Cisco 1417 (eol) config of IOS probleem?
  • 59 views sinds 30-01-2008
  • nilski
  • Laatst online: 14-07-2021
Ik kan gewoon opstarten en inloggen op de router maar hij ziet de ADSL interface niet. Mischien iemand met wat meer Cisco kennis die me bij kan staan?
Heb geprobeerd de running-config naar startup-config te copyen en naar flash: maar nix schijnt te helpen ...
System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
C1400 platform with 24576 Kbytes of main memory
program load complete, entry point: 0x4020060, size: 0x14c398
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
%Error opening tftp://255.255.255.255/cisco2-C1400 (Timed out)boot of "cisco2-C1400" using boot helper "eprom:c1400-rboot-r.120-3.T" failed
error returned: File read failed -- Timed out
loadprog: error - on file open
boot: cannot load "cisco2-C1400"
loadprog: bad file magic number: 0x0
boot: cannot load "flash:"
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco Internetwork Operating System Software
IOS (tm) 1400 Software (C1400-RBOOT-R), Version 1
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Tue 23-Feb-99 00:23 by ccai
Image text-base: 0x04020060, data-base: 0x02005000
cisco 1417 (68360) processor (revision D) with 21504K/3072K bytes of memory.
Processor board ID 14931016, with hardware revision 00000000
1 Ethernet/IEEE 802.3 interface(s)
Unrecognized interface found (0-1 = Motherboard interfaces 2 = WIC)
Interface 1 unrecognized by boothelper
Interface 2 unrecognized by boothelper
System/IO memory with parity disabled
8192K bytes of DRAM onboard 16384K bytes of DRAM on SIMM
System running from ROM
8K bytes of non-volatile configuration memory.
16384K bytes of processor board PCMCIA flash (Read/Write)
Press RETURN to get started!
WAZUUUUUUUP!!!!!
  • Duinkonijn
  • Laatst online: 14:06
Duinkonijn
Huh?
lijkt er op dat je ios hemelen is op je Flash.
[ Voor 47% gewijzigd door Duinkonijn op 06-01-2005 18:48 ]
Het is makkelijk om iemand zijn negatieve eigenschappen te benoemen, maar kan je ook de positieve eigenschappen benoemen?
  • nilski
daar ben ik idd ook bang voor :S Het is een oud lijk en ik wou 'm graag gaan gebruiken maar ik heb geen Cisco contract oid. bovendien weet ik niet welke IOS-en ik kan gebruiken..
Een andere 1417 is ook moelijk te vinden vrees ik om te copyen.
[ Voor 17% gewijzigd door nilski op 06-01-2005 18:52 ]
WAZUUUUUUUP!!!!!
  • Duinkonijn
Duinkonijn
Huh?
nilski schreef op donderdag 06 januari 2005 @ 18:51:
Cisco 1417 ADSL router (eol)
je had beter een move kunnen aanvragen
zal ff kijken of ik wat kan vinden, als hij op leeftijd is kan je die IOS meestal gratis downloaden
[ Voor 11% gewijzigd door Duinkonijn op 06-01-2005 18:54 ]
  • nilski
kheb me suf gezocht op Cisco. Als je iets kan vinden ben ik je zeer erkentelijk :)
WAZUUUUUUUP!!!!!
  • Duinkonijn
Duinkonijn
Huh?
nilski schreef op donderdag 06 januari 2005 @ 18:58:
met een std cco accountje kan je der ook bij...
klik
klik 2
ze hebben tig verschillende edities
[ Voor 19% gewijzigd door Duinkonijn op 06-01-2005 19:33 ]
  • nilski
hrmpf! ik krijg een blanco pagina bij allebei de links, ook al log ik in met m'n standaard guest-accountje..
Als ik op bv. de 12.3 versie zoek dan krijg ik uiteraard de melding "not authorized"...
ik geloof dat ik een 12.x(yz)T versie zou moeten hebben..
hoe zou ik die pagina kunnen vinden? (ik had al een account maar idd standaard)
[ Voor 67% gewijzigd door nilski op 06-01-2005 19:44 ]
WAZUUUUUUUP!!!!!
  • nilski
hmm, met een standaard guest account gat het niet lukken vrees ik :(
WAZUUUUUUUP!!!!!
  • Duinkonijn
Duinkonijn
Huh?
nilski schreef op donderdag 06 januari 2005 @ 19:47:
denk dat het aan sessies ligt als je via
http://www.cisco.com/kobayashi/sw-center/
http://www.cisco.com/cgi-...anner-tool/iosplanner.cgi?
als je der zo niet bij komt heb je denk ik idd een contract nodig
  • nilski
helaas, krijg weer volgende melding;
Invalid user name or password
You are logged in with a registered Guest-only account
Your Cisco.com user account is associated with a Cisco contract or registration key that does not entitle access to the Cisco IOS® Upgrade Planner
maw. een CD opspeuren of iemand met de juiste software..
kan ik ook een IOS van een ander apparaat met de juiste versie gebruiken?
WAZUUUUUUUP!!!!!
