Hoi, dit is vast simpel om op te lossen maar ik kwam er niet uit
Ik heb namelijk geen verstand van Javascript
. Ik had een preload script van Macromedia exchange gedownload en hij doet het helemaal das goed, maar wat ik nu wil is dat hij naar een netscape optimised page gaat of naar een explorer optimized page als hij klaar is met laden. Snappie?
dit is de code:
<script language="JavaScript1.1">
var locationAfterPreload = "main.html" //dit wil ik dus variabel hebben
var lengthOfPreloadBar = 304 // Length of preload bar (in pixels)
var heightOfPreloadBar = 18 // Height of preload bar (in pixels)
// Put the URLs of images that you want to preload below (as many as you want)
var yourImages = new Array("[..knip..]")
// Do not modify anything beyond this point!
if (document.images) {
var dots = new Array()
dots[0] = new Image(1,1)
dots[0].src = "images/px_black.gif" // default preloadbar color (note: You can substitute it with your image, but it has to be 1x1 size)
dots[1] = new Image(1,1)
dots[1].src = "images/px_grey.gif" // color of bar as preloading progresses (same note as above)
var preImages = new Array(),coverage = Math.floor(lengthOfPreloadBar/yourImages.length),currCount = 0
var loaded = new Array(),i,covered,timerID
var leftOverWidth = lengthOfPreloadBar%coverage
function loadImages() {
for (i = 0; i < yourImages.length; i++) {
preImages[i] = new Image()
preImages[i].src = yourImages[i]
for (i = 0; i < preImages.length; i++) {
loaded[i] = false
checkLoad()
function checkLoad() {
if (currCount == preImages.length) {
location.replace(locationAfterPreload)
return
for (i = 0; i <= preImages.length; i++) {
if (loaded[i] == false && preImages[i].complete) {
loaded[i] = true
eval("document.img" + currCount + ".src=dots[1].src")
currCount++ }
timerID = setTimeout("checkLoad()",10)
// end hiding -->
</script>
dit is de code:
loaded[i] = false
checkLoad()
return
loaded[i] = true
currCount++ }
// end hiding -->
</script>
