800RX XT Platinum op mijn systeem ?
  • carthorian
  • Laatst online: 02-06 06:21
Ik post dit maar even omdat ik nergens informatie vind over deze specifieke kaart (mss dat ze onder andere naam gaat).
Ik wou maar weten of dit goed samengaat met mijn p4 (draait op 2,9Ghz)
Mijn moederbord P4P800 Deluxe en 2048 pc3200 ram geheugen
voeding van 360w
2 p-ata schijven van 7200 rpm (80 & 160gb)
• Sixteen extreme parallel pixel pipelines
• Six programmable vertex shader pipelines
• 256-bit quad-channel GDDR3 memory interface
• Support for Microsoft® DirectX® 9.0 programmable vertex and pixel shadersl data format
• Direct X 9.0 Vertex Shaders
- Vertex programs up to 65,280 instructions with flow control
- Single cycle trigonometric operations.
• Direct X 9.0 Extended Pixel Shaders
- Up to 1,536 instructions and 16 textures per rendering pass
- 2nd generation F-buffer technology accelerates multi-pass pixel shader programs with
unlimited instructions
- 32 temporary and constant registers
- Facing register for two-sided lighting
- 128-bit, 64-bit & 32-bit per pixel floating point color formats
- Multiple Render Target (MRT) support
• Complete feature set also supported in OpenGL® via extensions
• 2x/4x/6x Anti-Aliasing modes
- Sparse multi-sample algorithm with gamma correction, programmable sample patterns, and
centroid sampling
- Temporal Anti-Aliasing
• 2x/4x/8x/16x Anisotropic Filtering modes
- Up to 128-tap texture filtering
- Adaptive algorithm with bilinear (performance) and trilinear (quality) options
• High quality 4:1 Normal Map Compression
• Works with any two-channel data format
• 3-level Hierarchical Z-Buffer with Early Z Test
• Lossless Z-Buffer Compression (up to 48:1)
• Fast Z-Buffer Clear
• Z Cache optimized for real-time shadow rendering
• Seamless integration of pixel shaders with video in real time
• FULLSTREAM™ video de-blocking technology for Real, DivX, and WMV9 formats
• VIDEOSOAP™ noise removal filtering for captured video
• MPEG1/2/4 decode and encode acceleration
- DXVA Support
- Hardware Motion Compensation, iDCT, DCT and color space conversion
• Adaptive Per-Pixel De-Interlacing and Frame Rate Conversion (temporal filtering)
• 0.13-micron low-k process technology for higher levels of integration and higher operating
clock speeds.
[url]undefined[/url]http://www.asus.com/prog/...=P4P800%20Deluxe&langs=01
  • Siebolt
  • Laatst online: 09-08 11:54
ze zeggen meestal iets van vannaf 3 ghz of een 3000+ maar waarom niet, en anders heb je voor je volgende systeem ook een mooi kaartje ;)
  • carthorian
zit nu aan 2,94 Ghz om precies te zijn, da zal wel gaan denkek :)
  • bigfoot1942
ik neem aan dat je een x800 XT PE bedoelt.
ja dat zal wel gaan, zelfs met een p3 nog wel, alleen je prestaties worden dan wel gelimiteerd door je proc. Vraag is of je dat erg vindt, en hoe erg.
  • Siebolt
ja dat bedoelde ik, dat ze anders een cpu hebben die remt ofzo :(
Er was een test daarover met CPU limited x800's en 6800 ultra's op http://www.guru3d.com/article/article/136/ das de link [edit]
En daar kwam uit dat de x800XT zeker limited zal worden door je cpu, maar kijk als je 85 fps limited is door je cpu op 1024/768 is de grap bij zon kaart da tje gewoon 1600/1200 kan draaien met alle filters aan ook op 85 fps want dat is puur videokaart werk snap je?
[ Voor 13% gewijzigd door Verwijderd op 07-01-2005 00:56 ]
  • carthorian
bij welke cpu socket478 komt deze kaart dan tot z'n volste recht (vind enkel maar a64 als vergelijkingsmateriaal)
heb gelezen van ongeveer 3Ghz, kwou het juiste ma wete, ofdak ne 3,0 neem (of overklok naar 3,0) of ineens ne 3,2Ghz koop
[ Voor 38% gewijzigd door carthorian op 07-01-2005 13:50 ]
  • Ultraman
  • Laatst online: 21:11
Ultraman
Boefje
zo uit de review:
Right now I look at it this way, up-to a 3000 MHz you simply are better suited with a Radeon x800 Pro or GeForce 6800 GT. If you have a faster than 3 GHz (3000+) system and want the best of the best, then and only then I can recommend you the GeForce 6800 Ultra or the Radeon x800 XT. That system would be ridiculously expensive though and you need to consider whether that's worth all that hard earned dough.
Met een CPU boven de 3GHz trek je de zaak volledig open. Mag je zelf een CPU uit kiezen :-). Kunt ook nu de kaart kopen en dan later alsnog een CPU upgrade doen natuurlijk.
[Update]
Dat van die 3.0GHz of 3,2GHz ligt natuurlijk helemaal aan je zelf. Heb je de cash en wil je max performence ga je voor de 3,2GHz. Iets minder geld maar toch goede performence ga je voor 3,0GHz.
Als ik zo zie (vluggertje pricewatch) dat een 3,0GHz ong 160 euro is en een 3,2GHz ong 200 euro is, dan denk ik dat je dat zelf moet bepalen. Het prijsverschil is er zeker. Helemaal als je ziet dat het prijs verschil tussen een 2,8GHz en een 3,0GHz maar 5 euro is en tussen de 3,0 en de 3,2 40 euro is. Ligt totaal aan jou portemonnee denk ik
[ Voor 35% gewijzigd door Ultraman op 07-01-2005 13:56 ]
  • carthorian
in belgie ligge de prijze toch een pakje hoger, 3,2 kost hier zo'n 220, maar denk dat ik daarvoor zal gaan. ga maar niet gierig doen en die 3,2 nemen bedankt voor alle hulp
