[ervaring] mitsubishi lvp-x70ux
iemand ervaring met Mitsubishi LVP-x70ux?
specs hier:
* Display technology: 0,9-inch polysillicon panel x 3
* Resolution: 1024 x 768 XGA (total 2,359,296 pixels)
* Brightness: 1100 ANSI lumens (Typical)
* Colors: 16,770,000
* Zoom / focus: Manually controlled (zoom ratio 1,3:1)
* Projection lens: F=1.7-2.0 f=33-43mm
* Picture size: 40” to 300” (102 to 762 cm) diagonal
* Source lamp: 150W UHP bulb; (Lamp Lifetime: 2,000 hours)
* Computer compatibility: Windows based PC, Macintosh, Sync. on green Resolution; VGA (640 x 400), SVGA (800x600), XGA (1024 x 768), SXGA Compressed (1280x 1024)
* Video compatibility: NTSC, NTSC4.43, PAL, SECAM, PAL-N, PAL-M, PAL-60, DVD, HDTV
* Scanning rates: Horizontal: 15~92kHz
o Vertical: 50~85kHz
o Dot clock: max 160 MHz
* Power consumption: 230W
* Power supply: AC100-240V+10%, 50/60Hz
* Dimensions (WxHxD): 242mm x 79mm x 294mm (excluding lens)
* Weight: 3.2kg / 7lbs
* Fan noise: 37db
Of kun je met dat geld (max. 450) betere beamer kopen?
raar is dat contrast onbekend is... heb ergens gelezen dat het 1:250 heeft maar of dat waar is.. :S (1:250 is toch niet genoeg?)
jascha
[ Voor 21% gewijzigd door Verwijderd op 21-12-2004 15:42 ]
kick...
iemand? :?
