(XP)could not peform fixation?
Ik brand met nero op 1x (evox Xbox) 6.3.1.10 is de versie van nero aan het eind bij 100 procent krijg ik dus de error: Could not pefrom fixation.
Heb al geupdate (win.) ander merk cd iso aangepast. is nu 509 mb (extra data pakt de xbox beter)
Hoe kan ik dit oplossen heb de error log meegestuurd.
op het einde staat dus dit: Logical unit not ready, operation in progress
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16-12-2003 20:18:06
Nero version: 6.3.1.10
Recorder: <HP CD-Writer+ 9300> Version: 1.0c - HA 3 TA 1 - 6.3.1.10
Adapter driver: <atapi> HA 3
Drive buffer : 4096kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <COMPAQ CD-ROM CRD-8484B>Version: 1.06 - HA 3 TA 0 - 6.3.1.10
=== Scsi-Device-Map ===
DiskPeripheral : ST340014A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : COMPAQ CD-ROM CRD-8484B atapi Port 3 ID 0 DMA: On
CdRomPeripheral : HP CD-Writer+ 9300 atapi Port 3 ID 1 DMA: On
CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 4 ID 0 DMA: Off
CdRomPeripheral : CD-R/RW RW8080A FCUSB Port 5 ID 0 DMA: Off
=== CDRom-Device-Map ===
COMPAQ CD-ROM CRD-8484B E: CDRom0
HP CD-Writer+ 9300 F: CDRom1
Generic DVD-ROM G: CDRom2
CD-R/RW RW8080A H: CDRom3
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 39845888 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 247MB (253420kB)
Free physical memory: 41MB (42668kB)
Memory in use : 83 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
7.10.2004
CD Image
12:06:03 #1 Text 0 File Reader.cpp, Line 118
Reader running
12:06:03 #2 Text 0 File Writer.cpp, Line 124
Writer HP CD-Writer+ 9300 running
12:06:03 #3 Text 0 File Burncd.cpp, Line 3200
Turn on Track-at-once, using CD-R/RW media
12:06:03 #4 Text 0 File DlgWaitCD.cpp, Line 244
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 259253 ( 57:38.53)
12:06:03 #5 Text 0 File DlgWaitCD.cpp, Line 249
Write in overburning mode: FALSE
12:06:03 #6 Text 0 File DlgWaitCD.cpp, Line 2107
Recorder: HP CD-Writer+ 9300;
CDR code: 00 97 17 06; OSJ entry from: Moser Baer India Limited
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 11 06 (LI 97:17.06), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
12:06:03 #7 Text 0 File DlgWaitCD.cpp, Line 410
>>> Protocol of DlgWaitCD activities: <<<
12:06:03 #8 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, ISO 9660)
2 indices, index0 (150) not provided
original disc pos #0 + 259254 (259254) = #259254/57:36.54
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 259252 blocks [HP CD-Writer+ 9300 ]
12:06:07 #9 Text 0 File ThreadedTransferInterface.cpp, Line 982
Prepare recorder [HP CD-Writer+ 9300 ] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 531259392, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
259254 | lead-out | 1 | 0x00 | 0x41
12:06:07 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1028
Removed 2 run-out blocks from end of track 1. Length: 259254 -> 259252.
12:06:07 #11 Phase 24 File dlgbrnst.cpp, Line 1841
Caching of files started
12:06:08 #12 Text 0 File Burncd.cpp, Line 4210
Cache writing successful.
12:06:08 #13 Phase 25 File dlgbrnst.cpp, Line 1841
Caching of files completed
12:06:08 #14 Phase 36 File dlgbrnst.cpp, Line 1841
Burn process started at 1x (150 KB/s)
12:06:08 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2345
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
13:03:27 #16 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
13:03:59 #17 Text 0 File Mmc.cpp, Line 14887
<HP CD-Writer+ 9300 > start Close Session
13:07:59 #18 SCSI -1169 File Cdrdrv.cpp, Line 1185
SCSI Exec, HA 3, TA 1, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x04
Sense Qual: 0x08
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x02 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x04 0x08
13:07:59 #19 CDR -1169 File ThreadedTransferInterface.cpp, Line 1181
13:07:59 #20 TRANSFER -19 File ThreadedTransferInterface.cpp, Line 1181
Could not perform Fixation
13:08:15 #21 Text 0 File Mmc.cpp, Line 14887
13:08:15 #22 Text 0 File dlgbrnst.cpp, Line 1699
Set remaining time: 0:00,000 (0ms) -> OK
13:08:16 #23 Phase 38 File dlgbrnst.cpp, Line 1841
Burn process failed at 1x (150 KB/s)
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 17-8-2001 17:07:32
File 'WNASPINT.DLL': Ver=V1.18, size=57344 bytes, created 16-6-2004 0:00:00
File 'Drivers\atapi.sys': Ver=5.1.2600.1211 (xpsp2.030422-1633), size=87296 bytes, created 23-4-2003 9:29:54 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
