[Suse 9.1 x86_64] geen geluid met soundblaster live emu10k1
Ik ben niet al te bekend met linux, maar wil dit wel worden :P
Ik heb een dual boot met winXP, geinstalleerd op mn Asus K8V SE Deluxe, VIAK8T800, op mn sata harde schijf, en in principe werkt alles, behalve mn geluidskaart.
lsmod:
Module Size Used by
snd_emu10k1 96936 3
snd_rawmidi 28964 1 snd_emu10k1
snd_pcm 113420 2 snd_emu10k1
snd_timer 27784 1 snd_pcm
snd_seq_device 9868 2 snd_emu10k1,snd_rawmidi
snd_ac97_codec 74372 1 snd_emu10k1
snd_util_mem 6016 1 snd_emu10k1
snd_hwdep 11656 1 snd_emu10k1
snd 68104 13 snd_emu10k1,snd_rawmidi,snd_pcm,snd_timer,snd_s
eq_device,snd_ac97_codec,snd_util_mem,snd_hwdep
joydev 11392 0
sg 40632 0
st 42148 0
sr_mod 18468 0
floppy 63856 0
usbserial 34552 0
parport_pc 39744 1
lp 12264 0
parport 45324 2 parport_pc,lp
ehci_hcd 30212 0
uhci_hcd 32416 0
emu10k1_gp 4480 0
gameport 5248 1 emu10k1_gp
ohci1394 33540 0
ieee1394 114648 1 ohci1394
evdev 10880 0
cpufreq_userspace 7008 0
powernow_k8 10376 0
freq_table 5256 1 powernow_k8
thermal 14604 0
processor 18620 2 powernow_k8,thermal
ipv6 266976 13
fan 4744 0
button 7584 0
battery 9864 0
ac 5768 0
snd_page_alloc 13840 2 snd_emu10k1,snd_pcm
soundcore 11040 1 snd
usbcore 121072 5 usbserial,ehci_hcd,uhci_hcd
3c59x 40756 0
subfs 9216 3
nls_utf8 2688 3
ntfs 85856 3
dm_mod 55992 0
reiserfs 247024 1
sata_via 8324 0
sata_promise 15492 4
libata 42496 2 sata_via,sata_promise,[permanent]
sd_mod 21376 5
scsi_mod 128512 6 sg,st,sr_mod,sata_promise,libata,sd_mod
modprobe emu10k1:
FATAL: Error inserting emu10k1 (/lib/modules/2.6.5-7.111-default/kernel/sound/oss/emu10k1/emu10k1.ko): Unknown symbol in module, or unknown parameter (see dmesg)
/bin/dmesg:
emu10k1: Unknown symbol midi_synth_reset
emu10k1: Unknown symbol midi_synth_controller
emu10k1: Unknown symbol midi_synth_set_instr
emu10k1: Unknown symbol midi_devs
emu10k1: Unknown symbol sound_alloc_mididev
emu10k1: Unknown symbol midi_synth_ioctl
emu10k1: Unknown symbol midi_synth_open
emu10k1: Unknown symbol midi_synth_send_sysex
emu10k1: Unknown symbol sequencer_init
emu10k1: Unknown symbol midi_synth_close
emu10k1: Unknown symbol midi_synth_bender
emu10k1: Unknown symbol midi_synth_start_note
emu10k1: Unknown symbol sound_unload_mididev
emu10k1: Unknown symbol midi_synth_load_patch
emu10k1: Unknown symbol midi_synth_panning
emu10k1: Unknown symbol midi_synth_aftertouch
emu10k1: Unknown symbol midi_synth_setup_voice
emu10k1: Unknown symbol midi_synth_kill_note
emu10k1: Unknown symbol midi_synth_hw_control
Ik zal wel iets verkeerd gedaan hebben, maar wat, en hoe los ik dit op?
google levert weinig op, behalve dat ik misschien mn kernel opnieuw moet compileren ofzow, maar wat moet er allemaal in dan, en hoe?
