[Ervaringen] MSI K8N Neo2 (-54G) deel 3
Pagina: 1 2 ... 6 Laatste
  • 3.378 views sinds 30-01-2008
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/border.PNG
Hier deel 3 van het ervaringen topic van hét nforce-3 socket 939 bord.
In principe is het niet nodig om vorige delen door te nemen.
Mijn doel is om alle belangrijke informatie in de topicstart te hebben.
• [rml][Ervaringen] MSI K8N Neo2 (-54G) deel 1[/rml]
• [rml][Ervaringen] MSI K8N Neo2 (-54G) deel 2[/rml]
In a nutshell, MSI can be greatly considered as the "King of K8 platform."
Afbeeldingslocatie: http://www.msi.com.tw/images/product_img/mbd_img/7025.jpg
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/specs.PNG
CPU
• Supports Socket 939 for AMD® Athlon™ 64 FX / Athlon™ 64 processor
• Supports up to 3500+, 3800+ Athlon 64 FX 53, or higher CPU
Chipset
• nVIDIA® nForce3 Ultra Chipset
- HyperTransport link to the AMD Athlon 64/Athlon 64 FX CPU
- HyperTransport supporting speed up to 1GHz (2000MT/s)
- AGP3.0 8X interface at 533 MT/s (million transfers per second)
- Two independent SATA controllers, for four drives
- IEEE 802.3 NVIDIA MAC for 1000BASE-T
- Dual Fast ATA-133 IDE controllers
Main Memory
• Supports dual channel DDR 266/333/400, using four 184-pin DDR DIMMs.
• Supports a maximum memory size up to 4GB with ECC.
• Supports 2.5v DDR SDRAM DIMM.
Slots
• One AGP (Accelerated Graphics Port) 1.5V 4X/8X slot
• Five 32-bit v2.3 Master PCI bus slots (support 3.3v/5v PCI bus interface).
On-Board IDE/SATA
• An IDE controller on the nVIDIA nForce3 Ultra chipset provides IDE HDD/CD-ROM with PIO,
Bus Master and Ultra DMA133/100/66 operation modes.
- Can connect up to 4 IDE devices
• Supports 4 SATA ports. Transfer rate is up to 150MB/s.
• NV RAID (Software)
• Supports up to 4 SATA & 2 ATA133 Hard drives
- RAID O or 1, 0+1, JBOD is supported
- RAID function work w/ATA133 + SATA H/D or 2 SATA H/D
Audio
• 7.1 channel audio codec RealTek ALC850.
- Compliance with AC97 v2.3 Spec.
- Meet PC2001 audio performance requirement.
LAN
• Supports dual LAN jacks
- 1 LAN supports 10/100/1000 Fast Ethernet by Marvell 88E1111 PHY
- 1 LAN supports 10/100/1000 Fast Ethernet by Realtek 8110S (1000Mbps)
IEEE1394
• VIA 6306 chipset
- Supports up to 3 x 1394 ports.
- Transfer rate is up to 400Mbps
Afbeeldingslocatie: http://www.viperlair.com/images/reviews/cpu_mobo/msi/amd/s939/k8npe/io.jpg
On-Board Peripherals
On-Board Peripherals include:
- 1 floppy port supports 2 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
- 1 serial port
- 1 parallel port supports SPP/EPP/ECP mode
- 1 Audio jack(5-in-1), coaxial/fiber SPDIF out
- 8 USB 2.0 ports (Rear x 4 / Front x 4)
- 2 RJ45 LAN jack
- 3 IEEE 1394 connectors (Rear x 1/ Front x 2)
BIOS
• The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and
expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface(DMI) function which records your mainboard specifications.
Dimension
• 30.5cm(L) x 24.5cm(W) ATX Form Factor
Mounting
• 6 mounting holes.
MSI’s Digicell
CoreCell Chip has four new technical features: Speedster, BuzzFree, PowerPro, and LifePro.
The Speedster technology of CoreCell Chip contains the most flexible BIOS options for overclocking, including async mode of FSB and memory frequency, 0.05V increment for memory voltage adjustment and the minimal increment of 0.0125V for Vcore.
BuzzFree technology examines the current system utilization and temperature level before leveraging thermal requirement & fan speed. It dramatically cuts the system noise by 50% by getting rid of the annoying buzz. Moreover, it also improves the quality of audio and video.
PowerPro prolongs the life of the motherboard, CPU, and fan by maintaining them under the optimum condition. It also detects and manages the motherboard utilization to prevent possible factors that may contribute to system crash.
LifePro technology prolongs the life of the motherboard, CPU and fan by maintaining then under the best condition. It can also detect and manage motherboard utilization to prevent possible factors that may contribute to system crash.
CoreCenter™, this all-in-one hardware console is an advanced combination of the popular PC alert and Fuzzy logic applications. It offers powerful functions such as hardware monitor, system alert, and instinctive overclocking UI.
Live Update™ 3 is a single utility software that automatically checks BIOS and driver updates. It includes MSI's Live BIOS™, Live Drive™, Live VGA BIOS™, and Live Utility™. Advanced users would also receive the latest information about MSI products and activities from MSI technical support.
De Doos :Y)
Afbeeldingslocatie: http://pics.computerbase.de/news/8228/2.jpg
[Meer...]
Inhoud:
• MSI Motherboard
• MSI Driver/Utility CD
• Sata(-raid)-Driver Floppy
• Sata-Cable (Optional)
• Sata Power-cable (for 2 Sata-devices)
• D-Bracket 2 (2 usb-ports)
• Round Cable of IDE-devices
• Round Cable of Floppydisk
• User's Guide
• Quick Guide
• Test Report
• Back IO Shield
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/overklokken.PNG
Dit bordje is ook aardig interessant om over te klokken. Anandtech kreeg in hun review het bordje met gemak op het maximale instelbare, namelijk 300 mhz FSB >:). Met de nieuwste bios is 350 450 mhz instelbaar. Met het standaard fannetje is al aardig ver te komen... 300 was dus geen probleem voor anandtech.
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/koelertje.JPG
Ik kreeg hem zelf met een zalman nj47b blokje op 330 HTT. Maar volgens mij was dit eerder het max van mn cpu, dan de nforce3.
Zoals te zien is, is het een wat andere plaats dan dat je gewend bent voor een northbridge (er is eigenlijk geen sprake meer van north- en southbridge, er is maar 1 chip). Voor waterkoeling op de northbridge lijkt deze plaats niet echt slim uitgekozen. Maar zoals je kan zien zou waterkoeling niet veel nut hebben, je zou er niet hoger door kunnen klokken. Verder zijn er wel wat wc-blokjes die erop passen. Bij koelercompatibility in de eerste reply staat welke koelers je zoal kan gebruiken.
Dit zijn de instelbare items met betrekking tot overklokken:
FSB: 200-450mhz, in stappen van 1mhz. Let wel dat je minimaal bios versie 1.2 erop moet hebben voor een max fsb van 450 mhz (bios 1.0: tot 300 mhz bios 1.1: tot 350 mhz) . Bios-links vind je onder links van dit topic.
CPU Multiplier: 4 - 20 x, Voor FX-cpu's kan men boven de standaard MP instellen. Vanaf bios 1.2 is het mogelijk dit met halve multipliers in te stellen :) Maar dit is niet altijd aan te raden (zie tips)
AGP: 66-100mhz, in stappen van 1mhz
Vcore: 1.55-1.85V, in stappen van 0,05V , maar met de Speedster technology van de Corecell in stappen van 0.0125V. Maar met modded bios kan je zelfs 1.55 v + 18,3 % pakken.
Vdimm: 2.50-2.85V, in stappen van 0,05V. (vind ik een klein beetje jammer :|, had liever tot 3.3 gezien ;) .. zie mods)
AGP-voltage: 1.50-1.85V, in stappen van 0,05V
Verder zijn er ook nog Hidden Bios Opties:
Vid Hiermee kan je het voltage van de voltageregulator regelen als ik het goed heb begrepen. Dit zou misschien wat impact kunnen hebben op de hoogte en stabiliteit van de vcore.
NV/ATI Speed up Met deze setting kan je jou agp-kaart wat extra mhz-en laten geven, geregeld door het moederboard. Zowel je videogeheugen als gpu wordt iets opgekrikt (10 à 20 mhz). Clock je liever zelf gewoon je kaart over, zet deze functie dan op disabled.
