able to identify cancer in early stages and select the proper treatment based on certain biomarkers).
btw, the memory requirements for WCG's Help Defeat Cancer project are 750MB of RAM. also, I'm reading that there are a relatively small number of workunits - apparently the Cancer Institute of New Jersey has to do some preliminary processing of the TMAs before they can be sent out as workunits (and they haven't figured out a way to make this preliminary step distributed).
In het Nederlands: UD kijkt naar mogelijke moleculen om deze te vergelijken met kanker proteïnen.
WCG kijkt naar kankermonsters om de kanker te kunnen herkennen in een vroeger stadium.
le·vens·moe (bn.)
  • Blue_man
Tijd om dit topic nieuw leven in te blazen.
Dear members,
Cancer job - Nothing new to report. We continue to crunch through the data. I uploaded a new batch today so there should be new workunits available.
Over de stats 'pauze' is er geen nieuws.
Mag ik jullie verder uitnodigen om grafiekjes te posten in de maandhitparade? Dat is een oude gewoonte dit ik graag zou herbeginnen met de huidige actieve leden :)
le·vens·moe (bn.)
  • rajackar
  • Laatst online: 13-11 09:39
rajackar
Blood Minister
Hee hoi!
Gisteren maar eens twee koeien aan het werk gezet voor dit project.
Nu vroeg ik me af of het ook mogelijk is om de client als service te draaien om zodoende onder twee accounts te kunnen werken.
TNX alvast!
Shrouded by night, but with steady stride. Colored by blood, but always clear of mind. - AMD 9800X3D - Asus RTX 5090 Astral - PS5
Toevallig staat er net een vervolgpost die weer naar een oude draad uit 2002 linked hoe dit te doen onder XP..... http://forum.grid.org/phpBB/viewtopic.php?t=4688
Posted: Mon Oct 09, 2006 4:25 pm Post subject: Grid.org status
Dear Members,
Cancer Job - No change. I did upload some new WUs late last week. Everything appears to be running smoothly.
Stats - We still have an issue with a couple of days of team stats - 10/5 and 10/8. I am going to manually kick off the rollup script so hopefully both will be fixed by tomorrow. As far as exactly why this occurs, I am not a mssqlserver expert (by far). Occassionally the stored procedure that does the work times out and does not complete. Nothing is lost and it is a simple matter to kick off the procedure again by hand so members should not panic about this.
_________________
Robby Brewer
United Devices
Iets verouderd nieuws, maar toch fijn om te weten dat er aandacht is voor de vorige 'stats-hiks'.
Of dit van invloed is dat de stats vandaag uitblijven ... who knows. Even afwachten maar ..
  • Blue_man
Zucht, jullie hebben het wel weer getroffen he?
Een kleine week zonder stats, een slechte informatiebron (forum.grid.org lijkt weer aardig uit de hand te lopen - als in trolls en flames richting UD/grid.org).
Ik hoop dat ze er de komende week wat aan kunnen doen en als één van de leden hier op het forum het nieuws dat op forum.grid.org te rapen valt ook hier wil posten?
Ik zet nu ook een link naar deze thread in m'n sig.
le·vens·moe (bn.)
PostPosted: Mon Oct 23, 2006 4:28 pm Post subject: Grid.org status Reply with quote
Dear Members,
Stats - We have an issue with stats currently. For some reason, the stats job keeps failing. We have not identified the problem yet. Nothing should be lost as far as points. We just need to get the job to run correctly to tally up all of the stats. I am not sure when this will be fixed so please be patient.
_________________
Robby Brewer
United Devices
  • Blue_man
Dear Members,
le·vens·moe (bn.)
  • Megaflix
  • Laatst online: 10-11 20:50
Blue_man nog niet wakker? Volgens mij was dat al gepost?
  • Blue_man
hm? *gaap* mja? :P
le·vens·moe (bn.)
Global stats zijn nu compleet t/n 25e oktober! :D
  • Blue_man
Dear Members,
Stats - The stats continue to be a bit erratic. We have not made any changes recently that would cause this behavior. They appear to eventually catch up, but are often a day or two behind. I am starting to suspect that this is because we have crossed some critical threshold of stats in the database (i.e. - DB has grown very big over the years). I think the stats job is not always able to finish running in the alloted time frame. We will continue to look into this, but know that we may need to continue to manually complete the stats rollup for a while. I will be manually running the team stats shortly.
le·vens·moe (bn.)
