[js] regular expression + variabele
  • 107 views sinds 30-01-2008
Ik kom er niet uit en heb me suf gezocht op o.a. Google (wellicht weet ik niet de juiste termen om op te zoeken, dus vergeef me)
De vollgende code:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>test</title>
</head>
<body>
<script type="text/javascript">
function checkAll(tButton, tBoxName) {
    var allInputs = document.forms[0].getElementsByTagName("input");
    var allUsedefaults = new Array();
    regExp = new RegExp(/[tBoxName]\\[\]/);
    regExp2 = new RegExp(/[tBoxName]\\[[^\]]+\]/);
    for (var i = 0; i < allInputs.length; i++) {
        if (allInputs[i].type != 'checkbox') continue;
        if (allInputs[i].name.match(regExp) || allInputs[i].name.match(regExp2)) {
            allUsedefaults.push(allInputs[i]);
    for (var i = 0; i < allUsedefaults.length; i++) {
        allUsedefaults[i].checked = tButton.checked;
</script>
<form action="<?=$_SERVER['PHP_SELF'];?>" method="post" name="frmTest" id="frmTest">
<table border="0" cellspacing="0" cellpadding="5">
  <tr>
    <td><strong>alles selecteren: </strong></td>
    <td><input name="btnToggle" type="checkbox" id="btnToggle" value="true" onclick="checkAll(this, 'chkTestbox');" /></td>
    <td><input name="btnToggle2" type="checkbox" id="btnToggle2" value="true" onclick="checkAll(this, 'chkTestbox2');" /></td>
  </tr>
  <tr>
    <td>optie 1 </td>
    <td><input name="chkTestbox[0]" type="checkbox" id="chkTestbox1" value="1" /></td>
    <td><input name="chkTestbox2[0]" type="checkbox" id="chkTestbox1" value="1" /></td>
  </tr>
  <tr>
    <td>optie 2 </td>
    <td><input name="chkTestbox[1]" type="checkbox" id="chkTestbox2" value="2" /></td>
    <td><input name="chkTestbox2[1]" type="checkbox" id="chkTestbox2" value="2" /></td>
  </tr>
  <tr>
    <td>optie 3 </td>
    <td><input name="chkTestbox[2]" type="checkbox" id="chkTestbox3" value="3" /></td>
    <td><input name="chkTestbox2[2]" type="checkbox" id="chkTestbox3" value="3" /></td>
  </tr>
  <tr>
    <td>optie 4 </td>
    <td><input name="chkTestbox[3]" type="checkbox" id="chkTestbox4" value="4" /></td>
    <td><input name="chkTestbox2[3]" type="checkbox" id="chkTestbox4" value="4" /></td>
  </tr>
  <tr>
    <td>optie 5 </td>
    <td><input name="chkTestbox[4]" type="checkbox" id="chkTestbox5" value="5" /></td>
    <td><input name="chkTestbox2[4]" type="checkbox" id="chkTestbox5" value="5" /></td>
  </tr>
  <tr>
    <td><strong>niet mee geselecteerd: </strong></td>
    <td><input name="chkNiet" type="checkbox" id="chkTestbox5" value="100" /></td>
    <td>&nbsp;</td>
  </tr>
  <tr>
    <td>&nbsp;</td>
    <td><input type="submit" name="Submit" value="Submit" /></td>
    <td>&nbsp;</td>
  </tr>
  <tr valign="top">
    <td>Resultaat formulier:</td>
    <td>&nbsp;</td>
    <td><pre><? print_r($_POST); ?></pre> </td>
  </tr>
</table>
</form>
</body>
</html>
Boven aan staan 2 checkboxen.
Als je de linker checked, moet het linker rijtje geselecteerd worden.
Als je de rechter checked, moet het rechter rijtje geselecteerd worden.
Lijkt me duidelijk.
Ik wil hiervoor 1 functie gebruiken en stuur dus bij het checken van 1 van de bovenste checkboxen de naam mee van de naam van de array van de checkboxen.
De namen van de checkboxen moeten met [] worden genoteerd, omdat ik met PHP deze arrays wil uitlezen.
Ik krijg het aanvinken van het linker of rechterrijtje niet voor elkaar.
En dat gaat fout bij de reguliere expressie.
Hoe krijg ik nu de variabele in de reguliere expressie?!
