[SuSE9.1] Tuxracer installen lukt niet
  • Maximilian
  • Laatst online: 21-09-2025
Maximilian
You've been Maxxed...
Ik wil hier TuxRacer installen (dat zit niet in SuSE9.1 personal :? )
Goed maar dan gaat ik em configen en dan krijg ik dit
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
linux:~/Downloads/tuxracer-0.61 # ./configure
creating cache ./config.cache
checking for a BSD compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... yes
checking for working aclocal... missing
checking for working autoconf... missing
checking for working automake... missing
checking for working autoheader... missing
checking for working makeinfo... missing
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking whether the C compiler (gcc  ) works... yes
checking whether the C compiler (gcc  ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for c++... c++
checking whether the C++ compiler (c++  ) works... yes
checking whether the C++ compiler (c++  ) is a cross-compiler... no
checking whether we are using GNU C++... yes
checking whether c++ accepts -g... yes
checking for ranlib... ranlib
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/time.h... yes
checking for unistd.h... yes
checking for working const... yes
checking whether time.h and sys/time.h may both be included... yes
checking for getcwd... yes
checking for gettimeofday... yes
checking for strdup... yes
checking for finite... yes
checking for isnan... yes
checking for _finite... no
checking for _isnan... no
checking for ieeefp.h... no
checking for Win32 platform... no
checking for X... no
checking for main in -ldl... yes
checking for main in -lm... yes
checking for tcl8.3 library... yes
checking for tcl.h... yes
checking for sdl-config... no
checking for SDL - version >= 1.0.1... no
*** The sdl-config script installed by SDL could not be found
*** If SDL was installed in PREFIX, make sure PREFIX/bin is in
*** your path, or set the SDL_CONFIG environment variable to the
*** full path to sdl-config.
*** SDL not found.  Configuring without audio or joystick support.
checking for GL library... yes
checking for glXGetProcAddressARB... yes
checking for GLU library... no
checking for MesaGLU library... no
checking for glu32 library... no
configure: error: Cannot find GLU library
Maar het stomme is dat ik wel gewoon GLUTFree heb geinstalled en mijn NVIDIA Drivers met OpenGL
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
linux:~/Downloads/tuxracer-0.61 # glxinfo
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.3
server glx extensions:
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIX_fbconfig,
    GLX_SGIX_pbuffer, GLX_SGI_video_sync, GLX_SGI_swap_control,
    GLX_ARB_multisample, GLX_NV_float_buffer
client glx vendor string: NVIDIA Corporation
client glx version string: 1.3
client glx extensions:
    GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_visual_info,
    GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_SGI_video_sync,
    GLX_NV_swap_group, GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
    GLX_SGI_swap_control, GLX_NV_float_buffer
GLX extensions:
    GLX_ARB_multisample, GLX_NV_float_buffer, GLX_ARB_get_proc_address
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce 6800 LE/AGP/SSE/3DNOW!
OpenGL version string: 1.5.2 NVIDIA 66.29
OpenGL extensions:
    GL_ARB_depth_texture, GL_ARB_fragment_program,
    GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader, GL_ARB_imaging,
    GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
    GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_shadow,
    GL_ARB_shader_objects, GL_ARB_shading_language_100,
    GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
    GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3,
    GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two,
    GL_ARB_texture_rectangle, GL_ARB_transpose_matrix,
    GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
    GL_ARB_window_pos, GL_ATI_draw_buffers, GL_ATI_texture_float,
    GL_ATI_texture_mirror_once, GL_S3_s3tc, GL_EXT_texture_env_add,
    GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
    GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
    GL_EXT_Cg_shader, GL_EXT_depth_bounds_test, GL_EXT_draw_range_elements,
    GL_EXT_fog_coord, GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels,
    GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
    GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
    GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_texture3D,
    GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
    GL_EXT_texture_edge_clamp, GL_EXT_texture_env_combine,
    GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
    GL_EXT_texture_lod, GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
    GL_EXT_texture_object, GL_EXT_vertex_array, GL_HP_occlusion_test,
    GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