  • Blue_man
Dear Members,
Stats - We are missing team stats for 11/8. I am manually rolling those up now so everything should be caught up in a few hours.
le·vens·moe (bn.)
Het is gelukt we zijn weer helemaal bij. Zie de inhaal stats.
  • Blue_man
Dear Members,
Here is the weekly status. I was out of the office on vacation last week which is why I did not post last week's status.
Stats - I see that some members are having issues accessing the stats. Obviously it should not take 10 minutes to bring up the page. It appears that there may be an issue with one of the load balanced servers. I will have IT look into this as soon as possible.
Cancer - I will be uploading some fresh workunits today.
le·vens·moe (bn.)
  • Blue_man
Dear Members,
Stats - Team stats have been running a bit behind, but there has not been any manual intervention needed recently.
Forum/Member Services - Our IT department recently reset all servers. I personally have not experienced the slow web page times since. Hopefully this issue is resolved for all members.
Mag ik verder opmerken dat grote teams het zich gemakkelijk kunnen maken (en tevens de spaarders) om een bulk-installer aan te vragen (DM me).
Tevens is er deze week een kleine update geweest van de FAQ. Die kan je ten allen tijde vinden in mijn sig, net als dit topic.
le·vens·moe (bn.)
  • Blue_man
Sekerob wist dit nieuwtje al in de DPCH te posten, bij deze ook een kopie in het nieuwstopic:
Dear Members,
Here is quick update on Grid.org:
The stats rollup had another glitch which has now been resolved. All stats are now up to date. We have still not identified the root cause of this sporadic issue, but are still looking into it. I will keep my troubleshooting progress to myself until we are sure we have identified the root cause since it just seems to generate more complaints from the member community.
There has been concern from many members about Grid.org in general as far as the status of projects, new work, software upgrades, etc. Please expect a posting next week from a UD executive regarding the future of Grid.org. (Before any conspiracy theories get started, we are not announcing that we are shutting down Grid.org).
As always, thank you for your continued contribution.
Ik ben even benieuwd als jullie! Verder wil ik nog een link geven naar het topic waar de leden van forum.grid.org zich volop laten gaan over het aankomende nieuws: http://forum.grid.org/phpBB/viewtopic.php?t=20824 .
(Sekerob: foei. projectreclame is net zo verboden als teamreclame)
[ Voor 1% gewijzigd door Blue_man op 09-12-2006 09:47 . Reden: Mijn bedoeling iets duidelijker gemaakt. ]
le·vens·moe (bn.)
Ik denk dat die reklame opmerking geen plaats heeft in dit nieuws draadje, vooral omdat het gerefereerde postje slechts aangaf dat multidraads crunchen zoals gezocht door een mij onbekend UD lid, al lang op het zusterproject mogelijk is, en nog wel voor kanker, waar het ons allen zeer aan gelegen is! Op WCG zijn alle projecten vrij besprekelijk om het cultuurverschil maar aan te geven!
  • Blue_man
Voor de volledigheid post ik de nieuwspost hier ook even, maar reacties en commentaren zijn welkom in dit draadje: \[UD-Grid] Upcoming plans for and changes to Grid.org
Greetings and Happy Holidays!
First of all, on behalf of United Devices I’d like to thank each and every one of you for your steadfast support of this unique, invaluable resource. For the last several years, Grid.org has played an important role in some tremendously important research and it is the largest and most respected volunteer-based grid of its kind in existence. None of that would be possible without all of you!
We have some exciting information to convey concerning Grid.org status and plans – but before I do that, please allow me to express our sincere regret for the frustrations that some of you have been experiencing lately. During the past year we have had technical difficulties with Grid.org that have contributed to your frustrations, but we have changes planned that should significantly improve your experience.
These are some of the plan highlights we have for Grid.org in the coming months:
We will migrate the Grid.org software to the latest version. Planning for this is well underway, and the migration will begin in the first quarter of 2007! In the first quarter (Jan-Mar) of 2007, we’ll begin a Beta Program (see below) in preparation for the final upgrade to the new release. We will perform the entire upgrade to the new version by end of Q2 of 2007.
The following new features will be introduced with the latest version.
