[ATi] Catalyst 4.12 uit!
  • 224 views sinds 30-01-2008
  • Pubbert
  • Laatst online: 14:52
Pubbert
random gestoord
Catalyst 4.12
Download: http://www.ati.com/support/driver.html
Releasenotes: http://www2.ati.com/drivers/Catalyst_412_release_notes.html
  • New Features This section provides information on new features introduced in the latest release of the CATALYST™ Software Suite. New features include: Problem Report Wizard for the CATALYST™ CONTROL CENTER OVERDRIVE™ Version 3.0 Problem Report Wizard for the CATALYST™ CONTROL CENTER The latest release of CATALYST™ introduces a new menu item in the CATALSYT™ CONTROL CENTER Help dashboard called Problem Report Wizard. This feature will provide all of the same Problem Report Wizard functionality found in the current ATI CLASSIC CONTROL PANEL to the CATALYST™ CONTROL CENTER. OVERDRIVE™ Version 3.0 The latest release of CATALYST™ introduces OVERDRIVE™ version 3.0 for the RADEON™ X850 XT. This version of OVERDRIVE™ will allow users to manually set the graphic and memory clocks, while still protecting the user from causing damage to their graphic card. OVERDRIVE™ version 3.0 also provides an optional automated search for maximum clock speeds. This feature is supported under both the Windows XP and 2000 operating systems Performance Improvements for CATALYST™ Display Driver Version 4.12 As with most CATALYST™ releases performance has increased in various situations. The following performance gains are noticed: Driver efficiency has improved considerably for both Direct3D and OpenGL. Numerous D3D games show 2-3% gains at low resolution. The small batch size tests in 3DMark05 show improvements as large as 15% on some products. In OpenGL, several game titles show improvements in the lower settings. Wolfenstein - Enemy Territory, for instance, shows gains as large as 15% in low resolution (driver-bound) cases. Doom III performance improves 5-10% at low settings. Call of Duty improves 5-6%. Half-Life 2 performance also improves as much as 20% over Catalyst 4.11 in certain sections of the game. Issues Resolved in CATALYST™ Display Driver Version 4.12 The following section provides a summary of issues that have been resolved in the latest version of CATALYST™. These include: Half-Life 2: Playing the game on a system containing an Athlon XP CPU no longer results in missing textures occationally being noticed Half-Life 2: Intermittent psychedelic patterns are no longer seen when playing the game under Windows XP CounterStrike: Playing the game under Windows XP with an ATI RADEON™ X800 series installed no longer results in display corruption being seen in the floor in de_chateau map Doom 3: Playing the game under Windows XP with an ATI RADEON™ X800 XT Platinum Edition no longer results in display corruption being seen when pressing CTRL+Alt+Delete followed by clicking Cancel Everquest: Playing the game under Windows XP with an ATI RADEON™ X800 XT Platinum Edition installed results in the game displaying a black screen when setting the texture quality to high and having all radio buttons selected Medal of Honor: Pacific Assault: Setting the model detail to high and change the game resolution to high no longer results in the game failing to respond under Windows XP with an ATI RADEON™ X800 series installed Tron2.0: Setting the display device resolution to 1280x1024 32bpp and setting the display option for the game to 800x600 32bpp no longer results in display corruption being seen in the game cinematics Star Wars Knights of the Old Republic: Playing the game under Windows XP with an ATI RADEON™ X800 series installed no longer results in triple buffering failing when enabling the option in the CATALYST™ CONTROL CENTER Attempting to rotate the display 90 degrees and play an OpenGL game under Windows XP may result in the game failing to launch Enabling clone mode along with theatre mode option under overlay no longer results in WinDVD and the operating system failing to respond when dragging the WinDVD window around