Hoi,
Ik heb op een windows xp pro bak ingestelt dat hij vpn verbindingen accepteert. nu heb ik het op zo manier in m'n debian bak ingestelt:
Maar hij blijft steken halverwege het inloggen, bij het username en password gedoeipchains -I input -p tcp -y -d 0.0.0.0/0 500 -m 5
ipmasqadm mfw -A -m 5 -r 192.168.1.60 500
ipchains -I input -p tcp -y -d 0.0.0.0/0 50 -m 6
ipmasqadm mfw -A -m 6 -r 192.168.1.60 50
ipchains -I input -p tcp -y -d 0.0.0.0/0 51 -m 7
ipmasqadm mfw -A -m 7 -r 192.168.1.60 51
ipchains -I input -p tcp -y -d 0.0.0.0/0 1723 -m 8
ipmasqadm mfw -A -m 8 -r 192.168.1.60 1723
via het normale netwerk verbind hij wel.721
A PPP conversation was attempted, but the remote computer did not respond. This error occurs when the server does not support PPP, such as a Windows NT 3.51 or earlier remote access server, or a SLIP server.
This error may also occur if the server requires logging on by using a terminal window before starting PPP. See To use the Terminal feature to log on to a remote computer. If using a terminal window to log on solves the problem, you can automate the process for future connections. See Automating the dial-up logon process by using Windows scripting.
This error can also indicate faulty hardware on your computer, or the remote server.
