Sorteren gegevens vanuit MDB naar ASP pagina.
  • 35 views sinds 30-01-2008
Yo people, kheb een klein dinkie, ben niet goed in deze coderingen dus here it goes:
<%@LANGUAGE="JAVASCRIPT" CODEPAGE="1252"%>
<!--#include file="../../Connections/conkam.asp" -->
var rsJaartal2__MMColParam = "Nieuwbouw";
if (String(Request.Form("hfSoort")) != "undefined" &&
String(Request.Form("hfSoort")) != "") {
rsJaartal2__MMColParam = String(Request.Form("hfSoort"));
var rsJaartal2 = Server.CreateObject("ADODB.Recordset");
rsJaartal2.ActiveConnection = MM_RemoteCon_STRING;
rsJaartal2.Source = "SELECT * FROM tbProjecten WHERE project_bouwvorm = '"+ rsJaartal2__MMColParam.replace(/'/g, "''") + "' AND project_status='Gerealiseerd' AND project_aanneming=true ORDER BY project_oplevering DESC";
rsJaartal2.CursorType = 0;
rsJaartal2.CursorLocation = 2;
rsJaartal2.LockType = 1;
rsJaartal2.Open();
var rsJaartal2_numRows = 0;
var Repeat1__numRows = -1;
var Repeat1__index = 0;
rsJaartal2_numRows += Repeat1__numRows;
<% var MM_paramName = ""; %>
// *** Go To Record and Move To Record: create strings for maintaining URL and Form parameters
// create the list of parameters which should not be maintained
var MM_removeList = "&index=";
if (MM_paramName != "") MM_removeList += "&" + MM_paramName.toLowerCase() + "=";
var MM_keepURL="",MM_keepForm="",MM_keepBoth="",MM_keepNone="";
// add the URL parameters to the MM_keepURL string
for (var items=new Enumerator(Request.QueryString); !items.atEnd(); items.moveNext()) {
var nextItem = "&" + items.item().toLowerCase() + "=";
if (MM_removeList.indexOf(nextItem) == -1) {
MM_keepURL += "&" + items.item() + "=" + Server.URLencode(Request.QueryString(items.item()));
// add the Form variables to the MM_keepForm string
for (var items=new Enumerator(Request.Form); !items.atEnd(); items.moveNext()) {
MM_keepForm += "&" + items.item() + "=" + Server.URLencode(Request.Form(items.item()));
// create the Form + URL string and remove the intial '&' from each of the strings
MM_keepBoth = MM_keepURL + MM_keepForm;
if (MM_keepBoth.length > 0) MM_keepBoth = MM_keepBoth.substring(1);
if (MM_keepURL.length > 0) MM_keepURL = MM_keepURL.substring(1);
if (MM_keepForm.length > 0) MM_keepForm = MM_keepForm.substring(1);
<html>
<head>
<title>Untitled Document</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<link rel="stylesheet" href="../../rood.css" type="text/css">
<style type="text/css">
.style2 {
font-size: 14pt;
font-weight: bold;
color: #FF0000;
.style3 {
color: #FF0000;
font-weight: bold;
</style>
</head>
<body bgcolor="#FFFFFF" text="#000000">
<table width="700" border="0" cellspacing="0" cellpadding="5">
<tr>
<td colspan="2" valign="top"> <span class="style2">Kam documenten:</span>
<hr> </td>
</tr>
<tr>
<td colspan="2" valign="top"><span class="style3">Hieronder staan de KAM documenten.</span></td>
</tr>
</table>
<br>
<tr>
<td width="337"> <div align="center">
<form name="form1" method="post" action="gerealiseerd.asp">
<input type="hidden" name="hfSoort" value="Nieuwbouw">
<input type="submit" name="Submit" value="KAM">
</form>
</div></td>
</tr>
</table>
<br>
<% if (!rsJaartal2.EOF || !rsJaartal2.BOF) { %>
<tr>
<td><b>KAM documenten: </b></td>
</tr>
</table>
<% while ((Repeat1__numRows-- != 0) && (!rsJaartal2.EOF)) { %>
<tr>
<td valign="top"><A HREF="project.asp?<%= MM_keepNone + ((MM_keepNone!="")?"&":"") + "project_id=" + rsJaartal2.Fields.Item("project_id").Value %>"><%=(rsJaartal2.Fields.Item("project_naam").Value)%></A> <hr> </td>
</tr>
</table>
Repeat1__index++;
rsJaartal2.MoveNext();
<% } // end !rsJaartal2.EOF || !rsJaartal2.BOF %>
<% if (rsJaartal2.EOF && rsJaartal2.BOF) { %>
<tr>
<td>Voor deze pagina zijn nog geen gegevens beschikbaar.</td>
</tr>
</table>
<% } // end rsJaartal2.EOF && rsJaartal2.BOF %>
Repeat1__index++;
</body>
</html>
rsJaartal2.Close();
Op deze pagina, moet hij gegevens vanuit een MDB halen en sorteren op volgorde.
Hij heeft de gegevens dat is het probleem niet, het gene is dat het wel 100 gegevens zijn, en deze erg lastig uit te zoeken zijn als ze niet op volgorde staan.
Iemand een idee hoe ik dat in die codering kan prakken?
alvast bedankt!
  • Pelle
  • Laatst online: 16:16
Pelle
Ja, dat idee heb ik wel.
Ga eerst dit maar eens doorlezen: [rml][ W&G FAQ] Welkom in W&G: FAQ en Beleid[/rml]
