Nikon D70s introductie
  • 415 views sinds 30-01-2008
  • Remy
  • Laatst online: 11-04 17:48
Remy
I usually get 100% accuracy
Nog vroeger dan de D50 (juni dit jaar) zal Nikon de D70s op de markt brengen. Net iets meer dan een jaar na de intro van de D70 komt deze 'version 2.0' van Nikon's hitcam op de markt :)
persbericht:
Refining the award-winning performance of 2004's Digital SLR camera of the Year brings even greater excitement to Nikon SLR photography
TOKYO – Nikon Corporation is pleased to announce the introduction of a new interchangeable-lens digital SLR camera that inherits the award-winning image quality, high performance and user-friendliness of the D70 while introducing refinements that further help photographers capture precious moments as they unfold: the Nikon D70s.
The D70s employs the Nikon DX Format sensor and Nikon F lens mount design shared by all Nikon SLR cameras for seamless compatibility with all AF Nikkor lenses as well as the expanding family of high quality DX Nikkor lenses.
Demonstrating just how well Nikon understands that performance is paramount when capturing precious moments, every system within the camera is optimized to keep the photographer on top of the action. Powering up in a mere 0.2 seconds, the D70s is ready to shoot the instant it is turned on. Shutter release time lag is minimized for quick response that makes shooting more efficient and more enjoyable. It is also capable of shooting a rapid 3 frames per second for a continuous burst of 144 pictures*.
(*When using JPEG NORMAL - Large setting, and a SanDisk SDCFH (Ultra II), SDCFX (Extreme/Extreme III), or Lexar Media 80X WA CompactFlash™ card).
Shutter speeds of 30 to 1/8,000 sec. ensure full creative control. The built-in auto pop-up flash can synchronize at shutter speeds of up to 1/500 sec. for great fill flash effects. Its new optimized design also increases flash coverage to support lenses as wide as 18mm. Sensitivity can be set between ISO 200 to 1600 or controlled automatically (AUTO ISO) across the same range of settings to maximize available light.
The 5-area autofocus system continues to feature a cross-type sensor in the center, broad frame coverage, and class-leading low light detection, but is improved to deliver greater precision with fast, more consistent subject acquisition and improved focus tracking. Also included is an AF-assist illuminator to help maximize performance when shooting in low lighting conditions.
The D70s' advanced System LSI processor produces the finest in vivid colors and clarity, while maximizing the speed of file compression, memory buffer handling, simultaneous recording of JPEG and NEF (Nikon Electronic Format) files, and near-instant LCD image display.
The 6.1 effective megapixel Nikon DX Format CCD image sensor features wide dynamic range and a high signal to noise ratio that produces 3,008 x 2,000-pixel images with high resolution and superbly sharp details suited for making large prints, or for cropping for creative detail.
Nikon's 3D Color Matrix Metering with 1,005-pixel sensor delivers consistently accurate exposure automatically by measuring brightness, color, contrast, selected focus area, and subject-to-camera distance information for each shot, and then referencing the results against an onboard database of 30,000 scenes from actual photography. Variable center-weighted metering and a choice of five spot meters are also available, as are exposure compensation, and auto exposure bracketing.
The D70s produces natural coloration by matching white balance to the light source of the shot. Advanced Auto white balance is capable of handling most situations, although the flexible options include white balance bracketing, a choice of six specific manual settings with fine-tuning, as well as a preset option for using a gray or white object as a reference for white balance.
Innovative shooting options simplify the photographic process, whether controlled manually or via advanced automatic operation. Of particular note are the seven automated Digital Vari-Program selections accessed from the mode dial for a combination of personal control and powerful automatic operation that helps achieve great results under complex shooting conditions, even when in a hurry to catch the shot.
The new high-energy rechargeable lithium-ion battery EN-EL3a delivers the power to shoot up to 2,500 images* on a single charge. The D70s can also be powered by the EN-EL3 battery used by the Nikon D100 and D70, or by CR2 batteries when using the optional battery holder (MS-D70).
Controls are located for easier access and smoother operation. Newly designed menus are presented clearly and in plain language on the large 2.0-inch LCD monitor, while intuitive help dialogs are available for on-the-spot reference to the respective menu selections.
