• Shapeshifter
  • Laatst online: 14-10 15:02
Shapeshifter
Get it over with
Ik zat net te gluren op de site van Nomad en wat zag ik daar...
Nieuwe Firmware: 1.20.08
Added Features or Enhancements:
- Supports Audible audio Type 4.
- Activates your Zen Xtra player in order to listen to and manage your Audible audio.
- Enables you to navigate sections within Audible audio by using the “Goto Section” feature from the “Now Playing” screen.
- Enables you to return to the last playback position of Audible programs after playing other audio tracks.
Requirements
- Microsoft® Windows® XP, Windows 2000, Windows Millennium Edition or Windows 98 Second Edition
- USB 1.1 or 2.0 port
- Creative Jukebox Zen Xtra
Notes
Before installing the firmware update, be sure that you have:
1. Charged the player's battery
2. Connected the power cable
3. Turned off your player
4. Disconnected your player's USB cable from your computer
To install the firmware update, you must first remove the firmware in your player using the Reload OS function:
1. Press and hold the Play button, while inserting a pin or paper clip into the Reset button on your player. The Reset button is near the Volume buttons.
2. The player starts up in Rescue mode.
3. Select the Reload OS option.
4. The current firmware will be erased from the player.
5. Connect your player to your computer with the USB cable.
6. Double-click the firmware file, and follow the instructions on the screen.
7. When prompted, click the Upgrade option.
8. When the upgrade is complete, your player restarts.
9. A "rebuilding the library" message appears on your player's LCD. This message disappears when your player has finished rebuilding the music library.
10. The firmware is now updated.
BELANGRIJK:
Houd er rekening mee dat dit de US firmware is; je speler zal nu 2X zo hard gaan (qua volume) en Creative is niet verantwoordelijk voor evt. schade aan je speler (of je gehoor :P) (en ik ook niet) - Dit vanwege Europese wetgeving qua volume van MP3-Spelers -
Edit
Voor de Nederlandse mensen onder ons ;)
Voorbereiding
1. Zorg dat je batterij is opgeladen
2. Sluit je stroomkabel aan (van wandcontactdoos naar speler)
3. Zet je speler UIT
4. Zorg dat je USB kabel los is (niet in de computer en/of speler zit)
Oude Firmware eraf gooien:
1. Druk op de "Play/Pause" knop (De ronde aan de rechterkant) en houd deze ingedrukt. Druk nu met een paperclip / nietje het "Reset" knopje in (Linksonderaan, onder de volumeknoppen) (Je hebt "Play/Pause" nog steeds ingedrukt...)
2. De speler start op in "Rescue Mode".
3. Kies voor "Reload OS" en bevestig dit.
4. Je oude firmware wordt er nu afgegooid.
5. Verbindt nu de speler met de computer (dmv van de USB kabel)
6. Open de firmwarefile en volg de instructies
7. Zodra de speler wordt "gezien" kun je op upgrade drukken (dit moet je dan ook doen)
8. Als dit achter de rug is zal je speler opnieuw opstarten.
9. Als je speler gestart is verschijnt er een "rebuilding the library" bericht, dit verdwijnt vanzelf (wacht ook even tot het balkje van links naar rechts is gegaan ;))
10. Gefeliciteerd, het is je gelukt :)
HP ZBook Studio G3 - Hyundai Ioniq EV Classic - Opel Vivaro-e 75kWh - 22x Prusa i3 MK3S - 8x Prusa MINI+ - Ooznest Workbee 1,5m x 1,5m
  • Shapeshifter
Shapeshifter
Get it over with
Ben er alleen nog niet achter wat Audible audio is... Het klinkt m.i. erg loos. Maar ik kan het mishebben.
Ik heb al een half jaar geleden kocht ik mijn Zen Xtra 60. overjoyed natuurlijk.
de enige nadelen waren; geluid te zacht, niet plug'n'play.
door de firmware-update kan mijn beestje nu een stuk woester brullen.
mijn dank is zeer groot (eu stinkt)
is er geen toetsencombinatie mogelijk om de Zen als externe hdd (zonder mediasource etc) te kunnen herkennen door pc ? Ik hoorde een vaag gerucht over die functie bij bepaalde ipods...
Nwe firmware, nu issie wel plug-and-play and drag 'n drop!
Maar helaas moet je wel genoegen nemen met een lege mp3 speler, volgens de readme raak je al
muziek kwijt, en al je andere bestanden
[ Voor 56% gewijzigd door Verwijderd op 04-01-2006 14:45 ]
( hoe edit ik mn posts?? )
o nu staat 't icoontje er wel, sorry!
[ Voor 73% gewijzigd door Verwijderd op 04-01-2006 14:56 ]
