[vb6] Rst.Movenext?
  • 65 views sinds 30-01-2008
Kan iemand mij vertellen waarom rst.movenext niet werkt? Hij blijft steeds op hetzelfde punt hangen...
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
Private Sub VulDb()
'On Error GoTo Fout
    Call FrmLaad.Laad
    Dim StrSql As String
    If DbArt.Recordset.EOF = False And DbArt.Recordset.BOF = False Then
        DbArt.Recordset.MoveFirst
        Do While DbArt.Recordset.EOF = False
            DbArt.Recordset.Delete
            DbArt.Recordset.MoveNext
        Loop
    End If
    RefreshDbArt
    'DbArt.NewPassword "", "dinges"
    Set Db = New ADODB.Connection
    Call Db.Open("Provider=SQLOLEDB;Data Source=" & TxtServer.Text & ";Initial Catalog=" & TxtDb.Text & ";User ID=" & TxtUser.Text & ";Password=" & TxtDbWW.Text)
    Db.CursorLocation = adUseServer
    Set Rst = CreateObject("ADODB.Recordset")
    Rst.CursorLocation = adUseServer
    StrSql = "SELECT items.ItemCode, items.Description FROM items, ItemAssortment WHERE " & _
    "items.Description NOT LIKE 'DISP%' AND " & _
    "items.Description NOT LIKE 'disp%' AND " & _
    "items.ItemCode <> '00' AND " & _
    "ItemAssortment.code <> 'Z5' AND " & _
    "ItemAssortment.code <> 'Z6' AND " & _
    "ItemAssortment.code <> 'Z7' AND " & _
    "ItemAssortment.code <> 'Z9' ORDER BY items.ItemCode"
    Rst.Open StrSql, Db, adOpenDynamic, adLockReadOnly, -1
    If Rst.EOF = True And Rst.BOF = True Then
        MsgBox "Kan geen geldige artikelen vinden in de database!", vbOKOnly + vbExclamation, "Fout!"
        Exit Sub
    Else
        Dim Tel As Integer
        Tel = 10
        'Do While Rst.EOF = False
        Do While Tel > 0
            MsgBox Rst("ItemCode"), vbOKOnly, "code"
            MsgBox Rst("Description"), vbOKOnly, "dec."
            DbArt.Recordset.AddNew
            DbArt.Recordset("Artikelnummer") = Rst("ItemCode")
            DbArt.Recordset("Omschrijving") = Rst("Description")
            DbArt.UpdateRecord
            Rst.MoveNext
            Tel = Tel - 1
        Loop
    End If
    'Afsluiten
    Rst.Close
    Unload FrmLaad
Exit Sub
Fout:
    Dim ErrN As String
    Dim ErrD As String
    ErrN = Err.Number
    ErrD = "FrmMain;VulDb(): " & Err.Description
    Call DispFout(ErrN, ErrD)
End Sub
Let ff niet op de slordigheidjes aub... :P
  • gorgi_19
  • Laatst online: 15:57
gorgi_19
Kruimeltjes zijn weer op :9
Debuggen is iets wat je zelf mag doen :)
Digitaal onderwijsmateriaal, leermateriaal voor hbo
