[w2k3 ent srv] multiprocessor wordt niet gezien
  • DaMoUsYs
  • Laatst online: 10:46
dag mensen
ik heb gezocht op google em hier en kwam op het volgende uit
- Opnieuw installeren werkt niet
- bij je device manager een andere PC installeren werkt ook niet
- wordt wel gezien in POST
dat was het enige wat ik kon vinden
specs
compaq pressario proliant 3000
2 * pentium II 333 mhz CPU ziet er maar 1 (duh)
25 GB SCSI RAID 5 (totaal)
256 MB RAM
standaard video
wie weet wat dit is ?
[ Voor 7% gewijzigd door DaMoUsYs op 14-10-2004 11:27 ]
Check dit en help mee!
http://www.google.nl/sear...%22Windows+Server+2003%22 :
There is a known issue with Windows Server 2003 on some Pentium Pro or Pentium II dual-processor or multiple-processor servers where the server may fire up with only one processor.
This situation may occur if you upgrade from Windows NT 4.0 or Windows 2000 to Windows Server 2003 and the error message of "Unsupported Multiprocessor Configuration" will be displayed according to Microsoft Knowledge Base Article - 319091 http://support.microsoft.com/default.aspx?scid=kb;en-us;319091
The Unsupported Multiprocessor Configuration issue affects the following Intel processors:
x86 Family 6 Model 1 Stepping X GenuineIntel (where X = 1, 2, 6, 7, or 9)
x86 Family 6 Model 3 Stepping X GenuineIntel (where X = 3 or 4)
When you perform the compatibility check after your upgrade the operating system you may receive the following message if you are using these processors:
"Microsoft Windows Server 2003 family of operating systems and the processors in this system do not operate together in a multiprocessor configuration."
The upgrade will continue but upon completion Windows Server 2003 will only operate with a single processor.
There does not seem to be a whole lot of additional information on this and the only real solution to the issue is to use processors with different revision levels.
Bron: http://www.networknewz.co...0onWindowsServer2003.html
Windows Server 2003 May Not Use Multiple Processors with Some Pentium Pro or Pentium II Processors
Naslag: http://support.microsoft.com/default.aspx?scid=kb;en-us;319091
[ Voor 96% gewijzigd door Verwijderd op 13-10-2004 00:13 ]
  • DaMoUsYs
mijn proc is
uit winmsd
x86 Family 6 model 5 stepping 1 GenuineIntel ~331mhz
dus die staat er niet bij
[ Voor 15% gewijzigd door DaMoUsYs op 13-10-2004 00:15 ]
  • DaMoUsYs
er staat ook niks in de resource kit van 2003
bij vorige versies van windows was er een .exe bestand voor heb ik gezien op google
is er ook zo iets voor 2003 ?
  • Question Mark
  • Laatst online: 13:35
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
Detecteert je bios beide CPU's wel goed?
  • DaMoUsYs
ja wel in de POST
hoe kom je btw IN het BIOS?
sorry
[ Voor 69% gewijzigd door DaMoUsYs op 13-10-2004 10:10 ]
  • Question Mark
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
DaMoUsYs schreef op 13 oktober 2004 @ 10:09:
ja wel in de POST
sorry
Als je de machine met SmartStart geinstalleerd hebt, staat er een speciale Compaq System Partition op, welke met F10 te benaderen is (Mits de server met een SmartStart versie lager dan 6.00 geinstalleerd is). In deze partitie staan diverse tools om het systeem te testen en systeem-info te verkrijgen en aanpassingen te doen.
Hogere versies van SmartStart installeren de System Partition niet meer, aangezien de geinstalleerde tools bij de servers die de SmartStart versie ondersteunen in het Bios hebben zitten. JE krijgt dan tijdens de post berichten als "Press F1 to configure....."
  • DaMoUsYs
o oke
f1 of iets dergelijks staat er niet bij f10 wel dus ff proberen
zou ik daar ook kunnen zien ofdat er iets mis is met mijn prossecor of socket oid?
ben nu op mijn stage dus strax ff zelf testen
  • mutsje
  • Laatst online: 28-10 22:09
mutsje
Certified Prutser
Question Mark schreef op 13 oktober 2004 @ 10:44:
Presario is Workstation geen server.
Verder kun je de HAL tijdens booten hard refreshen door F7 (ipv F8) in te rammen...