  • blouweKip
  • Laatst online: 21:13
Ik ben wat duf dus misschien zie ik het niet goed, maar die emu10k1 module is een oss (het oude geluidssysteem) module (misschien ook niet x64 compatible) en die modules met snd ervoor zijn alsa modules (nieuwe geluidssysteem)
Wat zegt de output van dmesg en krijg je nog foutmeldingen als je muziek probeert te spelen? (aangezien je geen oss emulatie lijkt te draaien met deze alsa install)
"For my friends, anything; for my enemies, the law."
  • a casema user
  • Laatst online: 26-10 12:49
Levert commando 'alsaconf' nog wat op ?
En wat voor foutmelding krijg je? Geen geluid of een error ?
Taaaa taa taa taaaa taa taa ta taaataaaaa.
ik krijg helemaal geen foutmeldingen.
xmms suggereert dat er wel geluid is (ik zie de equalizer bewegen). Het volume staat hoog, van alle onderdelen.
alsaconf, test de kaart, zegt dattie moet werken en wenst me veel plezier ermee, nadat ik 30 seconden naar nix heb zitten luisteren, terwijl er een .wav gespeeld wordt (schijnt)
Ik hoop dat je hier iets aan hebt?
dmesg geeft wel errug veel output, ik heb datgene wat mij relevant leek al gepost in mijn eerste post, maar hier is alles (wel erg veel...)
Bootdata ok (command line is root=/dev/sda7 vga=0x31a console=tty0 desktop resume=/dev/sda6 splash=silent)
Linux version 2.6.5-7.111-default (geeko@buildhost) (gcc version 3.3.3 (SuSE Linux)) #1 Wed Oct 13 15:45:13 UTC 2004
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000005ff30000 (usable)
BIOS-e820: 000000005ff30000 - 000000005ff40000 (ACPI data)
BIOS-e820: 000000005ff40000 - 000000005fff0000 (ACPI NVS)
BIOS-e820: 000000005fff0000 - 0000000060000000 (reserved)
BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
No mptable found.
On node 0 totalpages: 393008
DMA zone: 4096 pages, LIFO batch:1
Normal zone: 388912 pages, LIFO batch:16
HighMem zone: 0 pages, LIFO batch:1
ACPI: RSDP (v000 ACPIAM ) @ 0x00000000000fa8b0
ACPI: RSDT (v001 A M I OEMRSDT 0x05000418 MSFT 0x00000097) @ 0x000000005ff30000
ACPI: FADT (v001 A M I OEMFACP 0x05000418 MSFT 0x00000097) @ 0x000000005ff30200
ACPI: MADT (v001 A M I OEMAPIC 0x05000418 MSFT 0x00000097) @ 0x000000005ff30390
ACPI: OEMB (v001 A M I OEMBIOS 0x05000418 MSFT 0x00000097) @ 0x000000005ff40040
ACPI: DSDT (v001 A0058 A0058002 0x00000002 MSFT 0x0100000d) @ 0x0000000000000000
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Processor #0 15:4 APIC version 16
ACPI: IOAPIC (id[0x01] address[0xfec00000] global_irq_base[0x0])
IOAPIC[0]: Assigned apic_id 1
IOAPIC[0]: apic_id 1, version 3, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Using ACPI (MADT) for SMP configuration information
Checking aperture...
CPU 0: aperture @ e0000000 size 256 MB
Built 1 zonelists
Kernel command line: root=/dev/sda7 vga=0x31a console=tty0 desktop resume=/dev/sda6 splash=silent
bootsplash: silent mode.
Initializing CPU#0
PID hash table entries: 16 (order 4: 256 bytes)
CKRM Initialization
...... Initializing ClassType<taskclass> ........
...... Initializing ClassType<socket_class> ........
CKRM Initialization done
time.c: Using 1.193182 MHz PIT timer.
time.c: Detected 2050.159 MHz processor.
