javascript ik snap em niet
  • 69 views sinds 30-01-2008
hallo..
ik wil net zo iets als op deze pagina:
hier is een voorbeeld: http://www.luckysworld.com/ kies nederland..in et nav menu kies je crack pagina`s en dan crack pagina 2 of een andere pagina
je ziet dan dat je eerst op ze banner moet klikken voordat je verder kan
dit is de html code
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<!-- saved from url=(0047)http://www.luckysworld.com/Sponsor/Open-C1.html -->
<HTML><HEAD><TITLE>--==Lucky's World==--</TITLE>
<META http-equiv=Content-Type content="text/html; charset=windows-1252">
<META content=noindex,nofollow name=robots>
<SCRIPT language=JavaScript>
function FrameCheck() {
var found = false;
for (var i=0; i < top.frames.length;i++) {
if(top.frames[i].name == "main") {
found = true;
break;
if(!found) {
this.top.location = "../Foutmelding.html";
OnLoad=FrameCheck()
</SCRIPT>
<SCRIPT language=javascript>
function ExtraClick()
{ off('channel3');
off('channel4');
off('channel5'); }
function checkPoint (numChannels) // returns 0 if all channels have been clicked or name of first unvisited channel encountered
{ for (var i=1; i<=numChannels; i++)
{ if ( !(channelVisited[i]) )
{ return ( "Like I said.....You have to click through on my \nsponsor first before you can enter the cracks !!");
return ""; }
function off (n) // removes dot upon click of channel button and checks to see if OK to light quiz dot
{ channelVisited[ parseInt(n.substring(7,8)) ] = true;
if (isOK)
function loadAdd (addURL) // if all channels have been visited, then goto quiz
{ var result = checkPoint(numChannels);
if ( result == "" ) { self.window.location = addURL; } else { alert(result); } }
function makeBooleanArray (length) { // this function is an array constructor
this.size = length;
for (var i=1; i<=length; i++) { this[i] = false; }
return this; }
function main () // main routine
{ if (isOK)
{ blank = new Image(); blank.src = " ";
reddot = new Image(); reddot.src = " ";
lighton = new Image(); lighton.src = " ";
lightoff = new Image(); lightoff.src = " "; } }
var numChannels = 1; // global, number of channels on cruiser remote
var isOK = ( document.images ); //does this browser support image replaces?
var channelVisited = new makeBooleanArray(numChannels); //makes boolean array, with original elements all set to false
main ();
</SCRIPT>
<META content="Microsoft FrontPage 4.0" name=GENERATOR></HEAD>
<BODY text=#ffff99 vLink=red aLink=#33ff00 link=yellow bgColor=#000000
background=Open-C1_bestanden/Sterren.gif>
<CENTER><FONT face="Comic Sans MS,Arial,Helvetica"><IMG height=42 alt=""
src="Open-C1_bestanden/Head-crack1.jpg" width=270 border=0><BR><BR>Welcome to
<FONT color=#ffff00>---===Lucky's World===---</FONT> Crack and Hacks I
site<BR><BR>Before you go to the cracks You have to click through on my
sponsor,<BR>Once you have clicked the banner below and after that clicked on
"Enter" in<BR>the opening window, you can access my cracks by clicking <a onmouseover=" window.status='Enter Here';return true" style="COLOR: yellow" href="javascript:loadAdd('Unavailable-C1.html')">>> here <<</a>.
<BR><BR><a href="http://www.jurwebz.tk" target="_BLANK">[img]"Open-C1_bestanden/Mod1.gif"[/img]</a>
<BR><BR><FONT color=yellow>This is not some kind of cheap trick, it's just the
only <BR>way to keep the cracks free and available to
everyone.<BR><BR></FONT></FONT><BR>
<SCRIPT language=JavaScript1.2>
function notice(){
menutext.style.left=document.body.scrollLeft+event.clientX
menutext.style.top=document.body.scrollTop+event.clientY
menutext.style.visibility="visible"
return false
function hidenotice(){
menutext.style.visibility="hidden"
</SCRIPT>
<!--[if IE]>
<DIV id=menutext>
<DIV url=""></DIV></DIV><![endif]-->
document.oncontextmenu=notice;
if (document.all&&window.print)
document.body.onclick=hidenotice;
</SCRIPT>
<!--- Begin disclaimer --->
<CENTER><IMG height=20 alt="" src="Open-C1_bestanden/Strip.jpg" width=403
border=0> <BR><STRONG><FONT face=Arial color=white size=1><FONT face=""
color=red>This page is a part of</FONT><BR><A href="http://www.luckysworld.com/"
target=_top>---=== Lucky's World ===---</A><BR><BR><B>Copyright© 1998 <A
href="mailto:webmaster@luckysworld.com"><B>Lucky's World</B></A>. All rights
reserved.
</STRONG></B></FONT><BR></CENTER><!--- End disclaimer ---><BR></CENTER></BODY></HTML>
plz zeg me wat ik in het script moet veranderen zodat ik er ook mijn eigen banner eof tekstlink kan neerzettem
  • JHS
  • Laatst online: 24-06 10:44
JHS
Splitting the thaum.
Als ik je iets mag adviseren: leer gewoon zelf javascript, zijn veel tutorials en boeken over te vinden, en maak dan zelf een scriptje :) . Werkt meestal een stuk beter dan andere mensen proberen scripts van weer anderen aan te passen :) .
DM!
  • curry684
  • Laatst online: 04-09 14:38
curry684
left part of the evil twins
Lees de FAQ en zodadelijk je mailbox.
Professionele website nodig?
