Prince of persia Warrior Within - Vastlopers
Hey hallo
Ik heb sinds kort een nieuwe game. Prince of persia Warrior Within
Pc
P4 3.2 ghz
Schijf 120 gb
Video: leadtek winfast A340 TD [ GeFORCE FX 5200 128 mb]
En krijg nu de volgende fout
** Crash Report for: Prince of Persia
** Date: 12/19/2004 23:06:37
** Executable Size: 5,533,696
** Executable Time: Sat Dec 04 00:03:50 2004
-- DESCRIPTION --
Access Violation: Attempt to write data at 0x0BB64000
Error occured in thread: 0x000002F4 (756)
-- EXCEPTION --
Exception at: 0x3001C33F
Integer Registers: EDI=FFFCEB95 ESI=00000013 EAX=0BB64000 EBX =03922602 ECX =00000001 EDX =00026430
Control Registers: EBP=0012FB30 EIP=3001C33F ESP=0012F810 EFlags=00010297 SegCS=0000001B SegSS=00000023
-- MEMORY STATUS --
Load = 63 Total Physical = 535,826,432 Available Physical = 197,718,016
Total Virtual = 2,147,352,576 Available Virtual = 1,824,448,512
-- MODULES LIST --
Module: D:\Prince of Persia Warrior Within\POP2.exe Size: 10,256,470 Base Adress: 0x00400000
Module: C:\WINDOWS\system32\ntdll.dll Size: 745,472 Base Adress: 0x7C900000
Module: C:\WINDOWS\system32\kernel32.dll Size: 1,040,384 Base Adress: 0x7C800000
Module: C:\WINDOWS\system32\USER32.dll Size: 589,824 Base Adress: 0x77D10000
Module: C:\WINDOWS\system32\GDI32.dll Size: 286,720 Base Adress: 0x77E40000
Module: C:\WINDOWS\system32\ADVAPI32.dll Size: 700,416 Base Adress: 0x77F40000
Module: C:\WINDOWS\system32\RPCRT4.dll Size: 593,920 Base Adress: 0x77DA0000
Module: D:\Prince of Persia Warrior Within\EAX.DLL Size: 126,976 Base Adress: 0x10000000
Module: C:\WINDOWS\system32\ole32.dll Size: 1,294,336 Base Adress: 0x774A0000
Module: C:\WINDOWS\system32\msvcrt.dll Size: 360,448 Base Adress: 0x77BE0000
Module: C:\WINDOWS\system32\DINPUT8.dll Size: 233,472 Base Adress: 0x6D320000
Module: C:\WINDOWS\system32\DSOUND.dll Size: 376,832 Base Adress: 0x73E80000
Module: C:\WINDOWS\system32\WINMM.dll Size: 188,416 Base Adress: 0x76AF0000
Module: C:\WINDOWS\system32\VERSION.dll Size: 32,768 Base Adress: 0x77BD0000
Module: C:\WINDOWS\system32\d3d9.dll Size: 1,728,512 Base Adress: 0x4FD10000
Module: C:\WINDOWS\system32\d3d8thk.dll Size: 24,576 Base Adress: 0x6DEB0000
Module: D:\Prince of Persia Warrior Within\binkw32.dll Size: 466,944 Base Adress: 0x30000000
Module: C:\WINDOWS\system32\serwvdrv.dll Size: 28,672 Base Adress: 0x5D1A0000
Module: C:\WINDOWS\system32\umdmxfrm.dll Size: 28,672 Base Adress: 0x5B4C0000
Module: C:\WINDOWS\system32\IMAGEHLP.DLL Size: 163,840 Base Adress: 0x76C50000
Module: C:\PROGRA~1\NEWDOT~1\NEWDOT~2.DLL Size: 245,760 Base Adress: 0x02020000
Module: C:\WINDOWS\system32\OLEAUT32.dll Size: 573,440 Base Adress: 0x770E0000
Module: C:\WINDOWS\system32\urlmon.dll Size: 647,168 Base Adress: 0x77220000
Module: C:\WINDOWS\system32\SHLWAPI.dll Size: 483,328 Base Adress: 0x77E90000
Module: C:\WINDOWS\system32\WS2_32.dll Size: 94,208 Base Adress: 0x71A30000
Module: C:\WINDOWS\system32\WS2HELP.dll Size: 32,768 Base Adress: 0x71A20000
Module: C:\WINDOWS\system32\WININET.dll Size: 684,032 Base Adress: 0x77170000
Module: C:\WINDOWS\system32\CRYPT32.dll Size: 610,304 Base Adress: 0x77A40000
