[PC][WinXP] Call of duty OpenGl Error
  • 259 views sinds 30-01-2008
Ik krijg de volgende error in Call of duty:
COD 1.0 build win-x86 Oct 5 2003
----- FS_Startup -----
Current language: english
Current search path:
C:\PROGRA~1\CALLOF~1\main\pak6.pk3 (3 files)
C:\PROGRA~1\CALLOF~1\main\pak5.pk3 (4858 files)
C:\PROGRA~1\CALLOF~1\main\pak4.pk3 (1668 files)
C:\PROGRA~1\CALLOF~1\main\pak3.pk3 (1992 files)
C:\PROGRA~1\CALLOF~1\main\pak0.pk3 (12828 files)
C:\PROGRA~1\CALLOF~1/main
C:\PROGRA~1\CALLOF~1\main\localized_english_pak1.pk3 (3736 files)
localized assets pak file for english
C:\PROGRA~1\CALLOF~1\main\localized_english_pak0.pk3 (1204 files)
File Handles:
26289 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec config.cfg
couldn't exec autoexec.cfg
========= autoconfigure
configure.csv: using configuration 2000 cpu MHz 512 sys MB 128 vid MB
execing configure.cfg
fs_basepath is write protected.
fs_homepath is write protected.
Hunk_Clear: reset the hunk ok
...detecting CPU, found AMD w/ 3DNow!
Measured CPU speed is 2.09 GHz
System memory is 512 MB (capped at 1 GB)
Video card memory is 128 MB
Streaming SIMD Extensions (SSE) supported
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 6: 1024 768 FS
...using colorbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (1024x768)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...23 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...23 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (6)
...shutting down QGL
...unloading OpenGL DLL
Forcing 800x600 resolution to allow OpenGL to run in fullscreen
...initializing QGL
...setting mode 4: 800 600 FS
...calling CDS: ok
...created window@0,0 (800x600)
...23 PFDs found
...23 PFDs found
...WARNING: could not set the given mode (4)
Forcing 640x480 resolution to allow OpenGL to run in fullscreen
...initializing QGL
...setting mode 3: 640 480 FS
...calling CDS: ok
...created window@0,0 (640x480)
...23 PFDs found
...23 PFDs found
...WARNING: could not set the given mode (3)
----- CL_Shutdown -----
RE_Shutdown( 1 )
Could not load OpenGL. Make sure that you have the latest drivers for your video card from the manufacturer's web site.
Mijn systeem:
AMD2600XP
512 MB intern
MSI TI-4200 128 mb AGP8x
OS: WinXP SP 1
Videokaartdrivers: Nieuwste van nvidia.com
Wat heb ik al gedaan?
- Veel rondgelezen op tweakers (en andere forums), genoeg om te weten dat velen gaan zeggen: gebruik de searchoptie...
- Oude en de nieuwste detonator (heet inmiddels geloof ik anders?) drivers van nvidia geinstalleerd. Ook standaard drivers van windows geprobeerd.
- Van opengl.org een library gedownload (2.0) en geinstalleerd/ gedraaid
Spellen als: farcry, UT2004, Hidden and Dangerous 2...etc. draaien prima. Bij de OpenGL software zat ook een test/ benchmarktool om je OpenGL te testen, deze draaide uitstekend met goede fps score.
Wie heeft er nog een idee? Een link is ook goed, een simpele raad als gebruik de zoekoptie stel ik niet op prijs. Uit eigen ervaring kan ik zeggen dat het frustrerend is voor iemand met hetzelfde probleem om in >15 topics te lezen de search te gebruiken zonder dat er een concrete oplossing ligt...
[ Voor 1% gewijzigd door Verwijderd op 10-10-2004 20:49 . Reden: typo ]
  • Crash
  • Laatst online: 18-10 19:36
CoD al eens opnieuw geinstalleerd? :)
Er waren overigens problemen met CoD en de laatste officiele drivers van Nvidia, maar geheel zeker durf ik je dat niet te zeggen.
Vergeten te vermelden, gedaan!
*hoopvolle kick* ;)
  • Virgil
  • Laatst online: 18-10 22:12
Virgil
We're not alone
q3 engine, ken de foutmelding, opnieuw installeren van je nvidia drivers. EN REBOOTEN!
http://download.nvidia.co...61.77_win2kxp_english.exe
[ Voor 23% gewijzigd door Virgil op 11-10-2004 17:46 ]
Ik was heel, heeeel vroeger SeRRveR
Been there done that.
Videokaart ook al helemaal verwijderd --> gereboot, om er zeker van te zijn dat ie géén oude drivers gebruikt. Daarna de nvidia drivers geinstalleerd die jij nu aanbeveelt. (Dit proces al enkele keren geprobeerd...)
Geen resultaat.
Ter informatie/ toevoeging aan de knowledge base, de oplossing:
Bij de toendertijd gedane windows installatie kon een bestand niet van de windows XP cd gelezen worden (kwam ik later achter) en wel het volgende bestand: opengl.dll (ik kan er een karakter naast zitten qua naam). Bij nieuwe windowsinstall dit bestand van andere cd gehaald en het werkt!
