[CISCO] Static NAT mapping werkt niet
  • BasXcore
  • Laatst online: 16-07 16:18
Ik heb een PIX 2600 en daar wil ik een static NAT mapping in maken. En volgens mij doe ik het goed m.b.t. access lists, en de NAT mapping. Ik heb me er al suf over gestaart. Weet iemand wat ik fout doe. (ps, clear ip nat trans * al diverse malen gedraait)
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname XXXXXXXXX
enable secret 5 XXXXXXX
enable password 7 XXXXXXX
username XXXXXXX password 7 094E5B1A1300
username XXXXXXX password 7 04482B161F015E5A48
username XXXXXXX password 7 08224343191814
ip subnet-zero
no ip source-route
no ip finger
ip name-server 194.151.228.18
ip inspect max-incomplete high 1100
ip inspect one-minute high 1100
ip inspect name Ethernet_0_0 tcp
ip inspect name Ethernet_0_0 udp
ip inspect name Ethernet_0_0 cuseeme
ip inspect name Ethernet_0_0 ftp
ip inspect name Ethernet_0_0 h323
ip inspect name Ethernet_0_0 rcmd
ip inspect name Ethernet_0_0 realaudio
ip inspect name Ethernet_0_0 smtp
ip inspect name Ethernet_0_0 streamworks
ip inspect name Ethernet_0_0 vdolive
ip inspect name Ethernet_0_0 sqlnet
ip inspect name Ethernet_0_0 tftp
ip audit notify log
ip audit po max-events 100
isdn voice-call-failure 0
interface Ethernet0/0
 description connected to EthernetLAN
 ip address 192.168.101.1 255.255.255.0 secondary
 ip address 192.168.100.1 255.255.255.0
 ip access-group 100 in
 no ip directed-broadcast
 ip nat inside
 ip inspect Ethernet_0_0 in
interface BRI0/0
 no ip address
 isdn guard-timer 0 on-expiry accept
interface Serial0/0
 description MAIN WAN interface
 no ip address
 encapsulation frame-relay IETF
 frame-relay lmi-type ansi
interface Serial0/0.500 point-to-point
 description connected to Internet
 ip address 194.XX.64.97 255.255.255.240
 ip access-group 105 in
 ip nat outside
 frame-relay interface-dlci 500
interface Dialer1
 description inbelvoorziening Remote
 bandwidth 64
 ip address 192.168.30.1 255.255.255.0
 encapsulation ppp
 dialer remote-name remote1
 dialer pool 1
 dialer caller XXXXXXXX
 dialer-group 1
 peer default ip address pool isdnpc
 no cdp enable
 ppp callback accept
 ppp authentication chap
router rip
 version 2
 redistribute static
 passive-interface Serial0/0
 network 192.168.100.0
 network 192.168.101.0
ip local pool isdnpc 192.168.30.10 192.168.30.20
ip nat inside source list 7 interface Serial0/0.500 overload
ip nat inside source static tcp 192.168.100.24 25 194.XX.64.97 25 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0.500
ip route 192.168.30.0 255.255.255.0 Dialer1
ip http server
access-list 1 permit any
access-list 7 permit 0.0.0.0
access-list 7 permit any
access-list 100 permit ip 192.168.100.0 0.0.0.255 any
access-list 105 permit ip host 213.46.100.148 any
access-list 105 permit ip host 195.86.13.106 any
access-list 105 deny   ip any any
dialer-list 1 protocol ip permit
line con 0
 exec-timeout 15 0
 login local
 transport input none
line aux 0
line vty 0 4
 exec-timeout 15 0
 login local
end
Move PNS > NT