  • Question Mark
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
mutsje schreef op 13 oktober 2004 @ 15:46:
Oeps! :X Ik las per ongeluk proliant 3000 ipv pressario 3000...
  • DaMoUsYs
maakt niet uit
maar @ Question Mark
ik heb geinstalleerd met smartstart 4 maar als ik dan op F10 druk kan hij zijn System Partition niet vinden . of moet dan die cd er weer in ?
  • RawPeanut
  • Laatst online: 11-09 15:38
RawPeanut
Nog niet gare aardnoot
Het kan best zijn dat de computer niet ACPI compatible is en dat de setup hem dus niet herkent als een Mulitproc systeem. Er is meende ik een manier om zelf te kiezen wat voor HAL je installeert. Hoe ben ik op het moment vergeten.
Canon Digital Ixus V3
  • DaMoUsYs
RawPeanut schreef op 13 oktober 2004 @ 22:44:
hoe kan dit dan als er toch echt 2 processors in kunnen?
zelfs als je er maar 1 gebruikt moet er een dummie in
  • RawPeanut
RawPeanut
Dat heeft niks met ACPI te maken. ACPI houdt ruwweg in dat software een hoop kan configureren aan een pc en veel dingen ineens goed herkend. Of iets in die trend. Moderne PC's met ACPI kunnen bijvoorbeeld 6 apparaten op 1 IRQ hebben, wat een pc zonder ACPI niet kan. Ook automatische afsluiten is een functie van ACPI. Elke moderne windows gaat ervan uit dat het systeem waarop het geinstalleerd word een ACPI systeem is. Daarom moet je dus zelf aangeven dat het om een Mulitprocessor PC gaat. Vergeet niet dat Plug & Play maar net begon op te komen.
  • DaMoUsYs
oke das waar
hij sluit idd ook niet automatisch af
maar hoe krijg ik t dan wel werkend ?
  • mutsje
mutsje
Certified Prutser
DaMoUsYs schreef op 13 oktober 2004 @ 23:40:
oke das waar
door het goed te installeren. Ik heb een hele tijd geleden windows 2003 server op een HP LH Pro dual 200pro cpu system geinstalleerd en ik zag keurig 2 cpu's... dus je doet gewoon ergens iets fout :S zal wel ergens iets vergeten ofzo kan zo maar gebeuren zonder dat je het door hebt.
  • DaMoUsYs
wat zou ik dan moet doen ?
hij hoord dat toch zelf te zien ?
  • Question Mark
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
DaMoUsYs schreef op 13 oktober 2004 @ 22:34:
Zie je in de disk administator ook een kleine partitie (van ong. 36 MB)? Zo ja, dan is dit je system partition en zou deze benaderbaar moeten zijn. Zo niet, dan is deze niet juist geinstalleerd. Wat je overigens ook eens zou kunnen proberen is het installeren van het Compaq Support Pack wat op elke SmartStart cd zou moeten staan. Ik weet niet precies waar deze staat op SmartStart 4 (volgens mij is versie 4 ook nog 2 cd's). Probeer eens of je aan SmartStart 5.50 kunt komen (dit is waarschijnlijk de hoogste versie die jou machine ondersteund).
Het support pack installeert/vervangt alle drivers van je machine opnieuw, inclusief system drivers, voor Compaq certified drivers. Misschien dat dit iets helpt. Ik heb overigens zelf een dual CPU Proliant 1600 (server) thuis die ook geen Acpi ondersteund...
Weet je trouwens wel zeker dat het een Pressario is, en geen Proliant. Ik kan me herinneren dat SmartStart niet wil starten op een niet-Proliant machine.
[ Voor 3% gewijzigd door Question Mark op 14-10-2004 11:24 ]
  • DaMoUsYs
ja natuurlijk is het een proliant
sorry (ik was net een pressario aan t reinstallen) :+
en nee ik heb die extra partitie niet :? hoe maak ik die aan ?
door die smartstart cd erin te doen ?
[ Voor 39% gewijzigd door DaMoUsYs op 14-10-2004 11:50 ]
  • Question Mark
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
DaMoUsYs schreef op 14 oktober 2004 @ 11:25:
Ik ken jouw versie van SmartStart niet, maar bij versie 5.5 kun je booten van cd. Hij ziet dat hij al gedeeltelijk geconfigged is, dus er start een speciaal menu op, met daarin enkele opties. Één van deze opties is het aanmaken van de system partition..