Remote control options are also expanded for the D70s, with the new optional Remote Cord (MC-DC1) adding greater convenience and ease of use in a wider variety of shooting situations, including long exposures and close-ups. Cable-free operation is also available with the optional Wireless Remote Control ML-L3. A third option involves Nikon Capture 4 (Ver. 4.2) software, which can be used to control the D70s from a computer via the USB connection.
Diverse playback options, versatile custom settings, a USB interface for easy connectivity or direct printing to any PictBridge compatible printer, and a bevy of other features make the D70s a top-performer amongst digital SLR cameras.
Combine the inherit advantages of the camera's outstanding performance with the empowering and inspiring components of Nikon's Total Imaging System, including high-quality AF, AF-S and DX Nikkor lenses, advanced Speedlight technologies, and versatile software options. Top it off with superb pictures that are vivid, accurate in color, and crisp and clean in detail, and you discover the sheer enjoyment, expanded creative possibilities, and increased shutter opportunities of Nikon digital SLR photography with the D70s.
Sales release schedule: Nikon Corporation will launch the D70s worldwide in April 2005.
Specs: Ik zal alleen even de veranderingen/verbeteringen hier noemen tov de D70:
- 2-inch lcd tov 1,8 voor de D70
- remote cord shutter release (MC-DC1)
- Verbeterde EN-EL3a accu
- flash coverage 18mm ipv 20mm
- andere betere eyecup
Pics:
Afbeeldingslocatie: http://crew.tweakers.net/Remy/d70s-press.jpg
Afbeeldingslocatie: http://crew.tweakers.net/Remy/d70sfront.jpgAfbeeldingslocatie: http://crew.tweakers.net/Remy/d70sback.jpg
Afbeeldingslocatie: http://crew.tweakers.net/Remy/d70sleft.jpgAfbeeldingslocatie: http://crew.tweakers.net/Remy/d70stop.jpg
Ten opzichte van de D70 is er niet extreem veel veranderd, het is dan ook geen echt nieuw model maar een doorontwikkeling van de populaire cam :)
(P)reviews / nieuws:
DPReview nieuwsitem
Letsgodigital first look
[ Voor 3% gewijzigd door Remy op 20-04-2005 11:42 ]
LinkedIn
Instagram
  • Artz
  • Registratie: Mei 2001
  • Laatst online: 17-04 14:37
Geeft me in ieder geval een goed gevoel over de D70 die ik net heb gekocht. Daar kan ik nog wat jaartjes mee vooruit. Die kleine veranderingen die doorgevoerd zijn, zijn voor mij geen ramp. Het schermpje had iets groter mogen zijn op de D70..
  • urk_forever
  • Laatst online: 22-04 17:39
Die nieuwe eyecup lijkt me wat beter dan die nu bij de D70 zit, die ga ik zeker los kopen. Verder een mooie verdere ontwikkeling van een al mooie camera.
Hail to the king baby!
  • DarkSide
  • Laatst online: 23-04 21:44
DarkSide
theres no place like ::1
Verder schijnt het ook te zijn dat de snellere autofocus van de D70s via een firmware upgrade op de D70 te verkrijgen is.
  • patrickt35
  • Laatst online: 06:33
DarkSide schreef op woensdag 20 april 2005 @ 12:28:
Bron?
En per wanneer?
  • Zoefff
  • Laatst online: 23-04 22:34
Zoefff
Ik vind het inderdaad geen wereldschokkende veranderingen t.o.v. de D70, waar ik ergens wel blij mee ben. Het is ook wel duidelijk dat Nikon deze camera niet produceert om D70 gebruikers een D70s te laten kopen, maar puur bedoelt voor nieuwe kopers.
Het scherm op de D70 vind ik momenteel groot genoeg. Op de D70s bljift het aantal pixels ook gelijk, het scherm word alleen wat groter, weinig kwaliteitsverbetering dus.
Verbazingwekkend vind ik dat ze de accu nog beter hebben gemaakt. Ik ervaar het momentel al als vrijwel onmogelijk om m'n accu leeg te schieten, ben benieuwd hoe dat met de D70s is. Ik lees wel dat de EN-EL3 te gebruiken is in de D70s, is de EN-EL3a ook te gebruiken in de D70?