Console: colour dummy device 80x25
Memory: 1544252k/1572032k available (2169k kernel code, 27032k reserved, 854k data, 172k init)
Calibrating delay loop... 4022.27 BogoMIPS
Security Scaffold v1.0.0 initialized
SELinux: Disabled at boot.
Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
Mount-cache hash table entries: 256 (order: 0, 4096 bytes)
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 512K (64 bytes/line)
CPU: AMD Athlon(tm) 64 Processor 3000+ stepping 08
Using local APIC NMI watchdog using perfctr0
ENABLING IO-APIC IRQs
init IO_APIC IRQs
IO-APIC (apicid-pin) 1-0, 1-16, 1-17, 1-18, 1-19, 1-20, 1-21, 1-22, 1-23 not connected.
..TIMER: vector=0x31 pin1=2 pin2=-1
Using local APIC timer interrupts.
Detected 12.813 MHz APIC timer.
checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Looking for DSDT in initrd ...No customized DSDT found in initrd!
NET: Registered protocol family 16
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
ACPI: Subsystem revision 20040326
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (00:00)
PCI: Probing PCI hardware (bus 00)
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 10 *11 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 *10 11 14 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 7 10 11 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 7 10 11 14 15)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 10 11 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 10 11 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 10 11 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 11 14 15) *0, disabled.
IOAPIC[0]: Set PCI routing entry (1-16 -> 0xa9 -> IRQ 16 Mode:1 Active:1)
00:00:01[A] -> 1-16 -> IRQ 16
IOAPIC[0]: Set PCI routing entry (1-17 -> 0xb1 -> IRQ 17 Mode:1 Active:1)
00:00:01[B] -> 1-17 -> IRQ 17
IOAPIC[0]: Set PCI routing entry (1-22 -> 0xb9 -> IRQ 22 Mode:1 Active:1)
00:00:11[C] -> 1-22 -> IRQ 22
IOAPIC[0]: Set PCI routing entry (1-20 -> 0xc1 -> IRQ 20 Mode:1 Active:1)
00:00:0f[A] -> 1-20 -> IRQ 20
IOAPIC[0]: Set PCI routing entry (1-21 -> 0xc9 -> IRQ 21 Mode:1 Active:1)
00:00:10[A] -> 1-21 -> IRQ 21
IOAPIC[0]: Set PCI routing entry (1-18 -> 0xd1 -> IRQ 18 Mode:1 Active:1)
00:00:0b[C] -> 1-18 -> IRQ 18
IOAPIC[0]: Set PCI routing entry (1-19 -> 0xd9 -> IRQ 19 Mode:1 Active:1)
00:00:0b[D] -> 1-19 -> IRQ 19
number of MP IRQ sources: 15.
number of IO-APIC #1 registers: 24.
testing the IO APIC.......................
IO APIC #1......
.... register #00: 01000000
....... : physical APIC id: 01
.... register #01: 00178003
....... : max redirection entries: 0017
....... : PRQ implemented: 1
....... : IO APIC version: 0003
.... IRQ redirection table:
NR Log Phy Mask Trig IRR Pol Stat Dest Deli Vect:
00 000 00 1 0 0 0 0 0 0 00
01 001 01 0 0 0 0 0 1 1 39
02 001 01 0 0 0 0 0 1 1 31
03 001 01 0 0 0 0 0 1 1 41
04 001 01 0 0 0 0 0 1 1 49