Lees voordat je aan het overklokken gaat nog even de tips door, hier staan belangrijke dingen zoals het gebruik van sata-poorten en overklokken...
• Mods
OCZ DDR-Booster
Na even rondgeneusd te hebben op Xtreme Systems kwam ik een post tegen waar iemand de OCZ DDR-Booster gebruikte op de k8n Neo 2 :) Deze lijkt dus compatible te zijn:
Ok I am now running the ddr booster at 3.2v on my Neo2. It does work fine and has allowed me to hit 300HTT 1:1 so far on my 3500 EBs.
* Tutti-frutti heeft zelf de ddrbooster getest, en het werkte
Vdimm @ Vio mod
Helaas geen tussen stappen, maar wel 3.3 volt op je dimmetjes ! Handig als je winbond chippies hebt.
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/vdimmod.JPG
Thnx to Garrett
Vdimm-, Vdrain- , Vcore- en vht mod
Leef je uit
(Vht = ht-bus voltage, dus meer volt erop.. meer mhz over de bus mogelijk.)
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/tips.PNG
Hier staan bekende problemen met oplossingen, of tips waardoor je meer performance kan krijgen.
Hogere Memory-bandwidth
Voor hogere geheugen scores moet je in het Cell-menu, bij memory settings de "1T/2T Memory Timings" op 1T zetten. De score met een HTT van 200 (ddr400) vliegt dan van zo'n 4800 MB/s naar 5900 MB/s !
Oplossing voor de combinatie: overklokken + Sata-schijven
Het blijkt dat de Sata-poorten 1 en 2 geen goedwerkende PCI-lock hebben. De pci-lock functioneert wel correct op de poorten 3 en 4. Gebruik daarom als je van plan bent te gaan overklokken de sata-poorten 3 en4. Zorg er ook voor dat je minimaal bios 1.2 draait. Mijn advies is ook om sata 1/2 op disabled te zetten bij Integrated Peripherals.
Met de satapoorten 1 en 2 zou je niet hoog kunnen komen met de htt. Misschien komt hier nog een biosupdate voor...
Pas op met het gebruik van halve multipliers
Sinds bios 1.2 kunnen er in de cell menu (bios) halve multipliers voor de cpu-speed ingesteld worden. Het is aan te raden om deze niet te gebruiken, omdat je dan performance verliest op je geheugensnelheid. Het werkt namelijk alsvolgt:
Als je cpu-HTT en mem 1:1 lopen, en de multiplier van de cpu is 11x, dan wordt de memspeed vastgelegd door de cpu speed door 11 te delen. Voorbeeld: HTT=250, MP=10. Mem speed = 2500/10 = 250 (ddr500).
Pak je nu 10.5 als multiplier, dan wordt de mem speed als volgt:
cpu-speed = 10.5x250 = 2625
Mem-speed = 2625/11 = 239 mhz.
Dit zit hem in de cpu memcontroler en kan helaas niet veranderd worden, de cpu kan alleen door hele multipliers delen.
Halve multipliers zijn wel aan te raden , als je cpu nog niet aan zn max zit, maar mem wel. Je kan zelf het beste even kijken wat het beste resultaat oplevert.
In mijn geval heb ik ook even getest. Ik ga zelf wél voor een halve mp:
11x232 , ddr464 = 6903 MB/s @ sisoft membench
10.5x243 , ddr464 = 6907 MB/s @ sisoft membench
ik heb meerdere malen getest, maar veel verschil is het natuurlijk niet...
thnx to Pakjebakmeel voor quote van forum
Windows installeren op een Sata-Raid array
Tijdens het laden van de windows setup moet je, zoals gewoonlijk met raid-configuraties, op F6 rammen. Bij het bord is een floppy geleverd met daarop de Raid drivers. Je moet tijdens de setup niet 1, maar 2 drivers installeren, namelijk:
-Raid Class Driver
-Storage Controller
Dit is erg belangrijk, anders ziet windows de schijven appart, en niet als 1 raidarray.
BSOD's ? Aggressive timings op Disabled zetten!
Aggressive Timings blijkt nu ook een erg bekende oorzaak te zijn van de blauwe schermen. Je zal waarschijnlijk, met Aggresive timings aan, veel BSOD's krijgen met "Beginning of dump Physical Memory". Wanneer je Aggressive timings uitzet in het Cel menu, zal je systeem hoogstwaarschijnlijk stabiel zijn :).
Nog steeds Instabiel ?
Nadat er erg wat postings geweest waren met instabiliteitsproblemen lijkt het erop dat de gegevens uit de SPD-chips op de geheugenmodules niet goed worden uitgelezen. Ik weet niet of dit aan het bord of aan de geheugencontroler van de cpu's ligt. Oplossing lijkt gewoon het zelf instellen van memorytimings en geheugen voltage.
Daarnaast is het aan te raden om ALTIJD satapoort 3 en 4 te gebruiken, zoals hierboven beschreven.
Dual Channel, welke slots ?
Als je DUAL CHANNEL wilt laten werken dan moet je de 2 latjes ram in het groen EN paarse slot steken(slot 1 & 2). Dit zijn dus de 2 onderste geheugenbanken. Dit is dus niet, zoals bij intel, in het eerste en derde slot. Als je het in slot 1 & 3 plaatst heb je kans op een instabiel systeem. Dit staat ook volledig uitgelegd in de manual :)
thnx to kennes
Audio-driver installeren, erg belangrijk!
Als je standaard de drivers van nvidia installeerd (nforce drivers) dan worden de audio drivers niet geinstalleerd. En dan kan je de nvmixer ook niet gebruiken. En omdat de nvidia drivers veel beter klinken zijn die drivers toch aan te raden. Om hier gebruik van te kunnen maken moet je de drivers MANUEEL installeren. Rechts klikken in apparaatbeheer op het audiodingie. dan moet je NIET ZOEKEN nemen en dan bladeren en dan de file nvmcp.inf, en vervolgens 1 van de die items die erop komen. (die nvmcp.inf file haal je uit de c:\NVIDIA\4.27\audiodrv-map). Je kan op deze manier gebruik maken van alle nvidia geluidsfuncties, en bijvoorbeeld ook het volume per box instellen :).
thnx to kennes
Systeem hangt al VOOR de post
Misschien heb jij net zoals mindcrash het probleem dat het systeem niets doet. Dit kan natuurlijk aan van alles liggen. Het is natuurlijk zoals altijd goed, om in dat geval zo weinig mogelijk aan je moederboard te hangen, en een bios reset wil ook wel eens helpen. Mindcrash kwam erachter dat zijn muis voor het probleem zorgde:
Ik dacht eerst dat het spontane hangen bij het booten aan mijn videokaart lag, maar na het verwisselen van mijn Intellimouse aan de PS/2 poort voor mijn nieuwe MX1000 aan de USB poort start mijn rig zonder problemen op.
Koop geen Antec 350w
Wat er nu precies met dit type voeding aan de hand is dat het niet goed werkt met de neo 2, misschien de atx stekker (als je die aandrukt doet het systeem het), maar het is in ieder geval niet aan te raden deze voeding te kopen. Er zijn al 4 gevallen bekend onder de gotters hier met problemen.
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/links.PNG
• Fabrikantinfo:
MSI K8N Neo 2 Platinum
• Handleiding
De Handleiding V1.1 (pdf , 7MB)
• Reviews
Anandtech Socket939 motherboard Round Up
PC Perspective Review
Een magere Zdnet review
Hot Hardware S939-motherboard round up
• Waar is de MSI K8N Neo2 het goedkoopste?
Link Naar de pricewatch
• Biossen
Update je bios, en je moederboard wordt instelbaar tot 450mhz })
Msi Biossen
In bios 1.2 zitten de volgende changelogs:
- Support FSB to 450MHz
- Support K8 CPU Rev. D 939-Pin 128-bit
+ Added .5 multipliers !
+ Fixed CPU temps !
+ Pci-lock werkt correct. Helaas nog niet op sata-poort 1 en 2
Bios 1.3
- Update CPU ID.
- Support Sempron CPU 1800+
- Fixed K8-939 RevD CPU cool 'n' quiet can't work properly
Nu blijkt dat 1.3 beta 6 nog een toevoeging heeft op de officiele bios, hij is hieronder te downloaden:
-Fixes HT mess in the official 1.3 bios and adds higher CPU voltages.