- Support for multi-processor and multi-core machines
- Support for cache ahead so that users can request multiple work units
- Enhanced non-intrusiveness options
- The possibility for members to generate their own tools, GUIs, and reports using a new Grid MP Agent API
- New look and feel for the Grid MP Agent GUI
- Improved support for Microsoft XP operating system – enhances support for multi-users and allows fast user switching
- Support for Microsoft Vista operating system (both 32-bit and 64-bit)
- Support for Microsoft Internet Explorer 7
- Overall performance improvements to the grid
- General defect repairs
Right now our outreach committee is actively working on reviewing and selecting new projects to run on the updated Grid.org software. The initial conversations we’ve been having look very promising and we should be ready to make an announcement about the selected project by end of Q1 2007, to launch in the May-June timeframe. Your active co-operation in the Beta program will be key toward expediting this process!
As mentioned above, we will implement a Beta program and ask for volunteers to help with Beta testing of the new system. This program will initially be implemented with a target of 100 volunteers as the first phase of the upgrade to the new version of Grid.org. The Beta program will run for several weeks and is intended to identify any deployment issues that might be lingering in the new version so we can resolve them prior to the upgrade of the entire member community. We will provide you with additional details and initiate a call for Beta volunteers shortly before we begin the program.
Thank you once again for your continued support of Grid.org. We’re looking forward to keeping you informed on status of the initiatives outlined above – visit this site regularly for more information.
Sincerely,
Mary Bass
Directory of Marketing
United Devices, Inc.
Austin, Texas 78759
Graag je reacties hier: \[UD-Grid] Upcoming plans for and changes to Grid.org
le·vens·moe (bn.)
  • Blue_man
Dear Members,
We are aware of the stats issue, but will not be able to do anything about it for a couple of hours. As part of our routine maintenance, we are backing up the stats database. This process used to occur late in the evening, which is also when the stats rollup job runs. Since we have been having stats rollup problems, we decided to not run the database backup at the same time that the rollup was running, thinking that this may be contributing to the job periodically failing to complete.
Until we do a bit more investigation, we are not sure if the backup is causing the "stats still running" issue or if this was coincidence. If the backup turns out to be the cause, we will move the backups back to late night even if it causes stats to not complete occassionally. Please be patient while we work through this. Database backups are essential so that we do not have the catastrophic data loss like we had a year ago.
I will also post this in Member News so that everyone is aware of what is going on.
_________________
Robby Brewer
United Devices
Ook ik was naar stats aan het vragen :)
Blue_man in "\[UD-Grid] hitparade van 11 december"
le·vens·moe (bn.)
  • Blue_man
Er viel slecht nieuws te lezen op het forum van grid.org
Dear Members,
United Devices is closed Dec 25, 2006 - Jan 1, 2007 for the holidays. I am aware of the current issue and will try to contact our IT department, but the issue may not be resolved until after the holidays. I apologize for this inconvenience.
We zullen nog een tijdje zonder stats zitten.
le·vens·moe (bn.)
Dan maar geen stats, misschien zijn ze de update aan het plannen? Laten we het hopen!
  • Blue_man
Dear Members,
Here is the weekly status update.
Member Services - The issue we had over the holidays was due to a problem with a RAID controller on the member services server. Maintenance was performed on the RAID controller and the system has been brought back online. Although having no access to member services was an inconvenience, grid processing itself was not affected so there should be no lost work.
Team stats - Due to the hardware failure, team stats are a bit behind. I will begin manual rollup of the stats, but please be aware that this may take until tomorrow to finish. Stats must be rolled up one day at a time and it takes a couple of hours for each day to complete.
I hope everyone had a safe and happy New Year. As always, thank you for your continued contribution.
le·vens·moe (bn.)
  • Blue_man
Dear Members,
Stats - The stats have all been manually run and are up to date. As I mentioned previously, we have identified the problem as a conflict between our DB backups and the stats rollup job. We must take backups so this issue will persist until the migration. I will manually fix the stats whenever we have this issue and nothing will be lost.
Forums - I have received several complaints about posts in the forums. There is a lot of bickering by some members that is not productive and serves no purpose. The purpose of the Member to Member Support board (and others) is to help members that are having problems and disseminate useful information related to the Grid.org project. Please ask yourself before you post if you are contributing useful information that is helpful to other members or are you are posting something that is purposely antagonistic in order to prove a point. If your post does not contribute something useful, please refrain from posting or post to UDDer Nonsense where it may be more appreciated.
Het tweede deel van het bericht is minder interessant voor ons, maar het eerste deel beloofd niet veel goeds! Ik hou het in het ook wanneer er beta-testers gevraagd worden en hoop een aantal van jullie te mogen verwelkomen in het beta-testers gezinnetje.
le·vens·moe (bn.)