05 001 01 0 0 0 0 0 1 1 51
06 001 01 0 0 0 0 0 1 1 59
07 001 01 0 0 0 0 0 1 1 61
08 001 01 0 0 0 0 0 1 1 69
09 001 01 0 1 0 1 0 1 1 71
0a 001 01 0 0 0 0 0 1 1 79
0b 001 01 0 0 0 0 0 1 1 81
0c 001 01 0 0 0 0 0 1 1 89
0d 001 01 0 0 0 0 0 1 1 91
0e 001 01 0 0 0 0 0 1 1 99
0f 001 01 0 0 0 0 0 1 1 A1
10 001 01 1 1 0 1 0 1 1 A9
11 001 01 1 1 0 1 0 1 1 B1
12 001 01 1 1 0 1 0 1 1 D1
13 001 01 1 1 0 1 0 1 1 D9
14 001 01 1 1 0 1 0 1 1 C1
15 001 01 1 1 0 1 0 1 1 C9
16 001 01 1 1 0 1 0 1 1 B9
17 000 00 1 0 0 0 0 0 0 00
IRQ to pin mappings:
IRQ0 -> 0:2
IRQ1 -> 0:1
IRQ3 -> 0:3
IRQ4 -> 0:4
IRQ5 -> 0:5
IRQ6 -> 0:6
IRQ7 -> 0:7
IRQ8 -> 0:8
IRQ9 -> 0:9
IRQ10 -> 0:10
IRQ11 -> 0:11
IRQ12 -> 0:12
IRQ13 -> 0:13
IRQ14 -> 0:14
IRQ15 -> 0:15
IRQ16 -> 0:16
IRQ17 -> 0:17
IRQ18 -> 0:18
IRQ19 -> 0:19
IRQ20 -> 0:20
IRQ21 -> 0:21
IRQ22 -> 0:22
.................................... done.
PCI: Using ACPI for IRQ routing
PCI: if you experience problems, try using option 'pci=noacpi' or even 'acpi=off'
agpgart: Detected AGP bridge 0
agpgart: Maximum main memory to use for agp memory: 1430M
agpgart: AGP aperture is 256M @ 0xe0000000
PCI-DMA: Disabling IOMMU.
vesafb: framebuffer at 0xd0000000, mapped to 0xffffff000008f000, size 16384k
vesafb: mode is 1280x1024x16, linelength=2560, pages=5
vesafb: scrolling: redraw
vesafb: directcolor: size=0:5:6:5, shift=0:11:5:0
fb0: VESA VGA frame buffer device
Initial HugeTLB pages allocated: 0
IA32 emulation $Id: sys_ia32.c,v 1.32 2002/03/24 13:02:28 ak Exp $
VFS: Disk quotas dquot_6.5.1
Initializing Cryptographic API
PCI: Via IRQ fixup for 0000:00:10.0, from 11 to 5
PCI: Via IRQ fixup for 0000:00:10.1, from 11 to 5
PCI: Via IRQ fixup for 0000:00:10.2, from 10 to 5
PCI: Via IRQ fixup for 0000:00:10.3, from 10 to 5
bootsplash 3.1.6-2004/03/31: looking for picture...<6> silentjpeg size 52139 bytes,<6>...found (1280x1024, 24562 bytes, v3).
Console: switching to colour frame buffer device 147x55
Real Time Clock Driver v1.12
Non-volatile memory driver v1.2
Linux agpgart interface v0.100 (c) Dave Jones
Serial: 8250/16550 driver $Revision: 1.90 $ 8 ports, IRQ sharing disabled
ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 128000K size 1024 blocksize
loop: loaded (max 8 devices)
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VIA8237SATA: IDE controller at PCI slot 0000:00:0f.0
VIA8237SATA: chipset revision 128
VIA8237SATA: 100% native mode on irq 20
ide0: BM-DMA at 0xd000-0xd007, BIOS settings: hda:pio, hdb:pio
ide1: BM-DMA at 0xd008-0xd00f, BIOS settings: hdc:pio, hdd:pio
VP_IDE: IDE controller at PCI slot 0000:00:0f.1
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt8237 (rev 00) IDE UDMA133 controller on pci0000:00:0f.1
ide2: BM-DMA at 0xfc00-0xfc07, BIOS settings: hde:DMA, hdf:pio
ide3: BM-DMA at 0xfc08-0xfc0f, BIOS settings: hdg:DMA, hdh:DMA
hde: MAXTOR 6L040J2, ATA DISK drive
Using anticipatory io scheduler
