StatsaHolic; segmentation error
Ik heb statsaholic geinstalleerd op mijn linux machientje maar nu kom ik er niet helemaal uit. Ik hoop dat dit topic mag hier omdat het eigenlijk een software probleem is maar hier zit wel de meeste kennis over dit soort dingen.
wat ik gedaan heb :
statsaholic geinstalleerd dmv van het uitvoeren van php create.php
dit ging zonder problemen
update.php geeft echter de volgende meldingen :
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
PHP Warning:  Call-time pass-by-reference has been deprecated - argument passed by value;  If you would like to pass it by reference, modify the declaration of getindextotals().  If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file.  However, future versions may not support this any longer.  in /var/www/htdocs/php/update.php on line 1075
PHP Warning:  Call-time pass-by-reference has been deprecated - argument passed by value;  If you would like to pass it by reference, modify the declaration of getindextotals().  If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file.  However, future versions may not support this any longer.  in /var/www/htdocs/php/update.php on line 1083
PHP Warning:  Call-time pass-by-reference has been deprecated - argument passed by value;  If you would like to pass it by reference, modify the declaration of getusertotals().  If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file.  However, future versions may not support this any longer.  in /var/www/htdocs/php/update.php on line 1192
PHP Warning:  Call-time pass-by-reference has been deprecated - argument passed by value;  If you would like to pass it by reference, modify the declaration of getusertotals().  If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file.  However, future versions may not support this any longer.  in /var/www/htdocs/php/update.php on line 1199
PHP Notice:  Undefined index:  REMOTE_ADDR in /var/www/htdocs/php/update.php on line 510
PHP Notice:  Undefined variable:  REMOTE_ADDR in /var/www/htdocs/php/update.php on line 510
PHP Notice:  Undefined index:  argv in /var/www/htdocs/php/update.php on line 513
PHP Notice:  Undefined index:  argc in /var/www/htdocs/php/update.php on line 513
PHP Notice:  Undefined variable:  differentConfig in /var/www/htdocs/php/update.php on line 532
PHP Notice:  Undefined offset:  1 in /var/www/htdocs/php/update.php on line 540
PHP Notice:  Undefined offset:  137 in /var/www/htdocs/php/update.php on line 539
PHP Notice:  Undefined variable:  quiet in /var/www/htdocs/php/update.php on line 548
PHP Notice:  Undefined variable:  testMode in /var/www/htdocs/php/update.php on line 548
PHP Notice:  Undefined variable:  contestChoice in /var/www/htdocs/php/update.php on line 553
PHP Notice:  Undefined offset:  9 in /var/www/htdocs/php/update.php on line 652
PHP Notice:  Undefined offset:  1 in /var/www/htdocs/php/update.php on line 653
PHP Notice:  Undefined variable:  justHtml in /var/www/htdocs/php/update.php on line 657
PHP Notice:  Undefined variable:  rebuildDay in /var/www/htdocs/php/update.php on line 661
nou ben ik echt niet te beroerd om me ergens in te verdiepen maar dit is allemaal abacadabra voor mij. Ik hoop dat iemand weet wat de oorzaak en de oplossing is.
helaas is er zowel op google als op de sourceforge projectpagina van statsaholic niets te vinden
