[HTML] Redirect
  • 41 views sinds 30-01-2008
Heb al heel wat Javascipts enzo doorgespit, maar kan geen goede vinden. Het gaat om de ovlgende HTML-code:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
<html>
<head>
<script language="javascript" type="text/javascript" src="maxwindow.js"></script>
<script language="javascript">
SCRIPT VOOR VOLLEDIG VENSTER ZONDER WERK- & STATUSBALKEN VAN INTERNET EXPLORER
function openIT(u,W,H,X,Y,n,b,x,m,r) {
    var cU  ='close.jpg'   //gif for close on normal state.
    var cO  ='close.jpg'  //gif for close on mouseover.
    var cL  ='clock.gif'      //gif for loading indicator.
    var mU  ='minimize.jpg'     //gif for minimize to taskbar on normal state.
    var mO  ='minimize.jpg'    //gif for minimize to taskbar on mouseover.
    var xU  ='max.jpg'     //gif for maximize normal state.
    var xO  ='max.jpg'    //gif for maximize on mouseover.
    var rU  ='restore.jpg'     //gif for minimize on normal state.
    var rO  ='restore.jpg'    //gif for minimize on mouseover.
    var tH  ='<font face=verdana size=2></font>'   //title for the title bar in html format.
    var tW  ='Welkom op de website van de Meester K.J. Dijkstraschool!'   //title for the task bar of Windows.
    var wB  ='#FFFF00'   //Border color.
    var wBs ='#FFFF00'   //Border color on window drag.
    var wBG ='#FFFF00'   //Background of the title bar.
    var wBGs='#FFFF00'   //Background of the title bar on window drag.
    var wNS ='toolbar=0,location=0,directories=0,status=0,menubar=0,scrollbars=1,resizable=0'  //Html parameters for Netscape.
    var fSO ='scrolling=auto noresize'   //Html parameters for main content frame.
    var brd =b||5;   //Extra border size.
    var max =x||false;   //Maxzimize option (true|false).
    var min =m||false;   //Minimize to taskbar option (true|false).
    var res =r||false;   //Resizable window (true|false).
    var tsz =20;   //Height of title bar.
    return chromeless(u,n,W,H,X,Y,cU,cO,cL,mU,mO,xU,xO,rU,rO,tH,tW,wB,wBs,wBG,wBGs,wNS,fSO,brd,max,min,res,tsz)
</script>
</head>
<body>
[b]<p><a href="#" onclick="venster_index=openIT('index.htm',600,400,null,null,'venster_index',5,true,true,true);return false">
Index</a>[/b]
</body>
</html>
Als deze pagina wordt geladen, moet gelijk de vetgedrukte regel worden geladen. Hoe kan ik dit het beste doen?
  • mulder
  • Laatst online: 22:43
mulder
ik spuug op het trottoir
in de onload van de body
oogjes open, snaveltjes dicht
  • HielkeJ
Gewoon de javascript code in je head zetten is toch genoeg?
Maar volgens mij wordt dit standaard geblokkeerd door Mozilla en WinXP SP2 :)
[ Voor 41% gewijzigd door HielkeJ op 07-10-2004 12:26 ]
  • Xboty
  • Laatst online: 21-09 14:38
Dan kun je beter de php functie header() gebruiken als je hier de mogelijkheid toe hebt, het enigste nadeel is dat je geen output kan hebben voor je de functie gebruikt.
PHP:
<?PHP
header("Location: http://mijnsite.ext/dir/file.htm");
[ Voor 19% gewijzigd door Xboty op 07-10-2004 12:32 ]
<body onload="openIT('index.htm',600,400,null,null,'venster_index',5,true,true,true);">
of onderaan je pagina:
<script type="text/javascript">
</script>
en houdt er rekening mee dat scripting op sommige browsers uitgeschakeld zal zijn of popupfilters gebruikt worden. Plaats dus altijd een normaal alternatief (met MSIE bijv. kunnen mensen zelf met F11 in fullscreen kioskmode browsen).
Tnx! Ik heb het voor mekaar! :)
  • crisp
crisp
Devver
Pixelated
/basic
Intentionally left blank
