Boot Win MCE wil niet: Cannot boot from CD - Code: 4
  • wout-hugo
  • Laatst online: 14-09-2023
Ik wil Windows Media Center Edition installeren op mijn computer, maar bij het booten staat er:
Boot from ATAPI CD-ROM :
1. FD 1.44MB System Type-(06)
CDBOOT: Cannot boot from CD - Code: 4
Wat kan ik hier aan doen? Of is gewoon mijn systeem niet compatible met MCE?
MacBook Black C2D 2.16GHz 160GB 4GB -- Dell 24" -- iPhone 3G 16GB -- iPod Nano 3G -- Canon PowerShot S90 -- Smart Roadster Coupe
  • OnTracK
  • Laatst online: 10:47
laat me raden? gebrand met Nero en boot opties niet helemaal goed gezet?
Even mijn Howto make bootable lijstje erbij pakken:
Howto make a bootable CD of Windows XP
1. Open Nero, choose "Bootable CD"
2. Select the Tab "Boot" and check the following options:
    - Source of boot image data: flag "Image file", press "Browse..."
      and select Microsoft_Corporation.img (extract using Isobuster)
    - Flag "Enable expert settings" and check the following options:
        - Kind of emulation: No Emulation
        - Boot message: don't change
        - Load segment of sectors: don't change
        - Nubmer of loaded sectors: 4
3. Select the Tab "ISO" and check the following options:
    - ISO Level 2
    - Mode 1
    - ISO 9660
    - flag Joliet
    - Make sure you have three Relax ISO Restrictions and flag them all:
        - Allow pathdept of more than 8 directories
        - Allow more than 255 characters per path
        - Do not add the ';1' ISO file version extension
4. Now drag all the files from the Origional Windows XP directory
5. Burn this CD en Finalize it!
waarschijnlijk "Kind of Emulation" op "floppy emulation" laten staan of "Number of loaded sectors" op 1 laten staan
staat trouwens ook in deze Howto: [rml][ XP] Streaming SP1 en bootable cd maken[/rml]
[ Voor 67% gewijzigd door OnTracK op 24-10-2004 19:31 ]
Not everybody wins, and certainly not everybody wins all the time.
But once you get into your boat, push off and tie into your shoes.
Then you have indeed won far more than those who have never tried.
  • wout-hugo
OnTracK schreef op 24 oktober 2004 @ 19:27:
    - ISO Level 2
    - Mode 1
    - ISO 9660
    - flag Joliet
waarschijnlijk "Number of loaded sectors" op 1 laten staan
Dank je! Ik zal het eens proberen