ide2 at 0x1f0-0x1f7,0x3f6 on irq 14
hdg: _NEC DVD+RW ND-1100A, ATAPI CD/DVD-ROM drive
hdh: LITE-ON COMBO LTC-48161H, ATAPI CD/DVD-ROM drive
ide3 at 0x170-0x177,0x376 on irq 15
hde: max request size: 128KiB
hde: 78177792 sectors (40027 MB) w/1819KiB Cache, CHS=65535/16/63, UDMA(133)
hde: hde1 < hde5 >
hdg: ATAPI 40X DVD-ROM CD-R/RW drive, 2048kB Cache
Uniform CD-ROM driver Revision: 3.20
hdh: ATAPI 48X DVD-ROM CD-R/RW CD-MRW drive, 2048kB Cache
ide-floppy driver 0.99.newide
mice: PS/2 mouse device common for all mice
input: PC Speaker
serio: i8042 AUX port at 0x60,0x64 irq 12
input: ImExPS/2 Logitech Explorer Mouse on isa0060/serio1
serio: i8042 KBD port at 0x60,0x64 irq 1
input: AT Translated Set 2 keyboard on isa0060/serio0
md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
NET: Registered protocol family 2
IP: routing cache hash table of 16384 buckets, 128Kbytes
TCP: Hash tables configured (established 524288 bind 65536)
Resume Machine: resuming from /dev/sda6
Resuming from device unknown-block(0,0)
Resume Machine: Error -6 resuming
ACPI: (supports S0 S1 S3 S4 S5)
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
RAMDISK: Compressed image found at block 0
VFS: Mounted root (ext2 filesystem).
SCSI subsystem initialized
libata version 1.02 loaded.
sata_promise version 0.92
ata1: SATA max UDMA/133 cmd 0xFFFFFF000109F200 ctl 0xFFFFFF000109F238 bmdma 0x0 irq 18
ata2: SATA max UDMA/133 cmd 0xFFFFFF000109F280 ctl 0xFFFFFF000109F2B8 bmdma 0x0 irq 18
ata1: dev 0 cfg 49:2f00 82:7c6b 83:7b09 84:4003 85:7c69 86:3a01 87:4003 88:407f
ata1: dev 0 ATA, max UDMA/133, 240121728 sectors
ata1: dev 0 configured for UDMA/133
scsi0 : sata_promise
ata2: dev 0 cfg 49:2f00 82:7c6b 83:7f09 84:4003 85:7c69 86:3e01 87:4003 88:407f
ata2: dev 0 ATA, max UDMA/133, 398297088 sectors (lba48)
ata2: dev 0 configured for UDMA/133
scsi1 : sata_promise
Vendor: ATA Model: Maxtor 6Y120M0 Rev: 1.02
Type: Direct-Access ANSI SCSI revision: 05
ata1: dev 0 max request 124KB
SCSI device sda: 240121728 512-byte hdwr sectors (122942 MB)
SCSI device sda: drive cache: write through
sda: sda1 sda2 < sda5 sda6 sda7 >
Attached scsi disk sda at scsi0, channel 0, id 0, lun 0
Vendor: ATA Model: Maxtor 6Y200M0 Rev: 1.02
ata2: dev 0 max request 512KB (lba48)
SCSI device sdb: 398297088 512-byte hdwr sectors (203928 MB)
SCSI device sdb: drive cache: write through
sdb: sdb1 sdb2 < sdb5 >
Attached scsi disk sdb at scsi1, channel 0, id 0, lun 0
ReiserFS: sda7: found reiserfs format "3.6" with standard journal
ReiserFS: sda7: using ordered data mode
reiserfs: using flush barriers
ReiserFS: sda7: journal params: device sda7, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
ReiserFS: sda7: checking transaction log (sda7)
reiserfs: disabling flush barriers on sda7
ReiserFS: sda7: Using r5 hash to sort names
VFS: Mounted root (reiserfs filesystem) readonly.
