[OC-Ervaringen] Geil ONE W bh-5 1,5-2-2-5
Wie heeft er (oc)ervaring met het onderstaande modules???
Want na 2 maanden gekloot met mijn twinmos sp3500 bh-5 modules op mijn nf4 ultra-d ben ik het zat :( (210mhz 2-2-2-5 was max!!!) op bios 310
Op internet is er namelijk nog niets van het vinden, alleen de s (tccd) versie ervan.
Bedankt voor de input.
GeIL ONE Series
Geil ONE BH PC3200 400MHz DDR
Afbeeldingslocatie: http://www.geilusa.com/images/ONE-W%20(25%25).jpg
GeIL ONE Series BH Version Hand-picked (BH) 32x8 DDR Chips PC3200 400MHz DDR SDRAM. Capable running at DDR400MHz CAS 1.5-2-2-5 and DDR 500MHz CAS 2-2-2-5.
Available in 512MB Single Package, 512MB (2X256MB) and 1GB (2x512MB) Dual Channel Kit Package.
Specification
GeIL ONE hand-picked (BH) 32x8 DDR Chips
184-pin, Non-ECC, Un-buffered DDR DIMM
Working Voltage 2.55V - 3.80V
Platinum Copper Heatspreader
Thmperature Thermometer
Retail Package
Lifetime Replacement Warranty
*DISCLAIMER - Attention all users of GeIL ONE W (BH) Series, in order for your GeIL ONE W (BH) to be covered in the full lifetime warranty policy, the modules must be working under the below requirements of condition.
VOLTAGE: All GeIL ONE W (BH) memory modules require a working voltage range between 3.4V ~ 3.5V @ DDR500
COOLING: All GeIL ONE W (BH) memory modules require sufficient cooling. A 15~25CFM (Cubic Feet per Minute) of direct airflow towards the modules is strongly recommended. This could be easily accomplished with an 80mm low rpm fan installed on the side panel of the chassis/case. Modules that are not properly cooled may not meet the rated timings/speeds stated in official spec and could become susceptible or premature.
PLATFORM: All GeIL ONE W (BH) were tested on DFI Athlon 64 platforms. Only Socket 939 platforms are validated to run at rated timings/speeds. GeIL strongly recommend for the GeIL ONE W (BH) to only be used on DFI LanParty UT NForce 4 Ultra-D, DFI LanParty UT NForce4 SLI-DR and DFI LanParty NForce4 SLI-DR as they are the few mother boards on the market right now that provide the best combination of voltage options and compatibility.
  • FiXeR.nl
Voltage staat goed?
ik had je wel kunnen helpen met je twinmos speed premium pc3500.... Ik heb daar vooral opgemerkt dat ik in het begin niet meer dan 3,0V kon geven, nu kan ik tot 3,2V Met 3,1 of 3,2 kom ik tot 239Mhz.
[ Voor 10% gewijzigd door Verwijderd op 22-08-2005 20:20 ]
  • Gaming247
  • Laatst online: 23-09 12:49
Uit zijn post history kan je opmaken dat hij een MSI K8 NEO2 heeft, en die gaat standaard maar tot 2,85Volt dacht ik, als je geen booster gebruikt zal je niet veel hebben aan de Geil ONE's.
[Updated spec's]
  • FiXeR.nl
Er kan max 3.8 volt doorheen, en dan kom je een stuk verder ja!
  • Gaming247
Dat klopt niet helemaal;
Je garantie blijft gelden tot 3,8Volt, maar je mag er zoveel volt doorheen sturen als jezelf wil. })
[Updated spec's]
  • FiXeR.nl
nog beter :)
Sorry ff sig aanpassen, ben er een tijdje uit geweest.
Ik heb inmiddels DFI NF4 ultra-d i.c.m. Venice 3000+ 0520EPMW @ 2800, 1,47V. 2x Twinmos PC3500 Bh-5. Leadtek 6600GT. 2x Maxtor DM10 200gb raid0 en nog andere zaken die OC'ers minder interressant vinden.
Maar het gaat er dus om dat ik mijn geheugen om ga ruilen na oc problemen met mijn voormalige geheugen. Max 210 @ LL @ alle voltages
In het [OC] Het Winbond UTT geheugen topic - deel 2 staat alleen een prijskoppeling. Helemaal geen resultaten of what so ever.