Ik zou het alleen een rattenstreek vinden als ze voor de D70s wél een grip uitbrengen, dat is namelijk het enige wat ik op mijn D70 mis.
Doen ze dat niet, dan vind ik de D70s niet meer dan een opgepoetste D70 :)
FotoblogWerkaandemuur.nlMoestuincursus.nlTwitter
Zoefff schreef op woensdag 20 april 2005 @ 12:53:Doen ze dat niet, dan vind ik de D70s niet meer dan een opgepoetste D70 :)
Helemaal met die firmware update voor de D70, blij te horen dat Nikon snapt dat een D70 gebruiker zoals ik een prima camera heeft en dat die geen D70s zal aanschaffen met zulke kleine verschillen/verbeteringen, maar dat ze ons wel happy houden/maken door hem 'te verbeteren' middels firmware update omdat dat dus gewoon mogelijk is. _/-\o_ De meeste fabrikanten zouden zich alleen maar richten op het verkopen van hun nieuwe speeltjes, en het ontwikkelen van de volgende generatie. Nu met z'n allen nog wachten op de D200 :O ?!
  • mphilipp
  • Laatst online: 00:27
mphilipp
Romanes eunt domus
Ok, dan zeg ik het nog een keer:
Maar het is toch ook een opgepoetste D70?
  • Zoefff
Zoefff
Ja, dat is het inderdaad ook. Mijn bericht is ook alleen een bevestiging van dit feit :)
  • Puck
  • Laatst online: 23-04 21:04
Puck
EINDBAAS.org
Is er al bekend wanneer hij in Nederland verkocht gaat worden en wat de prijs gaat zijn?
ik zie op deze pagina:
Nikon D70 + AF-S DX 18-70mm
Onze prijs : 894 €
Nikon D70s + AF-S DX 18-70mm
Onze prijs : 1 284 €
Dit vind ik wel een belachelijk hoge meerprijs tegenover de kleine extra verbeteringen (waarvan een groot deel ook gewoon via firmware voor de D70 geupgrade kunnen worden)
[ Voor 69% gewijzigd door Puck op 29-04-2005 13:39 ]
Arrived anxious, left bored
  • DarkSide
DarkSide
PuCK schreef op vrijdag 29 april 2005 @ 13:33:
Onze prijs : 894 €
Tja toen ik mijn D70 nieuw kocht was deze 1250,- in een webwinkel. En rond de 1400 in een foto winkel. De prijzen van de D70s zullen wel snel dalen denk ik. Maar ik vindt het opzich logish dat de introductie prijs in het begin zo hoog is. Volgens mij wil Nikon dit bedrag ook officicieel hebben voor de D70. Dat hij nu bijna overal goedkoper is is wat anders.
Het feit dat de D70s een aansluiting voor een externe shutter-release heeft, maakt het de makers van third-party grips wel makkelijker. Geen geklungel meer met IR ledjes die op de IR-remote sensor geplakt moeten worden, maar gewoon een kabeltje dat je in de remote aansluiting prikt.
Onze prijs : 894 €
Ik denk dat dit te maken heeft met het feit dat de D70 een import model is en de D70s dus niet.
Momenteel worden er erg veel import modellen tegen lage prijzen op de nederlandse markt gedumpt.
In eerste instantie aantrekkelijk, maar als je camera voor een defect terug moet naar de importeur dan ben je het voordeel heel snel kwijt.
  • JeanLeGrand
  • Laatst online: 31-07-2024
Je replyt op een aardig oude topic ;). Maar bij Foto Konijnenberg kun je ook van de 70S een Engelse import kopen voor €150 euro minder. Verschil is dat je het eerste jaar niet garantie van Inca hebt maar van Konijn zelf. En na dat eerste jaar maakt het helemaal nix meer uit. En ik lees dat mensen in dat eerste jaar garantie bij Inca wel eens hun camera weken kwijt zijn, of dat een door jou geconstateerde Front- of Backfocus probleem door hun wordt afgewimpeld met "camera is OK" .
Dus - Shit Can Happen - grijze import of niet.
Denon AVR-X3600H