Het gaat dus om regel 13 en 14. Op de een of andere manier moet er de waarde van tBoxName in krijgen.
  • gorgi_19
  • Laatst online: 19-10 13:51
gorgi_19
Kruimeltjes zijn weer op :9
Javascript hoort thuis in Webdesign & Graphics, zoals al in een eerder topic tegen je is gezegd :)
>> [forurm=wg]
Digitaal onderwijsmateriaal, leermateriaal voor hbo
Excuus ... hoewel javascript toch eigenlijk ook betrekking heeft op programmeren en niet het designen van websites en/of graphics. Maar das een andere discussie.
doe eens new regexp(tBoxName+'\\[\]');
oid, gewoon strings optellen dus, volgens mij mag in een constructor niet eens een // declaratie staan, want da's een constructor op zichzelf:
http://www.devguru.com/Te...ript/quickref/regexp.html
[ Voor 58% gewijzigd door Verwijderd op 26-11-2004 13:58 ]
Heb de functie aangepast naar:
    exp1 = /[tBoxName]\\[\]/;
    exp2 = /[tBoxName]\\[[^\]]+\]/;
        if (allInputs[i].name.match(exp1) || allInputs[i].name.match(exp2)) {
</script>
Nope, dat werkt niet :(
[ Voor 15% gewijzigd door Verwijderd op 26-11-2004 14:15 ]
je doet ook niet wat ik zeg
exp1 = new regexp(tBoxName+'\\[\]');
[ Voor 42% gewijzigd door Verwijderd op 26-11-2004 14:25 ]
werkt ook niet
is er een reden dat je niet global zoekt? anders moet je dat natuurlijk ook even doen. En wellicht case insensitive
en denk even goed na over je regexp (zie nu pas dat dat een zooitje is)
\\[\] vind je niet terug, want er staat altijd een getal tussen, dus je moet eerder zoiets hebben:
\\[\d+\]
en wat is die 2e? bedoel je niet \\[.*?\]
[ Voor 51% gewijzigd door Verwijderd op 26-11-2004 14:38 ]
  • crisp
  • Laatst online: 00:00
crisp
Devver
Pixelated
JavaScript:
var exp1 = new RegExp('\\[' + tBoxName + '\]\\[\]');
Intentionally left blank
ik denk niet dat die tBoxName in een class moet crisp dat heb je ook niet 8)7, maar dan nog zie ik in z'n names die haken niet terug, en zoals ik al zei, met \\[\] vind ie niks terug
[ Voor 30% gewijzigd door Verwijderd op 26-11-2004 14:43 ]
Ik gebruik ook wel eens formulier waar er niets tussen de haken staat.
Er staat ook (toch?) dat ie aan 1 van de 2 moet voldoen, niet allebei.
Aangepast naar:
        if (allInputs[i].name.match(exp1)) {
</script>
Dan krijg ik een javascript error:
']' wordt verwacht in reguliere expressie
[ Voor 94% gewijzigd door Verwijderd op 26-11-2004 14:49 ]
  • crisp
crisp
Devver
Pixelated
ik had de rest van de code ook niet doorgelezen 8)7
zoiets dus:
JavaScript:
var exp1 = new RegExp(tBoxName + '\\[\d+\]');
maar ik neem aan dat het idee wel duidelijk is. Dit kan dus niet met de / / constructor.
Eventueel zou je nog ^ kunnen toevoegen om echt vanaf het begin te matchen. global match is niet nodig omdat je enkel wilt weten of er ueberhaupt een match is, derhalve kan je ook beter test() gebruiken ipv match().
[ Voor 33% gewijzigd door crisp op 26-11-2004 14:48 ]
Nu heb ik het als volgt aangepast:
</script>
Nu krijg ik geen foutmeldingen, maar de bedoelde rijtjes worden niet geselecteerd!
Ik heb even het totale script aangepast, zo zou het naar mijn idee wel moeten werken (copoy paste in een leeg bestandje om zelf te testen). Ik krijg geen foutmeldingen, maar er gebeurt niets ...