    GL_KTX_buffer_region, GL_NV_blend_square, GL_NV_centroid_sample,
    GL_NV_copy_depth_to_color, GL_NV_depth_clamp, GL_NV_fence,
    GL_NV_float_buffer, GL_NV_fog_distance, GL_NV_fragment_program,
    GL_NV_fragment_program_option, GL_NV_fragment_program2, GL_NV_half_float,
    GL_NV_light_max_exponent, GL_NV_multisample_filter_hint,
    GL_NV_occlusion_query, GL_NV_packed_depth_stencil, GL_NV_pixel_data_range,
    GL_NV_point_sprite, GL_NV_primitive_restart, GL_NV_register_combiners,
    GL_NV_register_combiners2, GL_NV_texgen_reflection,
    GL_NV_texture_compression_vtc, GL_NV_texture_env_combine4,
    GL_NV_texture_expand_normal, GL_NV_texture_rectangle,
    GL_NV_texture_shader, GL_NV_texture_shader2, GL_NV_texture_shader3,
    GL_NV_vertex_array_range, GL_NV_vertex_array_range2, GL_NV_vertex_program,
    GL_NV_vertex_program1_1, GL_NV_vertex_program2,
    GL_NV_vertex_program2_option, GL_NV_vertex_program3,
    GL_NVX_conditional_render, GL_SGIS_generate_mipmap, GL_SGIS_texture_lod,
    GL_SGIX_depth_texture, GL_SGIX_shadow, GL_SUN_slice_accum
glu version: 1.3
glu extensions:
    GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
   visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
 id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x21 16 tc  0 16  0 r  y  .  5  6  5  0  4 16  0 16 16 16 16  0 0 None
0x22 16 dc  0 16  0 r  y  .  5  6  5  0  4 16  0 16 16 16 16  0 0 None
0x23 16 tc  0 16  0 r  .  .  5  6  5  0  4 16  0 16 16 16 16  0 0 None
0x24 16 tc  0 16  0 r  y  .  5  6  5  0  4 24  8 16 16 16 16  0 0 None
0x25 16 tc  0 16  0 r  .  .  5  6  5  0  4 24  8 16 16 16 16  0 0 None
0x26 16 tc  0 16  0 r  y  .  5  6  5  0  4  0  0 16 16 16 16  0 0 None
0x27 16 tc  0 16  0 r  .  .  5  6  5  0  4  0  0 16 16 16 16  0 0 None
0x28 16 tc  0 16  0 r  y  .  5  6  5  0  4 16  0 16 16 16 16  2 1 Ncon
0x29 16 tc  0 16  0 r  y  .  5  6  5  0  4 16  0 16 16 16 16  4 1 Ncon
0x2a 16 tc  0 16  0 r  y  .  5  6  5  0  4 24  8 16 16 16 16  2 1 Ncon
0x2b 16 tc  0 16  0 r  y  .  5  6  5  0  4 24  8 16 16 16 16  4 1 Ncon
0x2c 16 dc  0 16  0 r  .  .  5  6  5  0  4 16  0 16 16 16 16  0 0 None
0x2d 16 dc  0 16  0 r  y  .  5  6  5  0  4 24  8 16 16 16 16  0 0 None
0x2e 16 dc  0 16  0 r  .  .  5  6  5  0  4 24  8 16 16 16 16  0 0 None
0x2f 16 dc  0 16  0 r  y  .  5  6  5  0  4  0  0 16 16 16 16  0 0 None
0x30 16 dc  0 16  0 r  .  .  5  6  5  0  4  0  0 16 16 16 16  0 0 None
0x31 16 dc  0 16  0 r  y  .  5  6  5  0  4 16  0 16 16 16 16  2 1 Ncon
0x32 16 dc  0 16  0 r  y  .  5  6  5  0  4 16  0 16 16 16 16  4 1 Ncon
0x33 16 dc  0 16  0 r  y  .  5  6  5  0  4 24  8 16 16 16 16  2 1 Ncon
0x34 16 dc  0 16  0 r  y  .  5  6  5  0  4 24  8 16 16 16 16  4 1 Ncon
En GLX Gears werkt ook perfect.
linux:~/Downloads/tuxracer-0.61 # glxgears
60527 frames in 5.0 seconds = 12105.400 FPS
73844 frames in 5.0 seconds = 14768.800 FPS
74207 frames in 5.0 seconds = 14841.400 FPS
74210 frames in 5.0 seconds = 14842.000 FPS
74191 frames in 5.0 seconds = 14838.200 FPS
74199 frames in 5.0 seconds = 14839.800 FPS
Dus ik snap niet wat ik fout doe (ben ook een btjuh een n00b eigenlijk... mja)
  • Wilke
  • Laatst online: 15:35
Antwoord 1:
Met andere woorden, opzoeken waar sdl-config staat en verder doen wat de melding zegt.
Over GLU, heb je daarvan de development versie geinstalleerd staan, inclusief header files etc.?
  • Maximilian
Maximilian
Wilke schreef op maandag 10 januari 2005 @ 23:51:
Antwoord 1:
Als het goed is wel en ik gaat de sdl-config eens ff opzoeken...
stom zeg overheen gekeken 8)7
  • DeMoN
  • Laatst online: 26-10 23:01
DeMoN
Pastafari
En wat is trouwens de reden om geen rpm'etje te gebruiken?
Dat kan ook schelen, en is sowiezo beter voor je systeem.
Gamertag: Cosmicv0id
"Het woord Gods is voor mij niets meer dan een expressie en het product van menselijke zwakheid. De Bijbel is een verzamelwerk van legendes die achtenswaardig zijn maar ook primitief en kinderachtig.'' - Albert Einstein
  • Maximilian
Maximilian
moet ik dan die rpm zelf maken of weet je een rpm te vinden voor tuxracer dan?
alles wat ik kan vinden is allemaal in tar.gz en alsnog daarin zonder rpm
  • DeMoN
DeMoN
Pastafari
Maximilian schreef op dinsdag 11 januari 2005 @ 11:49:
Je kan in SuSE toch via YaST het e.e.a. installeren?
Heb zelf beperkte kennis met SuSE maar heb onlangs wel eens achter een SuSE 9.1 prof bak gezeten. Daar kon je gewoon selecteren welk pakket je wilde installeren en tuxracer is meestal zelfs een pakket wat op de CD kan staan :)
btw:
ftp://194.199.20.114/linu...xracer-0.61-1137.i586.rpm
www.rpmfind.net :)
[ Voor 11% gewijzigd door DeMoN op 11-01-2005 11:59 ]
  • Maximilian
Maximilian
neej dit is een personal edition (1cd)
dus eigenlijk moet ik alle extra's nog installen, zoals make en GCC moest ik zelf installen
ik gaat nu tuxracer met yast proberen
[edit]
En nou doetie het wel :?
Install was ook makkelijk, gelijk rpmfind in de bookmarks :p
[ Voor 25% gewijzigd door Maximilian op 11-01-2005 13:24 ]