Module: C:\WINDOWS\system32\MSASN1.dll Size: 73,728 Base Adress: 0x77AE0000
Module: C:\WINDOWS\system32\SETUPAPI.dll Size: 1,011,712 Base Adress: 0x778E0000
Module: C:\WINDOWS\system32\MPR.dll Size: 73,728 Base Adress: 0x71AA0000
Module: C:\WINDOWS\system32\WINTRUST.dll Size: 188,416 Base Adress: 0x76BF0000
Module: C:\WINDOWS\system32\SHELL32.dll Size: 8,515,584 Base Adress: 0x7C9C0000
Module: C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2180_x-ww_a84f1ff9\comctl32.dll Size: 1,056,768 Base Adress: 0x77390000
Module: C:\WINDOWS\system32\comctl32.dll Size: 618,496 Base Adress: 0x5D4E0000
Module: C:\WINDOWS\system32\CLBCATQ.DLL Size: 520,192 Base Adress: 0x76F90000
Module: C:\WINDOWS\system32\COMRes.dll Size: 839,680 Base Adress: 0x77010000
Module: C:\WINDOWS\system32\wdmaud.drv Size: 36,864 Base Adress: 0x72C90000
Module: C:\WINDOWS\system32\msacm32.drv Size: 32,768 Base Adress: 0x72C80000
Module: C:\WINDOWS\system32\MSACM32.dll Size: 86,016 Base Adress: 0x77BB0000
Module: C:\WINDOWS\system32\midimap.dll Size: 28,672 Base Adress: 0x77BA0000
Module: C:\WINDOWS\system32\KsUser.dll Size: 16,384 Base Adress: 0x73E50000
Module: C:\WINDOWS\system32\HID.DLL Size: 36,864 Base Adress: 0x68DB0000
-- STACK WALK --
Address: 0x3001C33F Return : 0x00000000 Frame : 0x0BB32B95 Stack : 0x00000000
Address: 0x0BB32B95 Return : 0x00000000 Frame : 0x06060202 Stack : 0x00000000
Address: 0x06060202 Return : 0x00000000 Frame : 0x00000000 Stack : 0x00000000
Kan iemand me helpen met wat voor een fout dit is
  • Luppie
  • Laatst online: 01-03 23:21
Luppie
www.msxinfo.net
Kan zoveel zijn, maar het lijkt er op dat je geheugen niet helemaal lekker is. Probeer eens een nieuw bankje ram.
Heb je iets aan mijn antwoord ? Een thumbs-up wordt zeker op prijs gesteld.
  • Sir Baxx
  • Laatst online: 17:46
Als ik zo het lijstje bekijk, ligt het misschien aan de geluidskaart. Misschien dat je je drivers even kunt updaten?
En anders spel opnieuw installeren. (savegames behoudt je meestal als het goed is).
  • Thandor
  • Laatst online: 21:22
Thandor
SilverStreak
Welke drivers heb je voor de videokaart :?
Je zou eens kunnen proberen om andere (nieuwere én oudere) te installeren :)
Het kan zó veel zijn:
Rot geheugen
Rotte videokaart
Rotte drivers videokaart
Rotte drivers moederbord
Rotte CPU (één pin voor power krom)
Voeding die nét onder de grens zakt
Harddisk stuk
Game is incompatible met je processor (vreemd, maar kan).
Rotte drivers voor je [hier device invullen]
IRQ probleem
Nou ik heb alle updates gedaan
op me laptop getest
en op desktop
vind het allemaal maar raar
allebei zijn beide net nieuw
maja 1 nadeel het is dell..
Breng de game wel terug ....
  • Mentalist
  • Laatst online: 28-09 17:25
Mentalist
[avdD]
Niet echt een OH onderwerp..
Move :
Overige Hardware -> Spielerij - Problemen & Vragen
Wel kan Hangen en Opstartproblemen troubleshooter nuttig zijn. Test b.v. je geheugen met memtest, zo kan je hardware zoveel mogelijk uitsluiten.
Verstuurd vanaf mijn Computer®
Test eerst maar-es of die bak wel goed is. Het is mss geen sterke bak, maar test eerst maar eens.
