[javascript] filterlist
Besten,
PS: Ik ben nog niet zo goed in javascript. Dit is een bestaande code die ik heb herschreven.
Ik probeer een option-list te filteren door enkel naar de eerste letters te kijken.
index.html
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
<html>
<head>
    <SCRIPT src="filterlist.js" type=text/javascript></SCRIPT>
</head>
<body>
    <FORM name=myform action="">
        <SELECT size=10 name=myselect>
            <OPTION>Keanu Reeves
            <OPTION>Laurence Fishburne
            <OPTION>Monica Bellucci
            <OPTION>Daniel Bernhardt
            <OPTION>Nona Gaye
            <OPTION>Lachy Hulme
            <OPTION>Nathaniel Lees
            <OPTION>Harry J. Lennix
            <OPTION>Matt McColm
            <OPTION>Carrie-Anne Moss
            <OPTION>Collin Chou
            <OPTION>Genevieve O'Reilly
            <OPTION>Harold Perrineau Jr.
            <OPTION>Jada Pinkett Smith
            <OPTION>Adrian Rayment
            <OPTION>Neil Rayment
            <OPTION>Bruce Spence
            <OPTION>Hugo Weaving
            <OPTION>Lambert Wilson
            <OPTION>Anthony Wong
            <OPTION>Walter O'Riley
            <OPTION>Zach Taylor
            <OPTION>Yuri Andropov
            <OPTION>Xavier
            <OPTION>Tom Selleck
            <OPTION>Heather Graham
            <OPTION>Ursula Andrews
            <OPTION>Victoria Jackson
            <OPTION>Vivian Vance
            <OPTION>Star Jones
            <OPTION>Steve McQueen</OPTION>
        </SELECT>
        <SCRIPT type=text/javascript>
            var myfilter = new filterlist(document.myform.myselect);
        </SCRIPT>
        <INPUT onkeyup=myfilter.set(this.value) name=regexp>
        <INPUT onclick="myfilter.reset();this.form.regexp.value=''" type=button value=Clear>
    </FORM>
</body>
</html>
filterlist.js
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
function filterlist(selectobj)
    // HTML SELECT object
    this.selectobj = selectobj;
    // Make a copy of the options array
    this.optionscopy = new Array();
    for (var i=0; i < selectobj.options.length; i++)
            this.optionscopy[i] = new Option();
            this.optionscopy[i].text = selectobj.options[i].text;
            this.optionscopy[i].value = selectobj.options[i].value;
    // This method resets the select list to the original state.
    // It also unselects all of the options.
    this.reset = function()
            this.set("");
    this.set = function(pattern)
        // This method removes all of the options from the select list,
        // then adds only the options that match the pattern regexp.
        // In case of a regexp error, returns false
            var loop=0, index=0, regexp, e;
        // Clear the select list so nothing is displayed
            this.selectobj.options.length = 0;
            // Loop through the entire select list
            for (loop=0; loop < this.optionscopy.length; loop++)
            // Check if we have a match
                if (Left(this.optionscopy[loop].text, this.selectobj.text))
                // We have a match, so add this option to the select list
                    this.selectobj.options.length = index + 1;
                    this.selectobj.options[index].text = this.optionscopy[loop].text;
                    this.selectobj.options[index].value = this.optionscopy[loop].value;
                    this.selectobj.options[index].selected = false;
                    // Increment the index
                    index++;
        function Left(option, str)
            var n = String(str).length;
            if (String(option).substring(0,n) = String(str).substring(0,n));
                return true;
            else
                return false;
Hij geeft steeds een error op de pagina zodra er iets in de selectie wordt getypt.
Volgems mij zit de fout in functie Left.
Ofwel geeft hij niet de juiste parameters mee of 'this.selectobj.text' moet een andere waarde bevatten.
  • gorgi_19
  • Laatst online: 19-10 13:51
gorgi_19
Kruimeltjes zijn weer op :9
DHTML en HTML hoort thuis in Webdesign & Graphics
Digitaal onderwijsmateriaal, leermateriaal voor hbo
  • André
André
Analytics dude
substring moet je vervangen met substr :)
  • RM-rf
  • Laatst online: 19-10 13:08
RM-rf
1 2 3 4 5 7 6 8 9
André schreef op 05 oktober 2004 @ 11:21:
* RM-rf gooit een banaan naar André: 'php-aapje!'
Ecmascript: zoek naar de string-method String.substring()
http://www.ecma-internati...ns/standards/Ecma-262.htm
staat op pagina 105:
15.5.4.15 String.prototype.substring (start, end)
The substring method takes two arguments, start and end, and returns a substring of the result of
converting this object to a string, starting from character position start and running to, but not
including, character position end of the string (or through the end of the string is end is undefined).
The result is a string value, not a String object.
If either argument is NaN or negative, it is replaced with zero; if either argument is larger than the
length of the string, it is replaced with the length of the string.
If start is larger than end, they are swapped.
The following steps are taken:
1. Call ToString, giving it the this value as its argument.
2. Compute the number of characters in Result(1).
3. Call ToInteger(start).
4. If end is undefined, use Result(2); else use ToInteger(end).
5. Compute min(max(Result(3), 0), Result(2)).
6. Compute min(max(Result(4), 0), Result(2)).
7. Compute min(Result(5), Result(6)).
8. Compute max(Result(5), Result(6)).
9. Return a string whose length is the difference between Result(8) and Result(7), containing
characters from Result(1), namely the characters with indices Result(7) through Result(8)−1, in
ascending order.
PHP http://de.php.net/substr ... voor alle mensen die moeite hebben met complete method-namen typen ... :P
[ Voor 60% gewijzigd door RM-rf op 05-10-2004 11:28 ]
Intelligente mensen zoeken in tijden van crisis naar oplossingen, Idioten zoeken dan schuldigen
  • André
André
Analytics dude
RM-rf schreef op 05 oktober 2004 @ 11:25:
* André gooit de banaan terug:
alert("RM-rf is AAP".substr(9))
// resultaat = "AAP";
:7
  • crisp
  • Laatst online: 08:04
crisp
Devver
Pixelated
Zowel substr als substring zijn string-methods in JS:
http://devedge.netscape.c...rence/string.html#1194618
http://devedge.netscape.c...rence/string.html#1194665
Enkel IE is buggy met substr:
JavaScript:
alert("André is AAP".substr(-3))
Intentionally left blank
  • André
André
Analytics dude
In regel 55 moet een dubbele = staan trouwens :)
Het rare is dat als ik de functie left weghaal dat hij al meer doet. En je hebt zeker ook nog nooit van prototyping gehoord?
[ Voor 61% gewijzigd door André op 05-10-2004 12:00 ]
  • RM-rf
RM-rf
1 2 3 4 5 7 6 8 9
ik kom uit op de regel 39, dat moet worden
if ( Left(this.optionscopy[loop].text, this.selectobj.form.regexp.value) )
oftewel, de lengte van de ingegeven sorteerwaarde moet worden gechecked, niet de lengte van de text-waarde van de options zelf (die altijd even lang is, als de te controleren option-value)
verder zou ik de function Left() wat korter maken:
    return (String(option).substring(0,n) == String(str).substring(0,n));
Maar dat is volgens mij meer een kwestie van smaak