Beta en modded:
- Hier
- Hier
- Hier
- Hier *
*Op deze site kun je ook modded biossen vinden, met alle hidden options unlocked, en hogere vcore >:))
Nummering van biossen werkt als volgt: 1.23 = 1.2 beta 3 , 1.2= 1.2 official
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/etc.PNG
Mijn ervaring:
Voor mijn ervaring ga je naar deel 1 of 2 van dit topic. Mijn ervaring staat in de openingspost
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/thumbneo1.JPG Afbeeldingslocatie: http://www.chastelet.demon.nl/1/thumbneo2.JPG
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/thumbneo3.JPG Afbeeldingslocatie: http://www.chastelet.demon.nl/1/thumbneo4.JPG
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/thumbneo5.JPG Afbeeldingslocatie: http://www.chastelet.demon.nl/1/thumbneo6.JPG
Toevoegingen / Vragen ?
Heb je nog vragen of toevoegingen waarvan je denkt dat dit de startpost moet komen ?
Mail me via Afbeeldingslocatie: http://www.chastelet.demon.nl/1/neo2/email.GIF
[ Voor 31% gewijzigd door Tutti-frutti op 17-11-2004 01:13 ]
4015Wp west (Dordrecht)
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
(In)compatible Koelers
Afbeeldingslocatie: http://www.tweakers.net/g/table/spacer.gif
Als toevoeging op de startpost zal ik hier een lijst plaatsen met compatible koelers. Dit wegens de afwijkende lay-out van het bord die naast zijn voordelen (betere flow), helaas ook zijn nadelen kent dat er een aantal koelers niet passen. Hier plaats ik de koelers waar twijfels over kunnen bestaan.
Mail me dus als je weet dat jouw koeler/vgakoeler/cpukoeler-combinatie wel of niet past:
CPU
Zalman 7000 CNPS 7000 (A/B) (Cu/Al/Al-Cu)
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/neo2/zalman70001.JPG Afbeeldingslocatie: http://www.chastelet.demon.nl/1/neo2/zalman70002.JPG
Deze koeler past mits je geen passieve heatpipe koeling gebruikt. Mocht je ook gebruik maken van wat hogere geheugenmodules zoals Corsair XXL Pro geheugen, dan zou je deze in slot 3 en 4 moeten doen.
Coolermaster Hyper 6
Afbeeldingslocatie: http://www.viperlair.com/images/reviews/cpu_mobo/msi/amd/s939/k8npe/tight.jpg
Deze koeler past wel, alleen kan het zijn dat het niet echt super werkt voor de airflow in bepaalde kasten
Chipset
Zalman N47J
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/neo2/zalman47.JPG
De N47J past op de nforce3-chip, als je geen heatpipegeval of grote vgakoeler (Arctic silencer) gebruikt. Hij past in ieder geval met de volgende 3dkaarten:
-9800pro (evt. 2 pinnetjes iets naar binnen buigen, maar niet nodig)
-X800 (pro/xt) kaarten.
Hij past NIET met de volgende kaarten:
-Nvidia 6800 series.
Graph-O-Matic Rev2.0 VGA & Chipset
Afbeeldingslocatie: http://www.innovatek.de/contentServ/3.0/www.innovatek.de/data/media/191/500618.jpg
Deze past zonder problemen.
VGA-koelers
Heatpipe Koelers
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/neo2/zalman80hp.JPG
Door het gebruik van heatpipekoelers vervallen een aantal mogelijkheden voor het plaatsen van andere koelers. Bepaalde cpu-koelers zullen hierdoor in de knoop komen (zoals de 7000-serie van zalman). Andere chipset-koeling wordt onmogelijk, tenzij je een betere en net zo'n lage koeler als de standaard msi koeler weet te vinden.
Arctic Silencer
Afbeeldingslocatie: http://www.colorstone.com.tw/proimages/f1/arcticcooling/vga.jpg
Door het plaatsen van deze koeler wordt het moeilijker om andere chipsetkoelers te plaatsen.
  • wippo76
  • Laatst online: 17-05 08:32
QUOTE uit deel 2:Ik heb dit bordje ook sinds kort en het bevalt me aardig tot nu toe
Ik heb alleen helaas 2x512 mb Corsair dubbel sided erin zitten, dualchannel is 333 Mhz dus.
http://www.msi.com.tw/pro...ro_mbd_detail.php?UID=607
Volgens de manual moet het gewoon mogelijk zijn als je de reepjes dubbel sided in slot 1 en 2 duwt om ddr400 te draaien
dus dat is dan vreemd als dat niet werkt
[ Voor 29% gewijzigd door wippo76 op 28-10-2004 22:51 ]
Ja zou ik ook zeggen
Heb me ook nieuw systeem besteld op basis van dit bord:
AMD Athlon 3500+ Socket 939
Zalman CNPS 7000B-CU (AMD converted)
MSI K8N Neo2 Platinum Socket 939
2 x 512MB Corsair PC3200 CAS2 HSP DDR Dual Channel
Point of View GF 6800 GT 256 DDR3 @350/1000
Western Digital 160GB 8MB SATA150 7200RPM
Creative Soundblaster Audigy 2 SZ
Plextor DVD PX-116A
Pioneer DVR-108B Dual Layer DVD brander
Floppy Drive 3.5"
AOPEN H600B 350W Black Case Airguide 1.1
Is dit, op basis van de msi mobo, een goed overklokbaar systeem ?
  • ID-College
  • Laatst online: 19-11 20:39
Verwijderd schreef op 29 oktober 2004 @ 00:03:
Plextor DVD PX-116A
Floppy Drive 3.5"
Yep, volgens mij wel. Maar is die 350W genoeg denk je met overklokken?
  • Goofy
  • Laatst online: 20-10 13:19
Mijn G.Skill latjes zijn dubbel-sided, dus ik veronderstel dat de setjes van de andere tweakers hier dat ook zijn, en daar heeft afaik toch niemand 'problemen' mee gehad, dat ze bijvoorbeeld maar op 333Mhz wilden draaien? Of mis ik hier iets? :?
  • makje
  • Laatst online: 19-11 20:56
makje
Professioneel prutser
Nee hoor, voor zover ik weet heeeft niemand problemen om met 2 double-sided reepjes op 200Mhz te draaien.
Wil je in alle 4 sloten reepjes geheugen stoppen dán moeten ze allemaal single-sided zijn om op 200Mhz te werken, 4 double-sided reepjes werken slechts op 166Mhz, althans volgens de manual (p. E-2-8)
@ double-sided reepjes in sloten 1 en 3 (die beide aangesloten zijn op de 1e controller) resulteert ook in een maximale snelheid van 166Mhz. Hetzelfde geldt voor 2 double-sided reepjs in de sloten 2 en 4 (de 2e geheugencontroller), alleen zal dat sowieso niet werken daar het niet mogelijk is enkel de 2e geheugencontroller te gebruiken.
Conclusie hiervan is: MSI heeft moeite om om hogere snelheden stabiliteit te garanderen en garandeerd daarom op 200Mhz slechts 3 banken (= 1 double-sided + 1 single-sided reepje) per geheugencontroller
[ Voor 49% gewijzigd door makje op 29-10-2004 00:55 ]
9800x3d
ID-College schreef op 29 oktober 2004 @ 00:09:
Daar zeg je zoiets ... nu ja, een voeding is snel vervangen, het was vooral de kast die me aanstond :)
Aangezien dit mijn eerste amd-systeem is => is er iemand die een link heeft naar een overklok-guide of startersguide ? Wat jullie hier allemaal komen te vertellen is chinees voor mij :)
[ Voor 3% gewijzigd door Verwijderd op 29-10-2004 01:08 ]
  • Misterpc
  • Laatst online: 07:47
hallo ,
ook ik heb gisteren een MSI K8n neo2 plat. bord + 3500+ en zalman binnengekregen , nu heb ik alleen een heel vaag probleem ,
ik gebruik een Vidac TV kaart en deze geeft nu verticale strepen door het beeld heen als het lijjkt of de videokaart stuk is , maar 3dmark2003 doet het perfect !.
het zou kunnen zijn dat de tv kaart stuk is , maar daarvoor geen enkel probleem mee gehad onder Wxp op een epox 8rda3+ .
