Via 4in1 4.25a zegt:
"Contains INF 1.02b, AGP 4.04, IDE 2.1.50, IRQ 1.3a".
De allernieuwste stuff dus. Alleen van de IDE-driver uit de 4in1 2.1.50 weet ik de subversie niet. Zelf laad ik altijd de losse drivers, vandaar...
Maar er is wel behoorlijk aan die 2.1.50 gesleuteld, voor zover is weet is subversie 3 (van de 4, de eerste heeft geen subversie-nummer
) de beste, dit is er (volgens VIA) allemaal gefixed:
Changes:
Version 2.1.50
Win9x:
Fix copy-compare(enable Enhance Performance function) occure system hang problem
(for VT82C686B, VT8231)
Fix Pioneer DVD 2.6x same channel with hard disk will boot fail problem
Support ATA100 timing setting
While playing VCD and force the system into suspend, wake up system will occure blue screen.
(Windows 95 SE)
WinNT:
Fix Easy CD-Creator 4.02c audio DISC copy fail problem
Fix accessing Iomega zip 100(ATA interface) will occure blue screen
while there is no disk inside.
Win9xVSD:
Fix the previous version can't support Win95
Update INF. prevent to load it as static VxD Driver. (Ver 1.05)
Version 2.1.50(1)
Win9x:
Fix WinDVD Player hanging problem
Fix LS120 type mistake problem in 2.1.50 ( viaide.vxd ver 2.03)
Setup:
Fix Install VSD driver will copy MPD driver to system problem
Version 2.1.50(2)
NT:
Fix the Pioneer 16x DVD-ROM boot fail only for 2.1.50 and 2.1.50(1) (Ver 2.1.50.1)
Win9x:
Modify INF file for INF installation
MPD Driver Ver 2.1.50.1
VIAIDE Vxd Driver Ver 2.03
Win9xVSD:
Modify INF file for INF installation and HCT testing successful. Ver 1.05
Version 2.1.50(3)
Setup:
Add Digital Signature function inside
NT:
Modify initial function (Ver 2.1.50.2)
Win9x:
Update the DriverVer of INF to be 08/01/2000 for HCT 9.6
Win9xVSD:
Update the Driver Ver of INF to be 08/01/2000 for HCT 9.6