the desktop Display corruption is no longer noticed when playing a DVD using WinDVD and having subtitles enabled under Windows XP with an ATI RADEON™ X800 series installed Attempting to make a change to a saved profile within the CATALYST™ CONTROL CENTER no longer results in the Save button being greyed out Connecting a secondary CRT and clicking the X button to close the Enable this display window found in the CATALYST™ CONTROL CENTER Advanced view, no longer results in the window not closing Muting the audio during the playback of full screen HDTV video under Windows Media Center Edition no longer results in the video being paused Angle information in the rotation modes is now correct for the CATALYST™ CONTROL CENTER Enabling Overscan under Windows XP with an ATI ALL-IN-WONDER™ 9600 installed no longer results in the image not being centered properly on the display device Connecting a secondary CRT display device and extending the desktop, followed by unplugging the secondary device and hot-plugging a DFP device no longer results in the DFP remaining in the Additional display area when attempting to swap devices The Windows desktop brightness no longer dims when playing a DVD and having an HDTV connected as the primary display device Playing a DVD under Windows XP MCE with an ATI RADEON™ X800 XT installed no longer results in VPU Recover being activated when attempting to drag or resize the Media Center window An error message is no longer displayed when attempting to switch a secondary display device back to the primary display device when using the CATALYST™ CONTROL CENTER
[ Voor 76% gewijzigd door Pubbert op 14-12-2004 09:57 ]
  • Griffin
  • Laatst online: 31-03 12:34
Griffin
Is mythical
vanaaf maar even kijken of het wat is.
het moet vooral met COD goed lopen. ik loop momenteel namelijk nog wat achter met de drivertjes. volgens mij op 4.7 of 4.8 de andere heb ik gehoord dat ze niet super zijn met COD / COD UO
PS: als ik 4.12 niet super vind kan ik dan gewoon weer naar mijn oude terug schakelen door de setup te draaien. of moet ik eerst de 4.12 removen met iets ofzo.
[ Voor 27% gewijzigd door Griffin op 14-12-2004 12:08 ]
  • Dekaasboer
  • Laatst online: 17:50
Ik gebruikte de Beta al en die werkte perfect op mijn 9800pro->XT een must voor HL2
http://axrotterdam.blogspot.nl
Is er een meetbaar / merkbaar verschil met de 4.11 driver?
  • enchion
Vraagje
Zijn er meer mensen die er last van hebben dat alles ineens langzamer loopt , omdat hardware accelleration geforceerd uit staat.
In dxdiag staan bij mij alle 3d settings op "not available" maar alle testen die in dat progje staan werken gewoon goed .
Die halflife bugfixen vind ik erg belangrijk , daarom wil ik graag dat deze driver gaat werken.
Dus als iemand mij hiermee kan helpen . :*)
O`ja k heb een R9700 icm een athlon xp
[ Voor 4% gewijzigd door enchion op 14-12-2004 12:20 ]
How do you save a random generator ?
  • TwistedAnimator
  • Laatst online: 05-03 17:56
Griffin schreef op dinsdag 14 december 2004 @ 10:11:
http://ati.com/support/drivers/misc/catalystutils.html
download de Catalyst Uninstaller en verwijder daar je drivers mee, rebooten en de nieuwe installeren ;)
[ Voor 33% gewijzigd door TwistedAnimator op 14-12-2004 12:25 ]
  • MaTr1x
  • Laatst online: 11-03 12:33
Verwijderd schreef op dinsdag 14 december 2004 @ 10:50:
Uit de 4.12 release notes:
* Driver efficiency has improved considerably for both Direct3D and OpenGL.
* Numerous D3D games show 2-3% gains at low resolution. The small batch size tests in 3DMark05 show improvements as large as 15% on some products.
* In OpenGL, several game titles show improvements in the lower settings. Wolfenstein - Enemy Territory, for instance, shows gains as large as 15% in low resolution (driver-bound) cases. Doom III performance improves 5-10% at low settings. Call of Duty improves 5-6%.
* Half-Life 2 performance also improves as much as 20% over Catalyst 4.11 in certain sections of the game.
Vooral de laatste regel klinkt interessant.
