[Nec 2510A] Write error door slave modus?
  • pjonk
  • Laatst online: 29-12-2025
Met Nero 6.3.1.6 probeer ik een ISO DVD (Philips DVD+R 8x) te branden op een NEC 2510A (firmware 2.15) met 4,5 gb data. Nu geeft Nero kort nadat hij met branden is begonnen al een "Write error". Voor de volledigheid zie het log hieronder:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
15:17:55    #12 Phase 24 File dlgbrnst.cpp, Line 1841
    Caching of files started
15:17:55    #13 Text 0 File Burncd.cpp, Line 4214
    Cache writing successful.
15:17:55    #14 Phase 25 File dlgbrnst.cpp, Line 1841
    Caching of files completed
15:17:55    #15 Phase 36 File dlgbrnst.cpp, Line 1841
    Burn process started at 8x (11.040 KB/s)
15:17:55    #16 Text 0 File ThreadedTransferInterface.cpp, Line 2342
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
15:17:55    #17 SCSI -1066 File Cdrdrv.cpp, Line 1183
    SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x031E5000
    Status:     0x04 (0x01, SCSI_ERR)
    HA-Status   0x00 (0x00, OK)
    TA-Status   0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key:  0x05 (KEY_ILLEGAL_REQUEST)
    Sense Code: 0x24
    Sense Qual: 0x00
    CDB Data:   0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
    Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
                0x00 0x00 0x00 0x00 0x24 0x00
15:17:55    #18 Text 0 File dlgbrnst.cpp, Line 1699
    Set remaining time: 7:04,792 (424792ms) -> OK
15:17:55    #19 Text 0 File DVDPlusRW.cpp, Line 618
    Start write address at LBA 0
    DVD high compatibility mode: Yes
15:18:17    #20 SCSI -1135 File Cdrdrv.cpp, Line 1437
    SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03670000
    Sense Key:  0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x0C
    Sense Qual: 0x00
    CDB Data:   0x2A 0x00 0x00 0x00 0x5E 0xE0 0x00 0x00 0x10 0x00 0x00 0x00
    Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
                0x00 0x00 0x00 0x00 0x0C 0x00
15:18:17    #21 CDR -1135 File Writer.cpp, Line 304
    Write error
15:18:17    #22 Text 0 File ThreadedTransfer.cpp, Line 229
    all writers idle, stopping conversion
15:18:17    #23 Text 0 File ThreadedTransfer.cpp, Line 223
    conversion idle, stopping reader
15:18:18    #24 SCSI -1135 File Cdrdrv.cpp, Line 1183
    Sense Code: 0x0C
    Sense Qual: 0x00
    CDB Data:   0x5B 0x01 0x01 0x00 0x00 0x01 0x00 0x00 0x00 0x00 0x00 0x00
15:18:18    #25 SCSI -1176 File Cdrdrv.cpp, Line 1183
    Sense Code: 0x72
    Sense Qual: 0x03
    CDB Data:   0x5B 0x01 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
                0x00 0x00 0x00 0x00 0x72 0x03
15:18:18    #26 Phase 127 File dlgbrnst.cpp, Line 1841
    Generating DVD high compatibility borders
15:18:18    #27 Text 0 File dlgbrnst.cpp, Line 1699
    Set remaining time: 0:00,000 (0ms) -> OK
15:18:18    #28 CDR -1135 File WriterStatus.cpp, Line 164
    Write error
    _NEC DVD_RW ND-2510A\H1 T1
15:18:18    #29 TRANSFER -24 File WriterStatus.cpp, Line 164
    Could not perform end of Disc-at-once
15:18:18    #30 Text 0 File dlgbrnst.cpp, Line 1699
15:18:18    #31 Phase 38 File dlgbrnst.cpp, Line 1841
    Burn process failed at 8x (11.040 KB/s)
Nu vond ik met Google de volgende website:
http://www.pcwelt.de/forum/archive/index.php/t-133970.html
Hier staat dus het volgende:
Ich habe es doch noch zum Laufen gebracht. Das Laufwerk muss am 2ten IDE Port als Master angeschlossen sein. Bitte
hierbei beachten, der Brenner unterstützt nur den normalen UDMA-2 modus. :D
Ik begrijp hieruit dat de CD-ROM als Master op IDE-2 aangesloten moet zijn. Mijn DVD brander is als Slave aangesloten op IDE-2.
Is dit nou onzin of zou dit inderdaad het probleem kunnen zijn?
It’s nice to be important but it’s more important to be nice
  • BalusC
BalusC
Carpe diem
En heb je het eigenlijk zelf uitgeprobeerd :? Dat hoeft inderdaad geen onzin zijn :) De master heeft voorrang boven de slave bij gelijktijdige operaties. Kennelijk hangt je brander naast een veeleisende master :+
Zie verder ook de FAQ van dit subforum onder "Mijn CD/DVD lezer/brander werkt niet goed" en onder "Hoe kan ik mijn IDE configuratie het beste indelen?" B)
  • pjonk
BalusC schreef op 29 oktober 2004 @ 20:17:
Nee nog niet uitgeprobeerd ben bang om nog meer DVD schijfjes te verkl*ten. Heb helaas nog geen DVD/RW schijfjes hier om lekker mee te testen. Aangezien de Master mijn 2e HD is lijkt me het wel vreemd dat die teveel capaciteit zou vragen. Hieronder mijn volledige IDE configuratie:
DiskPeripheral       : Maxtor 5T030H3                   atapi Port 0 ID 0  DMA: On
CdRomPeripheral      : _NEC DVD_RW ND-2510A             atapi Port 1 ID 1  DMA: On
DiskPeripheral       : Maxtor 6Y080M0          YAR5   si3112r Port 2 ID 0  DMA: Off
Ik zat slap te ullen. Die Maxtor 6Y080M0 S-ATA zit natuurlijk niet op een IDE, maar op mijn Sillicon controller. Ik zal die 2e HD en de DVD/Burner gewoon op aparte IDE channels als master moeten aansluiten.
[ Voor 12% gewijzigd door pjonk op 29-10-2004 20:31 ]
  • pjonk
Even voor de searchers. Het probleem was inderdaad dat de writer als slave op IDE-2 was aangesloten. Foutje van mij, want ik had dit als enige device aangesloten als Slave 8)7
Daarna gejumpered als Master en opnieuw CD gebrand en geen problemen meer gehad.