Trying to move old root to /initrd ... failed
Unmounting old root
Trying to free ramdisk memory ... failed
Freeing unused kernel memory: 172k freed
Adding 1044184k swap on /dev/sda6. Priority:42 extents:1
md: autorun ...
device-mapper: 4.1.0-ioctl (2003-12-10) initialised: dm@uk.sistina.com
NTFS driver 2.1.6 [Flags: R/O MODULE].
NTFS volume version 3.1.
subfs 0.9
3c59x: Donald Becker and others. www.scyld.com/network/vortex.html
0000:00:0e.0: 3Com PCI 3c905C Tornado at 0xb000. Vers LK1.1.19
usbcore: registered new driver usbfs
usbcore: registered new driver hub
ACPI: Power Button (FF) [PWRF]
ACPI: Sleep Button (CM) [SLPB]
NET: Registered protocol family 10
IPv6 over IPv4 tunneling driver
ACPI: Processor [CPU1] (supports C1)
powernow-k8: Found 1 AMD Athlon 64 / Opteron processors (version 1.00.09d)
powernow-k8: BIOS error - no PSB
hde: drive_cmd: status=0x51 { DriveReady SeekComplete Error }
hde: drive_cmd: error=0x04 { DriveStatusError }
gameport: pci0000:00:0d.1 speed 1047 kHz
ieee1394: Initialized config rom entry `ip1394'
ohci1394: $Rev: 1203 $ Ben Collins <bcollins@debian.org>
ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[16] MMIO=[fda00000-fda007ff] Max Packet=[2048]
USB Universal Host Controller Interface driver v2.2
uhci_hcd 0000:00:10.0: UHCI Host Controller
uhci_hcd 0000:00:10.0: irq 21, io base 000000000000b400
uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
usb usb1: Product: UHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.5-7.111-default uhci_hcd
usb usb1: SerialNumber: 0000:00:10.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
uhci_hcd 0000:00:10.1: UHCI Host Controller
uhci_hcd 0000:00:10.1: irq 21, io base 000000000000b800
uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
usb usb2: Product: UHCI Host Controller
usb usb2: Manufacturer: Linux 2.6.5-7.111-default uhci_hcd
usb usb2: SerialNumber: 0000:00:10.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
uhci_hcd 0000:00:10.2: UHCI Host Controller
uhci_hcd 0000:00:10.2: irq 21, io base 000000000000c000
uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3
usb usb3: Product: UHCI Host Controller
usb usb3: Manufacturer: Linux 2.6.5-7.111-default uhci_hcd
usb usb3: SerialNumber: 0000:00:10.2
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
uhci_hcd 0000:00:10.3: UHCI Host Controller
uhci_hcd 0000:00:10.3: irq 21, io base 000000000000c400
uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 4
usb usb4: Product: UHCI Host Controller
usb usb4: Manufacturer: Linux 2.6.5-7.111-default uhci_hcd
usb usb4: SerialNumber: 0000:00:10.3
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
usb 2-2: new full speed USB device using address 2
usb 2-2: Product: SNAPSCAN e10
usb 2-2: Manufacturer: AGFA
ieee1394: Host added: ID:BUS[0-00:1023] GUID[00e018000055ab7f]
usb 3-1: new full speed USB device using address 2
usb 3-1: Product: USB 2.0 Camera
usb 3-1: Manufacturer: Crescentec Corp.
ehci_hcd 0000:00:10.4: EHCI Host Controller
ehci_hcd 0000:00:10.4: irq 21, pci mem ffffff00011f2000
ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 5
ehci_hcd 0000:00:10.4: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29
usb 2-2: USB disconnect, address 2
usb usb5: Product: EHCI Host Controller
usb usb5: Manufacturer: Linux 2.6.5-7.111-default ehci_hcd
usb usb5: SerialNumber: 0000:00:10.4
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 8 ports detected
usb 3-1: USB disconnect, address 2
parport0: PC-style at 0x378 [PCSPP]
parport0: irq 7 detected
lp0: using parport0 (polling).