π MW finishers
  • enchion
Cat uninstall heeft mijn probleem ook verholpen
Vanuit add-remove programs uninstallen is dus niet goed genoeg.
thanks . ;)
  • greatgonzo
  • Laatst online: 16:58
greatgonzo
schit-te-rend!
vraagje, heb nu 4.12 beta, met de laatste dna drivers (die dus ook geoptimaliseerd zijn voor HL2)
Wat kan ik nu het beste doen, 4.12 beta en dna eraf halen en 4.12 erop zetten, of 4.12 met dna drivers erop zetten?
  • Griffin
Griffin
Is mythical
TwistedAnimator schreef op dinsdag 14 december 2004 @ 12:23:
thnx m8.
nu ga ik thuis eerst alles van catalist verwijderen. dan 4.12 erop. loopt alles goed dan laten we het zo. anders 4.12 eraf en dan 4. .. erop
  • Nemesizz
  • Laatst online: 13:15
Nemesizz
Untouchable
Ik gebruik momenteel nog Cat 4.10...misschien toch maar eens 4.12 gaan uitproberen.
En dan hopen dat de driver goed is (want soms werken nieuwe drivers totaal niet goed met m'n kaart...) en 4.11 heb ik niet geprobeert omdat 4.10 het perfect deed.
  • greatgonzo
greatgonzo
schit-te-rend!
beetje gemengde gevoelens:
Hl2 stress test
1024*768
Beta: 40.82
Final 50.90
Behoorlijke verbertering dus, maar met de beta draaide het ook nog redelijk soepel op 1280*1024
Beta 39.04
Final: foutmelding:
Afbeeldingslocatie: http://img93.exs.cx/img93/8269/hl24ol.jpg
Iemand die weet hoe ik dit kan oplossen?
  • lemming_nl
greatgonzo schreef op dinsdag 14 december 2004 @ 18:55:
Hl2 stress test
1024*768
Beta: 40.82
Final 50.90
Beta 39.04
Final: foutmelding:
Ik weet niet zeker maar volgens mij heeft het wat met de fast-write functie te maken. Ik zou proberen die eens uit te zetten
Geluk is een weerloos oud vrouwtje, alleen op straat met een bom geld
  • freshy98
  • Laatst online: 11:13
freshy98
Atari
Hl2 stress test
1024*768
Beta: 40.82
Final 50.90
Beta 39.04
Final: foutmelding:
Je foutmelding staat hier beschreven.
Ik heb zelf de VPU Recover optie uitgezet, en de vsync in HL2 zelf. Welke van de twee precies hielp weet ik niet. Geen zin om het te checken, maar beide staan op de link genoemd.
Dit is met 4.11 trouwens. 4.12 moet ik nog installeren.
Succes!
[ Voor 8% gewijzigd door freshy98 op 14-12-2004 19:02 ]
  • Phyxion
Phyxion
_/-\o_
Hl2 stress test
1024*768
Beta: 40.82
Final 50.90
Beta 39.04
Final: foutmelding:
Ik heb ook vaak zulke errors, maar niet alleen met HL2...
Wat ik wel weet is dat het aan het geheugen ligt, dat zijn dus de lage timings, of te hoog geclocked. Heb mijn vorige RAM vervongen, door Kingston HyperX, en nooit meer last van iets.
'You like a gay cowboy and you look like a gay terrorist.' - James May
  • silitek
  • Laatst online: 17-03 12:02
silitek
Tubes Only
Ik draai nu ook de 4.12 final. HL2 ziet er wat beter uit..nou ja, de BETA was ook niet slecht. Ook start de game wat sneller op. Tis allemaal net een tikkie beter dan de BETA versie.
Ik ben zeer tevreden :9
Tubes....It's what make music music!
  • greatgonzo
greatgonzo
schit-te-rend!
Tom Weustink schreef op dinsdag 14 december 2004 @ 19:01:
Succes!
dit heb ik gedaan:
fast write uit
vpu cover uit
vsync aan
Krijg er nu deze melding bij:
Afbeeldingslocatie: http://img95.exs.cx/img95/1923/hl2pt.jpg
toch maar terug naar de beta?
