Het grote Phocus DVD160-4 DVD Recorder topic
Pagina: 1 2 Laatste
  • 8.857 views sinds 30-01-2008
  • jules
jules
leend3rs.nl
Van wanneer is die firmware? Thanks voor de handleidingen iig!
Foto Portfolio Follow me on Twitter!
jules schreef op zaterdag 16 februari 2008 @ 15:33:
Volgens de leesmij-bestand is de laatste firmware van 15-08-2006 :)
Gnomon je bent een held, thx voor het uploaden _/-\o_
[ Voor 47% gewijzigd door Verwijderd op 18-02-2008 00:57 ]
Informatie over de firmwares:
Phocus Electronics software release for DVHD 160-4
version:D2C_07_013_200600620 SW-D2C7HDXPHOCUS02
file name: D2C_07_013.bin
file size: 6.353.080 bytes
release date: 15-08-2006
New software release solves the following issues:
- improved multi copy algorithm
- finalising, convert +VR to DVD-Video
- channel auto naming and edit, now up to 8 characters
- improved channel organiser
It has the following new features:
- edit functions on hdd; mark, split, delete
- copy function removable media .mp3 .jpg .avi to hdd
- sound, picture and video folders on hdd for copied content
- dual audio support (for Germany)
- tumbnails and broadcaster/program name in hdd content listing
- add recordings to favorite playlist
- on screen source info by pressing 'display' on rc
version:D2C_04_031_20051230 SW-D2CHDPHOCUS08
file name: D2C_05_031_HDVX_PHOCUS_CDUPDATE.bin
file size: 5.427.312 bytes
release date: 06-01-2006
- timer entry, dates 29/12/XXXX/30/12/XXXX cannot be entered. Fixed
- DivX cd format iso, subtitles disappears after 50-60 minutes. Fixed.
- search algorithm is improved for SECAM-L channels.
- Auto time searching process improved.
- the scheduled recording icon on the VFD dissappears. Fixed.
- safer CD Update, MD5 checksum check.
- dubbing from HDD to DVD: the “disc number” is shown together
with clip number.
- new UI languages: Czech
version:D2C_04_022_20050726 SW-D2CHDPHOCUS06
file name: D2C_04_022_HDVX_PHOCUS_CDUPDATE.bin
file size: 5.113.608 bytes
release date: 26-07-2005
- Recurrent sound drop
- multi DVD burning error
- black screen when recording
- timer recording failure
- VPS failure
- Edit program positions
- Shutting down fan in stand-by
- Lip synchronisation problem
- 16 timer positions, was 8
- Resets night mode after stand by
- Easier program position procedure (press enter)
- Random Play (for MP3 and CD-DA (not Jpeg))
- New UI languages: Polish, Norwegian
he hallo , ik kan niet bij de handleiding komen, heeft iemand er 1 te verkrijgen op een andere manier. ik kan niet via de link van mediamax.com of ik doe het verkeerd
help aub
gnomon schreef op zaterdag 16 februari 2008 @ 11:41:
Voor iedereen die handleidingen en/of de jongste firmware zoekt:
Ik heb twee PDF's en een firmware-ZIP op Mediamax gezet. Username=gnomon, password=phocus.
Succes ermee!
Heeft iemand toevallig een Phocus liggen die bv kapot is, maar waar de afstandbediening het nog wel van doet ? mijn ab is namelijk kapot . . .
  • jongetje
Ik heb dit apparaat ook maar als ik divx wil afspelen blijft hij soms hangen bij het laden van de film en moet ik stekker erin en eruit. Ik heb nog maar één keer voor elkaar gekregen om een divx goed af te spelen. Meer mensen met dit probleem, of nog beter, een oplossing?
Ben op zoek naar een functionerende afstandsbediening van de Phocus 160HDDDVD Recorder of misschien een complete speler plus afstandsbediening.
  • jongetje
Mijn speler gaat binnen nu en aantal weken in de verkoop dus als je interesse hebt PM maar.
  • joey6666
  • Laatst online: 23-04 18:02
Voor degene die op zoek is naar tweede en zover ik weet laatste firmware, hij staat hier.
http://www.bi-design.nl/phocus/D2C_07_013.exe
Pagina: 1 2 Laatste
