ADSL blijft diconnecten
01/01/1970 00:00:00> Ethernet Device 0 Detected
01/01/1970 00:00:00> ATM: Detected
01/01/1970 00:00:00> ATM: Setting up vcc0, VPI=0, VCI=35
01/01/1970 00:00:00> Initialized Dynamic NAPT.
01/01/1970 00:00:00> CfgMgr: 'Console.dlz' module loaded.
01/01/1970 00:00:00> CfgMgr: 'Shtm.dlz' module loaded.
01/01/1970 00:00:00> NAT/NAPT Session Start: interface ss0, WAN IP is 213.148.136.11
01/01/1970 00:00:00> No Static Session Information is defined.
01/01/1970 00:00:00> CfgMgr: 'Washer.dlz' module loaded.
01/01/1970 00:00:00> CfgMgr: 'Apimage.dlz' module loaded.
01/01/1970 00:00:13> ATM Connected
01/01/1970 00:00:13> ATM layer is up, cell delineation achieved
01/01/1970 00:00:13> ADSL connected
01/01/1970 00:06:37> ATM Disconnected
01/01/1970 00:06:37> ADSL disconnected
01/01/1970 00:06:45> ADSL detected
01/01/1970 00:06:51> ATM Connected
01/01/1970 00:06:51> ATM layer is up, cell delineation achieved
01/01/1970 00:06:51> ADSL connected
01/01/1970 00:08:32> ATM Disconnected
01/01/1970 00:08:32> ADSL disconnected
01/01/1970 00:08:37> ADSL detected
01/01/1970 00:08:43> ATM Connected
01/01/1970 00:08:43> ATM layer is up, cell delineation achieved
01/01/1970 00:08:43> ADSL connected
01/01/1970 00:10:24> ATM Disconnected
01/01/1970 00:10:24> ADSL disconnected
01/01/1970 00:10:30> ADSL detected
01/01/1970 00:10:36> ATM Connected
01/01/1970 00:10:36> ATM layer is up, cell delineation achieved
01/01/1970 00:10:36> ADSL connected
01/01/1970 00:13:52> ATM Disconnected
01/01/1970 00:13:52> ADSL disconnected
01/01/1970 00:13:56> ADSL detected
01/01/1970 00:14:02> ATM Connected
01/01/1970 00:14:02> ATM layer is up, cell delineation achieved
01/01/1970 00:14:02> ADSL connected
01/01/1970 00:18:46> Primary DNS not found!
01/01/1970 00:18:52> ATM Disconnected
01/01/1970 00:18:52> ADSL disconnected
01/01/1970 00:18:56> ADSL detected
01/01/1970 00:19:03> ATM Connected
01/01/1970 00:19:03> ATM layer is up, cell delineation achieved
01/01/1970 00:19:03> ADSL connected
01/01/1970 00:19:03> Primary DNS not found!
Ik heb een SMC 7204BRB met concepts.nl adsl aansluiting. Ik kan gewoon internetten en mijn mail doet het ook.
Maar als ik een mailing wil versturen dan heeft mijn mailprogramma het probleem : ünable to connect with DNS" Ik heb zo'n beetje alles al nagekeken wat mogelijk is zoals hand matig instellen, router als bridge instellen, maar volgens mij ligt het echt aan mijn verbinding. Hier is het log van mijn modem, zoals je kan zien is mijn adsl om de paar minuten disconnected, desondanks kan ik wel gewoon i'netten en mail versturen ontvangen, Mijn instant messenger blijft ook gewoon aan, op 2 of 3 keer per dag na dat hij wel de verbinding kwijt raakt.........
Ik weet het echt niet meer......
  • Br@m
Ik zie dat de datum staat op 1970. Kan dat geen invloed hebben op jou probleem :?
Garmin NUVI 300 - ACER Aspire 5102WLMi
  • joopv
Dit lijkt op een slechte adsl lijn.
Ik zou beginnen met het aansluiten van het adsl modem *direct* op je kpn doos, met zo weinig mogelijk kabels en stekkers er tussen.
Vervolgens eventueel een ander modem proberen als je daar gemakkelijk aan kunt komen.
Als het dan nog niet goed is, contact opnemen met je provider
  • DeadMetal
  • Laatst online: 07:49
Dit probleem had ik ook al maanden, en vorige week met dank aan de KPN storingsdienst eindelijk de oplossing gevonden. Het bleek dat op de stekker waar de telefoon het huis binnen komt roest/aanslag zit. Iets waar je normaal gesproken helemaal niet aan denkt. Tussen het ISRA-punt en de splitter dus. Die hebben wij verbonden met een traditionele 'varkensneus'-aansluiting, zoals dat heet. Daar zat die aanslag op. Op allevier de pootjes, en ja, al het internet en telefoonverkeer gaat daar overheen.
Bij jou zou het dat ook best kunnen zijn, want als ik naar je log kijk gaat hij NIET iedere keer opnieuw inbellen bij je provider (anders zou er steeds password accepted o.i.d. in de log staan), maar raakt hij de verbinding kwijt en vind hij hem even later weer terug.
Zeer waarschijnlijk dus binnenshuis, en begin bij het ISRA punt met zoeken naar de oorzaak.
  • Tetsuo55
  • Laatst online: 28-10-2025
Tetsuo55
*~*GrahF Emperor of Darkness*~
Br@m schreef op zaterdag 25 december 2004 @ 09:11:
Dat staat er omdat de ATM geen time-sync aan de modem geeft.
Ik heb al andere stekkertje geprobeerde zowel van het isra naar mijn modem als van mijn modem naar de computer, ook ben ik niet met zo'n varkensneus aangesloten maar met zo'n stekkertje op het isra punt direct zonder splitter.
Helaas heb ik geen ander modem liggen om te proberen
[ Voor 14% gewijzigd door Verwijderd op 25-12-2004 13:34 ]
