(library qt-mt) not found, met laatste stable QT3
  • 53 views sinds 30-01-2008
Beste Tweaker,
ik krijg steeds de volgende melding wanneer ./configure uitvoer bij bepaalde modules.
checking for Qt... configure: error: Qt (>= Qt 3.1 (20021021)) (library qt-mt) not found. Please check your installation!
For more details about this problem, look at the end of config.log.
Make sure that you have compiled Qt with thread support!
Ik heb alle pakketten van KDE 3.3.1 geïnstalleerd: ftp://ftp.eu.uu.net/pub/kde/stable/3.3.1/SuSE/x86_64/9.1/
Waaronder dus ook de QT3:
qt3-3.3.3-24.x86_64.rpm
qt3-devel-3.3.3-24.x86_64.rpm
qt3-devel-doc-3.3.3-24.x86_64.rpm
qt3-devel-tools-3.3.3-24.x86_64.rpm
qt3-extensions-3.3.3-24.x86_64.rpm
qt3-man-3.3.3-24.x86_64.rpm
qt3-mysql-3.3.3-24.x86_64.rpm
qt3-non-mt-3.3.3-24.x86_64.rpm
qt3-postgresql-3.3.3-24.x86_64.rpm
qt3-unixODBC-3.3.3-24.x86_64.rpm
Verder ook alle verdere QT modules van mijn SUSE DVD.
Zie ik iets over het hoofd? B)
  • freggy
Wat staat er in config.log?
Freggy schreef op 10 november 2004 @ 20:42:
Sorry voor de late reactie, maar pc werkte niet mee.
config.log zegt heel veel, maar belangrijkste lijkt me dit:
configure:28637: $? = 0
configure:28640: test -s conftest
configure:28643: $? = 0
configure:28662: result: -ljpeg
configure: 28689: ${prefix}/include/jpeglib.h
configure: 28689: /usr/include/jpeglib.h
taking that
configure:28733: checking for perl
configure:28793: result: /usr/bin/perl
configure:28929: checking for Qt
configure: 28997: /usr/lib/qt3/include/qstyle.h
taking that
tried NO
configure:29112: rm -rf SunWS_cache; g++ -o conftest -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wwrite-strings -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common -I/usr/lib/qt3/include -I/usr/X11R6/include -DQT_THREAD_SUPPORT -D_REENTRANT -L/usr/lib/qt3/lib -L/usr/X11R6/lib64 conftest.cc -lqt-mt -lpng -lz -lm -ljpeg -ldl -lXext -lX11 -lSM -lICE -lpthread 1>&5
/usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib/qt3/lib/libqt-mt.so when searching for -lqt-mt
/usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../x86_64-suse-linux/bin/ld: cannot find -lqt-mt
collect2: ld returned 1 exit status
configure:29115: $? = 1
configure: failed program was:
#include "confdefs.h"
#include <qglobal.h>
#include <qapplication.h>
#include <qcursor.h>
#include <qstylefactory.h>
#include <private/qucomextra_p.h>
#if ! (QT_VERSION >= 0x030100)
#error 1
#endif
int main() {
(void)QStyleFactory::create(QString::null);
QCursor c(Qt::WhatsThisCursor);
return 0;
configure:29155: error: Qt (>= Qt 3.1 (20021021)) (library qt-mt) not found. Please check your installation!
Iemand verder een idee?
  • silentsnake
  • Laatst online: 17-06 05:34
Hij slikt het bestaande libqt-mt.so dus niet.
En "bepaalde" modules is een beetje vaag. Kan je niet wat precieser (spel je dat zo?) zijn?
[ Voor 6% gewijzigd door silentsnake op 10-11-2004 22:02 ]
silentsnake schreef op 10 november 2004 @ 22:02:
Nou met bepaalde modules dan heb ik het over de installatie van onder andere kaffeine-0.5-rc2 terwijl xine-lib-1-rc6a bijvoorbeeld geen problemen heeft opgeleverd.
  • freggy
Even googelen op je foutmelding uit config.log levert snel resultaat:
http://mail.kde.org/piper...004-September/005025.html en de oplossing op
http://mail.kde.org/piper...004-September/005035.html
Oké, ik wist niet dat je voor dit soort problemen ook google kon gebruiken. Weet ik dat voor de volgende keer. Anyway, bedankt voor de support ik ga testen of het werkt.
Ik heb de stappen voltooid.
Ik kreeg nog een bericht dat ik het volgende moest doen:
> Add /usr/local/kde/bin to your PATH and
> add /usr/local/kde to your KDEDIRS!
Ik doe dit voor het eerst keer en heb dit gedaan door:
(aan de hand van: http://mail.kde.org/pipermail/quanta/2004-June/004285.html )
export PATH=$PATH:/usr/local/kde/bin
export KDEDIRS=$KDEDIRS:/usr/local/kde
in Konsole in te voeren. Vervolgens gecheck door echo $PATH en echo $KDEDIRS en stonden erbij. Ze zijn alleen weer weg nadat ik Konsole heb afgesloten. Bovendien hou ik dezelfde foutmelding. Ik kan toch de Kosole afsluiten nadat dit:
ingevuld is?
[ Voor 7% gewijzigd door Verwijderd op 11-11-2004 02:34 ]
  • freggy
Voeg dit toe in je ~/.bashrc of /etc/profile of iets dergelijks...
  • Wilke
  • Laatst online: 22:43
OK, dit begint nu toch wel een beetje erg helpdesk-achtig te worden allemaal. Dit kun je ook zelf wel opzoeken. Daarom sluit ik dit topic.
Trouwens, let er ook op dat je de edit-knop gebruikt in plaats van meerdere keren (zeker binnen een uur!) onder elkaar te posten. Je bericht steeds kicken om meer aandacht te krijgen is 'not done' (behalve als het na meer dan een dag helemaal is weggezakt).
