[CASE] CasEdge Diabolic - Venom Green
  • TommyGun
  • Laatst online: 05-10 09:56
TommyGun
Stik er maar in!
Heyz,
Ik zit nu al een tijdje opgescheept met een Sweex Xeon CT P4 kast dat dus 3x niks is.... Nu wil ik een andere case gaan halen en mijn oog viel op de volgende kast;
http://shop.freezinghardw...?Pagina=00003&ItemID=1755
Afbeeldingslocatie: http://shop.freezinghardware.nl/productimages/1755-1748.gif
Nu is mijn vraag,
Krijg ik mijn hardware hierin? Specs;
Mobo: Asus P4P800 Deluxe
VGA: ATI Radeon 9800
Dit lijken me de belangrijkste specs aangezien stuff zoals een CD-RW wel past i.m.o.
Meer info;
Specs case;
SPECIFICATIONS
Dimension (D x W x H)
19" x 8" x 17"
490 x 200 x 430 mm
Drive Bays
4x5.25" Exposed (Slide in/out)
2x3.5" Exposed (Slide in/out)
4x3.5" Internal (Slide in/out)
Power Supply
SPI ODM 300W/350W/400W power supply
Front Panel
4xFront USB (2.0)
Audio and phone connector
1x1394 Firewire
3G Fan Duct
1x120 mm fan on the rear
Tool-less chassis design
Overig;
Support Intel 3G CPU (Intel Approved) Pentium P4 ready chassis
Supports up to four 5.25" devices secured with rails, which slide in/out from the front
Supports up to two 3.5" devices secured with rails, which slide in/out from the front
Supports up to four internal 3.5 HDD with handle, secured with thumbscrews which slide in/out from the side
Offers both ATX and Micro ATX motherboard compatibility
Includes seven I/O slots on rear panel, all ATX/BAT interchangeable
Features special vent holes on door and side panel (tool-less) for better thermal performance
Includes 120mm fan at rear
Support 2.0 Version front USB, IEEE 1394 Firewire, audio, and phone jack
Tool-less removable/installation of M/B tray
Key Lock
5 different colors to choose from: Electric Yellow, Venom Green, Storm Blue, Blood Red, Arcane Purple
Product Reviews: www.overclockercafe.com, www.cluboverclocker.com, www.ocia.net, www.extremeoverclocking.com, www.bigbruin.com, www.atruereview.com, www.modthebox.com
Alvast bedankt !!!
Ps; Iemand enig idee wat deze dingen onderaan op de screen zijn?
Afbeeldingslocatie: http://www.casedge.com/images/expand_diabolic02.jpg
  • jiroenu
  • Laatst online: 22-12-2025
jiroenu
Jiroenu
bedoel je die metalen dingen
[ Voor 58% gewijzigd door jiroenu op 17-10-2004 17:14 ]
Website
  • TommyGun
TommyGun
Stik er maar in!
Ja en dat doorzichtige kunstof (???) gedeelte tegen het front aan.
Aangezien dat een ATX-case is, en je mobo ook ATX is, zijn ze gewoon compatibel dus past 't er gewoon in. ;)
Dat is(denk ik - weet t niet zeker) het gedeelte waar je HDD´s in komen...Heb je er niet over in een review gelezen ofzo?
[ Voor 41% gewijzigd door Verwijderd op 17-10-2004 17:17 ]
een drivebay lijkt me want je heb volgends de case moet je 3 drivebays hebben
vette kast btw!
[ Voor 27% gewijzigd door Verwijderd op 17-10-2004 17:18 ]
  • tafkaw
  • Laatst online: 19:06
die zooi past wel, dat plastic ding lijkt me een hd cage en die metalen dingen zijn strips om je cdromspelers op te hangen...
  • TommyGun
TommyGun
Stik er maar in!
Ah ik had idd niet gezien dat dat doorzichte kunstof o.i.d een drivebay is.
Verder, Die ijzeren dingen... Wat is het nou precies? Kom er niet meer echt uit nu. Als ondersteuning voor de CD-ROM's e.d of om mee vast te klikken i.p.v schroeven?
Ty
Edit;
Extern is er ruimte voor vier 5,25" en twee 3,5" drives. Deze drives worden met het meegeleverde bevestigingsmateriaal in de sliding drive rail geschoven.
[ Voor 69% gewijzigd door TommyGun op 17-10-2004 17:24 ]
  • m-m
m-m
Topics over cases horen in Overige Hardware, waar ie bij deze staat :Y)
  • TommyGun
TommyGun
Stik er maar in!
Nu word me dat onderste gedeelte toch wel heel vreemd;
Afbeeldingslocatie: http://www.alltests.de/hardware/reviews_04/casedge_diabolic/oeffnung_1.jpg
Afbeeldingslocatie: http://www.alltests.de/hardware/reviews_04/casedge_diabolic/cdromfddschienen_1.jpg
Meer;
http://www.alltests.de/ha...abolic/casedge_diab_2.php
  • jiroenu
jiroenu
Jiroenu
wat is daar vreemd aan dan
zijn gewoon bevestigings beugels voor je 5,25 inch thingies en voor je floppy drive
staat er ook op "FOR FDD" en "FOR CDROM(ondersteboven)"
en dat ringetje is waarshijnlijk om die beugels onder in je kast vast te houden zodat ze niet gaan schuiven als je je case verplaatst
[ Voor 7% gewijzigd door jiroenu op 17-10-2004 21:25 ]
Website
