[Router]Error met inloggen via PPTP
Als ik met mijn edimax router (BR-6524K) een PPTP verbinding wil maken met mijn speedtouch adsl modem (verbonden met kpn adsl) dan krijg ik telkens devolgende error:
Nov  7 00:30:41 syslogd started: BusyBox v1.00-pre2 (2004.05.03-07:54+0000)
Nov  7 00:31:04 syslog: IGD root device successfully registered.
Nov  7 00:31:07 syslog: Advertisements Sent.  Listening for requests ...
Nov  7 00:31:11 udhcpc: udhcp client started
Nov  7 00:31:11 udhcpc: Sending select for 10.0.0.2...
Nov  7 00:31:11 udhcpc: Lease of 10.0.0.2 obtained, lease time 7200
Nov  7 00:31:18 syslog: anon log[main:pptp.c:219]: The synchronous pptp option is NOT activated
Nov  7 00:31:18 syslog: anon log[pptp_dispatch_ctrl_packet:pptp_ctrl.c:630]: Client connection established.
Nov  7 00:31:19 syslog: anon log[pptp_dispatch_ctrl_packet:pptp_ctrl.c:758]: Outgoing call established (call ID 0, peer's call ID 0).
Nov  7 00:31:19 pppd[21090]: pppd 2.4.1 started by root, uid 0
Nov  7 00:31:19 pppd[21090]: Couldn't create new ppp unit: Inappropriate ioctl for device
Nov  7 00:31:20 pppd[21090]: Exit.
Nov  7 00:31:21 syslog: anon warn[decaps_hdlc:pptp_gre.c:209]: short read (-1): Input/output error
Nov  7 00:31:21 syslog: anon warn[decaps_hdlc:pptp_gre.c:210]: pppd may have shutdown, see pppd log
Nov  7 00:31:21 syslog: anon log[callmgr_main:pptp_callmgr.c:236]: Closing connection
Nov  7 00:31:21 syslog: anon log[pptp_conn_close:pptp_ctrl.c:357]: Closing PPTP connection
Nov  7 00:31:23 syslog: anon log[call_callback:pptp_callmgr.c:76]: Closing connection
Nov  7 00:31:30 udhcpc: udhcp client started
Nov  7 00:31:31 udhcpc: Sending select for 10.0.0.2...
Nov  7 00:31:31 udhcpc: Lease of 10.0.0.2 obtained, lease time 7200
Nov  7 00:31:34 syslog: anon log[main:pptp.c:219]: The synchronous pptp option is NOT activated
Nov  7 00:31:34 syslog: anon log[pptp_dispatch_ctrl_packet:pptp_ctrl.c:630]: Client connection established.
Nov  7 00:31:35 syslog: anon log[pptp_dispatch_ctrl_packet:pptp_ctrl.c:758]: Outgoing call established (call ID 0, peer's call ID 0).
Nov  7 00:31:35 pppd[21583]: pppd 2.4.1 started by root, uid 0
Nov  7 00:31:35 pppd[21583]: Couldn't create new ppp unit: Inappropriate ioctl for device
Nov  7 00:31:36 pppd[21583]: Exit.
Ik heb geen idee wat er verkeerd gaat, het modem staat op mode:
PPPoA_to_PPTP,no-NAT,DHCP (via een speciaal tooltje van speedtouch geconfigureerd)
Vervolgens heb ik de router op PPTP gezet, mijn username en wachtwoord ingegeven en als gateway 10.0.0.138 ingesteld.
De MTU waarde staat op 1392 (door router zelf gekozen) en connectiontype: continue. Ip adres verkrijgen staat op automatisch.
Wat doe ik hier nu verkeerd, mijn username en wachtwoord zijn 100% correct.
Ik snap er werkelijk niets meer van.
