[PHP]Phpmyadmin 2.6.0 werkt niet met Mysql 4.1.7
  • 71 views sinds 30-01-2008
  • Daro
  • Laatst online: 09-01 14:42
Ik heb Apache 2, PHP 5, Mysql 4.1.7 en Phpmyadmin 2.6.0 op WindowsXP draaien.
Apache en php draaien goed. Ik vermoed dat Mysql ook werkt, allezinds dit werkt toch.
<?php
error_reporting(E_ALL);
$db = mysql_connect("localhost", "root", "123456") or die ("verbinding mislukt");
mysql_select_db("test", $db);
echo 'Houston, mission completed';
Maar als ik dan Phpmyadmin wil inloggen, krijg ik op de index.php volgende error:
Warning: Cannot modify header information - headers already sent by (output started at C:\Program Files\Apache Group\Apache2\htdocs\db\config.inc.php:828) in C:\Program Files\Apache Group\Apache2\htdocs\db\libraries\select_theme.lib.php on line 92
Warning: Cannot modify header information - headers already sent by (output started at C:\Program Files\Apache Group\Apache2\htdocs\db\config.inc.php:828) in C:\Program Files\Apache Group\Apache2\htdocs\db\index.php on line 26
Warning: Cannot modify header information - headers already sent by (output started at C:\Program Files\Apache Group\Apache2\htdocs\db\config.inc.php:828) in C:\Program Files\Apache Group\Apache2\htdocs\db\index.php on line 55
Weet iemand wat dit moet voorstellen, of nog beter, hoe dit kan opgelost worden? _/-\o_
Wat ik heb aangepast in config.inc.php van phpmyadmin:
$cfg['PmaAbsoluteUri'] = 'http://localhost/db/';
$cfg['Servers'][$i]['host'] = 'localhost'; // MySQL hostname or IP address
$cfg['Servers'][$i]['controluser'] = 'root'; // MySQL control user settings
// (this user must have read-only
$cfg['Servers'][$i]['controlpass'] = '123456'; // access to the "mysql/user"
// and "mysql/db" tables).
// The controluser is also
// used for all relational
// features (pmadb)
$cfg['Servers'][$i]['auth_type'] = 'config'; // Authentication method (config, http or cookie based)?
$cfg['Servers'][$i]['user'] = 'root'; // MySQL user
$cfg['Servers'][$i]['password'] = '123456'; // MySQL password (only needed
// with 'config' auth_type)
Als er meer info nodig is, vraag maar. Bedankt.
  • NMe
  • Laatst online: 29-09 10:17
NMe
Quia Ego Sic Dico.
Probeer auth_type = cookie.
  • chem
  • Laatst online: 06-10 20:24
chem
Reist de wereld rond
Dit heeft niets met programmeren te maken.
Klaar voor een nieuwe uitdaging.
