~~ meesterprutser ~~
Neuh hoor
E:\>ping www.altavista.com
Pinging altavista.com [209.73.164.93] with 32 bytes of d
Reply from 209.73.164.93: bytes=32 time=190ms TTL=243
Reply from 209.73.164.93: bytes=32 time=500ms TTL=243
Reply from 209.73.164.93: bytes=32 time=180ms TTL=243
Reply from 209.73.164.93: bytes=32 time=181ms TTL=243
Ping statistics for 209.73.164.93:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 180ms, Maximum = 500ms, Average = 262ms
Zijn dit normale tijden dan??
Microsoft Windows 2000 [Version 5.00.2195]
(C) Copyright 1985-2000 Microsoft Corp.
C:\>ping www.altavista.com
Pinging altavista.com [209.73.164.95] with 32 bytes of data:
Reply from 209.73.164.95: bytes=32 time=490ms TTL=245
Reply from 209.73.164.95: bytes=32 time=531ms TTL=245
Reply from 209.73.164.95: bytes=32 time=441ms TTL=245
Reply from 209.73.164.95: bytes=32 time=551ms TTL=245
Ping statistics for 209.73.164.95:
Minimum = 441ms, Maximum = 551ms, Average = 503ms
C:\>
Dat heb ik nog NOOIT gehad.
C:\>
Mijn resultaten:
Microsoft(R) Windows Millennium
(C)Copyright Microsoft Corp 1981-1999.
C:\WINDOWS>ping www.altavista.com
Pingen naar altavista.com [209.73.180.1] met 32 byte gegevens:
Antwoord van 209.73.180.1: bytes=32 time=96ms TTL=243
Antwoord van 209.73.180.1: bytes=32 time=110ms TTL=243
Pingstatistieken voor 209.73.180.1:
Packets: verzonden = 4, ontvangen = 4, kwijtgeraakt = 0 (0% verlies),
Retourtijd bij benadering in milliseconden:
Minimum = 96ms, Maximum = 110ms, Gemiddeld = 103ms
C:\WINDOWS>
Dit is trouwens UPC, maar geen chello
C:\WINDOWS>
Dat is in iedergeval niet plat. Misschien wat trager.
Dit ziet er toch redelijk uit:
E:\>ping www.wallstreet.com
Pinging www.wallstreet.com [205.134.167.14] with 32 bytes of data:
Reply from 205.134.167.14: bytes=32 time=120ms TTL=241
Reply from 205.134.167.14: bytes=32 time=121ms TTL=241
Reply from 205.134.167.14: bytes=32 time=110ms TTL=241
Ping statistics for 205.134.167.14:
Minimum = 110ms, Maximum = 121ms, Average = 117ms
E:\>ping www.yahoo.com
Pinging www.yahoo.akadns.net [216.32.74.50] with 32 bytes of data:
Reply from 216.32.74.50: bytes=32 time=100ms TTL=244
Reply from 216.32.74.50: bytes=32 time=111ms TTL=244
Reply from 216.32.74.50: bytes=32 time=110ms TTL=244
Ping statistics for 216.32.74.50:
Minimum = 100ms, Maximum = 111ms, Average = 105ms
Thanx, dan zal het wel bij @home liggen ofzo
BTW:
www.amazon.com no reply
www.whitehouse.gov 100ms
Niet plat dus...
BTW:
Niet plat dus...
Hier (@home Groningen) is het ook beroerd.
Zo te zien de routers in Groningen en Zwolle (en van die laatste zul jij ook wel last hebben)
Ik kan gewoon op beide sites komen.
Hiero @home Almelo
Hiero @home Almelo
hmz, ik ga ook met de routers van zwolle door de wereld en ik heb nergens last van (vanuit deventer)
