Software en codecs heb ik allemaal opnieuw geinstalleerd!
Een eerder herstelpunt werkte ook niet.
uit het storingsrapportje kwam het volgende maar volgens mij is er niks verkeerds aan ik kon in ieder geval niks ontdekken.
Hij crasht op de thumbs volgens mij
Hierbij het storings rapportje
EventType : MCX P1 : sh.5.1.2700.2230 P2 : VideoGalleryPage
P3 : NullRef P4 : UIHelper_GetVideoThumbnail P5 : 0
P6 : GetImageForFile P7 : Run
C:\WINDOWS\medctroc.log
Initialize setup: MedCtrOC.DLL 11/17/04 15:20:27
[freestyle - OC_PREINITIALIZE]
- complete
[freestyle - OC_INIT_COMPONENT]
OnOcInitComponent enter
OnOcInitComponent leave
- complete
[freestyle - OC_QUERY_STATE]
- complete
[freestyle - OC_CALC_DISK_SPACE]
g_SetupInfo.ComponentInfHandle = 0x00f7dc28
addComponent = TRUE
Leaving OnCalcDiskSpace... rc = 0x0000000d
- complete
[freestyle - OC_WIZARD_CREATED]
- complete
- complete
[freestyle - OC_QUERY_CHANGE_SEL_STATE]
- complete
addComponent = TRUE
- complete
[freestyle - OC_QUEUE_FILE_OPS]
OnQueueFileOps early out 1
- complete
OnQueueFileOps: SubcomponentId = freestyle
OnQueueFileOps, state = 1
Pid is 76396-OEM-0080661-98115
PID is OEM
Sequence # is 806098115
PID is in eHome range
Current install is not a slipstream upgrade.
OnQueueFileOps: Writing entry 'SYSTEM\WPA\MedCtrUpg', 'IsLegacyMCE' = 0x00000000.
Modifying the Boot.ini File
C:\boot.ini is Read-only
File attributes to apply to C:\boot.ini : 0x00000026.
Writing "Windows XP Media Center Edition" /noexecute=optin /fastdetect to C:\boot.iniSetting C:\boot.ini back to Read-only
CallPrivateFunction to netfx returned 0x00000000
CallPrivateFunction to WinPlus returned 0x00000000
Forcing creation of "Shared Video directory"...
SetupInstallFilesFromInfSection [freestyle] successful
- complete
[freestyle - OC_QUERY_STEP_COUNT]
- complete
- complete
[freestyle - OC_ABOUT_TO_COMMIT_QUEUE]
- complete
- complete
[freestyle - OC_COMPLETE_INSTALLATION]
- complete
SetupInstallFromInfSection [freestyle] successful.
Installing sections specific to Fresh installsSetupInstallFromInfSection [Freestyle_Fresh] successful
SetupInstallServicesFromInfSection [freestyle] successful. (Error status: 0x00000000).
- complete
- complete
[freestyle - OC_CLEANUP]
- complete
C:\WINDOWS\eHome\medctrro.exe
Will not add pre-Jitt assemblies
Will not add managed assemblies to the list of fully trusted assemblies
Will use a different inf name
Instruction file will be changed to 'C:\WINDOWS\inf\sonic.inf'
Will run in registration mode
Version 5.1.2700.2180
The System is not identified as a Media Center PC, will continue anyway
Parsing command line
Instruction file changed to 'C:\WINDOWS\inf\sonic.inf'
Initialize in Registration mode: 11/17/04 15:29:06
Successfully created configuration mutex "MCEConfigInProgress"
Opening inf file 'C:\WINDOWS\inf\sonic.inf'
Section [Managed_Exes] is not present in the inf file: will not process
Section [EHome_Self_Registering] is not present in the inf file: will not process
Section [System32_Self_Registering] is not present in the inf file: will not process
Section [RegASM] is not present in the inf file: will not process
Section [Strong_Named] is not present in the inf file: will not process
Section [Services] is not present in the inf file: will not process
Section [COM_servers] is not present in the inf file: will not process
Section [Processes_To_Kill] is not present in the inf file: will not process
No pending file renames detected.
Self-registering assemblies...
No file to process in inf section [EHome_Self_Registering]
No file to process in inf section [System32_Self_Registering]
Processing Managed assemblies...
Removing existing native assemblies...
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete SonicMCEBurnEngine"
No file to process in inf section [Managed_Exes]
Prejitting assemblies...
By command-line parameter, won't pre-jitt the assemblies.
Removing existing DLLs from the GAC...