Mijn vraag is nu , zijn er mensen die ook problemen hebben of gehad hebben met een TV kaart met dit moederbord en of ze daar ook een oplossing voor hebben kunnen vinden .
config :
Msi K8N neo 2 plat , AMD64 3500+ , Zalman 7000 , 2 * 512 MB corsair C2
Club3d 9800 pro , SB audigy , Vidac Vmagic , Wireless kaart MSI .
Samsung SP1614n SP1614C Sata , Toshiba DVD en nec 2500 brander ,
OS : Windows XP home + SP1 , Nforce 5.10 , DX9.0b .
B & W 5,8 KWp solar 12 * oost 10 * west
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Misterpc schreef op 29 oktober 2004 @ 08:51:
hallo ,
config :
Je hebt de kaart gewoon in een wit pci-slot zitten lijkt me. Misschien iets met de aarding van de pc te maken, je zou hem kunnen aarden.
  • Misterpc
@ Tutti-Frutti ,
Aarding is al jaren het geval , en let wel : het heeft ok al tijden goed gewerkt ,
helaas ben ik er gisteren avond niet meer aan toegekomen om te controleren of de tv kaart nog goed is maar het lijkt me wel .
Ik zelf zit te denken aan een combinatie probleem met bijvoorbeeld de W-lan kaart in het roze slot , iemand daar al problemen mee of niet ?
  • KeaveXL
  • Laatst online: 16:03
Ik heb ook net mn nieuwe systeempje besteld:
Thermaltake XaserV WinGo V7000A
Coolermaster Real Power 450 watt
Msi K8N Neo2 Platinum (-54g) (duh)
AMD Box Athlon 64 3500+ Box
Corsair TWINX1024-3200C2PT PC3200, 400 MHz, Kit of2
XFX 6800GT incl. DOOM3 256 MB
Seagate Barracuda 7200.7 160 GB, 7200 rpm, 8 MB
NEC ND-3500 16 Speed + Dual Layer Zwart
Zalman Surround Sound Headphones RS-6F + ZM-MIC
Logitech MX1000
Logitech media keybord
Samsung 710T, 17", 12ms
Krijg woensdag mn mobo, processor, brander, muis, tobo en monitor.. De rest komt over 18 dagen :( (door mn videokaart)
T zal vast wel werken allemaal, maar t wordt eigenlijk mn eerste zelfbouw systeempje O-)
Heb de voorgaande topics is ff doorgelezen maar niemand gezien met mijn voeding, maar die zal het wel moeten doen denk ik zo.
Verder geen schokkende post, wil alleen ff melden dat ik er ook ben (nieuw) >:)
PSN: KeaveXL
  • Slowmotion
  • Laatst online: 10:23
Sinds kort heb ik het probleem dat m`n Keyboard niet wordt herkend of
gewoon helemaal vastloopt. (num lock lampje blijft branden) maar de
PC loopt wel gewoon goed.
zijn hier meer mensen met dit probleem.
specs:
msi mobo bios 1.3
amd 3500 +
2 x 512 twinmos
nexus breeze
2 x 160 gig maxtor
heb nu zelf m`n bios quick boot (of zo iets) uit gezet zodat ik kan
testen of m`n keyboard het wel doet ja of nee.
hierna kan ik hem ff opnieuw inpluggen en de reset knop indrukken
en dan doet hij het weer perfect...
heb dit probleem nog niet eerder bij iemand tegen gekomen,
enof dit bij een andere PC tegengekomen..
anyone a ID
  • sn0x0r
  • Laatst online: 18-11 09:49
KeaveXL schreef op 29 oktober 2004 @ 09:16:
Naja, laten we het er maar op houden dat je hoop hebt :P
  • KeaveXL
sn0x0r schreef op 29 oktober 2004 @ 10:38:
Nou zo erg is het niet hoor :P , heb voor mn opleiding (ict) al meerdere nieuwe systemen moeten bouwen. Ook werk ik als monteur bij een computerwinkel, t is alleen wel voor het eerst dat ik zelf zon duur systeem koop en inelkaar ga zetten.
PSN: KeaveXL
  • pelican
pelican
Die nieuwe Zalman koeler gaat dus never nooit niet passen?
Zalman CNPS7700 is uit !
http://www.overclockers.r...?category=2&id=1098217414
  • Semetrix
  • Laatst online: 08:06
_/-\o_ @ Beta Bios 1.35 _/-\o_
Nu geen last meer van een lagere Vcore dan de ingestelde waarde tijdens het stressen.
En mijn G.Skill geheugen kan nu dus wel booten op 2,5-3-3-7 en werkt perfect zonder enige memtest error :)
Nog bedankt voor de tip Tutti-frutti.
  • William/Ax3
  • Laatst online: 20-11 09:48
William/Ax3
We are Starstuff
Zo kep de zooi ook binnen. Ff beetje ge oc'ed en resultaat is zie spec ;) Loopt hier super niks gerommel :D
Van de week is verder rotzooien maar tot nu toe tevreden ;)
[ Voor 25% gewijzigd door William/Ax3 op 29-10-2004 15:28 ]
|WOW Daggerspine | Troll Hunter Axejess |
hoe komen ze eigenlijk aan die beta biossen, vraag ik me af.
hallo,
begrijp ik dat doublesided memory verhaal nou goed? ik heb keurig kingston pc4000 512 reepjes wat ik wil gaan gebruiken. kan dat nu maximaal op 333??
het gaat om dit geheugen:
http://www.ec.kingston.co...asp?ktcpartno=KHX4000/512
icm een 3500+ en een k8n neo2
ik wilde toch echt richting de 250 gaan....
  • KifArU
Even opgemeten hoeveel ruimte er nog is met een 7000 tussen de koeler en de videokaart en dat is 9mm. De 7700 heeft een straal die 13mm groter is, dus dat gaat inderdaad niet lukken. Helaas.
[ Voor 5% gewijzigd door KifArU op 29-10-2004 22:58 ]
Slowmotion...
2 identieke maxtor HDD kunnen niet wegens fout in MSI BIOS.
Zie mijn postings in DEEL 2 achteraan.
Switch de 2e Maxtor voor Hitachi of Seagate (no joke).
Is waarschijnlijk dat.
Succes.
  • mindcrash
  • Laatst online: 25-09 21:15
mindcrash
Rebellious Monkey
Verwijderd schreef op 29 oktober 2004 @ 17:29:
Beta testers wellicht?
"The people who are crazy enough to think they could change the world, are the ones who do." -- Steve Jobs (1955-2011) , Aaron Swartz (1986-2013)
  • LoeiOrdinair
LoeiOrdinair
To Infinity and Beyond
Ik heb een probleem dat mijn pc met dit mobo niet goed opstart. Heel vaak "loopt hij vast" bij het checken van de IDE drives. Iemand hier met het zelfde probleem en ook met een oplossing.
systeem:
AMD64 3500+
Corsair 1024MB DDR 400 2X64MX64
WD 200gb SATA
  • William/Ax3
William/Ax3
We are Starstuff
Verwijderd schreef op 29 oktober 2004 @ 22:34:
hallo,
Moet geen prob zijn kep zelf hier corsair twinx pc3200 c2 erin in slot 1 en 2 en loopt vrolijk op 240 (ddr 480). Kijk maar naar de rest van de ervaringen in deze topic(s).
  • wenneyhanney
  • Laatst online: 26-09 13:23
Uit mijn ervaring is K8N Neo2 een goeie OC boord! Ik had in China 2x512MB GeiL Value Ram gekocht voor 130 euro :P .Standard draait hij op 3-4-4-8 @400 MHZ. Na het bios update (v1.3) had ik de geheugen vol opgevoerd naar 2.5-3-3-6 @444 MHZ >:) en alles draait nog prefect en dus zit ik nu met een 3500+ @2.44 GHZ. Het was niet in het geval bij mijn ouwe K7T600 Mobo.
Spec:
AMD Athlon 64 3500+ op stock Ajigo cooler
1GB GeiL value ram
Msi K8N Neo2 platinium
Conclusie: Het is dus een prefecte AMD 939 boord voor een aantrekkelijke prijs. _/-\o_
[ Voor 17% gewijzigd door wenneyhanney op 30-10-2004 00:27 ]
Hope for the best, prepare for the worst...
  • Misterpc
hallo ,
ondanks de problemen met de tv kaart (die het in een ander systeem wel goed doet) .
heb ik nog even een andere performance vraag ,
in 3dmark 2003 haal ik zo 6000 punten ,
met mijn AMD 64 3500+ en een radeon 9800 pro (niks ge oced).