Iemand in nl of belgië? laat het weten wat je er van vind, volgens mij draaien ze nl. super... ;)
[ Voor 6% gewijzigd door Verwijderd op 22-08-2005 21:39 ]
  • sapphire
  • Laatst online: 15:03
sapphire
Die-hard pruts0r
SP 3500 is ook niet bepaald ram waar je ff 3,X voolt doorheen jaagd en dat je dan de FSB omhoog kan gooien. Mijne booten in het begin niet eens als ik er 3v op zetten, maar na een tijdje inbranden doen ze 245 mop 3,2v @ 2-2-2-X 1T met een fannetje erop. De meeste SP's doen na inbranden op 3,2v wel 240~250 dacht ik.
Gabriël AM5
  • Lefty_38
  • Laatst online: 25-11-2024
Q6600 | 4GB | 24" Dell 2407-HC | Logitech Z-5500 | iPhone 4
  • Gaming247
De winstmarges op de OCZ VX en de Mushkin Redline's zijn blijkbaar nogal hoog.
[Updated spec's]
  • D-Three
Verwijderd schreef op maandag 22 augustus 2005 @ 19:41:
Probeer eens een andere BIOS want die 310 is nu ook niet bepaald nieuw meer. Probeer eens de 623-2, een variant op de officiële 623-3 maar geoptimaliseerd voor UTT en BH/CH.
Ik heb al legio bios geprobeerd. Alle versie's van oskar wu en big toe. Niets mocht baten. Vandaar dat ik op zoek ben naar nieuw geheugen. Dit geheugen lijkt me daarom wel wat...
GEIL ONE W SERIES <> OCZ VX 4000 en Mushkin Redline 4000
Geil garantie tot 3.8V :*)
Temperatuur sensors onboard
Goedkoper dan OCZ VX 4000 en Mushkin Redline 4000 (ca. 30 euro momenteel)
garantie 1.5-2-2-5 :o bij 200 mhz en 2-2-2-5 _/-\o_ bij 250mhz (zoals OCZ en Mushkin)
de tot nog toe niet bewezen oc resultaten (250+ 2-2-2-5)
Dit laatste weerhoud me ervan om deze modules direct te bestellen. Daarom, ervaringen laat het weten
  • Epsilon
  • Laatst online: 09:15
Epsilon
Avatar revival!
sapphire schreef op maandag 22 augustus 2005 @ 22:05:
Afbeeldingslocatie: http://members.home.nl/epsilon/temp/3000venice_9x355_266_3194_3750s.jpg
Booten doen ze niet boven de 3.6v bij mij, maar dat lag volgens mij meer aan het bord dan aan de rest. Dit is op een DFI NF4 ultra-d met de 4v jumper. Voltage is 3.8v.
Dit was na een paar maanden normaal gebruik. Echter kon ik in het begin ook op 3.7v draaien (met booster op NF3 250, 1 reepje gaf 270mhz 2.0-2-2-5).
Toch zeer mooie resultaten hier van de tm sp latjes. Alleen hoe doen de geil's het? Heeft iemand hier goede of slechte resultaten mee geboekt?
  • martijn_tje
  • Laatst online: 09-09 18:45
het zijn in principe de zelfde chips (volgens mij ook op brainpower pcb). Dus zo veel zal het niet verschillen. Het is meer een kweatie van mazzel hebben hoe hard ze gaan. 250 2-2-2-5 T1 zullen ze wel op 3,3 volt doen net als veel BH5 UTT.
Sony A6600 + Sigma 16 f/1.4, Tamron 17-70 f/2.8, Sigma 30 f/1.4, Sigma 56 f/1.4, Tamron 70-180 f/2.8 en Meike Mk320
  • sapphire
sapphire
Die-hard pruts0r
Epsilon schreef op dinsdag 23 augustus 2005 @ 12:04:
nijs, mijne heb k nog niet verder gehad dan 245 @ 3,2v 24/7 stabiel nog geen tijd gehad om verder te gaan.
Maar k heb zo'n idee dat k weer ontopic moet gaan.
Gabriël AM5
