Is dit een beetje goed voor een projector waar ik DVD films op wil kijken en soms een game:
VPL-CS2
Ultra portable LCD projector, SVGA panel, 600 ANSI lumen, 2.9 kg
Improving your presentation is cheaper than you think
To Buy: fl 7.385,00
Pay Per Period: fl 218,17
Exc. VAT per month
An impressive presentation for a modest price? It is all possible with the VPL-CS2, successor of the best selling LCD projector in Europe. Designed to work with almost any computer and video source, this projector offers true ''plug and play'' operation, which enables you to fully concentrate on your presentation.
But not only presentations can be improved. The VPL-CS2 also enhances your home video, PlayStation™ and DVD experience. And switching between professional and personal use is easy because it is so ultra portable.
Online Buy Offer
Buying online, the VPL-CS2 also includes a 3 year PrimeSupport Mobile contract featuring:
specialist telephone support
3 years warranty
free dispatch of a loan unit within 24 hours in the unlikely event of a product failure
Pay Per Period Offer
The Pay Per Period financial leasing option is a three year business-to-business solution that provides the latest projector technology, together with freedom and piece of mind. Pay Per Period offers your company the following benefits:
Spread of the capital expenditure, which improves cash flow
Unlike bank loans, lease payments are fully tax deductible
Full ownership over the projector at the end of the agreement
A projector from Sony is a business critical tool and, because of this, Pay Per Period includes a total support solution for 3 years: PrimeSupport Mobile.
Pay Per Period is open to VAT registered business users only and is currently not available in Austria, Denmark, Finland, Norway, Sweden and Portugal.
Customer Benefits
Ultra-portable. You're busy, you're mobile, you're staying ahead - you can't allow anything to slow you down. The Sony VPL-CS2 ultra-portable travel projector is light enough to sling over your shoulder at a moment's notice and take with you to the next briefing, presentation or meeting...wherever it is.
Bright picture in normal light. Circumstances aren't always ideal, but you can count on the performance from your Sony VPL-CS2 to be. Use any light-coloured surface to project a brilliant picture in normal light conditions.
Plug and Play. The VPL-CS2 is incredibly easy to set up and use. Just plug it in, attach it to your laptop, desktop, VCR or DVD player, press the APA (Auto Pixel Alignment) button for automatic fine-tuning of the picture and it's showtime.
Fully remote controlled. With the supplied RM-PJM10 remote commander, you do have full control over your projector. In addition you can use the remote as a wireless mouse and even start and stop your PowerPoint presentation with a single click.
Durable design. A lightweight, strong outer casing stands up to the rigours of travel. The front cover protects the lens, the integrated handle makes it easy to carry, and set-up is fast and efficient. The new hight adjsutable feet enables you to adjust the position of the picture precisely.
True audio-visual compatibility. With built-in stereo speakers, your presentation will sound every bit as good as it looks.
Product Features
Small size and light weight
Computer and video compatability
APA (Auto Pixel Alignmet) function
Unsurpassed video quality
USB and PS2 mouse connection
Carry handle and carry case
Height adjuster
Front cover
Supplied Accessories Fully featured remote control unit RM-PJM10
Video signal cable (2 m) SMF-410 HD D-sub 15-pin to HD D-sub 15-pin
USB Cable A type - B type
USB Application Software Projector Station 2©
Carrying bag
AAA size battery (x2)
Air Filter
Operating Manual
Quick Reference sheet
Optional Accessories Projector lamp LMP-C120 (for replacement)
Remote Commander RM-PJM610 includes Laser Pointer
Macintosh adaptor ADP-20 (Macintosh - VGA)
Screen VPS-50C 50-inch portable screen
Specifications Optical
Projection system 3 LCD panels, 1 lens projection system
LCD panel 0.7 inch p-Si TFT LCD panel
1,440,000 pixels (480.000 pixels x 3)
Projection lens 1.3 times zoom lens,
from 1.7 to 2.1,
from 28.74 to 37.36 mm
Lamp 120W UHP lamp LMP-C120
Screen coverage 40 to 150 inches (viewable area, measured diagonally)
Light output 600 ANSI lumens
Throwing distance
Screen diagonal in inches Screen width in mm throwing distance in mm
40-inch 810 mm 1580 to 2010 mm
60-inch 1220 mm 2390 to 3060 mm
80-inch 1630 mm 3210 to 4100 mm
100-inch 2030 mm 4030 to 5150 mm
120-inch 2440 mm 4850 to 6200 mm
150-inch 3050 mm 6080 to 7780 mm
Signals
Colour system NTSC, PAL, SECAM, NTSC 4.43, PAL-M, PAL-N
Resolution video: 600 TV lines
Resolution RGB: 800 x 600 pixels
Acceptable signals RGB (fH: 15 to 91 kHz, fV: 43 to 85 Hz), 15kHz component 50/60 Hz system, composite video, Y/C video
General
Cabinet colour Silky silver
Speaker Max. 0.5W x 2 (stereo)
Power requirements AC 100 to 240 V, 50/60Hz
Max 190W, Standby 4.2W
Operating temperature 0 to 35 degrees Celsius
Dimensions: 277(W) x 70 (H) x 214 (D) mm
Mass Approx. 2.9 kg
Inputs/Outputs
Composite video Phono type
Y/C Video input Mini DIN 4 pin can be selected by menu
Input A (RGB/Component) HD D-sub 15-pin (female) selection between RGB and component can be done by menu
Mouse Connection 6-pin (female)
USB Hub Up (B type female) x1, Down (A type female) x1
Audio In Stereo mini jack 3.5mm
Safety regulations cUL1950, EN60950, UL1950, CCIB, FCC class B, IC class B, CE, C-Tick, VCCI B
VPL-CS2
To Buy: fl 7.385,00
Exc. VAT per month
Online Buy Offer
3 years warranty
Customer Benefits
Product Features
Height adjuster
Front cover
Carrying bag
Air Filter
Operating Manual
from 1.7 to 2.1,
Throwing distance
Signals
General
Mass Approx. 2.9 kg
Inputs/Outputs
Thy will see the light...
