ATX 2.0, wat houdt dit in en wat is het verschil?
  • 608 views sinds 30-01-2008
  • Tim_R
  • Laatst online: 10-11-2025
Hey,
Op Informatique zag ik bij de AOpen H600B ATX 2.0 staan. Wat houdt dit in en wat is het verschil met gewoon ATX?
BTW het gaat blijkbaar om de voeding, dat ATX 2.0.
De search vertelde mij niets ;)
  • ramonp
  • Laatst online: 05-10 13:06
De stekker naar je moederbord is anders. 24 ipv 20 pins
Dat is de nieuwste standaard, met nog strengere eisen en kwaliteitsgarantie.
Die cijfertjes geven aan volgens welke revisienummer van de ATX specificatie ze voldoen: http://www.formfactors.org/
  • 1.0 = februari 2000
    • Public release
  • 1.1 = augustus 2000
    • Increase 3.3 V current; add more explanation for power sharing; do minor edits and format fixes
  • 1.2 = januari 2002
    • Typical Power Distribution. Change +5V loading on all power
      supplies distribution tables defined in DG to 0.3A
    • PS_ON# Add text “The power supply should not latch into a
      shutdown state when PS_ON# is driven active by pulses between
      10ms to 100ms during the decay of the power rails.”
    • Remove –5V from all power distribution tables.
  • 1.3 = april 2003
    • Update Power and Current guidance
    • Added efficiency guidance at typical and light load
    • Increased min efficiency at full load from 68% to 70%
    • Serial ATA* connector definition added
    • Acoustic levels added for low noise power supply design
    • Reformat and update revision table
    • Update Disclaimers
    • Remove guidelines for ATX
    • Remove guidance for –5V rail
    • Updated guidance for Energy Star and stand by efficiency
  • 2.0 = februari 2003
    • Added Terminology section
    • Updated power and current guidance
    • Includes 250W, 300W, 350W, and 400W guidance
    • Updated cross regulation graphs
    • Updated load tables
    • Updated required efficiency targets. Added recommended efficiency targets.
    • Increased required minimum efficiency at typical and light load.
    • Main Power Connector changes to 2x12.
    • Aux power connector removed.
    • Required Serial ATA Connector.
    • Isolated current limit on 2x2 connector for 12V2 rail.
  • 2.01 = juni 2004
    • Updated 3.3 V remote sense pin # on the main power connector
    • Updated 12V2 DC Output Noise/Ripple information
    • Updated 5Vsb maximum current step
  • Tim_R
ramonp schreef op dinsdag 16 november 2004 @ 16:43:
Hoezo, er zijn toch nog geen mobo's met 24 pins?? (Correct me if i'm wrong)
Verwijderd schreef op dinsdag 16 november 2004 @ 16:46:
*knip*
*slik*
Owke, maar normaal wordt dat toch nooit vermeld? Waarom nu dan wel, is dit zo speciaal :P
EDIT: als de 24-pins connector er al sinds feb 2004 is (neem ik aan dat het moet zijn :P ) waarom hebben dan nog alle mobo's een 20 pins connector en vaak zo'n rotte condensator in de weg zitten zodat je een verloopstekker moet kopen :?
[ Voor 18% gewijzigd door Tim_R op 16-11-2004 17:08 ]
  • vinnie1908
  • Laatst online: 05-10 10:38
vinnie1908
Appel != peer
Moederborden met 24 pins zijn er wel hoor, de nieuwere chipsets verwachten toch echt een 24 pins ;) overigens zijn er gewoon verloopjes te krijgen
"Sometimes I have a difficult time handling myself in social situations. I just start scampering around neurotically, frantically jumping all over guests. I think it all goes back to when I was raised in the wild by miniature schnauzers."
.. en kun je een 20 pins connector wel aansluiten op een 24 pins moederbord-aansluiting. :)
  • Skaah
EPS is toch ook 24pins?
  • Animal_X
  • Laatst online: 19:17
Animal_X
Rodin
Ik heb even een probleempje dat mij wel in dit topic thuis lijkt te horen, dus vandaar dat ik hem even omhoog schop. Ik heb het volgende vraag:
Die 24-pin naar 20-pin converters, verwijderen die de -5V lijn die normaal gesproken op een 20-pin ATX connector zit? (en dus niet op een 24-pin connector).
Waarom vraag ik dit?
Ik heb vorige week een MSI K8N SLI besteld, en dit moederbord is ATX 2.0 compliant. Dit betekent dus dat er een 24-pin ATX en een 4-pin ATX12V connector op moet worden aangesloten. Alleen hier komt het probleem: De onboard SB-Live chip die op het moederbord zit vereist een -5V lijn en deze zit dus naar mijn weten NIET op een ATX 2.0 voedingsconnector. Dus vandaar dat ik even wil weten of die 24-pin naar 20-pin converters de -5V lijn er ook tussen uit halen of niet aangezien de SB-Live chip het dan dus niet zou doen.
MSI Reminds You...
• These two connectors (JPWR1 & JPWR2) connect to the ATX power supply and have to work together to ensure stable operation of the mainboard.
• Power supply of 450 watts (and above) is highly recommeded for system stability.
• For ATX 12V power connection, it should be greater than 18A.
• For this model, you must use the power supply that with a -5V pin supply.
Kan iemand mij wat meer over de layout/pinout van die converters vertellen? euss?
[ Voor 12% gewijzigd door Animal_X op 22-01-2005 21:40 ]
"It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt."
Kijk of er wel een witte draad zit (of wat voor draad dan ook bij pin 18).
Bij deze dus wél: http://shop.freezinghardw...?Pagina=00003&ItemID=1681 en deze ook: TweakingPro in "ATX stekker past niet op moederbord"
bij deze is het rot te zien: http://www3.alternate.nl/html/nodes_info/tnzv01.html
Een mailtje naar de shop zal 100% uitsluitsel geven, maar het zal me verbazen als ze die draad niet gewoon voeren.
[ Voor 52% gewijzigd door Verwijderd op 22-01-2005 21:46 ]
  • Animal_X
Animal_X
Rodin
Juist, er moet dus een (witte) draad direct van pin 18 aan de ene kant naar pin 18 op de andere kant gaan.
Ok, thanx! Dan zou het dus in principe moeten werken! :)
Neemt trouwens niet weg dat het vreemd is, want de standaard voedingen met een 24-pin connector (die vereist is voor dit specifieke moederbord) heeft die -5V lijn dus niet...
[ Voor 44% gewijzigd door Animal_X op 22-01-2005 21:55 ]
