Sof2 Linux Server probleem!
  • 214 views sinds 30-01-2008
Dit is wat hij WEL doet!
Initialising zone memory .....
----- FS_Startup -----
Current search path:
/root/.sof2/rocmod
/root/sof2server/rocmod/z_Ultra_VoicePack_Final_v2.pk3 (394 files)
/root/sof2server/rocmod/z_tru_damage.pk3 (2 files)
/root/sof2server/rocmod/update101.pk3 (298 files)
/root/sof2server/rocmod/Super_Gore.pk3 (22 files)
/root/sof2server/rocmod/ROCmod-2.0c-client.pk3 (33 files)
./sof2ded/rocmod
/root/.sof2/base
/root/sof2server/base/MP
/root/sof2server/base/update104.pk3 (723 files)
/root/sof2server/base/update103.pk3 (55 files)
/root/sof2server/base/update102.pk3 (213 files)
/root/sof2server/base/update101.PK3 (298 files)
/root/sof2server/base/therest.pk3 (7125 files)
/root/sof2server/base/textures1234.pk3 (10843 files)
/root/sof2server/base/textures0.pk3 (2816 files)
/root/sof2server/base/skins.pk3 (4117 files)
/root/sof2server/base/musicandsound.pk3 (3055 files)
/root/sof2server/base/mp_italy.pk3 (16 files)
/root/sof2server/base/mp.pk3 (338 files)
/root/sof2server/base/monopoly.pk3 (84 files)
/root/sof2server/base/models.pk3 (3643 files)
/root/sof2server/base/maps.pk3 (466 files)
./sof2ded/base/MP
./sof2ded/base
34541 files in pk3 files
execing sof2mp_default.cfg
execing sof2mp.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
--- Common Initialization Complete ---
logfile opened on Sat Dec 4 12:03:11 2004
Opening IP socket: localhost:20100
Hostname: server.lan
IP: 10.0.0.15
Working directory: /root/sof2server
^3PunkBuster Server: pb_sv_SsNext = 440361 (0 to 999999)
^3PunkBuster Server: pb_sv_LogNext = 27 (1 to 999999)
^3PunkBuster Server: File Not Found: pbsv.cfg
^3PunkBuster Server: File Not Found: pbsvuser.cfg
^3PunkBuster Server: PunkBuster Server (v0.993 | A1293 C0.993) Enabled
execing sof2.cfg
execing sof2mp.cfg
execing hotbinds2.cfg
execing weap.cfg
execing grenade.cfg
execing ammo.cfg
execing armor.cfg
execing NoVote.cfg
Writing sof2mp.cfg.
execing SOF2_ROCmod.cfg
------ Server Initialization ------
Server: mp_shop2
Initializing Shaders
...loading 'shaders/airport.shader'
...loading 'shaders/bolt_ons.shader'
...loading 'shaders/common.shader'
...loading 'shaders/hud.shader'
...loading 'shaders/menu.shader'
...loading 'shaders/mp.shader'
...loading 'shaders/mp_hk2.shader'
...loading 'shaders/pick_ups.shader'
...loading 'shaders/simple.shader'
...loading 'shaders/weapons.shader'
...loading 'shaders/gfx.shader'
...loading 'shaders/dm_condom.shader'
...loading 'shaders/nx_scell.shader'
...loading 'shaders/nx_tower.shader'
...loading 'shaders/hospital.shader'
...loading 'shaders/mp_hos2.shader'
...loading 'shaders/threewave.shader'
...loading 'shaders/threewave3.shader'
...loading 'shaders/threewave4.shader'
...loading 'shaders/airport_models.shader'
...loading 'shaders/arioche.shader'
...loading 'shaders/armory.shader'
...loading 'shaders/armory_models.shader'
...loading 'shaders/average_armor.shader'
...loading 'shaders/average_sleeves.shader'
...loading 'shaders/cemetery.shader'
...loading 'shaders/chem_suit.shader'
...loading 'shaders/chunks.shader'
...loading 'shaders/colombia.shader'
...loading 'shaders/colombia_models.shader'
...loading 'shaders/colors.shader'
...loading 'shaders/common_models.shader'
...loading 'shaders/decals.shader'
...loading 'shaders/dog.shader'
...loading 'shaders/effects.shader'
...loading 'shaders/fat.shader'
...loading 'shaders/female_armor.shader'
...loading 'shaders/female_pants.shader'
...loading 'shaders/female_skirt.shader'
...loading 'shaders/finca.shader'
...loading 'shaders/finca_models.shader'
...loading 'shaders/fogs.shader'
...loading 'shaders/gore.shader'
...loading 'shaders/hongkong.shader'
...loading 'shaders/hongkong_models.shader'
...loading 'shaders/hospital_models.shader'
...loading 'shaders/instances.shader'
...loading 'shaders/jordan.shader'
...loading 'shaders/jordan_models.shader'
...loading 'shaders/kamchatka.shader'
...loading 'shaders/kamchatka_models.shader'
...loading 'shaders/liner.shader'
...loading 'shaders/liner_models.shader'
...loading 'shaders/metashader.shader'
...loading 'shaders/osprey.shader'
...loading 'shaders/prague.shader'
...loading 'shaders/prague_models.shader'
...loading 'shaders/roam.shader'
...loading 'shaders/shop.shader'
...loading 'shaders/shop_models.shader'
...loading 'shaders/skies.shader'
...loading 'shaders/skingore.shader'
...loading 'shaders/snow.shader'
...loading 'shaders/sprites.shader'
...loading 'shaders/suit_long_coat.shader'
...loading 'shaders/suit_sleeves.shader'
...loading 'shaders/test.shader'
...loading 'shaders/tools.shader'
...loading 'shaders/glass.shader'
...loading 'shaders/rmg.shader'
/root/.sof2/rocmod
./sof2ded/rocmod
/root/.sof2/base
./sof2ded/base/MP
./sof2ded/base
handle 1: qconsole.log
69082 files in pk3 files
Loading shader text .....
..... 5567 shader definitions loaded
----------- Loading MATERIALS ------------
32 material definitions loaded.
Couldn't read sof2mp.ban.
Loading dll file sof2mp_game.
Sys_LoadDll(/root/sof2server/rocmod/sof2mp_gamei386.so)...
Sys_LoadDll(/root/sof2server/rocmod/sof2mp_gamei386.so) failed: "/root/sof2server/rocmod/sof2mp_gamei386.so: cannot open shared object file: No such file or directory"
Sys_LoadDll(./sof2ded/rocmod/sof2mp_gamei386.so) failed: "./sof2ded/rocmod/sof2mp_gamei386.so: cannot open shared object file: Not a directory"
----- Server Shutdown -----
Shutting down cmShaderTable .....
Sys_Error: Sys_LoadDll(sof2mp_game) failed dlopen() completely!
Kan iemand mij helpen met dir probleem, ik snap er zelf de ballen niet meer van!
Zegt de error niet alles wat je nodig hebt?
Als ik het zo zie, bestaat "/root/sof2server/rocmod/sof2mp_gamei386.so" niet. Heb je dat al gecontroleerd? Als die niet bestaat, kun de server opnieuw installeren en/of de paden controleren.
Jah dat heb ik gedaan, het bestand bestaat zoiezo niet op mijn server, maar het bestaat al helemaal niet op internet! Ik had een andere sof2 server gezien en die was precies hetzelfde als die van mij en daar zat het bestandje ook niet tussen maar die werkte wel!
