9800SE , mogelijkheden?
$ffffffffff ---------------------------------------------------
$ffffffffff Northbridge information
$0400000000 Description : Intel i845 Brookdale-G
$0400000001 Vendor ID : 8086 (Intel)
$0400000002 Device ID : 2560
$0400000003 AGP bus : revision 2.0
$0400000004 AGP status : disabled
$ffffffffff Display adapter information
$0000000000 Description : RADEON 9800 PRO
$0000000001 Vendor ID : 1002 (ATI)
$0000000002 Device ID : 4e48
$0000000003 Location : bus 1, device 0, function 0
$0000000004 Bus type : AGP revision 2.0
$0000000005 AGP status : disabled
$0000000009 Base address 0 : f0000000 (memory range)
$000000000a Base address 1 : 0000ec00 (I/O range)
$000000000b Base address 2 : ff8f0000 (memory range)
$000000000c Base address 3 : none
$000000000d Base address 4 : none
$000000000e Base address 5 : none
$ffffffffff ATI specific display adapter information
$0900000000 Graphics core : R350 (8x1)
$0900000002 Memory bus : 128-bit
$0900000001 Memory type : DDR SGRAM / SDRAM
$0900000003 Memory amount : 256MB
$0900000004 Core clock : 378.000MHz
$0900000005 Memory clock : 202.500MHz (405.000MHz effective)
$0900000006 Reference clock : 27.000MHz
$ffffffffff Memory timings
$0900000100 WR latency : 1.0
$0900000101 CAS latency : 3
$0900000102 CMD latency : 0.0
$0900000103 STR latency : 1.5
$0900000110 TRCDRD,RAS to CAS read : 7
$0900000111 TRCDWR,RAS to CAS write : 2
$0900000112 TRP ,Row precharge : 7
$0900000113 TRAS ,Row active : 12
$0900000114 TRRD ,Row active to row active command : 2
$0900000115 TR2W ,Read to write turnaround : 6
$0900000116 TWR ,Write recovery : 3
$0900000117 TW2R ,Write to read turnaround : 2
$0900000118 TW2R ,Write to read turnaround/same bnk : 3
$0900000119 TR2R ,Read to read turnaround : 2
zoals jullie zien is dit niet een standaard 9800SE.. hij word benoemt als een PRO ( deze is niet gemod/overclocked of whatever )..
ook klopt dus me geheugen niet en me core schijnt meer in de buurt te komen van een PRO versie..
wat valt hier aan te overclocken of modden aangezien ik dit type/model hier nog niet gepost heb gezien.
ik kom hiermee ook maar aan de 2800 3dmark score :S
  • Tjark
  • Laatst online: 21-10 10:10
Tjark
DON'T PANIC
M'n 9800se wordt ook vaak 'gezien' als Pro. Niks raars aan de hand dus.
Verder heb je zo te zien een 128bit SE. Volgens mij kun je die dus ook niet 'unlocken'.
En overclocken: probeer 't gewoon met stapjes van 5Mhz. Je komt er vanzelf wel achter wanneer je artifacts krijgt.
*insert signature here
ok dus enigste mogelijkheden zijn core/mem overclocking..
wat vinden jullie trouwens van Atitools voor auto overclocking? ( zet ik dan 's nachts aan, weet ik zeker dat ik op 100% overclocked zit? ).. of komt deze niet aan de max/bugs/etc?
thx
