Vage fout met C++
  • 37 views sinds 30-01-2008
hey,
Ik ben dus nog C++ aan het leren, en nou moest ik deze code gebruiken. Hij werkt alleen niet
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
#include <windows.h>
#include <gl/gl.h>
#include <gl/glu.h>
HDC g_HDC;       //globale device context
//Pixelformatdescriptor
void setuppfd(HDC hDC)
  int nPixelFormat;
  static PIXELFORMATDESCRIPTOR pfd={
        sizeof(PIXELFORMATDESCRIPTOR),
        1,
        PFD_DRAW_TO_WINDOW|
        PFD_SUPPORT_OPENGL|
        PFD_DOUBLEBUFFER,
        PFD_TYPE_RGBA,
        32,
        0,0,0,0,0,0,
        0,
        0,
        0,
        0,0,0,0,
        16,
        0,
        0,
        PFD_MAIN_PLANE,
        0,
        0,0,0};
        nPixelFormat = ChoosePixelFormat(hDC, &pfd);
        SetPixelFormat(hDC,nPixelFormat, &pfd);
//Windows Procedure
LRESULT CALLBACK WndProc(HWND   hwnd,
             UINT   message,
             WPARAM wParam,
             LPARAM lParam)
  static HGLRC hRC;
  static HDC hDC;
  switch (message)
     case WM_CREATE:
    hDC = GetDC(hwnd);
    g_HDC = hDC;
    setuppfd(hDC);
    hRC = wglCreateContext(hDC);
    wglMakeCurrent(hDC,hRC);
    break;
     case WM_CLOSE:
    wglMakeCurrent(hDC,NULL);
    wglDeleteContext(hRC);
    PostQuitMessage(0);
    break;
     case WM_KEYDOWN:
    switch (wParam)
      case VK_ESCAPE:
      PostQuitMessage(0);
      break;
  return DefWindowProc(hwnd,message,wParam,lParam);
//Main Functie
int WINAPI WinMain(HINSTANCE    hInstance,
           HINSTANCE    hPrevInstance,
           LPSTR    lpCmdLine,
           int      nShowCmd)
  WNDCLASSEX    wc;
  HWND      hwnd;
  MSG       msg;
  bool      done=FALSE;
  wc.cbSize     =sizeof(WNDCLASSEX);
  wc.style      = CS_HREDRAW | CS_VREDRAW;
  wc.lpfnWndProc    = WndProc;
  wc.cbClsExtra     = 0;
  wc.cbWndExtra     = 0;
  wc.hInstance      = hInstance;
  wc.hIcon      = LoadIcon(NULL, IDI_APPLICATION);
  wc.hCursor        = LoadCursor(NULL, IDC_ARROW);
  wc.hbrBackground  = NULL;
  wc.lpszMenuName   = NULL;
  wc.lpszClassName  = "OpenGL";
  wc.hIconSm        = LoadIcon(NULL,IDI_WINLOGO);
  RegisterClassEx(&wc);
  hwnd=CreateWindowEx(NULL,
              "OpenGL",
              "glwindow",
              WS_OVERLAPPEDWINDOW |WS_VISIBLE |
              WS_SYSMENU | WS_CLIPCHILDREN |
              WS_CLIPSIBLINGS,
              100,100,
              400,400,
              NULL,
              NULL,
              hInstance,
              NULL);
  ShowWindow(hwnd, SW_SHOW);
  UpdateWindow(hwnd);
  while(!done)
    PeekMessage(&msg,NULL,0,0,PM_REMOVE);
    if (msg.message==WM_QUIT)
    done=TRUE;
    else
        glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
    glLoadIdentity();
    glTranslatef(0.0f,0.0f,0.0f);
    glColor3f(1.0f,0.0f,0.0f);
    glBegin(GL_TRIANGLES);
     glVertex3f(0.0f,0.5f,0.0f);
     glVertex3f(-0.5f,-0.5f,0.0f);
     glVertex3f(0.5f,-0.5f,0.0f);
    glEnd();
    SwapBuffers(g_HDC);
    TranslateMessage(&msg);
    DispatchMessage(&msg);
  return (msg.wParam);
De fout zit op regel 120
[ Voor 4% gewijzigd door Verwijderd op 06-11-2004 14:49 ]
  • Reptile209
  • Laatst online: 07:48
Reptile209
- gers -
Definieer "de fout" :)
Als je nou eens op de regel met CreateWindowEx op F1 ramt, vetelt je IDE hoe de functie zou moeten lopen, en waarom je geen NULL als laatste argument mag hebben staan.
Dit schiet natuurlijk niet op he: 153 regels code plakken en vragen "waarom het niet werkt" :| Zie ook de FAQ van P&W.
[ Voor 6% gewijzigd door Reptile209 op 06-11-2004 14:53 ]
Zo scherp als een voetbal!
Reptile209 schreef op 06 november 2004 @ 14:52:
hoe zou ik het dan moeten vragen? en waar kan ik die error zien? mn compiler zegt alleen dat er daar een fout zit
  • Reptile209
Reptile209
- gers -
Verwijderd schreef op 06 november 2004 @ 14:57:
Je compiler zegt vast niet alleen: "Error on line 120". Dan staat er vast iets als "syntax error on line ...", of "could not resolve CreateWindowEx()" of nog veel meer andere dingen. Zo niet, probeer het dan eens met een andere compiler, want dat soort informatie moet er minimaal wel terugkomen. Nu ik het er toch over heb: waarmee compileer je dit?
  • BasieP
  • Laatst online: 19-10-2025
dit riekt idd erg veel naar huiswerk vraag.
ik zou zeggen, ga zelf debuggen, en kom met een concrete vraag, bijv.
'ik krijg een ... error wanneer ik ... functie aanroep met ... argumenten'
This message was sent on 100% recyclable electrons.
kun je hier iets mee?
[Warning] passing NULL used for non-pointer argument passing 1 of 'HWND__*CreateWindowExa(long unsigned int, const CHAR*, const CHAR*,
[Warning] argument to non-pointer type 'long unsigned int' from NULL
Syntax error before '<<' token
[Build Error] [opengl.o] Error 1
  • Reptile209
Reptile209
- gers -
Okee, daar kunnen we inderdaad wat mee. Het laatste argument is bij jou NULL, ofwel een pointer-adres dat blijkbaar niet van toepassing is. De functie CreateWindowEx verwacht daar alleen geen pointer, maar een "long unsigned int". Maak van dat argument eens een 0 in plaats van een NULL, of lees de help van de betreffende functie er eens op na.
Ik gok dat het misgaat omdat jouw compiler een iets andere definitie voor NULL gebruikt, dan de compiler waarvoor/mee deze code geschreven is. Meestal is NULL namelijk als het getal 0 gedefinieerd en gaat het dus "per ongeluk" goed.
Lastig voor een beginner, maar je moet het ooit leren... :) De hele functie beschrijving vind je ook met [google=CreateWindowEx].
[ Voor 12% gewijzigd door Reptile209 op 06-11-2004 15:24 ]
  • .oisyn
  • Laatst online: 01:54
.oisyn
Moderator Devschuur®
Demotivational Speaker
Hoi,
P&W FAQ - de "quickstart"
Sorry, maar zoals je topic nu is kunnen we er niets mee. Geen goede titel, je geeft een lap code, en dat er iets fout is, maar niet wat er fout is. Wij gaan je code niet voor je debuggen, dat mag je helemaal zelf doen. Probeer de fout te isoleren, en plaats alleen relevante code.