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
<head>
<title>test</title>
</head>
<body>
    var exp1            = new RegExp(tBoxName + '\\[\d*\]');
</script>
  <tr>
    <td bgcolor="#CCCCCC"><input name="btnToggle" type="checkbox" id="btnToggle" value="true" onclick="checkAll(this, 'chkTestbox');" /></td>
  </tr>
  <tr>
    <td>optie 1 </td>
    <td bgcolor="#CCCCCC"><input name="chkTestbox[0]" type="checkbox" id="chkTestbox1" value="1" /></td>
    <td><input name="chkTestbox2[]" type="checkbox" id="chkTestbox1" value="1" /></td>
  </tr>
  <tr>
    <td>optie 2 </td>
    <td bgcolor="#CCCCCC"><input name="chkTestbox[1]" type="checkbox" id="chkTestbox2" value="2" /></td>
    <td><input name="chkTestbox2[]" type="checkbox" id="chkTestbox2" value="2" /></td>
  </tr>
  <tr>
    <td>optie 3 </td>
    <td bgcolor="#CCCCCC"><input name="chkTestbox[2]" type="checkbox" id="chkTestbox3" value="3" /></td>
    <td><input name="chkTestbox2[]" type="checkbox" id="chkTestbox3" value="3" /></td>
  </tr>
  <tr>
    <td>optie 4 </td>
    <td bgcolor="#CCCCCC"><input name="chkTestbox[3]" type="checkbox" id="chkTestbox4" value="4" /></td>
    <td><input name="chkTestbox2[]" type="checkbox" id="chkTestbox4" value="4" /></td>
  </tr>
  <tr>
    <td>optie 5 </td>
    <td bgcolor="#CCCCCC"><input name="chkTestbox[4]" type="checkbox" id="chkTestbox5" value="5" /></td>
    <td><input name="chkTestbox2[]" type="checkbox" id="chkTestbox5" value="5" /></td>
  </tr>
  <tr>
    <td>&nbsp;</td>
  </tr>
  <tr>
    <td>&nbsp;</td>
    <td>&nbsp;</td>
  </tr>
  <tr valign="top">
    <td>&nbsp;</td>
  </tr>
</table>
</form>
</body>
</html>
[ Voor 72% gewijzigd door Verwijderd op 26-11-2004 15:03 ]
Ok, heb even wat lopen spelen... met het volgende resultaat:
function checkAll(tButton, tBoxName){
    var pattern = new RegExp('^' + tBoxName + '\\\[\\\d+\\]$');
    var obj = tButton.form;
    for(var i = 0; i < obj.length; i++){
        if(obj.elements[i].type == 'checkbox' && obj.elements[i].name.match(pattern)){
        obj.elements[i].checked = true;
Ik geloof dat dit is wat je wou hebben?
Array::push is volgens mij alleen netscape (crisp? jij weet zulke dingen)
adhv van de laatste aanwijzing is het eindelijk helemaal gelukt !!!
Fantastisch, bedankt! De vakjes moesten ook nog uitgeschakeld kunnen worden en ook veldnamen met lege brackets moesten getoggled kunnen worden.
Uiteindelijk:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
<head>
<title>test</title>
</head>
<body>
    var exp1            = new RegExp('^' + tBoxName + '\\\[\\\d*\\]$');
</script>
  <tr>
  </tr>
  <tr>
    <td>optie 1 </td>
    <td bgcolor="#CCCCCC"><input name="chkTestbox[1]" type="checkbox" id="chkTestbox1" value="1" /></td>
  </tr>
  <tr>
    <td>optie 2 </td>
    <td bgcolor="#CCCCCC"><input name="chkTestbox[2]" type="checkbox" id="chkTestbox2" value="2" /></td>
  </tr>
  <tr>
    <td>optie 3 </td>
    <td bgcolor="#CCCCCC"><input name="chkTestbox[3]" type="checkbox" id="chkTestbox3" value="3" /></td>
  </tr>
  <tr>
    <td>optie 4 </td>
    <td bgcolor="#CCCCCC"><input name="chkTestbox[4]" type="checkbox" id="chkTestbox4" value="4" /></td>
  </tr>
  <tr>
    <td>optie 5 </td>
    <td bgcolor="#CCCCCC"><input name="chkTestbox[5]" type="checkbox" id="chkTestbox5" value="5" /></td>
  </tr>
  <tr>
    <td>&nbsp;</td>
  </tr>
  <tr>
    <td>&nbsp;</td>
    <td>&nbsp;</td>
  </tr>
  <tr valign="top">
    <td>&nbsp;</td>
  </tr>
</table>
</form>
</body>
</html>