  • TrailBlazer
  • Laatst online: 24-08 21:59
TrailBlazer
Karnemelk FTW
ziet er inderdaad naar uit dat je een account nodig hebt. Wel idioot trouwens dat je voor alle versies een account nodig hebt. Zonder IOS kan je niks.
nilski schreef op donderdag 06 januari 2005 @ 21:06:
nee je moet er een voor de c1400 hebben
[ Voor 50% gewijzigd door TrailBlazer op 06-01-2005 21:17 ]
  • Duinkonijn
Duinkonijn
Huh?
denk het niet.. je kan het proberen als je iets vergelijkbaars heb.
stuk zal hij niet echt gaan. hoogstens dat hij geen poorten herkend
TrailBlazer schreef op donderdag 06 januari 2005 @ 21:08:
ja dat is meesterlijk... vooral als je tijdens het configen de vraag erase Flash: krijgt en dan antwoord ja :P
nog leuker als je een CCO contract voor een 3750 heb (3 jaar lang)
en je wist toevallig een nieuwbinnen gekomen 1721 ... feest
* Duinkonijn spreekt uit ervaring :X grml
om maar niet over de activering van CCO contracten te praten (almere kent hij niet... amsterdam weer wel 8)7 met gevolg dat de support contracten op me huisadres staan ipv op me werk. met gevolg dat je sneller voor cisco op de stoep staat dan bij me thuis :P 8)7 )
[ Voor 42% gewijzigd door Duinkonijn op 06-01-2005 21:15 ]
  • Bor
  • Laatst online: 14:13
Bor
Coördinator Frontpage Admins / FP Powermod
01000010 01101111 01110010
Zonder support heb je geen recht op IOS versies.
Over Bor | Vraag & Aanbod feedback | Frontpagemoderatie Forum
  • Duinkonijn
Duinkonijn
Huh?
Bor_de_Wollef schreef op donderdag 06 januari 2005 @ 21:12:
mja maar de standaard IOS wordt alleen op de Flash geleverd.
niet op cd... dus het eerste wat je kan gaan doen is een cisco device gaan backuppen
  • TrailBlazer
TrailBlazer
Karnemelk FTW
Duinkonijn schreef op donderdag 06 januari 2005 @ 21:10:
GoldPartner zijn roelt :p
@ TS nee ik ga hem niet voor je downloaden ik geloof niet dat het bijgehouden wordt wil enkel geen gezeik hebben. Ik wil tweakers en mijn werk gewoon gescheiden houden met dit soort dingen heb ik ooit wel eens gezeik mee gehad.
bovendien het zou best kunnen dat je flash gewoon gaar is en je hem zo en zo weg kan flikkeren
[ Voor 5% gewijzigd door TrailBlazer op 06-01-2005 21:20 ]
  • nilski
mwoa, ik ga maar eens ff m'n rolodex raadplegen..
word hier wel schijtziek van. de flashkaart is ok, heb ik getest
[ Voor 44% gewijzigd door nilski op 06-01-2005 21:29 ]
WAZUUUUUUUP!!!!!
  • Duinkonijn
Duinkonijn
Huh?
TrailBlazer schreef op donderdag 06 januari 2005 @ 21:19:
hij vraagt er toch niet om :?
je kan eens bij cisco nederland gaan informeren of je wat kan regelen.
anders zou ik het niet weten.. winkels zullen het wel niet hebben
  • nilski
nou ja, bedankt voor de diagnose dan maar.. (zachtjes cisco vervloekend...)
WAZUUUUUUUP!!!!!
  • Meester_J
  • Laatst online: 31-08 19:56
staat er uberhaupt wel een image op je flash?
kan je gewoon met dir flash: opvragen geloof ik.
voor een cisco 1721 moet je de sy7-mz versie hebben om adsl, E1 en BGP ondersteuning te hebben, dus voor jou router zal ook zoiets gelden.
ik zie trouwens dat je een pcmcia flash kaart hebt... het kan zijn dat iemand dat ding in zijn laptop heeft gestopt, om bijvoorbeeld een file heen, en terug te kopieeren, maar dan is de IOS niet meer leesbaar voor de router. (FAT verprust ofzo), spreek uit ervaring... 8)7
in dat geval moet je hem er gewoon opnieuw opzetten vanaf de router.
moet je natuurlijk nog wel ff de goeie IOS downen...
[ Voor 48% gewijzigd door Meester_J op 06-01-2005 21:40 ]
  • nilski
nope, flashkaart is leeg. helaas peanutbutter
hmm, als je gold partner bent dan is dat een optie ja. niet als je een guest account hebt :(
[ Voor 63% gewijzigd door nilski op 06-01-2005 21:40 ]
WAZUUUUUUUP!!!!!
  • Lieuwe
  • Laatst online: 25-08 15:16
  • Meester_J
het ging dus om een 1400 series.... :9
c1400-k8osy-mz.123-12.bin
deze doet het wel denk ik
http://www.cisco.com/cgi-...type=Limited%20Deployment
mag je zelf een account regelen... :*)
[ Voor 82% gewijzigd door Meester_J op 06-01-2005 22:01 ]
  • TrailBlazer
TrailBlazer
Karnemelk FTW
exuses was niet zo grof bedoeld
  • nilski
nope, weer dezelfde melding;
Warning: Cisco IOS® Upgrade Planner - Authentication Failed
Ben helaas niet in het gelukkige bezit van een Cisco diploma of contract...
en op http://www.filesearching.com vind ik m ook niet :(
c1400-k8osy-mz.123-12.bin ? is dit niet de nieuwste IOS?
en ach kben niet zo snel op m'n pik getrapt hoor :P
[ Voor 80% gewijzigd door nilski op 06-01-2005 22:11 ]
WAZUUUUUUUP!!!!!
  • Duinkonijn
Duinkonijn
Huh?
nilski schreef op donderdag 06 januari 2005 @ 22:05:
je zit ook nog eens met de grote van je flash kaart :)
Dit is software die niet vrij te downloaden is. Wij gaan je dus ook niet helpen met dat vinden.