2 * 512 MB corsair cl2 3-3-9 .
en zelf vind ik dit een beetje te langzaam ,
wat halen mensen met een vergelijkbare config ?
  • William/Ax3
William/Ax3
We are Starstuff
Misterpc schreef op 30 oktober 2004 @ 11:00:
hallo ,
Volgens mij is dat best redelijk. Kan je geen vergelijking geven aangezien ik een 6800le heb ik zit nu over de 12k :D
  • sn0x0r
Ik zit er eigenlijk nu pas naar te kijken, maar het 1.3 beta 5 bios is toch ouder dan het 1.3 bios, en toch werkt het geheugen van GSkill beter met het beta 5 bios? (En het beta 7 bios, hoe zit het daarmee?)
  • NaZGuLL
NaZGuLL
Capo di Tutti Capi
Net even een MSI K8N Neo2 gescored, FX55 is ook binnen. Gaan met die banaan, ben benieuwd.
I've seen things you people wouldn't believe, a P4 on fire at Mach2. I watched DDR-memory glitter in the dark. All those moments will be lost in time, like money down the drain. Time to spend.
  • Slowmotion
Verwijderd schreef op 29 oktober 2004 @ 22:51:
Slowmotion...
Succes.
ik Ga m`n 2e HD is even los maken en even een weekje proberen of dit wat oplost.
Thnks 4 the info SimFan
Werkt dit mobo ook goed met pc3200 twinmos/twinmos dualchannel geheugen (2x512mb)? Ik zag op sommige webshops wel staan dat het niet met kingston ging werken maar twinmos zijden ze niks over.
Slowmotion,
Als dit bevestigd wordt (mijn probleem & oplossing is gemeld aan MSI) door uw ervaring zou het nuttig kunnen zijn dit op te nemen in de algemene posting bovenaan.
Probleem met deze dingen is natuurlijk: meestal doet het iets zich in een bepaald geval voor, niet altijd in een andere situatie.
Dit was met 2 Maxtor Diamondmax 10 - SATA - 200GB. Niets zegt dat het zich daarom algemeen voordoet.
Meld AUB of ontkoppelen van 2e HDD al dan niet hielp.
NB. BIOS was v1.3.
BIOS is in mijn geval het probleem.
hmm...
mijn nieuwe config zal ook 2 maxtors in raid 0 draaien..
maxtor diamond max plus 9 120 GB SATA
ik laat het weten of het lukt!
  • Misterpc
Na gisteren al wat opmerkingen te hebben geplaatst over problemen met het nieuwe MSI bord hier het vervolg :
De Vidac Vmagic TV kaart werkt in de andere PC perfect , maar icm msi blijft te software vaak hangen of gaat vaak hangen en opnamen zijn ronduit bagger ,
Beeld en geluid zijn dan gestoord , en de weergave geeft ook verticale beeld artifact , en ik weet eerlijk gezegd niet wie / wat ik nu verdenken moet en instellingen veranderen in de bios zijn ook al haast niet mogelijk , Tips Welkom .
ps , ik heb nog wel een screenshot / test opname die kan ik opsturen op verzoek .
2. Na meerdere Test met oa. 3dmark03/05 het resultaat 6080 / 2368 .
ik heb met de online result browser rondgekeken en kwam tot de ontdekking dat het sneller kan , 3dmark03 = 7000 , 05 = 2950 , maar ondanks dat er dan staat dat zowel het systeem als de videokaart niet worden overgeklokt vraag ik me dan af hoe kan het verschil zo groot zijn :O .
Als er iemand is die ook problemen heeft met een tv kaart icm met de MSI k8n neo2 en vond een oplossing hoor ik het graag .
[ Voor 6% gewijzigd door Misterpc op 31-10-2004 11:00 ]
LoeiOrdinair schreef op 29 oktober 2004 @ 23:00:
Mpass,
Ik had dit zelfde probleem bij het rebooten, maar niet bij gewoon opstarten. Wel als ik in de bios was geweest en daarvandaan wilde opstarten. Ik heb uiteindelijk iets eenvoudigs geprobeerd wat ik elders had gelezen:
- verwijder je ide apparaten in hardware manager (bij mij was dat 2 x dvd)
- pc uit
- koppel je ide apparaten af van het moederbord
- normaal opstarten
- je zal zien dat opstarten en rebooten gewoon gaat
- pc uit, ide weer aansluiten en opstarten maar
- windows ziet de nieuwe ide drives en bij mij werkte het vanaf dat moment.
give it a try......
Mace
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Verwijderd schreef op 31 oktober 2004 @ 10:16:
hmm...
Ja, dat lukt. Ik heb zelf 2x 80 GB dmp9 sata.
  • KeaveXL
Halo,
Ik heb nog even een vraagje. Ik krijg volgende week dus alles binnen maar dit wordt het eerste systeem dat ik bouw met sata schijven. Ik heb gelezen dat je dan eerst sata controllers moet installeren voordat je windows erop kan zetten. Die sata controllers moeten bij je moederbord op een floppy staan, alleen ik heb geen floppy drive bij mn pc besteld. Kan ik deze dan ook gewoon met een andere pc eerst op cd branden? Alvast bedankt!
PSN: KeaveXL
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
KeaveXL schreef op 31 oktober 2004 @ 13:02:
Halo,
Volgens mij kan windows xp alleen de drivers van FDD lezen. Er zou denk ik wel een oplossing zijn, maar die is niet zo makkelijk (zelf drivers op windows cd erbij branden ofzo), maar dit zou ik niet weten.
  • M55
M55
Ik sluit mijn Palm 3c aan via de craddle op de serieele poort. Maar hotsync ziet hem niet, vaag want in de systeemeigenschappen staat de COM1 poort er gewoon bij. Ik pak de Palm uit de craddle.. snif snif.. ja hoor brand lucht :(.
Kut craddle waarschijnlijk kapot, voor de zekerheid sluit ik serieele muis aan om te kijken of de COM poort wel werkt, maar niet dus.
Iemand een idee, hoe ik zeker kan weten dat de COM poort kaduk is?
En hoe kan die craddle zomaar doorbranden ? Op mijn vorige PC werkte hij gewoon goed ?
hmm heb me muis nu wat langer eraan hangen.. en wordt warm :X :X
ik maak wel ff nieuw topic
[ Voor 19% gewijzigd door M55 op 31-10-2004 15:51 ]
  • Nilco
  • Laatst online: 20-11 16:38
@m55: als ik dat zo lees zou ik denken dat er te veel stroom door je COMpoort gejaagd wordt.
  • M55
M55
MEGATRON schreef op 31 oktober 2004 @ 13:46:
ja, ik ga het maar ff nameten..
maar hoe kan dit gebeuren ?
ik meet ongeveer -7volt 8)7
[ Voor 7% gewijzigd door M55 op 31-10-2004 15:12 ]
  • Operations
  • Laatst online: 30-10 17:29
Is het nou waar dat dit moederbord problemen heeft met Kingston (hyperX) modules (volgens b.v. cool-prices.nl werkt dit bord niet met kingston modules)? Sta op het punt om dit bord te bestellen maar dan moeten me 2 kingston modules wel werken natuurlijk heb geen zin om ook nieuw geheugen te moeten kopen.
PC1: ASUS B850-Plus WiFi -- 9900X incl. X72 -- 64GB DDR5-6000Mhz -- Kingston Fury Renegade G5 2TB -- DELL 4025QW | Servers: 2x DELL R730 -- E5-2660 v4 -- 256GB -- Synology DS3617xs: 4x1,92TB SSD RAID F1 -- 6x8TB WD Purple RAID5
  • tweakraiser
  • Laatst online: 19-11 13:28
tweakraiser
I have such sites to show you
TheGeneral schreef op 31 oktober 2004 @ 15:02:
Ik heb precies de zelfde vraag!
Ik heb een MSI K8n neo2 besteld samen met Kingston 1GB DD400 HyperX 232 KIT KVR. Iemand ervaringen en tips over dit specifieke geheugen.
Ik heb van verschillende mensen verschillende verhalen gehoord (stabiliteits problemen e.d.)