  • freshy98
freshy98
Atari
greatgonzo schreef op dinsdag 14 december 2004 @ 20:02:
dit heb ik gedaan:
fast write uit
vpu cover uit
vsync aan
Ik heb zelf Fast-Write niet uitgezet in het BIOS.
Heb je die mogelijkheid ook geprobeerd toevallig?
En anders even verder lezen op de link die ik eerder gaf.
Probeer ook TrueForm op Application Preference te zetten..staat normaal op iets anders, kweeniemeerwat, maat heb het op Application Preference gezet. Is er ook een van delink ;-)
  • freshy98
freshy98
Atari
grmbl! damn forum software. lekkere foutmeldingen maar toch saven stiekum.
en aangezien er geen delete functie is in dit geweldig stuk bagger software!
[ Voor 82% gewijzigd door freshy98 op 14-12-2004 20:26 ]
  • schnumi
schnumi
Discothéque! Boom cha!
Ik heb ook al een fout gehad met HL1: Source jammergenoeg.
Maar deze driver doet hij bij mij wel een stuk beter als de 4.12 beta. Vooral in F1 challenge.
"The more you take the less you feel, The less you know the more you believe, The more you have the more it takes today"
  • Griffin
Griffin
Is mythical
argg. dacht ik even te installeren gister.
een of ander vaag ongeluk op de brug van zaltbommen en toen stond heel waardenburg vast. inclusief de bus waar ik in zat :(
ik was om 7 uur thuis. toen nog eten en naar een vriend.
ik hoop vanavond te kunnen installen, maar ik moet sporten dus het word kiellekielle.
ik laat hoe het loopt met COD en CODUO
  • Notna
  • Laatst online: 13:00
Notna
Where are you?®
Hmm jmmr dat deze driver niet modbaar is voor mij Mobility 9700 Pro :(
Dan maar w88 op de Omega drivers
Vindt het trouwens wel apart dat echt alle updates gerelateerd zijn met de nieuwe X series en niet de 'oude' vidkaarten.
Xbox Live ID:Notna8310
  • greatgonzo
greatgonzo
schit-te-rend!
Notna schreef op woensdag 15 december 2004 @ 10:22:
dat is marketing mijn jongen, zo weinig mogelijk verbetering geven voor oudere producten zodat mensen sneller geneigd zijn nieuwe producten te kopen
  • Bjk
  • Laatst online: 16:27
Bjk
Waar kan ik die overdrive functie vinden?
  • boesOne
  • Laatst online: 01-04 13:35
boesOne
meuh
Bjk schreef op woensdag 15 december 2004 @ 21:06:
Nergens, volgens mij ondersteund de Radeon9700 t niet..
Ik heb trouwens een nasty probleem met de 4.12's.
ELK spel loopt na een paar seconden vast. Daar had ik met de 4.11 geen last van. Ik heb de 4.12's nu op 3 manieren geinstalled.
- over de 4.11 heen
- Eerst 4.11 via control panel weg, reboot, 4.12 erop.
- 4.11 eraf met de cat uninstaller/removal tool van ATi, reboot, 4.12 erop..
Maakt niks uit. Games freezen of de VPU recover grijpt in..
specs:
club3D 9600 pro [niet OCed]
Asrock A7V880
OEM 512 MB reep PC3200 @ 200 MHz [ook ff voor test op 166 MHz gezet, maakt niks uit]
mobile Athlon XP 2400+ @ 3200+ [ook op 2400+ speeds gechecked, en zelfs op 1200 MHZ, maakt niks uit...]
Fast writes uit, AGP op 8x en 4x geprobeert..
Steeds precies t zelfde gezeur.. Alle games freezen zowel D3D [NFSU] als OGL [D3 en COD]
input heel erg welkom ! :)
I say we take off and nuke the entire site from orbit. It's the only way to be sure.