  • Omied
Blue_man schreef op maandag 15 januari 2007 @ 20:13:
Ik denk dat ik hier twee pc's op de beta zet... :)
  • Witlof
  • Laatst online: 16:49
Wat ik me eigenlijk af vroeg, aangezien het in de hitparades niet beantwoord is, is of er enig nieuws is mbt een nieuwe client die wel meerdere cpu's/cores ondersteund. Heeft iemand daar wat meer info over? Blue-man bijvoorbeeld? :)
  • Omied
Witlof schreef op dinsdag 23 januari 2007 @ 16:32:
Op deze pagina staat uitgelegd wat er nieuw is aan de nieuwe client. Ik citeer:
Het antwoord op je vraag is dus: Ja! ;)
  • Blue_man
Dear Members,
Connectivity - some members had problems with connectivity on Friday. I was able to connect and download a fresh WU so it does not appear that the system was down in any way. I suspect that there were some sporadic outages across the internet that caused some members to not be able to connect. Everything seems to be working fine now though.
Wat betreft de nieuwe client (ik heb er even de aankondiging bijgenomen: http://forum.grid.org/phpBB/viewtopic.php?t=20870 )
Januari - maart: start betafase
juni - juli: start ontplooiing nieuwe client
Ik ben even benieuwd als jullie en hoop dat we een (aantal) leden van DPC bij de testers mogen rekenen!
le·vens·moe (bn.)
  • Witlof
Voor zover ik lees hoor ik nergens iets over linux of andere OS ondersteuning. Klopt dit? Wordt het weer een Windows-only client?
  • Wolfje666
  • Laatst online: 15-11 10:24
Wolfje666
Shooter fanatic
Blue_man schreef op donderdag 25 januari 2007 @ 19:57:
Wil best wel een koetje als tester inzetten.
Maar zoals hierboven ook al aangegeven werd, helaas nog geen client voor bijv. Linux.
De Mazda 323F Club Holland
vanVlietDesign - Fotografie en Webdesign
  • Blue_man
Correct, tot hier toe nog geen support voor andere besturingssystemen dan Windows. Ik ben al blij als er multi-CPU - Multi-Core support komt.
Ik reken op de mensen die zich nu al opgeven om beta-lid te worden? Van zodra ik (of jullie) iets interessants zien ivm de de nieuwe (beta) klant, gelieve dit te melden in \[UD-Grid] Upcoming plans for and changes to Grid.org. Ik denk dat het in dit geval geen kwaad kan om een oud topic weer op te rakelen.
le·vens·moe (bn.)
  • Blue_man
Dear Members,
Things are pretty quiet this morning. Everything seems to be working as expected.
Nog geen nieuws over de nieuwe client. Bij deze is er een PM de deur uit met de vraag om meer informatie ivm de start van de beta-fase.
le·vens·moe (bn.)
  • Blue_man
Dear Members,
Sorry for the late post. I was hoping to have some additional information to share on the status of the migration/upgrade. Unfortunately due to the UD07 conference that UD is holding this week, it does not look like I am going to be able to do that. There should be some information Monday regarding the status of the Grid.org migration.
le·vens·moe (bn.)
  • Witlof
Hoop dat die nieuwe client snel komt. Hopelijk is er dan ook weer een mogelijkheid voor een 'subteamclient' waarbij je geen inloggegevens nodig hebt :)
Er staat nieuws van UD-grid klaar. Dit keer is het van Mary Bass:
Posted: Mon Mar 12, 2007 10:20 pm Post subject: Grid.org Upgrade Update
Greetings from UD!
My apologies for not posting an update sooner -- in case you aren't aware of this, UD had our yearly conference last week in Boston (see http://www.ud07.com/index.php ). Check out the agenda and speakers -- it was our best conference yet!
So, it's time for an update on the Grid.org migration and beta program I wrote about last quarter. The good news is that the new release of Grid MP is complete and we are still targeting Q2 for the upgrade of Grid.org (as previously announced).
We are still planning to implement a beta program for testing of this version prior to final upgrade. Several new requirements (including something exciting we'll be announcing by the end of Q2) have necessitated a slight delay in scheduling the beta program, so the target timeline to begin beta has slipped to early Q2 -- though we still intend to complete the full upgrade by end of Q2 as originally planned.