(Anders moet ik heel snel m'n bestelling gaan veranderen :()
[ Voor 5% gewijzigd door tweakraiser op 31-10-2004 16:35 ]
Strava | Webdesign
  • *discostar*
Hyper X Ultra Low-Latency (KHX3200UlK2/1G) werkt hier probleemloos in dualchannel :*)
  • Operations
*discostar* schreef op 31 oktober 2004 @ 17:00:
Ik heb hier 2x256 mb DDR500 Cas3 geloof ik. Maar ik moet het wel even zeker weten. En even voor de duidelijkheid heeft de MSI k8n neo (s754) nog wel of geen agp/pci lock?? (heb nou zoveel topics gezien met tegenstrijdige info dat ik het niet meer weet)
En als me kingston mem niet gaat werken, dan zit ik te denken aan de 2x512mb infineon originaal uit de BBG. Maar is dat geheugen wel een beetje over te klokken? Anders moet ik toch echt ander geheugen hebbe wat wel tot 430/440 ddr gaat.
Socket754 heeft geen dual channel toch? (ja wel de controller maar je hoeft dus geen 2 bankjes in dual channel te zetten toch?)
[ Voor 12% gewijzigd door Operations op 31-10-2004 17:34 ]
  • Goofy
TheGeneral schreef op 31 oktober 2004 @ 17:10:
Die heeft afaik géén agp/pci lock.
De s754 ondersteundt inderdaad geen dual channel. :)
  • Operations
Goofy666 schreef op 31 oktober 2004 @ 18:53:
Maar zonder agp/pci lock is overklokken toch een stuk moeilijker? Is de Epox 8KDA3+ of de ASUS A8V (die hebben wel agp/pci lock) dan geen betere optie? Terwijl ik in het AMD64 overklok topic toch een hoop van deze MSI borden zie staan. Dit snap ik dan ff niet, het is zonder agp/pci toch helemaal geen goed overklok bord? Ik dacht te weten welk bord ik wou hebben, maar zonder agp lock moet ik toch opzoek naar een ander bord ben ik bang.
Moeilijk dilemma wou eerst s939 maar die 3500 is net ff te duur. Toen toch maar een s754 met een 3400 dat koste me al 2 dagen om te bepalen ;) en dan valt me bord weer af :(
Want het is toch zo dat die s939 met dual channel niet op weegt tegen 200/300 mhz snellere cpu op een s754 bord? of is het toch slimmer om een 3200 op een s939 te prikken qua performance?
  • William/Ax3
William/Ax3
We are Starstuff
TheGeneral schreef op 31 oktober 2004 @ 19:05:
Tja moeilijke keuze. Ik heb de keuze voor s939 gemaakt met het oog op de toekomst. s754 loopt zo'n beetje op zijn einde. Als je dan daarlijk bijvoorbeeld naar pci-x wil gaan hoef je alleen ander mobo te nemen, Als je nu s754 neemt zal je ook weer je proc moeten vervangen. Ik heb mede hierdoor voor s939 gekozen en hierbij een 3500+ zodat ik voorlopig voldoende power heb.
  • Operations
William/Ax3 schreef op 31 oktober 2004 @ 19:13:
Maar jij hebt hem ook op het MSI Neo2 bord zitten, dus jij kan ook niet echt overklokken toch?
  • William/Ax3
William/Ax3
We are Starstuff
TheGeneral schreef op 31 oktober 2004 @ 19:18:
?? Zie me specs onderaan maar is :) Pci lock werkt geweldig :P. Proc draait standaard 2200 nu dus 2640 zonder echt veel moeite te doen. Wellicht dat die zelf hoger wil maar vindt ut eerst best zo. Standaard bus is 200 ik heb hem nu dus op
240 wat dus ook inhoud dat me geheugen op 480 in plaats van 400 loopt.
Jij dacht dus dat de pci lock niet op dit bordje zat? Nou dus wel. De nforce3 ultra heeft dat gewoon perfect erin zitten. De oudere via moederborden voor s939 werkt de pci lock vaak niet.
Denk dat je dus in de war zit met s754, das weer ander verhaal namelijk.
[ Voor 25% gewijzigd door William/Ax3 op 31-10-2004 20:42 ]
  • Dutchmega
Je kan toch gewoon een 3000+ socket 939 nemen :)
  • Goofy
De Neo2 heeft die locks wel, tov de eerdere Neo ;). Aan de resultaten in deze thread te zien valt er met dit bordje toch aardig wat op te voeren hoor :9.
  • Nilco
Effe een ander vraagje. Dit bord heeft CnQ en Smartfan maar als je nou zo'n stille cooler gebruikt (bv een Zalman7000 of een thermalright XP-90 met Papstfan) dan hoef je dat toch niet meer te enablen? Koelt erg goed en is superstil. Dan hebben CnQ en Smartfan toch geen nut meer.
  • Dutchmega
Smartfan is dacht ik automatisch fancontrole.. Als het al stil is, maakt het idd niet uit.
CnQ maakt dan ook niet erg veel uit qua lawaai. Qua stroomverbruik kan het nog wel schelen :)
  • Nilco
Dutchmega schreef op 31 oktober 2004 @ 22:16:
Stroomverbruik kan ik me bij een flaptop voorstellen maar niet bij een desktop-pc.
  • M55
M55
MEGATRON schreef op 31 oktober 2004 @ 22:26:
geloof het nu maar een desktop-pc gebruikt ook stroom :+
  • Nilco
ik bedoelde dat ik het bij een flaptop wel kan voorstellen om stroom te besparen ivm met je accu/batterij zodat die niet snel leeg is. Maar dit heb je bij een desktop niet. Bij gebruik van eerder genoemde coolers hebben CnQ en Smartfan geen enkel nut meer.
Tóch is het wel prettig om aan het eind van het jaar die rekening te zien naast die van het jaar daarvoor, en tot de conclusie komen dat je wat minder mag betalen. CnQ draagt daar aan bij.
M55 schreef op 31 oktober 2004 @ 23:04:
Ja? Ik dacht altijd dat die ventilatoren er in zaten om windenergie op te vangen, en zo stroom op te wekken. De enige reden om hem in het stopcontact te douwen (weet ik veel, m'n allereerste eigen PC was een laptop), was om energie terug te geven aan het energie bedrijf. M'n vermoeden werd laatst bevestigd, de PC viel uit, en alle lampen ook!.
[ Voor 58% gewijzigd door Verwijderd op 31-10-2004 23:20 ]
  • Nilco
Verwijderd schreef op 31 oktober 2004 @ 23:17:
Zoveel verschil zal dat nou ook weer niet zijn. Paar euro(centen)?
  • LoeiOrdinair
LoeiOrdinair
Verwijderd schreef op 31 oktober 2004 @ 12:51:
Mpass,
- pc uit
- normaal opstarten
give it a try......
Mace
Heb het geprobeerd maar mijn pc starten weer met problemen op. Ik denk dat ik mijn pc terug laat sturen. volgens mij doet het moederbord een beetje vreemd. Of heeft iemand anders dit probleem ook gehad?
  • M55
M55
was het maar zo, dan kon ik hier meteen mijn eigen energie centrale beginnen.
Heeft iemand hier al iets op zijn COM poort van de MSI Neo2 aangesloten ?
ben benieuwd of ik de enige ben die kaduke COM poort
oh ja en sluit er niet iets kostbaars op aan :)
[ Voor 52% gewijzigd door M55 op 01-11-2004 09:57 ]
  • Nilco
M55: COM-poorten disable ik altijd gelijk. Alles is tegenwoordig toch USB. Muis + Keyboard is PS/2.
Ik heb de afstandsbediening van mijn pinnacle PCTV Pro (nou, eigenlijk meer het IR-oogje) erop aangesloten, en dit werkt óók nog. En nee, het oogje is niet veranderd in een enorm gevaarlijke laser, waar ik een gat mee kan branden naar de aardkern, tenzij ik een miljard euro in ongenummerde biljetten voor de deur krijg.
WOOOOO!!!!
ik heb alles binnen!
:) K8N neo2 met 3500+ en een 6800GT (die ik al stieken getest heb en doodleuk op ultra loopt zonder blikken of blozen)
verder raid 0 SATA en 1GB kingston pc4000.
en als piek op de boom een 7000cu.
geen hond die mij vanavond nog de deur uit krijgt :P
  • KeaveXL
Verwijderd schreef op 01 november 2004 @ 14:00:
WOOOOO!!!!