GACAssembliesAddRemove: File was already uninstalled from the GAC (SonicMCEBurnEngine)
Adding existing DLLs to the GAC...
GACAssembliesAddRemove: Added (C:\WINDOWS\eHome\CreateDisc\SonicMCEBurnEngine.dll) to the GAC
By command-line parameter, won't add the assembly to the list of fully trusted assemblies.
Registering Managed assemblies (RegASM)
No file to process in inf section [RegASM]
Registering services and COM objects...
No file to process in inf section [Services]
No file to process in inf section [COM_servers]
Restarting Services...
Warning: No services are listed to restart.
Checking the status of ehSched and other processes
Service ehsched is running
Searching for process: 'ehrec.exe'.
Process "ehrec.exe" is not running.
Searching for process: 'ehtray.exe'.
Process "ehtray.exe" is not running.
Searching for process: 'ehshell.exe'.
Process "ehshell.exe" is not running.
Completed MedCtrOC (MedCtrRO.exe) in Registration mode: 11/17/04 15:29:06
C:\WINDOWS\ehome\medctrro.exe
Will execute optional setup tasks
Initialize in Registration mode: 11/17/04 15:33:35
Opening inf file 'C:\WINDOWS\inf\mcdftreg.inf'
SetupFindFirstLine failed: The section EHome_Self_Registering might be empty: 0xe0000102
Executing line "C:\WINDOWS\system32\regsvr32.exe /s C:\WINDOWS\system32\sbe.dll"
Executing line "C:\WINDOWS\system32\regsvr32.exe /s C:\WINDOWS\system32\quartz.dll"
Executing line "C:\WINDOWS\system32\regsvr32.exe /s C:\WINDOWS\system32\encdec.dll"
Executing line "C:\WINDOWS\system32\regsvr32.exe /s C:\WINDOWS\system32\VBICodec.ax"
Executing line "C:\WINDOWS\system32\regsvr32.exe /s C:\WINDOWS\system32\WSTPager.ax"
Executing line "C:\WINDOWS\system32\regsvr32.exe /s C:\WINDOWS\system32\WSTRenderer.ax"
Executing line "C:\WINDOWS\system32\regsvr32.exe /s C:\WINDOWS\system32\Mpeg2Data.ax"
Executing line "C:\WINDOWS\system32\regsvr32.exe /s C:\WINDOWS\system32\msvidctl.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete ehiwmp"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete ehiExtens"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete ehRecObj"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete ehCIR"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete ehepgdat"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete ehiPlay"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete ehiProxy"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete ehiuserxp"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete ehiVidCtl"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete ehiMsgr"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete ehepg"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete EhCM"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete ehcommon"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete bdatunepia"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete ehiWUapi"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete Microsoft.MediaCenter"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete ehshell"
GACAssembliesAddRemove: File was already uninstalled from the GAC (ehiwmp)
GACAssembliesAddRemove: File was already uninstalled from the GAC (ehiExtens)
GACAssembliesAddRemove: File was already uninstalled from the GAC (ehRecObj)
GACAssembliesAddRemove: File was already uninstalled from the GAC (ehCIR)
GACAssembliesAddRemove: File was already uninstalled from the GAC (ehepgdat)
GACAssembliesAddRemove: File was already uninstalled from the GAC (ehiPlay)
GACAssembliesAddRemove: File was already uninstalled from the GAC (ehiProxy)
GACAssembliesAddRemove: File was already uninstalled from the GAC (ehiuserxp)
GACAssembliesAddRemove: File was already uninstalled from the GAC (ehiVidCtl)
GACAssembliesAddRemove: File was already uninstalled from the GAC (ehiMsgr)
GACAssembliesAddRemove: File was already uninstalled from the GAC (ehepg)
GACAssembliesAddRemove: File was already uninstalled from the GAC (EhCM)
GACAssembliesAddRemove: File was already uninstalled from the GAC (ehcommon)
GACAssembliesAddRemove: File was already uninstalled from the GAC (bdatunepia)
GACAssembliesAddRemove: File was already uninstalled from the GAC (ehiWUapi)
GACAssembliesAddRemove: File was already uninstalled from the GAC (Microsoft.MediaCenter)
GACAssembliesAddRemove: Added (C:\WINDOWS\eHome\ehiwmp.dll) to the GAC
GACAssembliesAddRemove: Added (C:\WINDOWS\eHome\ehiExtens.dll) to the GAC