  • -Turbotetter-
  • Laatst online: 05-01 20:20
heej,
hee heb ff een vraagie: Wat ik niet he;emaal begrijp is, ik heb een Radeon 9200 en als ik wil downloade zeg maar staat erbij van:
1 package - English only
Supported on the RADEON 9500, RADEON 9600, RADEON 9700, RADEON 9800, RADEON X300, RADEON X600, RADEON X700 or RADEON X800 Series of products.
daar staat dus geen 9200 bij. dus kan iemand mij vertellen of het werkt of niet.
  • Pubbert
Pubbert
random gestoord
-Turbotetter- schreef op woensdag 15 december 2004 @ 21:56:
heej,
Probeer het eens? :?
3DMark 2005 (standaard instellingen)
4.11: 5422
4.12: 5425
  • Griffin
Griffin
Is mythical
Verwijderd schreef op woensdag 15 december 2004 @ 22:39:
4.11: 5422
4.12: 5425
leuk dat je 3 punten hoger haalt in 3dmark 2005, maar hoe loopt het met je games. lopen die beter of juist slechter. want als je games extreem slecht lopen wie zit er dan te wachten op 3 extra 3dmark punten.
* Griffin moet nog steeds 4.12 installen 8)7 hij heeft het gister aaf druk gehad en vanaaf weer, wat een leven :P
In spellen merk is geen verschil, maar een verschil van een paar FPS op de honderd is toch niet echt te merken.
Doom3 loopt voor de rest goed, maar heeft soms (vooral in het begin) last van wat "balken" in het beeld. Ik moet Doom3 nog testen met de 4.11 drivers..
Need for Speed Underground loopt voor de rest hetzelfde. Zijn er opties in Doom3 / NFSU2 om het aantal FPS te tonen tijdens het spel?
  • Bjk
Bjk
Heb het gisteravond even geprobeert met de Half-Life 2 video test.
Half-Life 2 test:
4.11 - 1024x768 - 81.4 FPS
4.12 - 1024x768 - 98.3 FPS
4.11 - 1280x1024 - 51.3 FPS
4.12 - 1280x1024 - 62.7 FPS
Alle details op hoog.
  • Yokozuna
  • Laatst online: 19-05-2025
Extreme vooruitgang, dat zegt wel weer hoe hoog de druk is op videokaart fabrikanten hun producten op tijd uit te brengen terwijl de drivers nog niet geoptimaliseerd zijn. Het is geen klagen (iedereen heeft onderhand wel fatsoenlijk internet waarmee je nieuwe drivers zo download) maar een constatering :)
ga terug naar 4.11??
  • thesystem
  • Laatst online: 27-03 06:46
dit heb ik gedaan:
fast write uit
vpu cover uit
vsync aan
ik krijg ook dezelfde foutmelding. ook met 4.11, de 4.11 omega drivers en 4.12 beta. weet iemand waar dit aan kan liggen? ik gebruik windows 2000 en directx 9c
  • Griffin
Griffin
Is mythical
Verwijderd schreef op donderdag 16 december 2004 @ 10:35:
gebruik FRAPS. ik vind het fijn werken.
als ik wil weten hoveel FPS er is gebruik ik dit even.
en een link
[ Voor 11% gewijzigd door Griffin op 16-12-2004 15:23 ]
  • Hom3r
  • Laatst online: 22-10-2025
HL2 draait een stuk beter alleen ik moest alles op Hi zetten toen pas liep het lekker beetje raar maar goed het werkt ;)
  • CyberTijn
  • Laatst online: 22-02 00:48
Heeft er iemand al een goeie refresh rate fix gevonden ? ik gebruikte eerst altijd ATI Refresh Fix 0.9.9.7 en dat werkte altijd goed met de vorige catalysts, alleen met 4.12 functioneert het niet meer :(
Tips zijn erg welkom! aangezien in games m'n monitor nu niet meer naar 100hz gaat maar naar 85hz (wat resulteert in ernstige tearing-effects)
  • Griffin
Griffin
Is mythical
COD UO loopt een paar FPS beter. niet echt veel maar ik ben er over te spreken.
