ik heb een probleem. Ik wil wma's naar mp3's converteren, maar mplayer kjan ze allereerst al niet afspelen, dus die leuke scripts daarvoor werken dan ook niet. Als ik "mplayer test.wma" doe, hoor ik een harde kssslrick, alsof hij in een 10e seconde door de file raast. Wat zou er mis kunnen zijn? ik heb de win32 codecs geinstalleerd.
Output :
MPlayer 1.0pre5-3.4.2 (C) 2000-2004 MPlayer Team
CPU: Advanced Micro Devices Athlon 4 /Athlon MP/XP Palomino 1533 MHz (Family: 6, Stepping: 2)
Detected cache-line size is 64 bytes
CPUflags: MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 0
Compiled with runtime CPU detection - WARNING - this is not optimal!
To get best performance, recompile MPlayer with --disable-runtime-cpudetection.
Reading config file /etc/mplayer/mplayer.conf
Reading config file /root/.mplayer/config
Reading /root/.mplayer/codecs.conf: Reading /etc/mplayer/codecs.conf: 73 audio & 180 video codecs
font: can't open file: /root/.mplayer/font/font.desc
Font /usr/share/mplayer/font/font.desc loaded successfully! (206 chars)
Using usleep() timing
Input config file /etc/mplayer/input.conf parsed: 53 binds
Playing test.wma.
Cache fill: 2.34% (196608 bytes) ASF file format detected.
Clip info:
name: Here We Are
author: Idols
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 44100 Hz, 2 ch, 16 bit (0x10), ratio: 8003->176400 (64.0 kbit)
Selected audio codec: [ffwmav2] afm:ffmpeg (DivX audio v2 (ffmpeg))
Checking audio filter chain for 44100Hz/2ch/16bit -> 44100Hz/2ch/16bit...
AF_pre: af format: 2 bps, 2 ch, 44100 hz, little endian signed int
AF_pre: 44100Hz 2ch Signed 16-bit (Little-Endian)
AO: [oss] 44100Hz 2ch Signed 16-bit (Little-Endian) (2 bps)
Building audio filter chain for 44100Hz/2ch/16bit -> 44100Hz/2ch/16bit...
Video: no video
Starting playback...
A: 0.0 0.0% 20%
A: 0.0 0.0% 19%
A: 0.0 0.0% 18%
enz. tot
A: 0.0 0.0% 0%
Exiting... (End of file)
Output :
Playing test.wma.
Clip info:
name: Here We Are
author: Idols
Video: no video
A: 0.0 0.0% 20%
A: 0.0 0.0% 19%
A: 0.0 0.0% 18%
enz. tot
A: 0.0 0.0% 0%
[ Voor 74% gewijzigd door Verwijderd op 20-10-2004 10:47 ]
