new mainboard, S939 or 775?
  • 89 views sinds 30-01-2008
Hello from Germany.
I am new here and I normally speak German so please excuse me for using (my bad) English. Lars, a cousin of mine, said me to ask my questions here 'cause he always gets good and guick answers so I will do so now.
I am searching for a new motherboard. It should have one AG-port and at least four SATA ports for running a raid 0+1 system. All the time I thought of taking a socket 939 board with an AMD Athlon64 3000+ Winchester. The only board which fits my specifications is the MSI K8N Neo2 Platinum. But this board does not support DDR400 at DualChannel, right? Or are there any alternatives? Now Lars told me to take an Intel CPU. But I do not know. It costs much more and I do not know what CPU and board is good. But the gaming-performance is less than the one of an A64 system and this is my primary target.
I Hope you can help me.
  • AlterMann
  • Laatst online: 23:56
The MSI K8N Neo2 Platinum does support DDR400 at DualChannel.. No problem ;)
Only problem I came across was using 4 double sided modules, max speed then is only DDR333.
Could have found it on the msi site, like me ;)
Well...
I understood it the way that doublesided DDR400 ist not supported at dualchannel at all. OK, I guess I will try.
  • Sayko
  • Laatst online: 13-09 16:19
Sayko
Knowledge Is Power
Check my sig. Double sided ram thoug. K8N NEO2 rocks!!!!
  • J0J0
  • Laatst online: 24-10-2025
Well this MSI s939 board could be considerd to be the walhalla for a AMD user.
If it didn't support ddr400 dc at all it wouldn't be all that popular. So no worries :)
EDIT
@ Siebolt
MSI owned die aarsus :P
@ DennisM
uhuh but why use 4 memorybanks :? you could go for a 2x512 or 2x1024 setup but anything above that is just plain stupid.
@copywizard
very complete :? LMAO :+
[ Voor 54% gewijzigd door J0J0 op 28-01-2005 23:13 ]
specs
  • Siebolt
  • Laatst online: 24-09 16:10
Und der Asus A8V Wireless ist nicht gut? kut duits,
it has dual channel poep and raid 0+1 :)
http://usa.asus.com/products/mb/socket939/a8v-d/overview.htm
  • Dennism
  • Registratie: September 1999
  • Laatst online: 00:54
I thought that was a cpu problem instead of a mainbord problem. It had to do with the onboard memory controller in the A64 cpu's. These can only do 2 dimm's in dual channel @ DDR400. with 4 dimm's it switches to DDR333 as said above.
But I think I read in another topic that the new steppings which will be out soon do support 4 dimm's @ DDR400
[ Voor 5% gewijzigd door Dennism op 28-01-2005 23:07 ]
  • copywizard
you could also try Gigabyte,s K8Ns-ultra 939 it has 4 sata ports and supports ddr400 dual channel its an very complete mobo
AMD Ryzen 5800X3D, Gigabyte Aorus B550 ITX, AMD RX6900XT, 32GB Corsair DDR4
Thanks.
The prob with Asus A8V and the Gigabyte Board is, that they have four SATA Ports but that they do not work in raid 0+1. The Gigabyte supports only raid systems with two sata ports (I think 'cause of two different raid controllers). And the ASUS supports raid 0+1 but only with two SATA and two PATA HDDs and not with four SATA ports. And I need a raid system with four SATA ports at a time.
  • BalusC
BalusC
Carpe diem
Helaas, dit is een Nederlandstalig forum. Van de gebruikers verwachten we ook dat ze hier Nederlands kunnen spreken en lezen. Vooral omdat de [faq]registratievoorwaarden[/] en de FAQ's in het Nederlands zijn geschreven. Er zijn genoeg Engelstalige alternatieven te over op het web ;)