usb 5-5: new high speed USB device using address 2
usb 5-5: Product: USB 2.0 Camera
usb 5-5: Manufacturer: Crescentec Corp.
drivers/usb/serial/usb-serial.c: USB Serial support registered for Generic
usbcore: registered new driver usbserial
drivers/usb/serial/usb-serial.c: USB Serial Driver core v2.0
usb 2-2: new full speed USB device using address 3
inserting floppy driver for 2.6.5-7.111-default
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
eth0: no IPv6 routers present
usbcore: registered new driver snd-usb-audio
st: Version 20040318, fixed bufsize 32768, s/g segs 256
Attached scsi generic sg0 at scsi0, channel 0, id 0, lun 0, type 0
Attached scsi generic sg1 at scsi1, channel 0, id 0, lun 0, type 0
end_request: I/O error, dev fd0, sector 0
mtrr: 0xd0000000,0x10000000 overlaps existing 0xd0000000,0x1000000
btw, ik krijg WEL een foutmelding... bij het opnieuw configureren van de kaart met yast2:
De kernel module snd-emu10k1 voor geluidsondersteuning kon niet geladen worden. Dit kan veroorzaakt zijn door een foutieve module parameters, een ongeldige IO of verkeerde IRQ parameters
en nou?
  • Slayer
  • Laatst online: 23:59
Slayer
1981 - 2019 - 2024?
http://cdb.suse.de/showPr...a7809ea82859e3a7bb1960922
Geen onder steuning voor de amd64 ,wel voor de i386 .
Black Sabbath - End of the Beginning
Elizabeth is lief :)
Firefox Browser
KINKpuntnl
ho ho zo makkelijk ben ik niet te vangen
volgens onderstaande link zou mijn VIA8237 onboard ook niet moeten werken, aangezien ik die altijd al disabled had staan had ik het nog niet geprobeerd, maar na de vorige reactie toch maar ff gedaan: automatisch wordt hij gedetecteerd, deed ff moeilijk en zei dattie m niet kon configureren ivm verkeerde parameters (kernel-modules konden niet geladen worden ofzo). Heb card verwijderd, opnieuw geinstalleerd: en voila! :9
Maar, nu wil ik (natuurlijk) mn creative soundblaster live draaiende hebben... Dus mocht iemand nog suggesties hebben.... :)
[a href]http://hardwaredb.suse.de/showProduct.php?LANG=en_UK&searchtype=simple&product_id=25547&arch_id=&dist_id=&PHPSESSID=c57fb285d87dcbcde90d24c7c8c19c77[/a]
  • blouweKip
Het feit dat die module wel netjes wordt geladen als je bent opgestart (afgaande op je lsmod) geeft mi aan dat die foutmelding vast iets te mken heeft met iets wat yast fout doet (?)
je kunt met amixer iig bekijken wat er allemaal aan mixer controls zijn en welke gemute zijn (ik neem aan dat minstens master en pcm geunmute moeten zijn), met alsamixer kun je meteen zien welke dingen aanstaan en op welk volume niveau
Bij xmms kun je bovendien een oss output plugin gebruiken en een alsa output plugin, kijk eens bij de prefs welk hij nu gebruikt (waarschijnlijk oss) en probeer dan eens de alsa plugin
hier vind je iig wat extra info over je kaartje met alsa (ik neem aan dat dit toch wel met x64 moet werken)
tnx for the reply :)
xmms heb ik alle mogelijke output plugins laten gebruiken, met consequent hetzelfde resultaat.
Ik heb idd de volumes bekeken en alles op zo ongeveer 80 gezet. MAster en pcm in ieder geval. Van de ongeveer 12 kanalen die ik harder en zachter kon zetten was er ook eentje die heet SBlaster Live, hier kon ik doen wat ik wil, maar kreeg het volume niet omhoog. (hij was niet gemute, maar staat op nul)
Ik zal die alsa-instructies uitvoeren, wellicht dat dat ene oplossing biedt, t ziet er geloofwaardig uit :)