GACAssembliesAddRemove: Added (C:\WINDOWS\eHome\ehRecObj.dll) to the GAC
GACAssembliesAddRemove: Added (C:\WINDOWS\eHome\ehCIR.dll) to the GAC
GACAssembliesAddRemove: Added (C:\WINDOWS\eHome\ehepgdat.dll) to the GAC
GACAssembliesAddRemove: Added (C:\WINDOWS\eHome\ehiPlay.dll) to the GAC
GACAssembliesAddRemove: Added (C:\WINDOWS\eHome\ehiProxy.dll) to the GAC
GACAssembliesAddRemove: Added (C:\WINDOWS\eHome\ehiuserxp.dll) to the GAC
GACAssembliesAddRemove: Added (C:\WINDOWS\eHome\ehiVidCtl.dll) to the GAC
GACAssembliesAddRemove: Added (C:\WINDOWS\eHome\ehiMsgr.dll) to the GAC
GACAssembliesAddRemove: Added (C:\WINDOWS\eHome\ehepg.dll) to the GAC
GACAssembliesAddRemove: Added (C:\WINDOWS\eHome\EhCM.dll) to the GAC
GACAssembliesAddRemove: Added (C:\WINDOWS\eHome\ehcommon.dll) to the GAC
GACAssembliesAddRemove: Added (C:\WINDOWS\eHome\bdatunepia.dll) to the GAC
GACAssembliesAddRemove: Added (C:\WINDOWS\eHome\ehiWUapi.dll) to the GAC
GACAssembliesAddRemove: Added (C:\WINDOWS\eHome\Microsoft.MediaCenter.dll) to the GAC
Disable CASPOL prompting...
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -pp off"
Adding managed assemblies to the list of trusted assemblies...
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -af C:\WINDOWS\eHome\ehiwmp.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -af C:\WINDOWS\eHome\ehiExtens.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -af C:\WINDOWS\eHome\ehRecObj.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -af C:\WINDOWS\eHome\ehCIR.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -af C:\WINDOWS\eHome\ehepgdat.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -af C:\WINDOWS\eHome\ehiPlay.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -af C:\WINDOWS\eHome\ehiProxy.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -af C:\WINDOWS\eHome\ehiuserxp.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -af C:\WINDOWS\eHome\ehiVidCtl.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -af C:\WINDOWS\eHome\ehiMsgr.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -af C:\WINDOWS\eHome\ehepg.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -af C:\WINDOWS\eHome\EhCM.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -af C:\WINDOWS\eHome\ehcommon.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -af C:\WINDOWS\eHome\bdatunepia.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -af C:\WINDOWS\eHome\ehiWUapi.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -af C:\WINDOWS\eHome\Microsoft.MediaCenter.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -af C:\WINDOWS\eHome\ehshell.exe"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\RegAsm.exe /noLogo /codebase C:\WINDOWS\eHome\ehRecObj.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\RegAsm.exe /noLogo /codebase C:\WINDOWS\eHome\ehCIR.dll"
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\RegAsm.exe /noLogo /codebase C:\WINDOWS\eHome\ehepgdat.dll"
Executing line "C:\WINDOWS\eHome\ehSched /unregServer"
Executing line "C:\WINDOWS\eHome\ehRecvr /unregServer"
Executing line "C:\WINDOWS\eHome\ehSched /service"
Executing line "C:\WINDOWS\eHome\ehRecvr /service"
Executing line "C:\WINDOWS\eHome\ehRec.exe /regserver"
Executing line "C:\WINDOWS\eHome\ehmsas.exe /regserver"
Registering Fonts
Successfully added Font resource segmcr.ttf: number of fonts added: 1
Successfully added Font resource segmcsb.ttf: number of fonts added: 1
Changing value ENTRY "Link1" of Registry Key "HKLM\Software\Microsoft\Windows\CurrentVersion\SMDEn".
Completed MedCtrOC (MedCtrRO.exe) in Registration mode: 11/17/04 15:33:42
Initialize setup: MedCtrOC.DLL 11/17/04 16:16:52
- complete
- complete
- complete
g_SetupInfo.ComponentInfHandle = 0x00c54c80
addComponent = TRUE
- complete
- complete
Instruction file will be changed to 'C:\WINDOWS\INF\kb888316rg.inf'
Will run in unregister mode
The System is identified as a Media Center PC
Instruction file changed to 'C:\WINDOWS\INF\kb888316rg.inf'
Initialize in UnRegister mode: 12/01/04 22:12:46
Opening inf file 'C:\WINDOWS\INF\kb888316rg.inf'
SetupFindFirstLine failed: The section System32_Self_Registering might be empty: 0xe0000102
SetupFindFirstLine failed: The section RegASM might be empty: 0xe0000102
SetupFindFirstLine failed: The section COM_servers might be empty: 0xe0000102
Unregister Services...