6800Gt welk merk en waarvandaan? Ik moet namelijk nog 20 dagen wachten :(
PSN: KeaveXL
KeaveXL schreef op 01 november 2004 @ 15:46:
POV tweedehands van iemand die 'm uit duitsland had.
(funcomputers.de)
330 euri was ie van mij :)
Hmm.... ik heb nu een nieuwe cpu en mem binnen.... Moet ik nu eerst mn bios resetten en daarna de cpu en mem erin doen of eerst cpu en mem erin en daarna bios resetten?
Ik moet ook nog een tijdje wachten op m'n 6800GT, AOpen waar ik €420 voor betaal.
Overige spul is al een tijdje binnen naar volledige tevredenheid:
MSI K8N Neo2 -54G
3500+ DH7-CG
2x 512MB Corsair value (érg leuk RAM!, gaat best ver).
2x WD Raptor 360GD 10Krpm (is al een jaartje van de 5 jaar garantie af, en ze doen het nog na volle tevredenheid).
Gigabyte 3D Cooler pro
Het presteerd érg netjes, zonder veel moeite 2640MHz gehaald, echt verder ben ik niet gegaan. Dit allemaal in een LianLi PC75 (ook al een tijdje oud). Beetje zonde van de 9600Pro die d'r nu nog in zit, maar daar komt verandering in :D.
Takemenow:
Maakt geen donder uit, toen ik m'n PC2700 verving door 3200 heb ik gewoon de BIOS zo gelaten, en handmatig opnieuw ingesteld. Niks geen reset. Waarom andere CPU? Was je 3500+ stuk ofzo?
[ Voor 15% gewijzigd door Verwijderd op 01-11-2004 17:01 ]
Verwijderd schreef op 01 november 2004 @ 16:59:
MSI K8N Neo2 -54G
3500+ DH7-CG
Takemenow:
Nee, heb een 3500+ 90nm aangeschaft :*)
  • Operations
Okee ik ben eruit wordt toch de K8n neo2(s939) met een 3500 nu wil ik alleen dit geheugen erop prikken Corsair TWINX1024-3200C2PT PC3200 (2-3-3-6). Volgens mij is dit geheugen wel goed over te klokken (is alleen een levering van 2 weken bij Salland :( )
Maar dit geheugen staat niet in de compatible lijst van msi. En aangezien die mem controller van de AMD64 nog al kieskeurig is met het geheugen (lees ik overal). Hoopte ik dat iemand ook dit geheugen in zijn msi heeft zitten.
[ Voor 3% gewijzigd door Operations op 01-11-2004 17:19 ]
Qua kieskeurigheid valt het wel mee hoor, en gewoon vragen of je het mag ruilen mocht het niet werken. Mijn corsair value 3200 staat ook niet in de compatibility list.
  • KeaveXL
TheGeneral schreef op 01 november 2004 @ 17:18:
Ik heb dit geheugen bij mijn pc besteld, hopen dat het werkt dan :S
PSN: KeaveXL
  • Semetrix
Hmmz.. Na een aantal dagen draaien met mijn nieuwe aanwinst PC4400 van G.Skill is mijn systeem opeens zwaar onstabiel geworden.
Op 9x278 en met een HTT Freq mp van 3x wil mijn systeem niet booten vanuit een koude start. Na een korte tijd verschijnt er beeld maar dan draait het geheugen op 200MHz default. Dus de bios in en save en exit en het draait weer op 278MHz.
Maar in windows na een willekeurige tijd flikkert het systeem zonder enige waarschuwing uit :X
Ik draai nu weer fijn op 10x250 en geheugen op 208MHz (dus voor jan met de korte achternaam G.Skill gekocht). Ff een tijdje toekijken of dit nog lekker wilt draaien 8)7
  • M55
M55
MEGATRON schreef op 01 november 2004 @ 10:44:
mijn palm 3c nog niet :)
maar zou het aan de antec voeding kunnen liggen dan ?
ik snap er niks van 8)7
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Semetrix schreef op 01 november 2004 @ 18:31:
Vcore verhogen. Je cpu gaat waarschijnlijk moeilijk doen bij deze htt speed.
mem 1:1 wil niet op 250 htt :?
[ Voor 3% gewijzigd door Tutti-frutti op 01-11-2004 18:44 ]
  • William/Ax3
William/Ax3
We are Starstuff
Kep hier ook dat corsair c2 twinx geheugen. Loopt gewoon super ;)
  • Stuiterbal
  • Laatst online: 22-08 15:19
Zie http://gathering.tweakers.net/forum/view_message/21893795
In het kort komt het er op neer dat ik mijn HyperX geheugen niet op CL2 kon laten draaien en wel op CL2.5 terwijl het toch echt CL2 geheugen was.
Nu lees ik na de zoveelste keer zoeken lees ik in dit topic het volgende;
Het is een bekend probleem op A64 systemen dat dualsided geheugen niet op CL2 wil draaien.
WTF! :? :(
Nooit geweten dit. Is dit algemeen bekend? In het topic staat ook een link naar de geheugen pagina van Corsair waar bij de specificaties staat dat het op AMD 64 systemen op CL2.5 en op Intel systemen op CL2 kan draaien. Op de geheugenpagina van Kingston vind ik dit nergens terug?
Ik voel me nu toch wel een beetje genaaid. Ik heb €290 neergelegd voor dit Kingston HyperX CL2 geheugen en nu blijkt het platform het alleen op CL2.5 aan te willen.
Daarnaast zou ik nog willen vragen of iemand nog antwoord heeft op mijn vraag;
Ook snap ik niet helemaal waarom er bij FSB:DRAM staat "CPU/11" staat. M'n AMD Athlon 64 3500+'s z'n FSB is 200Mhz en m'n geheugen draait ook op 200Mhz, dus dan hoort het toch 1:1 te zijn? Ik snap wel dat het 2200Mhz : 11 = 200Mhz moet zijn, maar wat wordt hier mee bedoeld?
[ Voor 18% gewijzigd door Stuiterbal op 01-11-2004 20:21 ]
  • Goofy
Verwijderd schreef op 01 november 2004 @ 17:03:
Kun je eigenlijk aan de verpakking oid zien dat de proc een 90nm is, of kan je dat alleen aan de proc zelf zien? :?
Er wordt wel gesproken over de VGA + NB coolers van zalman dat die niet samen willen, maar kan je oko de Cpu 7000 en de VGA cooler van zalman erop kunnen krijgen? want volgens mij wil dat niet als ik het zo kijk..?
de cpu is af te lezen door de verpakking... kost 3 seconden om het te zien.
  • Operations
William/Ax3 schreef op 01 november 2004 @ 19:35:
Draait het wel op Cas2 dan? Aangezien ik hier vlak boven lees dat, dat dus niet kan. (kwam ik trouwens in meerdere topics tegen bedenk ik me nu)
  • Nilco
Staat ook op de corsair site dat de twinx3200C2 op een AMD systeem op 2.5 draait.
(op een Intel systeem wel 2) Beetje misleidend van corsair. Veel mensen met AMD kopen dit geheugen om op 2 te draaien en komen dus bedrogen uit.
  • William/Ax3
William/Ax3
We are Starstuff
TheGeneral schreef op 01 november 2004 @ 22:52:
nope draai ut op c2.5 maar dat komt mede omdat ik geheugen ook wat geoced heb. Op 480 (240) haal je c2 toch zelden volgens mij.
  • makje
makje
Stuiterbal schreef op 01 november 2004 @ 20:19:
WTF! :? :(
Dikke onzin, alle tests en reviews die je op het internet kunt vinden hebben dat nog nooit vermeld, maar vermelden wel het benutten van dual channel met reepjes van 512MB welke meest (altijd?) dual channel zijn.
In ieder geval het Crucial Ballistix geheugen hier bij Anandtech is dual sided en zij krijgen het ook gewoon op 2-2-2-8
De post in het topic dat jij linkte is daarnaast ook al verouderd. Corsair had voor hun oude topmodel TWINX1024-3200C2PRO (2x 512MB) geheugen inderdaad 2 specificaties voor AMD en Intel (uitzondering welke werd aangegeven met een * erachter).
Echter de meeste andere (huidige) reepjes hebben niet zo'n * erachter en hebben dus voor alle platformen dezelfde SPD timings. Het huidige topmodel TWINX1024-3200XLPRO (2x 512MB) heeft dan ook gewoon overal 2-2-2-5 timings...
