[VBA] van PHP naar VBA
  • Kage Musha
  • Laatst online: 04-10 22:39
Ik heb een stuk pseudo PHPcode die vertaald moet worden in VBA (Access).
Tot zover heb ik dit al vertaald
29
30
31
Private Sub Command26_Click()
Dim cnn As Connection
Dim strSQL As String
Dim no_rows
Dim no_choices, max_courses, p, i As Integer
Dim Recordset As New ADODB.Recordset
    no_choices = 4   'the number of choices each student has
    max_courses = 2  'the number of courses a stundent is allowed (and has to) select p = 0
    Do While i <= no_choices
         p = p + 1
    Set cnn = CurrentProject.Connection
    Set Recordset = Command.Execute("SELECT _fd_id, choice" + p + " FROM N_Data_Tbl")
    Set no_rows = Command.Execute("SELECT COUNT(*) FROM N_Data_Tbl")
    ReDim all_fd_ids(no_rows) As Integer 'Array of all _fd_id's
    ReDim all_choices(no_rows) As String 'Array of Strings to save all 'p' choices...
    i = 0
    Do While i <= no_rows 'this fills the arrays with the data from the query
        i = i + 1
       all_fd_ids(i) = Recordset(i, 0)
       all_choices(i) = Recordset(i, 1)
    Loop
    Loop
End Sub
en dit is de PHP Code
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
/* DON'T FORGET THAT THIS IS PSEUDO-CODE ITS NOT VB OR VBA !!! MORE LIKELY SOMETHING LIKE JAVA / PHP
   It just tells you, what you should do to achieve what you want!*/
int no_choices=4;   //the number of choices each student has
int max_courses=2;  //the number of courses a stundent is allowed (and has to) select
for(int p=0;i<no_choices;p++)
    mysql_query("SELECT _fd_id, choice" + p + " FROM N_Data_Tbl");
    int     no_rows = mysql_num_rows();
    int all_fd_ids[no_rows];    //Array of all _fd_id's
    String  all_choices[no_rows];   //Array of Strings to save all 'p' choices...
    for(int i=0;i<no_rows;i++)  //this fills the arrays with the data from the query
        all_fd_ids[i]  = mysql_result(i,0);
        all_choices[i] = mysql_result(i,1);
        mysql_query("SELECT MaxStudents FROM Course WHERE CourseName = '" + all_choices[i] + "'");
        int MaxStudents = mysql_result(0,0);
        mysql_query("SELECT * FROM Rel_SelectedCourses WHERE CourseName = '" + all_choices[i] + "'");
        if (MaxStudents > mysql_num_rows()) // if there are free places left (the maximum number of stundents is higher then the number of stundents which are assigned to the course) assing the student to the course
            mysql_query("SELECT * FROM Rel_SelectedCourses WHERE _fd_id=" + all_fd_ids[i]);
            if (mysql_num_rows()<max_courses)
                //the following line inserts 1 line to the Rel_SelectedCourses table containing the currently selected student and choice (selected by the index "i")
                mysql_query("INSERT INTO Rel_SelectedCourses (_fd_id, CourseName) VALUES (" + all_fd_ids[i] + ", '" + all_choices[i] +"')";
////////////////////////////////  OUTPUT ROUTINE  ///////////////////////////
int max_courses=2;  //should be a global variable
mysql_query("SELECT _fd_id, gname, iname, lname FROM N_Data_Tbl ORDER BY _fd_id");
String  all_names[no_rows][3];  //2-dimensional Array, to save all needed strings... in this case names
for(int i=0;i<no_rows;i++)  //fills the upper arrays
    all_names[i][0] = mysql_result(i,1);
    all_names[i][1] = mysql_result(i,2);
    all_names[i][2] = mysql_result(i,3);
String  selected_courses[no_rows][max_courses];
    mysql_query("SELECT * FROM Rel_SelectedCourses WHERE _fd_id=" + all_fd_ids[i] + " ORDER BY _fd_id");
    num_rows=mysql_num_rows();
    for(p=0;p<num_rows;p++)
        selected_courses[i][p]=mysql_result(1,p);
//we have filled all arrays now with the data we need to achieve the following output:
// gname | iname | lname | course1 | course2
    print all_names[i][0];
    print all_names[i][1];
    print all_names[i][2];
    for(p=0;p<max_courses;p++)
        print selected_courses[i][p];
    print endline;
//Ofcourse you will have to put this in a table instead... this is kept dynamic, so that you are able to change the number of courses for each stundent, if you don't need this you can still keep it - it also works for 2 courses well ;)
 example for JOIN: "SELECT N_Data_Tbl.gname, N_Data_Tbl.iname, N_Data_Tbl.lname, Rel_SelectedCourses.CourseName FROM N_Data_Tbl, Rel_SelectedCourses WHERE N_Data_Tbl._fd_id=Rel_SelectedCourses._fd_id" <--- would be a possible but bad join.... doesn't give it well formated
Het stukje code wat ik vertaald heb, werkt zo ongeveer op dat ene stukje met Recordset na, als ik die stukje code compile dan krijg ik de volgende melding "Wrong number of arguments or invalid property assignement".
Hoe fix ik dit of zit ik helemaal verkeerd met Recordsets als vervanging van mysql_result?
[ Voor 5% gewijzigd door Kage Musha op 11-01-2005 15:13 ]
o.o
  • henkleerssen
henkleerssen
Your life is as you narrate it
welke vba parent app heb je? Word, excel of access? of wat? Scheelt weer een beetje vandaar.
Ook.. waar precies geeft die de fout als je debugt (f8)?
Kijk ook ff wat je in die recordset krijgt per record(i).. Kijk maar eens in de locals window.
Je hoeft niet met i++ te werken in vba.. je gaat gewoon alle records af in een recordset met
.. eeuh ja.. wat was het ook alweer? Tot laatste met recordcount ...kijk maar eens..
  • Kage Musha
Sorry, vergeten te vermelden ja. Ik werk met Access (2003)
Hij geeft hier de foutmelding
Als ik op F8 druk gebeurt er niks maar als ik voor Compile kies dan krijg ik die foutmelding.
in the Locals Window geeft ie niks weer
en met i++ bedoel je dan dat ik Next i moet gebruiken? (heb dat ergens gezien)
o.o