If you've already volunteered for the beta program, thanks! If you would like to, please let us know as there is still time. We will reach out to all volunteers with beta program info in the next few weeks.
So, to summarize, here's what you can expect from UD regarding grid.org in the next 3-4 months:
> By early Q2: Beta program initiated
> Mid Q2: Announcement about the next big Grid.org project
> By end of Q2: Grid.org migration to the latest release complete
Thanks once again for your support of Grid.org!
--Mary
_________________
Mary Bass
Director of Marketing
United Devices
www.ud.com
Ik neem aan dat Blue_man dit zonodig nog toelicht.
  • Blue_man
  • Laatst online: 21-05-2024
Verwijderd schreef op dinsdag 13 maart 2007 @ 22:01:
Dat heb jij goed gezien ;)
Ik was geïntrigeerd door de volgende quote:
Had ik iets gemist?
Maar iets verderop in het forum las ik dit:
Sorry for the confusion. When I said “if you’ve already volunteered,” I was referring to the several people who volunteered by replying to my last post in Q407. The best way to volunteer is to post a message to either me or Robby with Beta Volunteer (or something like that) in the subject line. Once the program is ready to kick off (early Q2), Robby will reach out to all volunteers.
Thanks
Bij deze heb ik Robby Brewer en Mary Bass een PM gestuurd met de mededeling dat er wel enkele leden van DPC te vinden zijn voor het beta testen.
Ik zit zelf ook in het beta-test-team van UD-Grid dus ik hoop dat ik hierbij één van de eerste ben om iets te weten te komen over het betaprogramma.
Over de vertraging die het testen blijkbaar opgelopen heeft: tja, de ene ziet er weer een UD-manouvre in, de ander hoopt op een 'onzettend grote en oer-hollandse' verrassing. Wat ik zelf denk? Ik weet het niet. Ik wacht af en ben blij dat men bij UD-Grid eindelijk beseft dat die client niet langer voldoet!
le·vens·moe (bn.)
1.genoeg van het leven hebbend, het leven als een last beschouwend.
  • Blue_man
De PM's zijn ondertussen aangekomen en ik heb het bericht gekregen dat we geregistreerd staan als toekomstige beta-testers. Ik word dus gecontacteerd wanneer het beta-programma begint.
Zou ik jullie dan ook iets laten weten? :p
Ik heb ook nog een mededeling wat betreft mezelf.
Ik had al eerder aangegeven om te (willen) stoppen met ProjectVerantwoordelijke UD-Grid te zijn, maar omdat ongeveer mijn enigste ontspanning is en ik weet dat er geen betere PV is (*kuch* ;) ) zal ik gewoon minder actief zijn. Waar het op neerkomt is dat ik meestal enkel tijdens de weekends tijd zal hebben, maar ik werk aan een oplossing om bvb meer via mail bereikbaar te zijn (soort PDA ofzoiets).
le·vens·moe (bn.)
  • Blue_man
Dear Members,
Member services - we continue to have a sporadic problem with one of the two web servers. The monitor that we are using to watch this machine has an issue because inbound connection to the web service is successful. Only outbound http is affected. We need a different way to monitor this box. IT is investigating.
Beta program - the beta program will start up as soon as we start migrating the actual software. I will make a public announcement and then we will run the beta using the beta forum. More info will be made as we get closer to that time.
_________________
Robby Brewer
United Devices
le·vens·moe (bn.)
  • Blue_man
Aangaande de stats op heeftdelangste.nl
Blijkbaar slaagt het script er om verschillende redenen niet in om alle teams te updaten.
Nu is er wel een proceduren (ik heb net m'n mailhistoriek overlopen) die ik voor de teams met problemen uit de doeken wil doen.
Omdat te maken heeft met de beveiliging van de server/het script/de pagina ga ik dit hier niet op GoT uittikken.
Teams met problemen mogen mij hun teamnaam doormailen en ik zal proberen iets aan de stats te doen?
Iedereen akkoord? Aangenomen!
Ik hoop in het begin van volgende week eens een update te geven van het grid.org front zelf.
le·vens·moe (bn.)
  • Xaverius
  • Laatst online: 05-09 22:53
Blue_man schreef op zaterdag 14 april 2007 @ 10:52:
Bericht verstuurd voor de stats van Los Alcoholicos. :)
Doet wat met CLP, loopt niet meer hard 😢
Pagina: 1 2 Laatste