Verder klopt die oude post nog wel trouwens, AMD 64 processoren hebben moeite met 2 dual sided reepjes per geheugencontroller. Een socket 754 heeft maar 1 geheugencontroller en heeft dus moeite met 2 dual sided reepjes, een socket 939 processor heeft 2 geheugencontrollers en kan dus wel goed 2 reepjes dual sided aan.
Als je de manual van dit MSI moederbord leest dan kan het mobo niet goed overweg met 4 dual sided reepjes: dan moet de snelheid teruggeschroeft worden naar DDR333 ipv DDR400
9800x3d
  • Operations
William/Ax3 schreef op 01 november 2004 @ 23:03:
Dan heb ik straks hetzelfde bord/cpu/mem als jij. Ik wil ook gaan overklokken Cas2,5 op 480 vind ik dan niet z'n probleem :D
Ga denk ik morgen me bestelling plaatsen bij Salland, cpu en bord staan alleen wel op 2 weken levertijd :(
P.S. wat voor settings gebruik jij? (vcore, HTT/MP, Vmem)
[ Voor 7% gewijzigd door Operations op 02-11-2004 10:01 ]
in de beginpost staat: koop geen antec 350 watt.
geld dit voor alle antecs of echt alleen voor de 350.
ikzelf heb een antec 430watt in mun pc zitten.
hopen dat die het wel doet :)
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Verwijderd schreef op 02 november 2004 @ 12:32:
Ik heb tot nu toe alleen gevallen gezien van de antec 350 watt. Het zit het um in de atx connecter denk ik. Als deze hard wordt aangedrukt dan doetie het nameljik wel.
ok tnx.
en heeft iemand ervaring met twinmos geheugen met dit mobo.
thuis heb ik 2x512mb twinmos liggen.
  • needless to say
  • Laatst online: 02-03 17:32
Ik heb een probleem met mijn temperature readings. Als ik kijk in het BIOS geeft hij een systeem-temperatuur van 27-30 graden aan. Een keer in windows geeft corecenter of speedfan echter maar 17 graden aan. De CPU-temp lijkt wel overeen te komen. Het lijkt me redelijk sterk dat de temperatuur plots zoveel zou dalen :p.
Mijn specs:
MSI K8N NEO2 BIOS v1.3
Antec Case ATX SX 1040 II Black Smart Power 400W
AMD64 3500+
CORSAIR TWINX1024-3200C2 (matched 2x512MB)
2x MAXTOR Diamond Max 9 80GB SATA (RAID0)
NEC DVDRW 3500AG
ASUS DVD-E616P2
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Verwijderd schreef op 02 november 2004 @ 12:45:
ok tnx.
Als er twinmos chippies opzitten werkt het denk ik wel, ik had het ook Twinx 2x 512 MB ddr400 c2.5.
ok tnx.
tim ik heb een antec 430 watt @ mn k8n neo2 (in een 1080AMG kast)
werkt perfect :P
dat twinmos zal misschien problemen geven... is algemeen probleem geheugen met amd64.
heb het zelf ook gehad 2x 512 3200 maar bij mij draaide 1 lat iig wel de andere was gewoon stuk.
meteen geruild voor infineon 2 x 512 infineon :)
draait superstabiel
Verwijderd schreef op 02 november 2004 @ 16:01:
werkt perfect :P
hierzo precies dezelfde opstelling werkt ook perfect :Y)
  • Pakjebakmeel
  • Laatst online: 17-11 03:28
Recommended Memory Combination List
DIMM Slots  Max Speed
Green Purple Green
 Purple
DIMM1 DIMM2 DIMM3 DIMM4
S - - - DDR 400
- - S - DDR 400
D - - - DDR 400
- - D - DDR 400
S - S - DDR 400
D - D - DDR 333
S S - - DDR 400
- - S S DDR 400
D D - - DDR 400
- - D D DDR 400
S S S S DDR 400
D D D D DDR 333
S: Single Side                  D: Double Side
Kan DD - SS ook?
[ Voor 188% gewijzigd door Pakjebakmeel op 02-11-2004 16:57 ]
  • Goofy
Dan zul je DS - DS moeten nemen denk ik, aangezien dat 1 controller dan de double sided latjes heeft, en de andere de single sided. Of maakt het niet uit?
DSDS zal niet werken, er dienen per kanaal een identiek aantal chipjes/rijen te zijn. DD-SS zal mss wel werken.
  • makje
makje
^^ Met Cabal eens is.
MSI heeft het niet in de manual gezet omdat ze het niet willen/kunnen garanderen. Echter ze zetten er ook niet neer dat het niet kan of dat de snelheid dan naar beneden moet.
De geheugencontroller van de AMD 64 kan 3 geheugenbanken adresseren en kan dus in principe goed 1 reepje DS en 1 reepje SS aan. Of het op de hoge snelheid van DDR400 én met snelle timings stabiel kan....
Ik denk zelf dat het wel kan, maar met goed merkgeheugen en met lagere timings (2,5-3-3-7 ofzo)
[ Voor 13% gewijzigd door makje op 02-11-2004 17:53 ]
9800x3d
vraagje;
- op welke bios settings heb je alles staan? ik kom niet hoger dan 220-222, daarna heb ik spontane reboots.
Mijn 12 volt lijn (zalman 400 watt) ik ook 11.61, is dat te laag? kan dat het zijn?
Ook wil mijn 6800GT duidelijk minder dan op mijn P4...
setje:
k8n neo2
3500+
2x120 GB maxtor SATA
2x512 kingstong hyperX pc4000
POV 6800GT
zalman 7000cu + 400watt PSU
niet verder kunnenkomen dan 4000 3dmark05...
  • steven2
  • Laatst online: 04-11 05:38
Ik heb sinds de laatste tijd het probleem als ik met mijn DVD-brander (Lite-On SOHW-823S) een dvd bekijk met powerdvd 5, dat het beeld schokkerig gaat en langzaam vast loopt. Kijk ik dan bij de eigenschappen van mijn IDE-poorten dan staat er bij de informatie van mijn secundaire poort - slave, hier zit dan ook mijn brander aan, een melding dat de software de snelheid van heeft aangepast naar PIO-mode, omdat er erg veel fouten gemaakt zijn tijdens het doorvoeren van data.
Er wordt dan ook aangeraden om een 80 conductor flatcable te gebruiken.
Dit probleem komt niet voor bij mijn plextor px-116a dvd-speler.
Wat heb ik geprobeerd:
Flatcable vervangen door een splinter nieuwe
Een image van het begin in het laden via ghost
Tijdens branden van cd's / DVD's komt de klacht niet voor.
Drivers van IDE niet meer geinstalleerd, dan komt de klacht niet meer voor, maar dan heeft de driver ook niet de mogelijkheid om uberhaupt wat aan de verbindingssnelheid te veranderen.
ASUS Sabertooth X79, Intel Core i7 3930@3800MHz, 16 GB DDR3 (G.Skill F3-17000CL9Q-16GBZ), XFX Radeon R9 290, Sound Blaster X-Fi XtremeMusic, 1x 256 GB Samsung 840 pro SSD, 1x 1 TB Samsung Spinpoint F3, 1 x 3 TB Seagate ST3000DM001
  • William/Ax3
William/Ax3
We are Starstuff
Ben weer ff an het spelen geweest. Denk dat ik de max ongeveer nu heb, 250 wil niet 100% stabiel meer.
Afbeeldingslocatie: http://home.planet.nl/~cleme359/proc.JPG
TheGeneral schreef op 01 november 2004 @ 23:17:
Vraag wordt zo beantwoord :)
Verwijderd schreef op 02 november 2004 @ 19:30:
vraagje;
vcore: 1.55 + 5% (volgens mij geeneens nodig maar goed)
HTT: 246 x 4
MP: 11
Vmem 2.8
mem settings: Zie sig
Tja volgens mij moet een zalman toch wel beter zijn als mijn chieftech 360w.
ff offtopic..
4k maar :P haal nu met me le'tje 4.2k, kan denk ik nog wel hoger als ik de gpu is op 1,4v ga gooien, zijn veel lui die dan boven de 400core komen. Maar kep wel 16,6 dus mij hoor je niet klagen verder :D. Top score van le in 2005 staat nu op 4.6k geloof ik.