Maar, als je kunt booten vanaf SmartStart kun je dezelfde tools ook opstarten vanaf de SmartStart cd. (Vanaf system partition gaat alleen sneller). Het gaat vooral om de optie "Configure Hardware".
  • endless
Ik heb ook een probleem met Windows 2k3 server & een dubbel processor systeem.
Bij de install vraagt ie of het een dual processor system is, en wat voor één.
Ik heb ze allemaal geprobeerd, geen enkele werkt.
Ook werkt het niet als ik er 1 processor uithaal.
Het is een Pentium 2 450 Mhz Dual systeem.
Kan dit misschien ook aan de SCSI schijven liggen?
Dat het een schrijffout is of iets dergelijks?!
  • DaMoUsYs
@endless wanneer vraagt hij dat?
@Question Mark
ik heb het allerlaatste pack gedownd.
had ik dit niet moeten doen en alleen maar wat op mijn cd staat ?
  • Question Mark
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
DaMoUsYs schreef op 14 oktober 2004 @ 14:04:
Zou niet uit moeten maken het laatste Support Pack (version 7.10 A - 18 Jun 04) wat ik heb kunnen vinden (voor W2K3) ondersteunt gewoon alle versies van de Proliant 3000.
Standaard wordt alle software in het support pack geinstalleerd. Is de hardware niet aanwezig in het systeem, dan wordt de installatie van die betreffende driver overgeslagen:
Even when selected, only software that is appropriate for the system it is being run on will actually be installed. After installation of the appropriate software, the utility will display its results, including indication of software successfully installed, software not needed for the current system configuration, and any installation failures.
De enige tip die ik je kan geven is een call aanmaken bij HP/Compaq. Dit kan middels mail en gaat verder vrij anoniem. Er is tijdens aanschaf van de server al genoeg betaalt voor de service/support van Compaq.
  • DaMoUsYs
oke ik heb nu het laatste SPS geinstalleerd en met smartstart geboot
daar ziet ie wel 2 CPU's maar in windows nog steeds niet
weet iemand wat ik nu nog kan proberen ?
de 2 x p2 333 vervangen door 1 x p3 600 :?
  • DaMoUsYs
Verwijderd schreef op 15 oktober 2004 @ 16:08:
hier heb ik toch niks aan of wel ?
  • Frankie02
  • Laatst online: 31-08-2025
Een bios-update al gedaan??
  • DaMoUsYs
waar kan ik die halen?
moet ik dan bij compaq zijn ?
  • Frankie02
DaMoUsYs schreef op 15 oktober 2004 @ 18:09:
Bij HP tegenwoordig.....wel even zoeken vrees ik.
http://h18023.www1.hp.com...es/server/us/winroms.html
[ Voor 14% gewijzigd door Frankie02 op 15-10-2004 18:12 ]
  • Rolfie
  • Laatst online: 16:51
Wat zou zou kunnen is dat de server geconfigureerd is voor niet windows. Je kan in je bios (F10 / Smartstart) instellen wat het OS is wat op de server geinstalleerd word. Hierdoor worden een aantal settings in de bios ingesteld. Wat precies weet ik niet allemaal, maar dit zou je probleem kunnen zijn.
  • Sayko
  • Laatst online: 29-10 18:18
Sayko
Knowledge Is Power
Of tijdens de installatie, waar ie vraagt druk f6 voor.................., op f5 drukken en handmatig aangeven dat je multiprocessor wil installen.
  • DaMoUsYs
ja dat zou idd ook kunnen ja
@rolfje die staat daar gewoon op windows NT
Kun je de processor niet wisselen in Device Manager ?
Ik kon van ACPI Uniprocessor kernel naar ACPI SMP kernel, en zowel met 1 als ook 2 cpu's deed Windows het dan gewoon.
In taskmgr (ctrl-alt-del) moet je dan 2 processor-grafiekjes zien.
  • DaMoUsYs
ik zie niet eens een prossecor in device manager
probeer eens het progje SMPSeesaw van Mlin,is ideaal voor dual proc's gebruikers
http://www.mlin.net/SMPSeesaw.shtml
  • DaMoUsYs
ja dat is inderdaad handig als ik mijn twee processoren had
maar die heb ik niet
