nieuwe versie pre-release client
  • 179 views sinds 30-01-2008
  • Gizmo_mokum
  • Laatst online: 05-09 11:45
http://www.distributed.net/download/prerelease.html
dnetc v2.8012-465-GTR-00122516 for Win32 (WindowsNT 5.0).
dacht, meld het even.
PS: OGR-crucncher schijnt weer verbetert te zijn
2.8011.464 imp: many: OGR cores improved - should now be slightly faster
new: many: AltiVec OGR cruncher by Dan Oetting and Chris Cox
new: AmigaOS: added full lurk functionality
new: AmigaOS: -shutdown, -restart and -(un)pause support added
new: AmigaOS: "Pause if running" support now enabled
new: all: command line options may be passed via a 'dnetc_opt='
(or 'DNETC_OPT=') environment variable.
new: *nix: command line options may be overridden by a command
file in [/usr/local]/etc/. Refer to the man page for details.
new: *nix: optional -multiok=0 switch to prohibit multiple
instances of the client from running at the same time.
new: linux: now supports -[un]install for SYSV-style rc.d
chg: rc5: random-prefix is no longer written to the .ini
chg: all: If a dialup connection had been previously initiated
by the client AND the link drops while doing network i/o,
the client will dial again.
new: the crunch-o-meter displays a twirling baton (by default) if
not running with a GUI window and output is not redirected.
imp: networking layer rewritten from scratch. It is also a lot
more chatty, and prints very specific messages on error.
new: client can be configured with multiple keyserver names.
fix: all: no more uneccesary connects when using frequent-checks
fix: all: mail sent correctly on shutdown.
fix: all: no longer discards work-to-do on fetch.
fix: win9x: client no longer hangs on sys shutdown
chg: all: smtp/firewall hostname settings have different semantics
(port # is appended to the name in the form hostname:port)
fix: all: for 'rotate' log file types: if the interval (limit)
is specified in days then the date in the filename reflects
the date of the first day of that interval.
new: all: by default displays a different crunch-o-meter when an
OGR packet is being worked on. (any sug. for improvement?)
chg: minor adjustments to Loaded/Saved/Completed/Summary messages
for project independance (format doesn't have to be processed
differently for different projects). Inexact percentages
(ie, for OGR) are no longer displayed at load/save time.
new: win16/32: crunch-o-scope, menus et al. (christmas present :)
new: AmigaOS: fifo log file type now enabled
new: macos: temp. sensing support for single CPU G3 and G4 Macs
new: macos: LURK support for users of OT-PPP or RemoteAccess
chg: nonpreemptive systems yield much more when running OGR
new: macos: pause-on-battery support for battery driven macs
new: macosx: pause-on-battery support for battery driven macs
  • wildhagen
wildhagen
Blablabla
Virussen? Scan ze hier!
  • [eNeRGy]
  • Laatst online: 24-04-2025
En dan heb ik via een ftp in duitsland al weer een nieuwere build gezien van deze versie!
  • wildhagen
wildhagen
Blablabla
Klopt, dat is http://fb14.uni-mainz.de/~cyp/dnetc_w32/010512.zip
Die lost wat problemen op, met name met openen en resizen van het window. (overigens is het versie nummer nog steeds 2.8012.465)
Op vrijdag 05 januari 2001 21:01 schreef [eNeRGy] het volgende:
/me ziet meteen Rabbit weer rondhuppelen in de stats [img=15,15]i/s/biggrin.gif[/img]
  • Yohost!
  • Laatst online: 23:17
klopt
:( Gaat bij mij iets langzamer...