KillProcess: Process (ehmsas.exe) was terminated.
KillProcess: Process (ehshell.exe) could not be terminated because it was not running.
KillProcess: Process (ehtray.exe) was terminated.
Stopping service 'ehSched'
Stopping service 'ehRecvr'
Completed MedCtrOC (MedCtrRO.exe) in UnRegister mode: 12/01/04 22:12:47
Initialize setup: MedCtrOC.DLL 12/01/04 22:12:50
- complete
- complete
- complete
g_SetupInfo.ComponentInfHandle = 0x01360ba8
addComponent = TRUE
- complete
- complete
Initialize in Registration mode: 12/01/04 22:16:53
GACAssembliesAddRemove: Removed (ehepg) from the GAC
Starting service 'ehSched'
Launched service 'ehSched'
Starting service 'ehRecvr'
Launched service 'ehRecvr'
Completed MedCtrOC (MedCtrRO.exe) in Registration mode: 12/01/04 22:17:03
Version 5.1.2700.2230
Initialize in UnRegister mode: 12/11/04 19:01:34
Executing line "C:\WINDOWS\eHome\ehRec.exe /unregServer"
Executing line "C:\WINDOWS\eHome\ehmsas.exe /unregServer"
Completed MedCtrOC (MedCtrRO.exe) in UnRegister mode: 12/11/04 19:01:34
Initialize setup: MedCtrOC.DLL 12/11/04 19:01:38
- complete
- complete
- complete
g_SetupInfo.ComponentInfHandle = 0x0017e688
addComponent = TRUE
- complete
- complete
Instruction file will be changed to 'C:\WINDOWS\INF\MCUpd1rg.inf'
Instruction file changed to 'C:\WINDOWS\INF\MCUpd1rg.inf'
Initialize in Registration mode: 12/11/04 19:05:16
Opening inf file 'C:\WINDOWS\INF\MCUpd1rg.inf'
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\ngen.exe /nologo /delete ehiproxy"
GACAssembliesAddRemove: Removed (ehRecObj) from the GAC
GACAssembliesAddRemove: Removed (EhCM) from the GAC
GACAssembliesAddRemove: Removed (ehcommon) from the GAC
GACAssembliesAddRemove: Removed (ehepgdat) from the GAC
GACAssembliesAddRemove: Removed (ehiproxy) from the GAC
GACAssembliesAddRemove: Added (C:\WINDOWS\eHome\ehiproxy.dll) to the GAC
Executing line "C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\caspol.exe -af C:\WINDOWS\eHome\ehiproxy.dll"
Process "ehtray.exe" is running.
Completed MedCtrOC (MedCtrRO.exe) in Registration mode: 12/11/04 19:06:02
Initialize setup: MedCtrOC.DLL 12/15/04 19:13:06
- complete
- complete
- complete
g_SetupInfo.ComponentInfHandle = 0x00ce6ac8
addComponent = TRUE
- complete
- complete
Initialize setup: MedCtrOC.DLL 12/15/04 19:13:14
- complete
- complete
- complete
g_SetupInfo.ComponentInfHandle = 0x0017ece0
addComponent = TRUE
- complete
- complete
Initialize setup: MedCtrOC.DLL 12/15/04 19:13:18
- complete
- complete
- complete
g_SetupInfo.ComponentInfHandle = 0x0017e0b0
addComponent = TRUE
- complete
- complete
Initialize setup: MedCtrOC.DLL 12/15/04 19:13:27
- complete
- complete
- complete
g_SetupInfo.ComponentInfHandle = 0x00ca23b0
addComponent = TRUE
- complete
- complete
Initialize setup: MedCtrOC.DLL 12/31/04 12:38:23
- complete
- complete
- complete
g_SetupInfo.ComponentInfHandle = 0x00c841e8
addComponent = TRUE
- complete
- complete
Initialize setup: MedCtrOC.DLL 01/03/05 15:32:07
- complete
- complete
- complete
g_SetupInfo.ComponentInfHandle = 0x0157c8e0
addComponent = TRUE
- complete
- complete
- complete
- complete
addComponent = TRUE
- complete
- complete
alvast bedankt voor degene die een oplossing weet
Voor 5% gewijzigd door
Verwijderd op 03-01-2005 19:57