* Griffin is running 4.12
  • _Ernst_
  • Laatst online: 18:28
_Ernst_
Mark It Zero!
Net geinstalleerd en getest. Ik draaide nog op de 4.10 drivers omdat de 4.11 een foutmelding gaf (die ik nu overigens ook weer kreeg, maar dat heb ik opgelost door Net FrameWork 1.1 te installeren)
Eerst haalde ik met mijn R9800 non pro @ 400/324 2171 3dmark2005 marks en nu 2624. Dus dat is een hele verbetering. Ik weet dus niet hoe de 4.11 het deden dus daar kan ik niks over zeggen.
Farcry loopt ook beter voor mijn gevoel.
* _Ernst_ is also running 4.12 :)
Last.fm
  • MaTr1x
CyberTijn schreef op donderdag 16 december 2004 @ 19:39:
Heb je RefreshLock al geprobeerd? Die gebruik ik al jaren. (BTW Niet kunnen testen met 4.12 omdat mobo RMA is...)
π MW finishers
  • CyberTijn
MaTr1x schreef op donderdag 16 december 2004 @ 20:33:
Hey super! bedankt man! Met dat refresh lock is het prima gelukt. Kan nu netjes UT2004 op 100Hz spelen.
  • Nemesizz
Nemesizz
Untouchable
Ik heb de 4.12 gisteren ook geinstalleerd en met meerdere games en benchmarks getest.
Overal verbetering, en de driver is mooi stabiel (is soms maar afwachten met nieuwe ati drivers...in mijn geval).
Meeste games kregen een winst van ongeveer 5FPS (openGl games). Dus dat is opzich wel aardig (kan net de doorslag geven :P ).
  • kwiebus
  • Laatst online: 20:18
Bij mij werkt de ATI Catalyst Control Center alleen als ik deze toegang geef tot het internet. Als ik de toegang blokkeer met ZoneAlarm dan start deze niet eens. Weet iemand wat de reden is dat deze applicatie cli.exe perse naar het internet wil? Ik heb namelijk een hekel aan applicaties die te pas en te onpas naar het internet willen.
  • Passievrucht
  • Laatst online: 01-04 15:46
Passievrucht
swarma
Control Center zuigt zwaar :) bij mij heeft eht verbinding en krijg nog een error
Steam id is passievrucht \\ Xbox Live GT: Meneer Passievrucht
  • MaTr1x
* MaTr1x is niet blij met 4.12 :(
Heb dus vandaag een 'schone' install gedaan met me unattended dvd op een nieuwe hd. Daarbij werd Omega 4.10b mee geïnstalleerd. Ik heb die vervolgens netjes verwijderd en vervolgens de officiële 4.12 geïnstalleerd met CCC. Na een reboot kwam die met de melding dat SmartGart de snelheid moest vastellen ofzo, daarna werd Windows supertraag, reageerde totaal niet op muisklikken totdat die vastliep. Na twee pogingen heb ik 'm teruggezet met Systeemherstel. Gelukkig werkte dat, toen gelijk Omega 4.12b gedownload, en we're back in business :)
π MW finishers
Ik heb eerst de nieuwste Omega drivers gedownload.. oude geuninstalled..
Op een of andere manier startte de Omega catalyst 4.12 installer niet..
Toen geprobeerd de gewone 4.12 erop te zetten..zonder succes.
Ik krijg steeds foutmeldingen als de driver instal zich aan het voorbereiden is..
Ik heb ati catalyst uninstaller al geprobeerd zonder succes.. ik krijg alleen de oude driver installers aan de praat..
  • Gamo
  • Laatst online: 23-06-2025
Gamo
Research Before You Buy
ik heb nu Omega 4.12 draaien, en mijn scherm slaat af/standy stand waneer ik GTA VC open! echt erg :)
Hl2 stress test
1024*768
Beta: 40.82
Final 50.90
Beta 39.04
Final: foutmelding:
ik heb precies ditzelfde probleem en ik heb die .NET geinstalled van MS
